  3. MYSBootloader 1.3.0-beta.3
182 Posts 44 Posters 94.7k Views 42 Watching
  • tekkaT tekka
    @Werwolfx Please also update the bootloader file.
    W
    W
    Werwolfx
    wrote on last edited by Werwolfx
    #29
    @tekka If i ENABLE #define MY_OTA_FIRMWARE_FEATURE
    i see ST_FIRMWARE_CONFIG_REQUEST in MYSCONTROLLER logs!!!
    if i DISABLE //#define MY_OTA_FIRMWARE_FEATURE msg not in log
    i not have external flash/
    402	14.01.2017 21:29:28	TX	4 - Water Meter	N/A	C_INTERNAL	NO	I_REBOOT	0
    403	14.01.2017 21:29:28	RX	4	1	C_REQ	NO	V_VAR1
    408	14.01.2017 21:29:34	RX	4	INTERNAL	C_STREAM	NO	ST_FIRMWARE_CONFIG_REQUEST	FFFFFFFF48044E100300
    409	14.01.2017 21:29:34	TX	4	N/A	C_STREAM	NO	ST_FIRMWARE_CONFIG_RESPONSE	0A0001005000D446
    410	14.01.2017 21:29:34	RX	4	INTERNAL	C_PRESENTATION	NO	S_ARDUINO_NODE	2.1.0
    411	14.01.2017 21:29:34	RX	4	INTERNAL	C_INTERNAL	NO	I_CONFIG	0
    412	14.01.2017 21:29:34	TX	4	INTERNAL	C_INTERNAL	NO	I_CONFIG	M
    414	14.01.2017 21:29:34	RX	4 - Water Meter	INTERNAL	C_INTERNAL	NO	I_SKETCH_NAME	Water Meter
    417	14.01.2017 21:29:34	RX	4 - Water Meter	INTERNAL	C_INTERNAL	NO	I_SKETCH_VERSION	1.1
    419	14.01.2017 21:29:34	RX	4 - Water Meter	1 - S_WATER	C_PRESENTATION	NO	S_WATER
    i load this HEX
    load from Arduino IDE 1.8.0
    0_1484418874223_MYSBootloader.hex
    board.txt
    proMYSBL.bootloader.low_fuses=0xFF
    proMYSBL.bootloader.extended_fuses=0xFE
    tekkaT 1 Reply Last reply
    • W Werwolfx
      i load this HEX
      board.txt
      tekkaT
      tekkaT
      tekka
      @Werwolfx Ok, seems like you also upload the sketch via USBasp thereby erasing/overwriting the bootloader. Try uploading the sketch via serial or OTA after flashing the bootloader.
      • Mark SwiftM
        Mark SwiftM
        Mark Swift
        wrote on last edited by Mark Swift
        #31
        @tekka am I correct in thinking the HEX found on Github can be used with all Arduino's? I noticed my old folder has one hex for 16, 8 and 1Mhz?
        I'm using this board.txt
        menu.cpu=Processor
        MYSBL13.name=MYS Bootloader - atmega328p
        MYSBL13.upload.tool=arduino:avrdude
        MYSBL13.upload.protocol=arduino
        MYSBL13.upload.maximum_size=30720
        MYSBL13.upload.maximum_data_size=2048
        MYSBL13.bootloader.tool=arduino:avrdude
        MYSBL13.bootloader.unlock_bits=0x3F
        MYSBL13.bootloader.lock_bits=0x0F
        MYSBL13.build.mcu=atmega328p
        MYSBL13.build.board=AVR_PRO
        MYSBL13.build.core=arduino:arduino
        MYSBL13.build.variant=arduino:standard
        MYSBL13.menu.cpu.16MHzatmega328=ATmega328 16MHz (XTAL, BOD1V8)
        MYSBL13.menu.cpu.16MHzatmega328.upload.speed=115200
        MYSBL13.menu.cpu.16MHzatmega328.bootloader.low_fuses=0xFF
        MYSBL13.menu.cpu.16MHzatmega328.bootloader.high_fuses=0xDA
        MYSBL13.menu.cpu.16MHzatmega328.bootloader.extended_fuses=0x06
        MYSBL13.menu.cpu.16MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader.hex
        MYSBL13.menu.cpu.16MHzatmega328.build.f_cpu=16000000L
        MYSBL13.menu.cpu.8MHzatmega328=ATmega328 8MHz (RC, BOD1V8)
        MYSBL13.menu.cpu.8MHzatmega328.upload.speed=38400
        MYSBL13.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xE2
        MYSBL13.menu.cpu.8MHzatmega328.bootloader.high_fuses=0xDA
        MYSBL13.menu.cpu.8MHzatmega328.bootloader.extended_fuses=0x06
        MYSBL13.menu.cpu.8MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader.hex
        MYSBL13.menu.cpu.8MHzatmega328.build.f_cpu=8000000L
        MYSBL13.menu.cpu.1MHzatmega328=ATmega328 1MHz (RC/8, BOD1V8)
        MYSBL13.menu.cpu.1MHzatmega328.upload.speed=9600
        MYSBL13.menu.cpu.1MHzatmega328.bootloader.low_fuses=0x62
        MYSBL13.menu.cpu.1MHzatmega328.bootloader.high_fuses=0xDA
        MYSBL13.menu.cpu.1MHzatmega328.bootloader.extended_fuses=0x06
        MYSBL13.menu.cpu.1MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader.hex
        MYSBL13.menu.cpu.1MHzatmega328.build.f_cpu=1000000L```
        • Mark SwiftM
          Mark SwiftM
          Mark Swift
          I guess not... The old hex for 8Mhz works, but the one from this thread does not... :(
          I'm trying to upload this to my Pro Mini, does anyone have an 8Mhz that works?
