  3. rs485 on nano
rs485 on nano
44 Posts 14 Posters 25.7k Views 15 Watching
  • P pjr
    @skatun did you got this working?
    I faced similar situation when I was accidentally connected rx & tx wrong way around on my GW. The sensor node was constantly polling for parent but got no response.
    The "gibberish" on RS485 bus might also be the control chars the transport uses.. SOH, STX, ETX and EOT.
    See this post.
    In my GW sketch I have these two enabled:
    skatunS
    skatunS
    skatun
    @pjr @consul58 Have been away the last 5 days, will update the thread with the result tomorrow. Can anyone lighten me up on benefit of having inclusion button, and what inclusion time should be set to?
      The inclusion mode was initially developed for Vera because it had the bad behaviour of needing a restart (of its main process) each time a device was added.
      It is all a controller-side thing after all (all messages, including presentation is always passed to controller). But the mode can be turned on using a physical button on the gateway device. Which results in a message to controller saying start/stop inclusion mode.
      • P
        P
        pjr
        Good to know. Think then I can throw that away since I'm using domoticz.
        • skatunS
          skatunS
          skatun
          Implemented fixed node ID without success, I think maybe the rs485 adapter on gateway is broken, will test more tomorrow
          wimdW 1 Reply Last reply
          • skatunS skatun
            wimdW
            wimdW
            wimd
            @skatun Will join this discussion as well. I have exately the same issue. My set up is a nano as sensor and an uno as gateway.
            I verified correct wiring of RS485 network is correctly doen I used this sketch (swith ReceiveOrSend to RS485Transmit or RS485Receive on both nodes;
            #include <AltSoftSerial.h>
            AltSoftSerial altSerial;
            #define SSerialTxControl 2 //RS485 Direction control
            #define RS485Transmit HIGH
            #define RS485Receive LOW
            bool ReceiveOrSend = RS485Transmit;
            Serial.begin(9600);
            Serial.println("AltSoftSerial Test Begin");
            pinMode(SSerialTxControl, OUTPUT);
            digitalWrite(SSerialTxControl, RS485Transmit); // Enable RS485 Transmit
            altSerial.begin(9600);
            if (ReceiveOrSend ){
            Serial.println("send mode");
            } else
            digitalWrite(SSerialTxControl, RS485Receive); // Enable RS485 Transmit
            Serial.println("receive mode");
            char receivedOnRS485;
            altSerial.println(" Hello world");
            delay(2000);
            } else
            if (altSerial.available()) {
            receivedOnRS485 = altSerial.read();
            Serial.print("ontvagen=");
            Serial.println(receivedOnRS485);
            dbemowskD 1 Reply Last reply
            • wimdW wimd
              Serial.begin(9600);
              } else
              delay(2000);
              } else
              dbemowskD
              dbemowskD
              @wimd As my reply stated in the other thread, it would be helpful to see all sketches being used so we can determine better where the problem may lie.
              • dbemowskD dbemowsk
                wimdW
                wimdW
                wimd
                @dbemowsk It are the standard examples.
                For the gateway (Uno) :
                 * The RS485 Gateway prints data received from sensors on the serial link.
                 * The gateway accepts input on seral which will be sent out on
                 * the RS485 link.
                 * LEDs (OPTIONAL):
                 * - To use the feature, uncomment MY_LEDS_BLINKING_FEATURE in MyConfig.h
                 * The gateway uses AltSoftSerial to handle two serial links
                 * on one Arduino. Use the following pins for RS485 link
                 *  Board          Transmit  Receive   PWM Unusable
                 * Teensy 3.0 & 3.1  21        20         22
                 * Teensy 2.0         9        10       (none)
                 * Teensy++ 2.0      25         4       26, 27
                 * Arduino Uno        9         8         10
                 * Arduino Leonardo   5        13       (none)
                 * Arduino Mega      46        48       44, 45
                 * Wiring-S           5         6          4
                 * Sanguino          13        14         12
                // Enable RS485 transport layer
                #define MY_RS485
                // Define this to enables DE-pin management on defined pin
                #define MY_RS485_DE_PIN 2
                // Set RS485 baud rate to use
                // Enable serial gateway
                #define MY_GATEWAY_SERIAL
                // Flash leds on rx/tx/err
                // Set blinking period
                // Enable inclusion mode
                #define MY_DEFAULT_ERR_LED_PIN 4  // Error led pin
                #define MY_DEFAULT_RX_LED_PIN  5  // Receive led pin
                #define MY_DEFAULT_TX_LED_PIN  6  // the PCB, on board LED
                For the sensor (Nano):
                 * Version 1.0 - Henrik Ekblad
                 * This is an example of sensors using RS485 as transport layer
                 * The transport uses AltSoftSerial to handle two serial links
                 * Wiring-S           5         6          4
                 * Sanguino          13        14         12 *
                #define MY_RS485
                // Initialize motion message
                  present(CHILD_ID, S_MOTION);
                  // Read digital motion value
                  Serial.println(tripped);
                skatunS 1 Reply Last reply
                • wimdW wimd
                   * the RS485 link.
