  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 256.4k Views 53 Watching
  • AnticimexA
    AnticimexA
    Anticimex
    The architecture we use would place this kind of situation to the controller to solve. One gw per network. So one gw for nrf and one for rfm.
    HW is cheap, and library should be kept simple.
    • AnticimexA Anticimex
      FotoFieberF
      FotoFieberF
      FotoFieber
      @Anticimex
      One gateway per radio, that is what I think is best. :+1:
      What I try to do, is to implement a controller with arduino due for up to three serial gateways. If there would be a solution for ethernet&rfm69 I may not have invested time in this. :laughing:
      • tbowmoT
        tbowmoT
        tbowmo
        @FotoFieber
        Well sensebender GW supports rfm69 with ethernet ;)
        FotoFieberF alexsh1A 2 Replies Last reply
        • tbowmoT tbowmo
          @FotoFieber
          FotoFieberF
          FotoFieberF
          FotoFieber
          @tbowmo
          Yes, that is really nice. :+1:
          My other goal was to have a new MQTTClientGateway, as it existed with MySensors 1.1 (which is not only a gateway, but a controller too). It would have been really painful to add it to MySensors 2.1.x, as I would have to patch core files. It is much easier, to throw hardware at it. :laughing:
          • tbowmoT tbowmo
            @FotoFieber
            alexsh1A
            alexsh1A
            alexsh1
            @tbowmo More practical question. I have received the GW and it already has MySensors 2.1.0 software. Excellent service by Itead. Can you please help me how to map LEDs in the GW sketch? I can see that they are connected to pins 38, 41, 42, 39, 40 as LED1, LED2, LED3, LED4 and LED5. Thanks
            tbowmoT 1 Reply Last reply
            • alexsh1A alexsh1
              tbowmoT
              tbowmoT
              tbowmo
              #104
              @alexsh1
              you should be able to use LED_BLUE, LED_GREEN etc. defines (or even just LED_1, LED_2..) in your sketch, to access the different LED's on board the gateway. That is, if you are using the SenseBender GW hardware support files in arduino (installation instructions are here https://github.com/mysensors/ArduinoBoards)
              Also, look at the board definition files, located here https://github.com/mysensors/ArduinoHwSAMD/blob/master/variants/mysensors_gw/variant.cpp
              and here https://github.com/mysensors/ArduinoHwSAMD/blob/master/variants/mysensors_gw/variant.h
              alexsh1A 1 Reply Last reply
              • tbowmoT tbowmo
                @alexsh1
                alexsh1A
                alexsh1A
                alexsh1
                @tbowmo Excellent links, many thanks. BTW the board is working with the standard arduino samd, the problem I suppose comes with things LEDs.
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @alexsh1
                  You might be able to compile with the standard arduino zero BSP files. But the IO mapping is not the same at all.. I have swapped some pins to make routing a bit easier. Also the SPI channels are configured a bit differently than the standard arduino, if I remember right. So I will advise to use the mysensors gateway BSP files..
                  • tbowmoT tbowmo
                    @alexsh1
                    alexsh1A
                    alexsh1A
                    alexsh1
                    #107
                    @tbowmo it is already done. Thanks to your link I have now Sensebender Gateway board added.
                    Waiting for an ethernet board now, it has stuck in the post
                    • F
                      F
                      Fabien
                      @tbowmo : Did you try to use this board with platformio ?
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @Fabien
                        No, platformio is still on my bucketlist.. There is just not hours enough for everything :)
                        • tbowmoT tbowmo
                          @Fabien
                          F
                          F
                          Fabien
                          @tbowmo Ok I will install arduino IDE to upgrade it to 2.1.1
                          Please post here iwhen you have more information. I think I will try but I have no experience with this architecture.
                          • delivereathD
                            delivereathD
                            delivereath
                            Has anyone designed a case for the sensebender gateway ?
                            • delivereathD delivereath
                              tbowmoT
                              tbowmoT
                              tbowmo
                              @delivereath
                              I designed one in freecad for the GW and a nrf24l01 with lna/pa and external antenna.
                              But I still have some fine tuning to do before releasing it, as the lid locking mechanism didn't turn out like expected.
                                #113
                                Tea time..
                                Here is my custom box for your RFM69 Sensebender GW ! Beautiful board though ;)
                                No nail no screw :)
                                Last final minor check and i release the files, sure! (i've done one for nrf too in case..)
                                alexsh1A F 2 Replies Last reply
                                • scalzS scalz
                                  Tea time..
                                  No nail no screw :)
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @scalz beautiful box!!!
                                  Looking forward to print it too as soon as you publish it, but mine will be with nrf24l01+. Having been running both networks, I'm so much in favour of rfm69. It just works. No more caps to stabilise power or any other rf issues.
                                  I have decided to use Moteino Mega with a built-in antenna as rfm69 gateway though - it is very small and goes inside into an RPi box. And has got more memory than atmega328p
                                  • scalzS scalz
                                    Tea time..
                                    No nail no screw :)
                                    F
                                    F
                                    Fabien
                                    @scalz Yeah ! I will print this one.
                                      #116
                                      Little gift.. :)
                                      Custom box for the NRF non PA version:
                                      A bit enlarged for NRF.
                                      And here the 3d preview for both versions with my little cheat for bicolor as i've still not added this feature to my printer
                                      You can see i've added a little slot near usb on the NRF version, it's for the leds indication in case box wouldn't be white (no need for white box, you can see it by transparency). I'll do the same for rfm69, and put variant stl with it or not.
                                      Next Nrf PA version, and that'll be fine ;)
                                        Thank you @scalz!
                                          Thank you @scalz!
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @scalz Please share the STL files!
