  3. MYSBootloader 1.3.0-beta.3
182 Posts 44 Posters 94.7k Views 42 Watching
  • tekkaT tekka
    @Werwolfx Please also update the bootloader file.
    W
    W
    Werwolfx
    I'll update more than once, but there is no effect.
    avrdude writes that everything is OK
    I do not know what to do = (
    avrdude: erasing chip
    avrdude: auto set sck period (because given equals null)
    avrdude: warning: cannot set sck period. please check for usbasp firmware update.
    avrdude: reading input file "/media/werwolfx/SSDData/arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors/MYSBootloader.hex"
    avrdude: writing flash (32762 bytes):
    avrdude: 32762 bytes of flash written
    avrdude: verifying flash memory against /media/werwolfx/SSDData/arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors/MYSBootloader.hex:
    avrdude: load data flash data from input file /media/werwolfx/SSDData/arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors/MYSBootloader.hex:
    avrdude: input file /media/werwolfx/SSDData/arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors/MYSBootloader.hex contains 32762 bytes
    avrdude: verifying ...
    avrdude: 32762 bytes of flash verified
    avrdude: reading input file "0x0F"
    avrdude: verifying lock memory against 0x0F:
    avrdude: load data lock data from input file 0x0F:
    avrdude: input file 0x0F contains 1 bytes
    avrdude done.  Thank you.
    tekkaT 1 Reply Last reply
    • W Werwolfx
      tekkaT
      tekkaT
      tekka
      @Werwolfx sorry, maybe I was not clear - please upload it here to the forum I will try to reproduce your setup.
      • tekkaT tekka
        W
        W
        Werwolfx
        wrote on last edited by Werwolfx
        #29
        @tekka If i ENABLE #define MY_OTA_FIRMWARE_FEATURE
        i see ST_FIRMWARE_CONFIG_REQUEST in MYSCONTROLLER logs!!!
        if i DISABLE //#define MY_OTA_FIRMWARE_FEATURE msg not in log
        i not have external flash/
        402	14.01.2017 21:29:28	TX	4 - Water Meter	N/A	C_INTERNAL	NO	I_REBOOT	0
        403	14.01.2017 21:29:28	RX	4	1	C_REQ	NO	V_VAR1
        408	14.01.2017 21:29:34	RX	4	INTERNAL	C_STREAM	NO	ST_FIRMWARE_CONFIG_REQUEST	FFFFFFFF48044E100300
        409	14.01.2017 21:29:34	TX	4	N/A	C_STREAM	NO	ST_FIRMWARE_CONFIG_RESPONSE	0A0001005000D446
        410	14.01.2017 21:29:34	RX	4	INTERNAL	C_PRESENTATION	NO	S_ARDUINO_NODE	2.1.0
        411	14.01.2017 21:29:34	RX	4	INTERNAL	C_INTERNAL	NO	I_CONFIG	0
        412	14.01.2017 21:29:34	TX	4	INTERNAL	C_INTERNAL	NO	I_CONFIG	M
        414	14.01.2017 21:29:34	RX	4 - Water Meter	INTERNAL	C_INTERNAL	NO	I_SKETCH_NAME	Water Meter
        417	14.01.2017 21:29:34	RX	4 - Water Meter	INTERNAL	C_INTERNAL	NO	I_SKETCH_VERSION	1.1
        419	14.01.2017 21:29:34	RX	4 - Water Meter	1 - S_WATER	C_PRESENTATION	NO	S_WATER
        i load this HEX
        load from Arduino IDE 1.8.0
        0_1484418874223_MYSBootloader.hex
        board.txt
        proMYSBL.bootloader.low_fuses=0xFF
        proMYSBL.bootloader.extended_fuses=0xFE
        • W Werwolfx
          i load this HEX
          board.txt
          tekkaT
          tekkaT
          tekka
          @Werwolfx Ok, seems like you also upload the sketch via USBasp thereby erasing/overwriting the bootloader. Try uploading the sketch via serial or OTA after flashing the bootloader.