          • Mark SwiftM
            Mark SwiftM
            Mark Swift
            #33
            @tekka I've noticed some odd things with my nodes when running the bootloader.
            To test I uploaded a simple count time sketch. When running the MYS bootloader the timer resets every 10 seconds, see:
            Time: 999
            Time: 2000
            Time: 3000
            Time: 4001
            Time: 5001
            Time: 6002
            Time: 7004
            Time: 8003
            Time: 9005
            Time: 0
            Time: 999
            Time: 2000
            Time: 3000
            Time: 4001
            Time: 5001
            Time: 6002
            Time: 7004
            Time: 8003
            Time: 9005
            Time: 0
            Using the stock Pro Mim 8Mhz 3.3v bootloader it works fine, any ideas?
            Perhaps this is because I'm testing using a non-MySensors sketch?
            • Mark SwiftM Mark Swift
              Time: 999
              Time: 2000
              Time: 3000
              Time: 4001
              Time: 5001
              Time: 6002
              Time: 7004
              Time: 8003
              Time: 9005
              Time: 0
              Time: 999
              Time: 2000
              Time: 3000
              Time: 4001
              Time: 5001
              Time: 6002
              Time: 7004
              Time: 8003
              Time: 9005
              Time: 0
              tekkaT
              tekkaT
              tekka
              wrote on last edited by tekka
              #34
              @Mark-Swift yeah, this is intended behavior: the watchdog kicks in after ~8s, so either you reset it in loop() or disable it in setup().
              • rmtuckerR
                rmtuckerR
                rmtucker
                Is there a version or branch of this for the rfm69?
                • rmtuckerR rmtucker
                  tekkaT
                  tekkaT
                  tekka
                  @rmtucker No, but everybody is welcome to contribute and enhance the functionality.
                  • Mark SwiftM
                    Mark SwiftM
                    Mark Swift
                    @tekka, I'm trying to compile the HEX using OSX. I have installed avr-gcc with homebrew but I get
                    rm *.o
                    rm: *.o: No such file or directory
                    make: [clean] Error 1 (ignored)
                    rm *.elf
                    rm: *.elf: No such file or directory
                    rm *.hex
                    rm: *.hex: No such file or directory
                    "avr-gcc" -funsigned-char -funsigned-bitfields -DF_CPU=16000000L -Os -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -mrelax -Wall -Wextra -Wundef -pedantic -mmcu=atmega328p -c -std=gnu99 -MD -MP -MF "MYSBootloader.d" -MT"MYSBootloader.d" -MT"MYSBootloader.o" -I MYSBootloader.c -o MYSBootloader.o
                    avr-gcc: fatal error: no input files
                    compilation terminated.
                    make: *** [MYSBootloader.o] Error 1
                    When issueing the Make command, can you help, any suggestions?
                      rm *.o
                      rm *.elf
                      rm *.hex
                      tekkaT
                      tekkaT
                      tekka
                      @Mark-Swift I haven't tested that with OSX - maybe somebody can help here?
                      ? 1 Reply Last reply
                      • Mark SwiftM
                        Mark SwiftM
                        Mark Swift
                        @tekka, started a windows VM, run via MinGW and got this when running makefile, does it look okay?
