  3. MYSBootloader 1.3.0-beta.3
182 Posts 44 Posters 94.7k Views 42 Watching
  • tekkaT tekka
    @Werwolfx but still no signs of MYSBootloader - what RF channel are you on?
    W
    W
    Werwolfx
    wrote on last edited by Werwolfx
    #23
    @tekka
    NRF24L01+
    What is the "no signs of MYSBootloader"?
    tekkaT 1 Reply Last reply
    • W Werwolfx
      @tekka
      NRF24L01+
      tekkaT
      tekkaT
      tekka
      @Werwolfx As soon as the bootloader takes over, in your case after the reboot request (1), but before the MYS lib 2.1.0 init message (2):
      (1) 14.01.2017 11:38:03 TX  4;0;3;0;13;0
      (2) 14.01.2017 11:38:09 RX  4;255;0;0;17;2.1.0
      it will send a I_FIRMWARE_CONFIG_REQUEST message to inform the controller about the currently loaded FW and request a new FW.
      looks like this:
      4;255;4;0;0;BE0001003003D8490102
      This is missing in your case, therefore I'm wondering if you have incompatible radio settings. Please post your GW sketch and upload your MYSBootloader.hex file for further troubleshooting.
      W 1 Reply Last reply
      • tekkaT tekka
        looks like this:
        W
        W
        Werwolfx
        #25
        @tekka GW on esp8266 (default sketch) + NRF24L01+
        on GW
         * Version 1.0 - Henrik EKblad
         * Contribution by Ivo Pullens (ESP8266 support)
         * The EthernetGateway sends data received from sensors to the WiFi link.
         * VERA CONFIGURATION:
         * LED purposes:
         * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
         * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
         * nRF24L01+  ESP8266
         * VCC        VCC
         * CE         GPIO4
         * CSN/CS     GPIO15
         * SCK        GPIO14
         * MISO       GPIO12
         * MOSI       GPIO13
         * GND        GND
          * Inclusion mode button:
        #define MY_BAUD_RATE 115200
        #define MY_GATEWAY_ESP8266
        #define MY_ESP8266_SSID "WiFI"
        #define MY_ESP8266_PASSWORD "password[0_1484386469111_MYSBootloader.hex](/uploads/files/1484386469171-mysbootloader.hex) "
        // Enable UDP communication
        //#define MY_USE_UDP
        // #define MY_ESP8266_HOSTNAME "sensor-gateway"
        #define MY_PORT 5003
        // Enable inclusion mode
        // #define MY_INCLUSION_BUTTON_FEATURE
        // Set blinking period
        // #define MY_DEFAULT_LED_BLINK_PERIOD 300
        // Flash leds on rx/tx/err
        #if defined(MY_USE_UDP)
          #include <WiFiUdp.h>
        #include <ESP8266WiFi.h>
        In MYSController on mudule i click INFO
        FW Update = no
        Bootloader = N/A
        may be problem in the Bootloader.hex?
        0_1484386859986_upload-c59e469e-e015-4099-88d8-607a7408a1da
        • W Werwolfx
          on GW
           * LED purposes:
           * nRF24L01+  ESP8266
           * VCC        VCC
           * CE         GPIO4
           * CSN/CS     GPIO15
           * SCK        GPIO14
           * MISO       GPIO12
           * MOSI       GPIO13
           * GND        GND
          FW Update = no
          Bootloader = N/A
          tekkaT
          tekkaT
          tekka
          @Werwolfx Please also update the bootloader file.
          W 2 Replies Last reply
          • tekkaT tekka
            W
            W
            Werwolfx
            I'll update more than once, but there is no effect.
            avrdude writes that everything is OK
            I do not know what to do = (
            avrdude: erasing chip
            avrdude: auto set sck period (because given equals null)
            avrdude: warning: cannot set sck period. please check for usbasp firmware update.
            avrdude: reading input file "/media/werwolfx/SSDData/arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors/MYSBootloader.hex"
            avrdude: writing flash (32762 bytes):
            avrdude: 32762 bytes of flash written
            avrdude: verifying flash memory against /media/werwolfx/SSDData/arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors/MYSBootloader.hex:
            avrdude: load data flash data from input file /media/werwolfx/SSDData/arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors/MYSBootloader.hex:
            avrdude: input file /media/werwolfx/SSDData/arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors/MYSBootloader.hex contains 32762 bytes
            avrdude: verifying ...
            avrdude: 32762 bytes of flash verified
            avrdude: reading input file "0x0F"
            avrdude: verifying lock memory against 0x0F:
            avrdude: load data lock data from input file 0x0F:
            avrdude: input file 0x0F contains 1 bytes
            avrdude done.  Thank you.