          • Mark SwiftM
            Mark SwiftM
            Mark Swift
            wrote on last edited by Mark Swift
            #31
            @tekka am I correct in thinking the HEX found on Github can be used with all Arduino's? I noticed my old folder has one hex for 16, 8 and 1Mhz?
            I'm using this board.txt
            menu.cpu=Processor
            MYSBL13.name=MYS Bootloader - atmega328p
            MYSBL13.upload.tool=arduino:avrdude
            MYSBL13.upload.protocol=arduino
            MYSBL13.upload.maximum_size=30720
            MYSBL13.upload.maximum_data_size=2048
            MYSBL13.bootloader.tool=arduino:avrdude
            MYSBL13.bootloader.unlock_bits=0x3F
            MYSBL13.bootloader.lock_bits=0x0F
            MYSBL13.build.mcu=atmega328p
            MYSBL13.build.board=AVR_PRO
            MYSBL13.build.core=arduino:arduino
            MYSBL13.build.variant=arduino:standard
            MYSBL13.menu.cpu.16MHzatmega328=ATmega328 16MHz (XTAL, BOD1V8)
            MYSBL13.menu.cpu.16MHzatmega328.upload.speed=115200
            MYSBL13.menu.cpu.16MHzatmega328.bootloader.low_fuses=0xFF
            MYSBL13.menu.cpu.16MHzatmega328.bootloader.high_fuses=0xDA
            MYSBL13.menu.cpu.16MHzatmega328.bootloader.extended_fuses=0x06
            MYSBL13.menu.cpu.16MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader.hex
            MYSBL13.menu.cpu.16MHzatmega328.build.f_cpu=16000000L
            MYSBL13.menu.cpu.8MHzatmega328=ATmega328 8MHz (RC, BOD1V8)
            MYSBL13.menu.cpu.8MHzatmega328.upload.speed=38400
            MYSBL13.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xE2
            MYSBL13.menu.cpu.8MHzatmega328.bootloader.high_fuses=0xDA
            MYSBL13.menu.cpu.8MHzatmega328.bootloader.extended_fuses=0x06
            MYSBL13.menu.cpu.8MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader.hex
            MYSBL13.menu.cpu.8MHzatmega328.build.f_cpu=8000000L
            MYSBL13.menu.cpu.1MHzatmega328=ATmega328 1MHz (RC/8, BOD1V8)
            MYSBL13.menu.cpu.1MHzatmega328.upload.speed=9600
            MYSBL13.menu.cpu.1MHzatmega328.bootloader.low_fuses=0x62
            MYSBL13.menu.cpu.1MHzatmega328.bootloader.high_fuses=0xDA
            MYSBL13.menu.cpu.1MHzatmega328.bootloader.extended_fuses=0x06
            MYSBL13.menu.cpu.1MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader.hex
            MYSBL13.menu.cpu.1MHzatmega328.build.f_cpu=1000000L```
            • Mark SwiftM
              Mark SwiftM
              Mark Swift
              I guess not... The old hex for 8Mhz works, but the one from this thread does not... :(
              I'm trying to upload this to my Pro Mini, does anyone have an 8Mhz that works?
              • Mark SwiftM
                Mark SwiftM
                Mark Swift
                #33
                @tekka I've noticed some odd things with my nodes when running the bootloader.
                To test I uploaded a simple count time sketch. When running the MYS bootloader the timer resets every 10 seconds, see:
                Time: 999
                Time: 2000
                Time: 3000
                Time: 4001
                Time: 5001
                Time: 6002
                Time: 7004
                Time: 8003
                Time: 9005
                Time: 0
                Time: 999
                Time: 2000
                Time: 3000
                Time: 4001
                Time: 5001
                Time: 6002
                Time: 7004
                Time: 8003
                Time: 9005
                Time: 0
                Using the stock Pro Mim 8Mhz 3.3v bootloader it works fine, any ideas?
                Perhaps this is because I'm testing using a non-MySensors sketch?
