  3. rs485 on nano
rs485 on nano
44 Posts 14 Posters 25.7k Views 15 Watching
  • wimdW wimd
    @dbemowsk It are the standard examples.
    For the gateway (Uno) :
     * The RS485 Gateway prints data received from sensors on the serial link.
     * The gateway accepts input on seral which will be sent out on
     * the RS485 link.
     * LEDs (OPTIONAL):
     * - To use the feature, uncomment MY_LEDS_BLINKING_FEATURE in MyConfig.h
     * The gateway uses AltSoftSerial to handle two serial links
     * on one Arduino. Use the following pins for RS485 link
     *  Board          Transmit  Receive   PWM Unusable
     * Teensy 3.0 & 3.1  21        20         22
     * Teensy 2.0         9        10       (none)
     * Teensy++ 2.0      25         4       26, 27
     * Arduino Uno        9         8         10
     * Arduino Leonardo   5        13       (none)
     * Arduino Mega      46        48       44, 45
     * Wiring-S           5         6          4
     * Sanguino          13        14         12
    // Enable RS485 transport layer
    #define MY_RS485
    // Define this to enables DE-pin management on defined pin
    #define MY_RS485_DE_PIN 2
    // Set RS485 baud rate to use
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Flash leds on rx/tx/err
    // Set blinking period
    // Enable inclusion mode
    #define MY_DEFAULT_ERR_LED_PIN 4  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  5  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  6  // the PCB, on board LED
    For the sensor (Nano):
     * Version 1.0 - Henrik Ekblad
     * This is an example of sensors using RS485 as transport layer
     * The transport uses AltSoftSerial to handle two serial links
     * Wiring-S           5         6          4
     * Sanguino          13        14         12 *
    #define MY_RS485
    // Initialize motion message
      present(CHILD_ID, S_MOTION);
      // Read digital motion value
      Serial.println(tripped);
    skatunS
    skatunS
    skatun
    @wimd include debug and remove inclusion from the sketches and it should be ok. I have ordered new rs485 shield, i expect that to be the issue..
    wimdW R 2 Replies Last reply
    • consul58C consul58
      @skatun
      I found the solution.
      Look at this
      Place the following in your Node-Sketch e.g. for Node ID 23
       #define MY_NODE_ID 23
      and the communication between node and Gateway is ok.
      I hope this works for you.
      bocmauB
      bocmauB
      bocmau
      Thanks for the tip now works
      • skatunS skatun
        wimdW
        wimdW
        wimd
        @skatun include debug, removal of inclusion and define MY_NODE_ID enabled communication on the RS485 bus.
        • R
          R
          Reza
          • skatunS skatun
            R
            R
            Reza
            wrote on last edited by Reza
            #24
            @skatun my problem is solve . you test this and feedback me. use 3.3v and gnd pins in arduino use for rs485 module.
            b0rmannB 1 Reply Last reply
            • R
              R
              Reza
              #25
              is this wiring true for rs485 ? thank you
              also which cable is appropriate for A and B?
              • R Reza
                b0rmannB
                b0rmannB
                b0rmann
                @Reza
                no. rs485 must have LINEAR BUS topology.
                • b0rmannB b0rmann
                  @Reza
                  R
                  R
                  Reza
                  @b0rmann my pic is not a bus ? i think this is a bus topology !
                  • b0rmannB b0rmann
                    @Reza
                    R
                    R
                    Reza
                    #28
                    @b0rmann
                    this is a bus ?
                    so in end of A and B , what am i do ?
                    dbemowskD wimdW 2 Replies Last reply
                    • R
                      R
                      Reza
                      • R Reza
                        @b0rmann
                        this is a bus ?
                        dbemowskD
                        dbemowskD
                        @Reza Though your two pictures are both bus topologies, your first one is a star bus topology and your second is a linear bus topology. As to your second question "so in end of A and B , what am i do ?" Depending on a few factors such as equipment connected, cable type, cable length and data speed (baud rate) used, you may or may not need a termination resistor at the end of the line. For short runs you typically won't need them, but if you have hundreds of feet you are working with, you may want them, especially if you want to run at a higher baud like 115200 or higher. As to the resistor value, just do a google search for "RS485 termination resistor."
                        wallyllamaW 1 Reply Last reply
                        • R Reza
                          @b0rmann
                          this is a bus ?
                          wimdW
                          wimdW
                          wimd
                          @Reza
                          This is how you build your network.
                          0_1485774949144_upload-db051496-c19d-4aea-8587-147867877ea3
                          I assume that you use these :
                          0_1485775090027_upload-6265356e-49b3-4577-8666-060af56319df
                          Node 1 is the MAX485 RS-485 Module connected to your gateway.
                          Node N is the MAX485 RS-485 Module connected to your last sensor of your network.
                          Between node 1 and N you can add addtional nodes but you need to keep the bus structure.