                        C:\MySensorsBootloaderRF24-development>mingw32-make.exe
                        rm *.o
                        process_begin: CreateProcess(NULL, rm *.o, ...) failed.
                        make (e=2): The system cannot find the file specified.
                        Makefile:40: recipe for target 'clean' failed
                        mingw32-make.exe: [clean] Error 2 (ignored)
                        rm *.elf
                        process_begin: CreateProcess(NULL, rm *.elf, ...) failed.
                        rm *.hex
                        process_begin: CreateProcess(NULL, rm *.hex, ...) failed.
                        "C:/Arduino/hardware/tools/avr/bin/avr-gcc" -funsigned-char -funsigned-bitfields
                        D -MP -MF "MYSBootloader.d" -MT"MYSBootloader.d" -MT"MYSBootloader.o"  -IC:/Ardu
                        ino/hardware/tools/avr/avr/include/avr MYSBootloader.c -o MYSBootloader.o
                        In file included from Core.h:40:0,
                                         from MYSBootloader.c:69:
                        HW.h:51:2: warning: #warning is a GCC extension
                         #warning BAUD_RATE error greater than 2%
                        HW.h:51:2: warning: #warning BAUD_RATE error greater than 2% [-Wcpp]
                        In file included from Core.h:42:0,
                        MyMessage.h:292:3: warning: ISO C99 doesn't support unnamed structs/unions [-Wpe
                        dantic]
                        "C:/Arduino/hardware/tools/avr/bin/avr-gcc" -nostartfiles -Wl,-s -Wl,-static -Wl
                        ,-Map=".map" -Wl,--start-group -Wl,--end-group -Wl,--gc-sections -mrelax -Wl,-se
                        ction-start=.text=0x7800 -mmcu=atmega328p   -o MYSBootloader.elf MYSBootloader.o
                         -lm
                        "C:/Arduino/hardware/tools/avr/bin/avr-objcopy" -O ihex -R .eeprom MYSBootloader
                        .elf MYSBootloader.hex
                        "C:/Arduino/hardware/tools/avr/bin/avr-size" MYSBootloader.elf
                           text    data     bss     dec     hex filename
                           2036       6      72    2114     842 MYSBootloader.elf
                        • Mark SwiftM
                          Mark SwiftM
                          Mark Swift
                          @tekka Just wanted to check if the above log looks okay, currently rolling the bootloader out to 14 nodes (painful process!) and wanted to check if it looks okay before I do.
                          I'm also using this board.txt, I made a separate entry for my Uno's, do they all look okay? I basically used the fuses from the standard Arduino boards.txt with the change of 0x05 to 0x06 for the BOD? I noticed in the makefile that you can specify the fuses, do I need to compile a bootloader for each device with the exact fuses, or will one bootloader for 16 / 8 / 1Mhz suffice?
                          Thank you very much in advance, the bootloader is amazing work.
                          menu.cpu=Processor
                          pro.name=MySensors Bootloader for Pro Mini
                          pro.upload.tool=arduino:avrdude
                          pro.upload.protocol=arduino
                          pro.upload.maximum_size=30720
                          pro.upload.maximum_data_size=2048
                          pro.bootloader.tool=arduino:avrdude
                          pro.bootloader.unlock_bits=0x3F
                          pro.bootloader.lock_bits=0x0F
                          pro.build.mcu=atmega328p
                          pro.build.board=AVR_PRO
                          pro.build.core=arduino:arduino
                          pro.build.variant=arduino:standard
                          ## Arduino with MYSBootloader Beta 2
                          ## pro.menu.cpu.16MHzatmega328=ATmega328 16MHz (XTAL, BOD1V8) 1.3 Beta 2
                          ## pro.menu.cpu.16MHzatmega328.upload.speed=115200
                          ## pro.menu.cpu.16MHzatmega328.bootloader.low_fuses=0xFF
                          ## pro.menu.cpu.16MHzatmega328.bootloader.high_fuses=0xDA
                          ## pro.menu.cpu.16MHzatmega328.bootloader.extended_fuses=0x06
                          ## pro.menu.cpu.16MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B2_16Mhz.hex
                          ## pro.menu.cpu.16MHzatmega328.build.f_cpu=16000000L
                          ## pro.menu.cpu.8MHzatmega328=ATmega328 8MHz (RC, BOD1V8) 1.3 Beta 2
                          ## pro.menu.cpu.8MHzatmega328.upload.speed=38400
                          ## pro.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xE2
                          ## pro.menu.cpu.8MHzatmega328.bootloader.high_fuses=0xDA
                          ## pro.menu.cpu.8MHzatmega328.bootloader.extended_fuses=0x06
                          ## pro.menu.cpu.8MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B2_8Mhz.hex