                • Mark SwiftM Mark Swift
                  Time: 999
                  Time: 2000
                  Time: 3000
                  Time: 4001
                  Time: 5001
                  Time: 6002
                  Time: 7004
                  Time: 8003
                  Time: 9005
                  Time: 0
                  Time: 999
                  Time: 2000
                  Time: 3000
                  Time: 4001
                  Time: 5001
                  Time: 6002
                  Time: 7004
                  Time: 8003
                  Time: 9005
                  Time: 0
                  tekkaT
                  tekkaT
                  tekka
                  wrote on last edited by tekka
                  #34
                  @Mark-Swift yeah, this is intended behavior: the watchdog kicks in after ~8s, so either you reset it in loop() or disable it in setup().
                  • rmtuckerR
                    rmtuckerR
                    rmtucker
                    Is there a version or branch of this for the rfm69?
                    • rmtuckerR rmtucker
                      tekkaT
                      tekkaT
                      tekka
                      @rmtucker No, but everybody is welcome to contribute and enhance the functionality.
                      • Mark SwiftM
                        Mark SwiftM
                        Mark Swift
                        @tekka, I'm trying to compile the HEX using OSX. I have installed avr-gcc with homebrew but I get
                        rm *.o
                        rm: *.o: No such file or directory
                        make: [clean] Error 1 (ignored)
                        rm *.elf
                        rm: *.elf: No such file or directory
                        rm *.hex
                        rm: *.hex: No such file or directory
                        "avr-gcc" -funsigned-char -funsigned-bitfields -DF_CPU=16000000L -Os -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -mrelax -Wall -Wextra -Wundef -pedantic -mmcu=atmega328p -c -std=gnu99 -MD -MP -MF "MYSBootloader.d" -MT"MYSBootloader.d" -MT"MYSBootloader.o" -I MYSBootloader.c -o MYSBootloader.o
                        avr-gcc: fatal error: no input files
                        compilation terminated.
                        make: *** [MYSBootloader.o] Error 1
                        When issueing the Make command, can you help, any suggestions?
                          rm *.o
                          rm *.elf
                          rm *.hex
                          tekkaT
                          tekkaT
                          tekka
                          @Mark-Swift I haven't tested that with OSX - maybe somebody can help here?
                          ? 1 Reply Last reply
                          • Mark SwiftM
                            Mark SwiftM
                            Mark Swift
                            @tekka, started a windows VM, run via MinGW and got this when running makefile, does it look okay?
                            C:\MySensorsBootloaderRF24-development>mingw32-make.exe
                            rm *.o
                            process_begin: CreateProcess(NULL, rm *.o, ...) failed.
                            make (e=2): The system cannot find the file specified.
                            Makefile:40: recipe for target 'clean' failed
                            mingw32-make.exe: [clean] Error 2 (ignored)
                            rm *.elf
                            process_begin: CreateProcess(NULL, rm *.elf, ...) failed.
                            rm *.hex
                            process_begin: CreateProcess(NULL, rm *.hex, ...) failed.
                            "C:/Arduino/hardware/tools/avr/bin/avr-gcc" -funsigned-char -funsigned-bitfields
                            D -MP -MF "MYSBootloader.d" -MT"MYSBootloader.d" -MT"MYSBootloader.o"  -IC:/Ardu
                            ino/hardware/tools/avr/avr/include/avr MYSBootloader.c -o MYSBootloader.o
                            In file included from Core.h:40:0,
                                             from MYSBootloader.c:69:
                            HW.h:51:2: warning: #warning is a GCC extension
                             #warning BAUD_RATE error greater than 2%
                            HW.h:51:2: warning: #warning BAUD_RATE error greater than 2% [-Wcpp]
                            In file included from Core.h:42:0,
                            MyMessage.h:292:3: warning: ISO C99 doesn't support unnamed structs/unions [-Wpe
                            dantic]
                            "C:/Arduino/hardware/tools/avr/bin/avr-gcc" -nostartfiles -Wl,-s -Wl,-static -Wl
                            ,-Map=".map" -Wl,--start-group -Wl,--end-group -Wl,--gc-sections -mrelax -Wl,-se
                            ction-start=.text=0x7800 -mmcu=atmega328p   -o MYSBootloader.elf MYSBootloader.o
                             -lm
                            "C:/Arduino/hardware/tools/avr/bin/avr-objcopy" -O ihex -R .eeprom MYSBootloader
                            .elf MYSBootloader.hex
                            "C:/Arduino/hardware/tools/avr/bin/avr-size" MYSBootloader.elf
                               text    data     bss     dec     hex filename
                               2036       6      72    2114     842 MYSBootloader.elf
                            • Mark SwiftM
                              Mark SwiftM
                              Mark Swift
                              @tekka Just wanted to check if the above log looks okay, currently rolling the bootloader out to 14 nodes (painful process!) and wanted to check if it looks okay before I do.