            • W Werwolfx
              tekkaT
              tekkaT
              tekka
              @Werwolfx sorry, maybe I was not clear - please upload it here to the forum I will try to reproduce your setup.
              • tekkaT tekka
                W
                W
                Werwolfx
                #29
                @tekka If i ENABLE #define MY_OTA_FIRMWARE_FEATURE
                i see ST_FIRMWARE_CONFIG_REQUEST in MYSCONTROLLER logs!!!
                if i DISABLE //#define MY_OTA_FIRMWARE_FEATURE msg not in log
                i not have external flash/
                402	14.01.2017 21:29:28	TX	4 - Water Meter	N/A	C_INTERNAL	NO	I_REBOOT	0
                403	14.01.2017 21:29:28	RX	4	1	C_REQ	NO	V_VAR1
                408	14.01.2017 21:29:34	RX	4	INTERNAL	C_STREAM	NO	ST_FIRMWARE_CONFIG_REQUEST	FFFFFFFF48044E100300
                409	14.01.2017 21:29:34	TX	4	N/A	C_STREAM	NO	ST_FIRMWARE_CONFIG_RESPONSE	0A0001005000D446
                410	14.01.2017 21:29:34	RX	4	INTERNAL	C_PRESENTATION	NO	S_ARDUINO_NODE	2.1.0
                411	14.01.2017 21:29:34	RX	4	INTERNAL	C_INTERNAL	NO	I_CONFIG	0
                412	14.01.2017 21:29:34	TX	4	INTERNAL	C_INTERNAL	NO	I_CONFIG	M
                414	14.01.2017 21:29:34	RX	4 - Water Meter	INTERNAL	C_INTERNAL	NO	I_SKETCH_NAME	Water Meter
                417	14.01.2017 21:29:34	RX	4 - Water Meter	INTERNAL	C_INTERNAL	NO	I_SKETCH_VERSION	1.1
                419	14.01.2017 21:29:34	RX	4 - Water Meter	1 - S_WATER	C_PRESENTATION	NO	S_WATER
                i load this HEX
                load from Arduino IDE 1.8.0
                0_1484418874223_MYSBootloader.hex
                board.txt
                proMYSBL.bootloader.low_fuses=0xFF
                proMYSBL.bootloader.extended_fuses=0xFE
                • W Werwolfx
                  i load this HEX
                  board.txt
                  tekkaT
                  tekkaT
                  tekka
                  @Werwolfx Ok, seems like you also upload the sketch via USBasp thereby erasing/overwriting the bootloader. Try uploading the sketch via serial or OTA after flashing the bootloader.
                  • Mark SwiftM
                    Mark SwiftM
                    Mark Swift
                    wrote on last edited by Mark Swift
                    #31
                    @tekka am I correct in thinking the HEX found on Github can be used with all Arduino's? I noticed my old folder has one hex for 16, 8 and 1Mhz?
                    I'm using this board.txt
                    menu.cpu=Processor
                    MYSBL13.name=MYS Bootloader - atmega328p
                    MYSBL13.upload.tool=arduino:avrdude
                    MYSBL13.upload.protocol=arduino
                    MYSBL13.upload.maximum_size=30720
                    MYSBL13.upload.maximum_data_size=2048
                    MYSBL13.bootloader.tool=arduino:avrdude
                    MYSBL13.bootloader.unlock_bits=0x3F
                    MYSBL13.bootloader.lock_bits=0x0F
                    MYSBL13.build.mcu=atmega328p
                    MYSBL13.build.board=AVR_PRO
                    MYSBL13.build.core=arduino:arduino
                    MYSBL13.build.variant=arduino:standard
                    MYSBL13.menu.cpu.16MHzatmega328=ATmega328 16MHz (XTAL, BOD1V8)
                    MYSBL13.menu.cpu.16MHzatmega328.upload.speed=115200
                    MYSBL13.menu.cpu.16MHzatmega328.bootloader.low_fuses=0xFF
                    MYSBL13.menu.cpu.16MHzatmega328.bootloader.high_fuses=0xDA
                    MYSBL13.menu.cpu.16MHzatmega328.bootloader.extended_fuses=0x06
                    MYSBL13.menu.cpu.16MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader.hex
                    MYSBL13.menu.cpu.16MHzatmega328.build.f_cpu=16000000L
                    MYSBL13.menu.cpu.8MHzatmega328=ATmega328 8MHz (RC, BOD1V8)
                    MYSBL13.menu.cpu.8MHzatmega328.upload.speed=38400
                    MYSBL13.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xE2
                    MYSBL13.menu.cpu.8MHzatmega328.bootloader.high_fuses=0xDA
                    MYSBL13.menu.cpu.8MHzatmega328.bootloader.extended_fuses=0x06
                    MYSBL13.menu.cpu.8MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader.hex
                    MYSBL13.menu.cpu.8MHzatmega328.build.f_cpu=8000000L
                    MYSBL13.menu.cpu.1MHzatmega328=ATmega328 1MHz (RC/8, BOD1V8)
                    MYSBL13.menu.cpu.1MHzatmega328.upload.speed=9600
                    MYSBL13.menu.cpu.1MHzatmega328.bootloader.low_fuses=0x62
                    MYSBL13.menu.cpu.1MHzatmega328.bootloader.high_fuses=0xDA
                    MYSBL13.menu.cpu.1MHzatmega328.bootloader.extended_fuses=0x06
                    MYSBL13.menu.cpu.1MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader.hex