                          ## pro.menu.cpu.8MHzatmega328.build.f_cpu=8000000L
                          ## pro.menu.cpu.1MHzatmega328=ATmega328 1MHz (RC/8, BOD1V8) 1.3 Beta 2
                          ## pro.menu.cpu.1MHzatmega328.upload.speed=9600
                          ## pro.menu.cpu.1MHzatmega328.bootloader.low_fuses=0x62
                          ## pro.menu.cpu.1MHzatmega328.bootloader.high_fuses=0xDA
                          ## pro.menu.cpu.1MHzatmega328.bootloader.extended_fuses=0x06
                          ## pro.menu.cpu.1MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B2_1Mhz.hex
                          ## pro.menu.cpu.1MHzatmega328.build.f_cpu=1000000L
                          ## Arduino with MYSBootloader Beta 3
                          pro.menu.cpu.16MHzatmega328=ATmega328 16MHz (XTAL, BOD1V8) 1.3 Beta 3
                          pro.menu.cpu.16MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B3_16Mhz.hex
                          pro.menu.cpu.8MHzatmega328=ATmega328 8MHz (RC, BOD1V8) 1.3 Beta 3
                          pro.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xFF
                          pro.menu.cpu.8MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B3_8Mhz.hex
                          pro.menu.cpu.1MHzatmega328=ATmega328 1MHz (RC/8, BOD1V8) 1.3 Beta 3
                          pro.menu.cpu.1MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B3_1Mhz.hex
                          menu.cpu=Processor
                          uno.name=MySensors Bootloader for Uno
                          uno.upload.tool=arduino:avrdude
                          uno.upload.protocol=arduino
                          uno.upload.maximum_size=32256
                          uno.upload.maximum_data_size=2048
                          uno.bootloader.tool=arduino:avrdude
                          uno.bootloader.unlock_bits=0x3F
                          uno.bootloader.lock_bits=0x0F
                          uno.build.mcu=atmega328p
                          uno.build.board=AVR_UNO
                          uno.build.core=arduino:arduino
                          uno.build.variant=arduino:standard
                          ## uno.menu.cpu.16MHzatmega328=ATmega328 16MHz (XTAL, BOD1V8) 1.3 Beta 2
                          ## uno.menu.cpu.16MHzatmega328.upload.speed=115200
                          ## uno.menu.cpu.16MHzatmega328.bootloader.low_fuses=0xFF
                          ## uno.menu.cpu.16MHzatmega328.bootloader.high_fuses=0xDA
                          ## uno.menu.cpu.16MHzatmega328.bootloader.extended_fuses=0x06
                          ## uno.menu.cpu.16MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B2_16Mhz.hex
                          ## uno.menu.cpu.16MHzatmega328.build.f_cpu=16000000L
                          uno.menu.cpu.16MHzatmega328=ATmega328 16MHz (XTAL, BOD1V8) 1.3 Beta 3
                          uno.menu.cpu.16MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B3_16Mhz.hex
                            rm *.o
                            rm *.elf
                            rm *.hex
                            dantic]
                             -lm
                            tekkaT
                            tekkaT
                            tekka
                            @Mark-Swift What changes did you make to the bootloader - the code size seems increased
                            Mark SwiftM 1 Reply Last reply
                            • tekkaT tekka
                              Mark SwiftM
                              Mark SwiftM
                              Mark Swift
                              #42
                              @tekka None that I'm aware of? :(
                              I just changed the fuses in the makefile to match the ones in my boards.txt, not sure if that's required, can you take a look at my questions above, I really want to be sure I'm doing all of this right before deploying.
                              To recap with regards the bootloader.
                              1. Installed Windows 7
                              2. Installed mingw (core and c++ compiler)
                              3. Installed Arduino IDE and MySensors library (Installed at the same location as you, at c drive root)
                              4. Downloaded bootloader from github
                              5. Edited the fuses and clock speed at the top of the makefile to match my boards.txt
                              6. Ran makefile from cmd
                                tekkaT
                                tekkaT
                                tekka
                                @Mark-Swift ok, most probably a false alarm. I assume you tested it after compilation?
                                • Mark SwiftM
                                  Mark SwiftM
                                  Mark Swift
                                  @tekka It seems to work? I guess if there was an issue it wouldn't work at all?
