  3. 💬 RFM69 Serial GW (ATMEGA328P)
mysensors gatewayserial
24 Posts 7 Posters 9.0k Views 6 Watching
  • O Offline
    O Offline
    openhardware.io
    https://www.openhardware.io/view/316/RFM69-Serial-GW-ATMEGA328P
    • H Offline
      H Offline
      :thumbsup: Nice!
      • N Offline
        N Offline
        The cp2102 is a good choice: you can upload at a faster speed than you can with an FTDI.
        kalinaK 1 Reply Last reply
        • N NeverDie
          kalinaK Offline
          kalinaK Offline
          kalina
          I studied this question and knew that FTDI is more faster than CP2102....
          • mtiutiuM Offline
            mtiutiuM Offline
            mtiutiu
            I chosed CP2102 mainly for the low component count which is needed to create a simple usb to serial converter. The baudrate is sufficient enough for the most of the projects imho.
            • mtiutiuM mtiutiu
              kalinaK Offline
              kalinaK Offline
              kalina
              @mtiutiu said in 💬 MySensors RFM69W serial GW:
              As for me, i chose CP2102 because he has On-chip voltage regulator 3.3V.
              • mtiutiuM Offline
                mtiutiuM Offline
                mtiutiu
                I won't rely on the integrated voltage regulator because usually it's not capable to supply high currents. As I've seen on other USB to serial converter chips the current capability of the integrated voltage regulator is about 50mA or so(maybe some can provide up to 100mA). Anyway if using NRF24l01 radios and small current LEDs then maybe it won't be an issue but I wouldn't count on it on the long term. Radio module + microcontroller + LEDs + other components can reach the 50mA limit especially when using RFM69W or HW variant. Now I know that the TX period may be short and only the average drawn current matters in the end but still I won't take it to the near limits. Just my 2 cents here.
                N 1 Reply Last reply
                • mtiutiuM mtiutiu
                  N Offline
                  N Offline
                  @mtiutiu
                  I agree. According to the schematic, you do use the MCP1703A-3302 as a voltage regulator, which is rated to 250ma. It seems that many problems are easily avoided when there's a more than ample power source.
                  Also, for whatever reason, the Arduino IDE doesn't seem to support the highest baud rate that's apparently possible with the FTDI. It does though with the CP2101.
                  • mtiutiuM Offline
                    mtiutiuM Offline
                    mtiutiu
                    Today I managed to finish this project: hardware assembly and initial serial gw sketch upload and I get I_GATEWAY_READY from serial console so everything seems to be in order. I need to perform some more tests though with some nodes attached and see the messages coming in and out but so far it seems very promising. I didnt' soldered the LEDs yet but that's not so important for now :simple_smile: .
                    CP2102 usb to serial converter chip working(first line from usb devices listing):
                    mtiutiu@mtiutiu-H67MA-USB3-B3 ~/Work/AVR_Playground/sensors_network/project/SerialGateway $ lsusb
                    Bus 002 Device 015: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP210x UART Bridge / myAVR mySmartUSB light
                    Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
                    Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                    Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                    Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                    Bus 001 Device 005: ID 045e:0779 Microsoft Corp. LifeCam HD-3000
                    Bus 001 Device 004: ID 1bcf:0005 Sunplus Innovation Technology Inc. Optical Mouse
                    Bus 001 Device 003: ID 046d:c31c Logitech, Inc. Keyboard K120
                    Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
                    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                    Code uploading using arduino serial bootloader POC:
                    mtiutiu@mtiutiu-H67MA-USB3-B3 ~/Work/AVR_Playground/sensors_network/project/SerialGateway $ platformio run --target upload
                    [Tue Feb 14 17:48:38 2017] Processing pro16MHzatmega328 (upload_protocol: arduino, build_flags: -I./lib/MySensors, lib_ignore: MySensors, board_f_cpu: 16000000UL, platform: atmelavr, board: pro16MHzatmega328, framework: arduino)
                    Verbose mode can be enabled via `-v, --verbose` option
                    Collected 69 compatible libraries
                    Looking for dependencies...