                    MYSBL13.menu.cpu.1MHzatmega328.build.f_cpu=1000000L```
                    • Mark SwiftM
                      Mark SwiftM
                      Mark Swift
                      I guess not... The old hex for 8Mhz works, but the one from this thread does not... :(
                      I'm trying to upload this to my Pro Mini, does anyone have an 8Mhz that works?
                      • Mark SwiftM
                        Mark SwiftM
                        Mark Swift
                        #33
                        @tekka I've noticed some odd things with my nodes when running the bootloader.
                        To test I uploaded a simple count time sketch. When running the MYS bootloader the timer resets every 10 seconds, see:
                        Time: 999
                        Time: 2000
                        Time: 3000
                        Time: 4001
                        Time: 5001
                        Time: 6002
                        Time: 7004
                        Time: 8003
                        Time: 9005
                        Time: 0
                        Time: 999
                        Time: 2000
                        Time: 3000
                        Time: 4001
                        Time: 5001
                        Time: 6002
                        Time: 7004
                        Time: 8003
                        Time: 9005
                        Time: 0
                        Using the stock Pro Mim 8Mhz 3.3v bootloader it works fine, any ideas?
                        Perhaps this is because I'm testing using a non-MySensors sketch?
                        • Mark SwiftM Mark Swift
                          Time: 999
                          Time: 2000
                          Time: 3000
                          Time: 4001
                          Time: 5001
                          Time: 6002
                          Time: 7004
                          Time: 8003
                          Time: 9005
                          Time: 0
                          Time: 999
                          Time: 2000
                          Time: 3000
                          Time: 4001
                          Time: 5001
                          Time: 6002
                          Time: 7004
                          Time: 8003
                          Time: 9005
                          Time: 0
                          tekkaT
                          tekkaT
                          tekka
                          wrote on last edited by tekka
                          #34
                          @Mark-Swift yeah, this is intended behavior: the watchdog kicks in after ~8s, so either you reset it in loop() or disable it in setup().
                          • rmtuckerR
                            rmtuckerR
                            rmtucker
                            Is there a version or branch of this for the rfm69?
                            • rmtuckerR rmtucker
                              tekkaT
                              tekkaT
                              tekka
                              @rmtucker No, but everybody is welcome to contribute and enhance the functionality.
                              • Mark SwiftM
                                Mark SwiftM
                                Mark Swift
                                @tekka, I'm trying to compile the HEX using OSX. I have installed avr-gcc with homebrew but I get
                                rm *.o
                                rm: *.o: No such file or directory
                                make: [clean] Error 1 (ignored)
                                rm *.elf
                                rm: *.elf: No such file or directory
                                rm *.hex
                                rm: *.hex: No such file or directory
                                "avr-gcc" -funsigned-char -funsigned-bitfields -DF_CPU=16000000L -Os -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -mrelax -Wall -Wextra -Wundef -pedantic -mmcu=atmega328p -c -std=gnu99 -MD -MP -MF "MYSBootloader.d" -MT"MYSBootloader.d" -MT"MYSBootloader.o" -I MYSBootloader.c -o MYSBootloader.o
                                avr-gcc: fatal error: no input files
                                compilation terminated.
                                make: *** [MYSBootloader.o] Error 1
                                When issueing the Make command, can you help, any suggestions?
                                  rm *.o
                                  rm *.elf
                                  rm *.hex
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @Mark-Swift I haven't tested that with OSX - maybe somebody can help here?