                   * LEDs (OPTIONAL):
                   * Wiring-S           5         6          4
                   * Sanguino          13        14         12
                  #define MY_RS485
                   * Wiring-S           5         6          4
                  #define MY_RS485
                  skatunS
                  skatunS
                  skatun
                  @wimd include debug and remove inclusion from the sketches and it should be ok. I have ordered new rs485 shield, i expect that to be the issue..
                  wimdW R 2 Replies Last reply
                  • consul58C consul58
                    @skatun
                    I found the solution.
                    Look at this
                    Place the following in your Node-Sketch e.g. for Node ID 23
                     #define MY_NODE_ID 23
                    and the communication between node and Gateway is ok.
                    I hope this works for you.
                    bocmauB
                    bocmauB
                    bocmau
                    Thanks for the tip now works
                    • skatunS skatun
                      wimdW
                      wimdW
                      wimd
                      @skatun include debug, removal of inclusion and define MY_NODE_ID enabled communication on the RS485 bus.
                      • R
                        R
                        Reza
                        • skatunS skatun
                          R
                          R
                          Reza
                          wrote on last edited by Reza
                          #24
                          @skatun my problem is solve . you test this and feedback me. use 3.3v and gnd pins in arduino use for rs485 module.
                          b0rmannB 1 Reply Last reply
                          • R
                            R
                            Reza
                            #25
                            is this wiring true for rs485 ? thank you
                            also which cable is appropriate for A and B?
                            • R Reza
                              b0rmannB
                              b0rmannB
                              b0rmann
                              @Reza
                              no. rs485 must have LINEAR BUS topology.
                              • b0rmannB b0rmann
                                @Reza
                                R
                                R
                                Reza
                                @b0rmann my pic is not a bus ? i think this is a bus topology !
                                • b0rmannB b0rmann
                                  @Reza
                                  R
                                  R
                                  Reza
                                  #28
                                  @b0rmann
                                  this is a bus ?
                                  so in end of A and B , what am i do ?
                                  dbemowskD wimdW 2 Replies Last reply
                                  • R
                                    R
                                    Reza
                                    • R Reza
                                      @b0rmann
                                      this is a bus ?
                                      dbemowskD
                                      dbemowskD
                                      @Reza Though your two pictures are both bus topologies, your first one is a star bus topology and your second is a linear bus topology. As to your second question "so in end of A and B , what am i do ?" Depending on a few factors such as equipment connected, cable type, cable length and data speed (baud rate) used, you may or may not need a termination resistor at the end of the line. For short runs you typically won't need them, but if you have hundreds of feet you are working with, you may want them, especially if you want to run at a higher baud like 115200 or higher. As to the resistor value, just do a google search for "RS485 termination resistor."
                                      wallyllamaW 1 Reply Last reply
                                      • R Reza
                                        @b0rmann
                                        this is a bus ?
                                        wimdW
                                        wimdW
                                        wimd
                                        @Reza
                                        This is how you build your network.
                                        0_1485774949144_upload-db051496-c19d-4aea-8587-147867877ea3
                                        I assume that you use these :
                                        0_1485775090027_upload-6265356e-49b3-4577-8666-060af56319df
                                        Node 1 is the MAX485 RS-485 Module connected to your gateway.
                                        Node N is the MAX485 RS-485 Module connected to your last sensor of your network.
                                        Between node 1 and N you can add addtional nodes but you need to keep the bus structure.
                                        Important are the terminating resistors (1) and (2). They are R7 on the RS-485 module.
                                        If you add modules between node 1 and node N and you have a failure in transmitting, check then with removal of R7 on that added node.
                                        R 1 Reply Last reply
                                        • wimdW wimd
                                          @Reza
                                          R
                                          R
                                          Reza
                                          #32
                                          @wimd
                                          i use this module (rs485) . for max 30 or 40 meter. is need resistors ? ( if need 100 ohm is good ?)
                                          i think the problem that @skatun told was solve with 3.3v pin on arduino but no. i use static ID for nodes and remove INCLUSION MODE in gateway but when connect i have error:
                                          2035 !TSM:FPAR:NO REPLY
                                          2037 TSM:FPAR
                                          2055 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          4063 !TSM:FPAR:NO REPLY
                                          4065 TSM:FPAR
                                          4082 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          6090 !TSM:FPAR:NO REPLY
                                          6092 TSM:FPAR
                                          6110 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          8118 !TSM:FPAR:FAIL
                                          8119 TSM:FAIL:CNT=1
                                          8121 TSM:FAIL:PDT
                                          after some reset and change pins of vcc and gnd , when use 3.3v in gateway for vcc rs485 module i see (in serial monitor) node is connect to gateway. so i think this is ok always. but today i try for new node and i see same problem again
                                          do you think this is related to power ?
