  3. rs485 on nano
rs485 on nano
44 Posts 14 Posters 25.7k Views 15 Watching
  • R
    R
    Reza
    wrote on last edited by Reza
    #25
    is this wiring true for rs485 ? thank you
    also which cable is appropriate for A and B?
    • R Reza
      @skatun my problem is solve . you test this and feedback me. use 3.3v and gnd pins in arduino use for rs485 module.
      b0rmannB
      b0rmannB
      b0rmann
      @Reza
      no. rs485 must have LINEAR BUS topology.
      R 2 Replies Last reply
      • b0rmannB b0rmann
        @Reza
        R
        R
        Reza
        @b0rmann my pic is not a bus ? i think this is a bus topology !
        • b0rmannB b0rmann
          @Reza
          R
          R
          Reza
          #28
          @b0rmann
          this is a bus ?
          so in end of A and B , what am i do ?
          dbemowskD wimdW 2 Replies Last reply
          • R
            R
            Reza
            • R Reza
              @b0rmann
              this is a bus ?
              dbemowskD
              dbemowskD
              @Reza Though your two pictures are both bus topologies, your first one is a star bus topology and your second is a linear bus topology. As to your second question "so in end of A and B , what am i do ?" Depending on a few factors such as equipment connected, cable type, cable length and data speed (baud rate) used, you may or may not need a termination resistor at the end of the line. For short runs you typically won't need them, but if you have hundreds of feet you are working with, you may want them, especially if you want to run at a higher baud like 115200 or higher. As to the resistor value, just do a google search for "RS485 termination resistor."
              wallyllamaW 1 Reply Last reply
              • R Reza
                @b0rmann
                this is a bus ?
                wimdW
                wimdW
                wimd
                @Reza
                This is how you build your network.
                0_1485774949144_upload-db051496-c19d-4aea-8587-147867877ea3
                I assume that you use these :
                0_1485775090027_upload-6265356e-49b3-4577-8666-060af56319df
                Node 1 is the MAX485 RS-485 Module connected to your gateway.
                Node N is the MAX485 RS-485 Module connected to your last sensor of your network.
                Between node 1 and N you can add addtional nodes but you need to keep the bus structure.
                Important are the terminating resistors (1) and (2). They are R7 on the RS-485 module.
                If you add modules between node 1 and node N and you have a failure in transmitting, check then with removal of R7 on that added node.
                R 1 Reply Last reply
                • wimdW wimd
                  @Reza
                  R
                  R
                  Reza
                  #32
                  @wimd
                  i use this module (rs485) . for max 30 or 40 meter. is need resistors ? ( if need 100 ohm is good ?)
                  i think the problem that @skatun told was solve with 3.3v pin on arduino but no. i use static ID for nodes and remove INCLUSION MODE in gateway but when connect i have error:
                  2035 !TSM:FPAR:NO REPLY
                  2037 TSM:FPAR
                  2055 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  4063 !TSM:FPAR:NO REPLY
                  4065 TSM:FPAR
                  4082 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  6090 !TSM:FPAR:NO REPLY
                  6092 TSM:FPAR
                  6110 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  8118 !TSM:FPAR:FAIL
                  8119 TSM:FAIL:CNT=1
                  8121 TSM:FAIL:PDT
                  after some reset and change pins of vcc and gnd , when use 3.3v in gateway for vcc rs485 module i see (in serial monitor) node is connect to gateway. so i think this is ok always. but today i try for new node and i see same problem again
                  do you think this is related to power ?
                  • R
                    R
                    Reza
                    i found a thing about this . i think all of problem is related to power ! when power of node is with a adaptor 1A and power of gateway is with usb of raspberry so i have this error "!TSM:FPAR:NO REPLY" but when connect both ( node and gateway to laptop with usb) after several test i see all of connect is ok ( several reset and connect/disconnect usb cable) . i am beginner sorry , so for this what am i do ? can i use another power for vcc and gnd rs485 module ? how ? or you have better solution ?