                                  ? 1 Reply Last reply
                                  • Mark SwiftM
                                    Mark SwiftM
                                    Mark Swift
                                    @tekka, started a windows VM, run via MinGW and got this when running makefile, does it look okay?
                                    C:\MySensorsBootloaderRF24-development>mingw32-make.exe
                                    rm *.o
                                    process_begin: CreateProcess(NULL, rm *.o, ...) failed.
                                    make (e=2): The system cannot find the file specified.
                                    Makefile:40: recipe for target 'clean' failed
                                    mingw32-make.exe: [clean] Error 2 (ignored)
                                    rm *.elf
                                    process_begin: CreateProcess(NULL, rm *.elf, ...) failed.
                                    rm *.hex
                                    process_begin: CreateProcess(NULL, rm *.hex, ...) failed.
                                    "C:/Arduino/hardware/tools/avr/bin/avr-gcc" -funsigned-char -funsigned-bitfields
                                    D -MP -MF "MYSBootloader.d" -MT"MYSBootloader.d" -MT"MYSBootloader.o"  -IC:/Ardu
                                    ino/hardware/tools/avr/avr/include/avr MYSBootloader.c -o MYSBootloader.o
                                    In file included from Core.h:40:0,
                                                     from MYSBootloader.c:69:
                                    HW.h:51:2: warning: #warning is a GCC extension
                                     #warning BAUD_RATE error greater than 2%
                                    HW.h:51:2: warning: #warning BAUD_RATE error greater than 2% [-Wcpp]
                                    In file included from Core.h:42:0,
                                    MyMessage.h:292:3: warning: ISO C99 doesn't support unnamed structs/unions [-Wpe
                                    dantic]
                                    "C:/Arduino/hardware/tools/avr/bin/avr-gcc" -nostartfiles -Wl,-s -Wl,-static -Wl
                                    ,-Map=".map" -Wl,--start-group -Wl,--end-group -Wl,--gc-sections -mrelax -Wl,-se
                                    ction-start=.text=0x7800 -mmcu=atmega328p   -o MYSBootloader.elf MYSBootloader.o
                                     -lm
                                    "C:/Arduino/hardware/tools/avr/bin/avr-objcopy" -O ihex -R .eeprom MYSBootloader
                                    .elf MYSBootloader.hex
                                    "C:/Arduino/hardware/tools/avr/bin/avr-size" MYSBootloader.elf
                                       text    data     bss     dec     hex filename
                                       2036       6      72    2114     842 MYSBootloader.elf
                                    • Mark SwiftM
                                      Mark SwiftM
                                      Mark Swift
                                      @tekka Just wanted to check if the above log looks okay, currently rolling the bootloader out to 14 nodes (painful process!) and wanted to check if it looks okay before I do.
                                      I'm also using this board.txt, I made a separate entry for my Uno's, do they all look okay? I basically used the fuses from the standard Arduino boards.txt with the change of 0x05 to 0x06 for the BOD? I noticed in the makefile that you can specify the fuses, do I need to compile a bootloader for each device with the exact fuses, or will one bootloader for 16 / 8 / 1Mhz suffice?
                                      Thank you very much in advance, the bootloader is amazing work.
                                      menu.cpu=Processor
                                      pro.name=MySensors Bootloader for Pro Mini
                                      pro.upload.tool=arduino:avrdude
                                      pro.upload.protocol=arduino
                                      pro.upload.maximum_size=30720
                                      pro.upload.maximum_data_size=2048
                                      pro.bootloader.tool=arduino:avrdude
                                      pro.bootloader.unlock_bits=0x3F
                                      pro.bootloader.lock_bits=0x0F
                                      pro.build.mcu=atmega328p
                                      pro.build.board=AVR_PRO
                                      pro.build.core=arduino:arduino
                                      pro.build.variant=arduino:standard
                                      ## Arduino with MYSBootloader Beta 2
                                      ## pro.menu.cpu.16MHzatmega328=ATmega328 16MHz (XTAL, BOD1V8) 1.3 Beta 2
                                      ## pro.menu.cpu.16MHzatmega328.upload.speed=115200
                                      ## pro.menu.cpu.16MHzatmega328.bootloader.low_fuses=0xFF
                                      ## pro.menu.cpu.16MHzatmega328.bootloader.high_fuses=0xDA
                                      ## pro.menu.cpu.16MHzatmega328.bootloader.extended_fuses=0x06
                                      ## pro.menu.cpu.16MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B2_16Mhz.hex
                                      ## pro.menu.cpu.16MHzatmega328.build.f_cpu=16000000L
                                      ## pro.menu.cpu.8MHzatmega328=ATmega328 8MHz (RC, BOD1V8) 1.3 Beta 2