                          Important are the terminating resistors (1) and (2). They are R7 on the RS-485 module.
                          If you add modules between node 1 and node N and you have a failure in transmitting, check then with removal of R7 on that added node.
                          R 1 Reply Last reply
                          • wimdW wimd
                            @Reza
                            R
                            R
                            Reza
                            #32
                            @wimd
                            i use this module (rs485) . for max 30 or 40 meter. is need resistors ? ( if need 100 ohm is good ?)
                            i think the problem that @skatun told was solve with 3.3v pin on arduino but no. i use static ID for nodes and remove INCLUSION MODE in gateway but when connect i have error:
                            2035 !TSM:FPAR:NO REPLY
                            2037 TSM:FPAR
                            2055 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            4063 !TSM:FPAR:NO REPLY
                            4065 TSM:FPAR
                            4082 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            6090 !TSM:FPAR:NO REPLY
                            6092 TSM:FPAR
                            6110 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            8118 !TSM:FPAR:FAIL
                            8119 TSM:FAIL:CNT=1
                            8121 TSM:FAIL:PDT
                            after some reset and change pins of vcc and gnd , when use 3.3v in gateway for vcc rs485 module i see (in serial monitor) node is connect to gateway. so i think this is ok always. but today i try for new node and i see same problem again
                            do you think this is related to power ?
                            • R
                              R
                              Reza
                              i found a thing about this . i think all of problem is related to power ! when power of node is with a adaptor 1A and power of gateway is with usb of raspberry so i have this error "!TSM:FPAR:NO REPLY" but when connect both ( node and gateway to laptop with usb) after several test i see all of connect is ok ( several reset and connect/disconnect usb cable) . i am beginner sorry , so for this what am i do ? can i use another power for vcc and gnd rs485 module ? how ? or you have better solution ?
                              • R
                                R
                                Reza
                                i tested again . connected gateway to my laptop (use domoticz for laptop) and use a 30 meter wire between gateway and first node. and again use a 5 meter wire for second node ( without any resistor). when start domoticz , nodes detect easy and start working well. i test again and again (with reset and power off/on)but this is ok and dont any problem(relay give command and send ack and all of thing is true) . then i connect gateway to raspberry (2 nodes is connect to laptop yet) so for a short time relay worked ( 2 - 3 command send and relay on without ack ) then all command can not send....
                                again i connect gateway to laptop and all command send and ok .
                                so i think this is related to power of usb port (raspberry)
                                can i use rx-tx gpio on raspberry and arduino and use other power for arduino ?how configure on raspberry ? thank you
                                K 1 Reply Last reply
                                • vikmadV
                                  vikmadV
                                  vikmad
                                  Many hours I solved why MySe485 example does not work :angry: ... I tried Mega, Uno, Mini, Nano, reinstallation of IDE, libraries, ClearEepromConfig, HWserial / AltSoftSerial / direct (Tx <> Rx) + (Rx <> TX) without MAX485 ...
                                  The other day I came across this forum and the solution is:
                                    #define MY_NODE_ID xx
                                  I saw a bug that RS485 communication is bad, because it is illegible. My mistake, the communication between GW and the node is not readable ASCII ...
                                  RS485 communication: Node waiting to GW respone:
                                  0_1485894929734_upload-fb5458be-c704-4c5a-9377-61558ce658c5
                                  dbemowskD 1 Reply Last reply
                                  • R Reza
                                    K
                                    K
                                    kimot
                                    @Reza
                                    Maybe stupid question from me, but have got you connected ground wires between nodes?
                                    Not only A and B?
                                    http://www.chipkin.com/rs485-cables-why-you-need-3-wires-for-2-two-wire-rs485/
                                    • vikmadV vikmad
                                      dbemowskD
                                      dbemowskD
                                      @vikmad Are your gateway and receiving node baud rates the same? You can get gibberish like that if your baud rates differ between nodes.
                                      vikmadV 1 Reply Last reply
                                      • dbemowskD dbemowsk
                                        vikmadV
                                        vikmadV
                                        vikmad
                                        @dbemowsk It works now. To sketch, I added the line: #define MY_NODE_ID xx
                                        Arduino IDE 1.8.1, MySensors Library v2.1.1:
                                        • Upload ClearEepromConfig
                                        • Upload MotionSensorRS485
                                          = not working
                                        • Add #define MY_NODE_ID 1 to MotionSensorRS485 and upload
                                          = working
                                        • K kimot
                                          @Reza
                                          Not only A and B?
                                          R
                                          R
                                          Reza
                                          #39
                                          @kimot said in rs485 on nano:
                                          @Reza
                                          Not only A and B?
                                          no i use just 2 wire ( A & B ) . but problem is solve. i change power of raspberry. this work well !
                                          this is compulsion (wire for ground) ? or if i connect ground of 2 nodes is better ?