                                  Please can you conform my fuses look okay in the boards.txt I posted above? Also, do I need to change the fuses in the makefile and make a file for each device, or just 1 x 16Mhz and 1 x 8Mhz for example?
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @Mark-Swift I'm not at my workstation right now - you have to adjust the fuse settings according to your HW configurations and preferences. The fuse settings in the makefile are obsolete if you use the Arduino IDE / boards.txt for flashing. Please use the AVR fuse calculator to calculate to correct fuse settings:
                                    http://www.engbedded.com/fusecalc/
                                    • Mark SwiftM
                                      Mark SwiftM
                                      Mark Swift
                                      I @tekka, I thought as much, so basically I just need a bootloader with the right Mhz and then set fuses in the Arduino IDE boards.txt.
                                      I used the fuse settings from the original boards.txt included with the Arduino IDE, but adjusted the extended one to 0x06 (Adjust BOD).
                                      I noticed you used slightly different fuses to the Arduino IDE, you're using fuses that indicate a floating crystal or something?
                                      • A
                                        andreground
                                        wrote on last edited by andreground
                                        #47
                                        @tekka
                                        First of all, thanks for working so hard on the new version of the BL.
                                        My setup:
                                        • MYSBootloader 1.3.0-beta3 (md5 49ef3dc263110613c9c25ac21a8c3d83)
                                        • MYSController 1.0.0.beta (updated to latest version)
                                        • GW on Arduino Nano
                                        • Node on Arduino Pro Mini @ 5V 16 Mhz with MockMySensors sketch running
                                        What I did:
                                        • Flashed latest bootloader version from github on the Pro Mini ATMEGA328P (using AVRDUDESS 2.4 & USBasp, fuses L: 0xFF, H: 0xDA, E: 0x05)
                                        • Flashed latest mysensors lib on both node & gw (tested with both 2.0.0 & 2.1) on the Nano
                                        What I got:
                                        • FW upgrade through MYSController: Working
                                        • Reboot through MYSController: Working
                                        • Serial flashing with Arduino IDE: Working
                                        • Request presentation through MYSController: Working
                                          Request heartbeat through MYSController: Working
                                        But...
                                        Reassign ID through MYSController: NOT WORKING (the node reboots but still preserves the old ID)
                                        (MY_NODE_ID IS NOT DEFINED / THUS SET AS AUTO AS PER MYSENSORS DEFAULTS)
                                        Clear EEPROM through MYSController: NOT WORKING (the node reboots but still holds the value saved in EEPROM using saveState)
                                        Node bootlog after Clear EEPROM from MYSBootloader (you can see my debug LOADSTATE which still loads the value 123 from EEPROM):
                                        TSM:INIT
                                        TSM:RADIO:OK
                                        TSP:ASSIGNID:OK (ID=4)
                                        TSM:FPAR
                                        TSP:MSG:SEND 4-4-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                        TSP:MSG:READ 150-150-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                        TSP:MSG:BC
                                        TSP:MSG:READ 0-0-4 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                        TSP:MSG:PAR OK (ID=0, dist=1)
                                        TSM:FPAR:OK
                                        TSM:ID
                                        TSM:CHKID:OK (ID=4)
                                        TSM:UPL
                                        TSP:PING:SEND (dest=0)
                                        TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                                        TSP:MSG:READ 0-0-4 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                        TSP:MSG:PONG RECV (hops=1)
                                        TSP:CHKUPL:OK
                                        TSM:UPL:OK
                                        TSM:READY
                                        GW Started
                                        LOADSTATE
                                        123
                                        And...is it expected that the "Info" tab on my node shows bootloader version 1.2?
                                        Is there anything I'm missing to have these features working?
                                        Thanks in advance
                                        • A andreground
                                          @tekka
                                          My setup:
                                          What I did:
                                          What I got:
                                          But...
                                          TSM:INIT
                                          TSM:RADIO:OK
                                          TSM:FPAR
                                          TSP:MSG:BC
                                          TSM:FPAR:OK
                                          TSM:ID
                                          TSM:CHKID:OK (ID=4)
                                          TSM:UPL
                                          TSP:CHKUPL:OK
                                          TSM:UPL:OK
                                          TSM:READY
                                          GW Started
                                          LOADSTATE
                                          123
                                          Thanks in advance
                                          tekkaT
                                          tekkaT
                                          tekka
                                          #48
                                          @andreground Yes, re-assigning can be done nowadays with the MySensors framework, i.e. send a C_INTERNAL/I_ID_RESPONSE/<NEW ID> message to the (active) node.
                                          A 1 Reply Last reply