                                      ## pro.menu.cpu.8MHzatmega328.upload.speed=38400
                                      ## pro.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xE2
                                      ## pro.menu.cpu.8MHzatmega328.bootloader.high_fuses=0xDA
                                      ## pro.menu.cpu.8MHzatmega328.bootloader.extended_fuses=0x06
                                      ## pro.menu.cpu.8MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B2_8Mhz.hex
                                      ## pro.menu.cpu.8MHzatmega328.build.f_cpu=8000000L
                                      ## pro.menu.cpu.1MHzatmega328=ATmega328 1MHz (RC/8, BOD1V8) 1.3 Beta 2
                                      ## pro.menu.cpu.1MHzatmega328.upload.speed=9600
                                      ## pro.menu.cpu.1MHzatmega328.bootloader.low_fuses=0x62
                                      ## pro.menu.cpu.1MHzatmega328.bootloader.high_fuses=0xDA
                                      ## pro.menu.cpu.1MHzatmega328.bootloader.extended_fuses=0x06
                                      ## pro.menu.cpu.1MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B2_1Mhz.hex
                                      ## pro.menu.cpu.1MHzatmega328.build.f_cpu=1000000L
                                      ## Arduino with MYSBootloader Beta 3
                                      pro.menu.cpu.16MHzatmega328=ATmega328 16MHz (XTAL, BOD1V8) 1.3 Beta 3
                                      pro.menu.cpu.16MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B3_16Mhz.hex
                                      pro.menu.cpu.8MHzatmega328=ATmega328 8MHz (RC, BOD1V8) 1.3 Beta 3
                                      pro.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xFF
                                      pro.menu.cpu.8MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B3_8Mhz.hex
                                      pro.menu.cpu.1MHzatmega328=ATmega328 1MHz (RC/8, BOD1V8) 1.3 Beta 3
                                      pro.menu.cpu.1MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B3_1Mhz.hex
                                      menu.cpu=Processor
                                      uno.name=MySensors Bootloader for Uno
                                      uno.upload.tool=arduino:avrdude
                                      uno.upload.protocol=arduino
                                      uno.upload.maximum_size=32256
                                      uno.upload.maximum_data_size=2048
                                      uno.bootloader.tool=arduino:avrdude
                                      uno.bootloader.unlock_bits=0x3F
                                      uno.bootloader.lock_bits=0x0F
                                      uno.build.mcu=atmega328p
                                      uno.build.board=AVR_UNO
                                      uno.build.core=arduino:arduino
                                      uno.build.variant=arduino:standard
                                      ## uno.menu.cpu.16MHzatmega328=ATmega328 16MHz (XTAL, BOD1V8) 1.3 Beta 2
                                      ## uno.menu.cpu.16MHzatmega328.upload.speed=115200
                                      ## uno.menu.cpu.16MHzatmega328.bootloader.low_fuses=0xFF
                                      ## uno.menu.cpu.16MHzatmega328.bootloader.high_fuses=0xDA
                                      ## uno.menu.cpu.16MHzatmega328.bootloader.extended_fuses=0x06
                                      ## uno.menu.cpu.16MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B2_16Mhz.hex
                                      ## uno.menu.cpu.16MHzatmega328.build.f_cpu=16000000L
                                      uno.menu.cpu.16MHzatmega328=ATmega328 16MHz (XTAL, BOD1V8) 1.3 Beta 3
                                      uno.menu.cpu.16MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B3_16Mhz.hex
                                        rm *.o
                                        rm *.elf
                                        rm *.hex
                                        dantic]
                                         -lm
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @Mark-Swift What changes did you make to the bootloader - the code size seems increased
                                        Mark SwiftM 1 Reply Last reply
                                        • tekkaT tekka
                                          Mark SwiftM
                                          Mark SwiftM
                                          Mark Swift
                                          #42
                                          @tekka None that I'm aware of? :(
                                          I just changed the fuses in the makefile to match the ones in my boards.txt, not sure if that's required, can you take a look at my questions above, I really want to be sure I'm doing all of this right before deploying.
                                          To recap with regards the bootloader.
                                          1. Installed Windows 7
                                          2. Installed mingw (core and c++ compiler)
                                          3. Installed Arduino IDE and MySensors library (Installed at the same location as you, at c drive root)
                                          4. Downloaded bootloader from github
                                          5. Edited the fuses and clock speed at the top of the makefile to match my boards.txt
                                          6. Ran makefile from cmd