                              I'm also using this board.txt, I made a separate entry for my Uno's, do they all look okay? I basically used the fuses from the standard Arduino boards.txt with the change of 0x05 to 0x06 for the BOD? I noticed in the makefile that you can specify the fuses, do I need to compile a bootloader for each device with the exact fuses, or will one bootloader for 16 / 8 / 1Mhz suffice?
                              Thank you very much in advance, the bootloader is amazing work.
                              menu.cpu=Processor
                              pro.name=MySensors Bootloader for Pro Mini
                              pro.upload.tool=arduino:avrdude
                              pro.upload.protocol=arduino
                              pro.upload.maximum_size=30720
                              pro.upload.maximum_data_size=2048
                              pro.bootloader.tool=arduino:avrdude
                              pro.bootloader.unlock_bits=0x3F
                              pro.bootloader.lock_bits=0x0F
                              pro.build.mcu=atmega328p
                              pro.build.board=AVR_PRO
                              pro.build.core=arduino:arduino
                              pro.build.variant=arduino:standard
                              ## Arduino with MYSBootloader Beta 2
                              ## pro.menu.cpu.16MHzatmega328=ATmega328 16MHz (XTAL, BOD1V8) 1.3 Beta 2
                              ## pro.menu.cpu.16MHzatmega328.upload.speed=115200
                              ## pro.menu.cpu.16MHzatmega328.bootloader.low_fuses=0xFF
                              ## pro.menu.cpu.16MHzatmega328.bootloader.high_fuses=0xDA
                              ## pro.menu.cpu.16MHzatmega328.bootloader.extended_fuses=0x06
                              ## pro.menu.cpu.16MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B2_16Mhz.hex
                              ## pro.menu.cpu.16MHzatmega328.build.f_cpu=16000000L
                              ## pro.menu.cpu.8MHzatmega328=ATmega328 8MHz (RC, BOD1V8) 1.3 Beta 2
                              ## pro.menu.cpu.8MHzatmega328.upload.speed=38400
                              ## pro.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xE2
                              ## pro.menu.cpu.8MHzatmega328.bootloader.high_fuses=0xDA
                              ## pro.menu.cpu.8MHzatmega328.bootloader.extended_fuses=0x06
                              ## pro.menu.cpu.8MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B2_8Mhz.hex
                              ## pro.menu.cpu.8MHzatmega328.build.f_cpu=8000000L
                              ## pro.menu.cpu.1MHzatmega328=ATmega328 1MHz (RC/8, BOD1V8) 1.3 Beta 2
                              ## pro.menu.cpu.1MHzatmega328.upload.speed=9600
                              ## pro.menu.cpu.1MHzatmega328.bootloader.low_fuses=0x62
                              ## pro.menu.cpu.1MHzatmega328.bootloader.high_fuses=0xDA
                              ## pro.menu.cpu.1MHzatmega328.bootloader.extended_fuses=0x06
                              ## pro.menu.cpu.1MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B2_1Mhz.hex
                              ## pro.menu.cpu.1MHzatmega328.build.f_cpu=1000000L
                              ## Arduino with MYSBootloader Beta 3
                              pro.menu.cpu.16MHzatmega328=ATmega328 16MHz (XTAL, BOD1V8) 1.3 Beta 3
                              pro.menu.cpu.16MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B3_16Mhz.hex
                              pro.menu.cpu.8MHzatmega328=ATmega328 8MHz (RC, BOD1V8) 1.3 Beta 3
                              pro.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xFF
                              pro.menu.cpu.8MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B3_8Mhz.hex
                              pro.menu.cpu.1MHzatmega328=ATmega328 1MHz (RC/8, BOD1V8) 1.3 Beta 3
                              pro.menu.cpu.1MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B3_1Mhz.hex
                              menu.cpu=Processor
                              uno.name=MySensors Bootloader for Uno
                              uno.upload.tool=arduino:avrdude
                              uno.upload.protocol=arduino
                              uno.upload.maximum_size=32256
                              uno.upload.maximum_data_size=2048
                              uno.bootloader.tool=arduino:avrdude
                              uno.bootloader.unlock_bits=0x3F