                    • R
                      R
                      Reza
                      i tested again . connected gateway to my laptop (use domoticz for laptop) and use a 30 meter wire between gateway and first node. and again use a 5 meter wire for second node ( without any resistor). when start domoticz , nodes detect easy and start working well. i test again and again (with reset and power off/on)but this is ok and dont any problem(relay give command and send ack and all of thing is true) . then i connect gateway to raspberry (2 nodes is connect to laptop yet) so for a short time relay worked ( 2 - 3 command send and relay on without ack ) then all command can not send....
                      again i connect gateway to laptop and all command send and ok .
                      so i think this is related to power of usb port (raspberry)
                      can i use rx-tx gpio on raspberry and arduino and use other power for arduino ?how configure on raspberry ? thank you
                      K 1 Reply Last reply
                      • vikmadV
                        vikmadV
                        vikmad
                        Many hours I solved why MySe485 example does not work :angry: ... I tried Mega, Uno, Mini, Nano, reinstallation of IDE, libraries, ClearEepromConfig, HWserial / AltSoftSerial / direct (Tx <> Rx) + (Rx <> TX) without MAX485 ...
                        The other day I came across this forum and the solution is:
                          #define MY_NODE_ID xx
                        I saw a bug that RS485 communication is bad, because it is illegible. My mistake, the communication between GW and the node is not readable ASCII ...
                        RS485 communication: Node waiting to GW respone:
                        0_1485894929734_upload-fb5458be-c704-4c5a-9377-61558ce658c5
                        dbemowskD 1 Reply Last reply
                        • R Reza
                          K
                          K
                          kimot
                          @Reza
                          Maybe stupid question from me, but have got you connected ground wires between nodes?
                          Not only A and B?
                          http://www.chipkin.com/rs485-cables-why-you-need-3-wires-for-2-two-wire-rs485/
                          • vikmadV vikmad
                            dbemowskD
                            dbemowskD
                            @vikmad Are your gateway and receiving node baud rates the same? You can get gibberish like that if your baud rates differ between nodes.
                            vikmadV 1 Reply Last reply
                            • dbemowskD dbemowsk
                              vikmadV
                              vikmadV
                              vikmad
                              @dbemowsk It works now. To sketch, I added the line: #define MY_NODE_ID xx
                              Arduino IDE 1.8.1, MySensors Library v2.1.1:
                              • Upload ClearEepromConfig
                              • Upload MotionSensorRS485
                                = not working
                              • Add #define MY_NODE_ID 1 to MotionSensorRS485 and upload
                                = working
                              • K kimot
                                @Reza
                                Not only A and B?
                                R
                                R
                                Reza
                                #39
                                @kimot said in rs485 on nano:
                                @Reza
                                Not only A and B?
                                no i use just 2 wire ( A & B ) . but problem is solve. i change power of raspberry. this work well !
                                this is compulsion (wire for ground) ? or if i connect ground of 2 nodes is better ?
                                • R
                                  R
                                  Reza
                                  • RedguyR
                                    RedguyR
                                    Redguy
                                    No, connecting ground is not mandatory.. In fact, i would not recommend it at all, especialy not on longer bus lengts.. Just use A&B
                                    If you have shielded cables.. Connect the shielding to gnd on 1 side only and leave the other side unconnected..
                                    This will provide shielding but prevent ground loop issues.
                                    • RedguyR
                                      RedguyR
                                      Redguy
                                      Also keepin mind that those cheap rs485 adapters have a 120ohm load resistor and pull up and pulldown resistors installed for the rs485 bus..
                                      Those should only ve installed on the ends of the data bus.. So remove them from the rest of the adapters if you use more than 2.
                                        wallyllamaW
                                        wallyllamaW
                                        wallyllama
                                        • wallyllamaW wallyllama
                                          [[topic:post-is-deleted]]
                                          wallyllamaW
                                          wallyllamaW
                                          wallyllama