                    Library Dependency Graph
                    |-- <SPI> v1.0
                    Looking for upload port...
                    Auto-detected: /dev/ttyUSB0
                    Uploading .pioenvs/pro16MHzatmega328/firmware.hex
                    avrdude: reading input file ".pioenvs/pro16MHzatmega328/firmware.hex"
                    avrdude: writing flash (13122 bytes):
                    Writing | ################################################## | 100% 3.96s
                    avrdude: 13122 bytes of flash written
                    avrdude: verifying flash memory against .pioenvs/pro16MHzatmega328/firmware.hex:
                    avrdude: load data flash data from input file .pioenvs/pro16MHzatmega328/firmware.hex:
                    avrdude: input file .pioenvs/pro16MHzatmega328/firmware.hex contains 13122 bytes
                    Reading | ################################################## | 100% 3.00s
                    avrdude: verifying ...
                    avrdude: 13122 bytes of flash verified
                    avrdude: safemode: Fuses OK (E:00, H:00, L:00)
                    avrdude done.  Thank you
                    MySController serial gw connection and startup ok message:
                    • mtiutiuM Offline
                      mtiutiuM Offline
                      mtiutiu
                      Serial gw is working. Tested with real MySensors nodes and it's working properly. Now regarding stability and such - well...that only time will tell us.
                      • tonnerre33T Offline
                        tonnerre33T Offline
                        tonnerre33
                        Hello, what is the goal of the TXB0104, it's the first time that i see him in a project ?
                        mtiutiuM 1 Reply Last reply
                        • tonnerre33T tonnerre33
                          mtiutiuM Offline
                          mtiutiuM Offline
                          mtiutiu
                          @tonnerre33
                          It's a logic level voltage converter. The MCU runs at 5V so the logic level voltage that it uses on the SPI port which connects to the RFM69W use 5V too. But the RFM69W module runs at 3.3V and it's not 5V tolerant on its SPI port pins.
                          The purpose of that IC is to convert voltage levels on the SPI lines forward and backward (from 5V to 3.3V and vice versa) in order to not damage the RFM69W chip.
                          • mtiutiuM mtiutiu
                            @tonnerre33
                            tonnerre33T Offline
                            tonnerre33T Offline
                            tonnerre33
                            @mtiutiu said in 💬 MySensors RFM69W serial GW(ATMEGA328P):
                            Oh ok, and just for know, why we don't power the atmega with 3.3V ?
                              mtiutiuM Offline
                              mtiutiuM Offline
                              mtiutiu
                              @tonnerre33
                              Because at 3.3V the atmega328p mcu can run at max 8MHz as per datasheet. So I wanted it to run at double the speed and for that it needs 5V as per datasheet again. Why at 16MHz? Well because I want the gateway to be more faster in general and to quickly process the incoming messages from the entire radio network.
                                tonnerre33T Offline
                                tonnerre33
                                Thanks a lot, now i know why ;)
                                  mtiutiuM Offline
                                  mtiutiuM Offline
                                  mtiutiu
                                  @tonnerre33
                                  And to use higher baudrates for the serial port on the mcu also. To achieve higher baudrates you need a higher mcu clock frequency too.
                                  • S Offline
                                    shabba
                                    Does anyone have a BOM for this?
                                    • S shabba
                                      mtiutiuM Offline
                                      mtiutiuM Offline
                                      mtiutiu
                                      @shabba
                                      Sorry but I don't have one now. When I have time I will generate it. For now I'm busy with the Livolo stuff.
                                        tonnerre33T Offline
                                        tonnerre33
                                        0_1494000655324_upload-1cfecb9c-1343-4411-a8c4-b4546cd9a63e
                                        A fast extraction without traitment if that can help ;)
                                        • S Offline
                                          shabba
                                          I see C5 on the board has polarity. My ceramic caps seem to have no polarity (no markings on it - https://www.digikey.com/product-detail/en/murata-electronics-north-america/ZRB18AR61E106ME01L/490-10991-1-ND/5321192).
                                          I assume that this is ok and this does not need to be a tantalum cap?
                                          12.2k