                              uno.bootloader.lock_bits=0x0F
                              uno.build.mcu=atmega328p
                              uno.build.board=AVR_UNO
                              uno.build.core=arduino:arduino
                              uno.build.variant=arduino:standard
                              ## uno.menu.cpu.16MHzatmega328=ATmega328 16MHz (XTAL, BOD1V8) 1.3 Beta 2
                              ## uno.menu.cpu.16MHzatmega328.upload.speed=115200
                              ## uno.menu.cpu.16MHzatmega328.bootloader.low_fuses=0xFF
                              ## uno.menu.cpu.16MHzatmega328.bootloader.high_fuses=0xDA
                              ## uno.menu.cpu.16MHzatmega328.bootloader.extended_fuses=0x06
                              ## uno.menu.cpu.16MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B2_16Mhz.hex
                              ## uno.menu.cpu.16MHzatmega328.build.f_cpu=16000000L
                              uno.menu.cpu.16MHzatmega328=ATmega328 16MHz (XTAL, BOD1V8) 1.3 Beta 3
                              uno.menu.cpu.16MHzatmega328.bootloader.file=MYSBootloader/MYSBootloader_B3_16Mhz.hex
                                rm *.o
                                rm *.elf
                                rm *.hex
                                dantic]
                                 -lm
                                tekkaT
                                tekkaT
                                tekka
                                @Mark-Swift What changes did you make to the bootloader - the code size seems increased
                                Mark SwiftM 1 Reply Last reply
                                • tekkaT tekka
                                  Mark SwiftM
                                  Mark SwiftM
                                  Mark Swift
                                  #42
                                  @tekka None that I'm aware of? :(
                                  I just changed the fuses in the makefile to match the ones in my boards.txt, not sure if that's required, can you take a look at my questions above, I really want to be sure I'm doing all of this right before deploying.
                                  To recap with regards the bootloader.
                                  1. Installed Windows 7
                                  2. Installed mingw (core and c++ compiler)
                                  3. Installed Arduino IDE and MySensors library (Installed at the same location as you, at c drive root)
                                  4. Downloaded bootloader from github
                                  5. Edited the fuses and clock speed at the top of the makefile to match my boards.txt
                                  6. Ran makefile from cmd
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @Mark-Swift ok, most probably a false alarm. I assume you tested it after compilation?
                                    • Mark SwiftM
                                      Mark SwiftM
                                      Mark Swift
                                      @tekka It seems to work? I guess if there was an issue it wouldn't work at all?
                                      Please can you conform my fuses look okay in the boards.txt I posted above? Also, do I need to change the fuses in the makefile and make a file for each device, or just 1 x 16Mhz and 1 x 8Mhz for example?
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @Mark-Swift I'm not at my workstation right now - you have to adjust the fuse settings according to your HW configurations and preferences. The fuse settings in the makefile are obsolete if you use the Arduino IDE / boards.txt for flashing. Please use the AVR fuse calculator to calculate to correct fuse settings:
                                        http://www.engbedded.com/fusecalc/
                                        • Mark SwiftM
                                          Mark SwiftM
                                          Mark Swift
                                          I @tekka, I thought as much, so basically I just need a bootloader with the right Mhz and then set fuses in the Arduino IDE boards.txt.
                                          I used the fuse settings from the original boards.txt included with the Arduino IDE, but adjusted the extended one to 0x06 (Adjust BOD).
                                          I noticed you used slightly different fuses to the Arduino IDE, you're using fuses that indicate a floating crystal or something?
