  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 256.7k Views 53 Watching
  • tbowmoT tbowmo
    @FotoFieber
    But you ditched the sensebender Gateway, as it doesn't support multiple radios at the same time? Now you are saying that you would keep it as one radio per gateway?
    This doesn't make sense :)
    FotoFieberF
    FotoFieberF
    FotoFieber
    @tbowmo
    Maybe the design of the sensebender gateway doesn't make sense to my architectural viewpoint....
    • FotoFieberF FotoFieber
      @alexsh1
      The question is: will the software restriction be solved? If not, I do not care if it is a software or a hardware restriction. :)
      alexsh1A
      alexsh1A
      alexsh1
      @FotoFieber This is a question for the MySensors dev team. Sensebender can handle both radios. Currently, there is a software restriction.
        @tbowmo
        No, I don't have to hack the core. I use the serial API. From an architectural point of view, I don't see the need to change anything in MySensors. A serial controller can be built for under 20€ Including the radio. Why should I add complexity to support more than one radio support with one cpu in MySensors, if I can have the functipnality with the abstraction layer of the serial API? Please keep MySensors s simple as possible.
        alexsh1A
        alexsh1A
        alexsh1
        #98
        @FotoFieber No, you do have to hack the core if you want both radios to be handled properly, i.e. to handle message queues with corresponding radios. For example, sending a message is done via rfm69 only and not via nrf24l01+
        • AnticimexA
          AnticimexA
          Anticimex
          The architecture we use would place this kind of situation to the controller to solve. One gw per network. So one gw for nrf and one for rfm.
          HW is cheap, and library should be kept simple.
          • AnticimexA Anticimex
            FotoFieberF
            FotoFieberF
            FotoFieber
            @Anticimex
            One gateway per radio, that is what I think is best. :+1:
            What I try to do, is to implement a controller with arduino due for up to three serial gateways. If there would be a solution for ethernet&rfm69 I may not have invested time in this. :laughing:
            • tbowmoT
              tbowmoT
              tbowmo
              @FotoFieber
              Well sensebender GW supports rfm69 with ethernet ;)
              FotoFieberF alexsh1A 2 Replies Last reply
              • tbowmoT tbowmo
                @FotoFieber
                FotoFieberF
                FotoFieberF
                FotoFieber
                @tbowmo
                Yes, that is really nice. :+1:
                My other goal was to have a new MQTTClientGateway, as it existed with MySensors 1.1 (which is not only a gateway, but a controller too). It would have been really painful to add it to MySensors 2.1.x, as I would have to patch core files. It is much easier, to throw hardware at it. :laughing:
                • tbowmoT tbowmo
                  @FotoFieber
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @tbowmo More practical question. I have received the GW and it already has MySensors 2.1.0 software. Excellent service by Itead. Can you please help me how to map LEDs in the GW sketch? I can see that they are connected to pins 38, 41, 42, 39, 40 as LED1, LED2, LED3, LED4 and LED5. Thanks
                  tbowmoT 1 Reply Last reply
                  • alexsh1A alexsh1
                    tbowmoT
                    tbowmoT
                    tbowmo
                    #104
                    @alexsh1
                    you should be able to use LED_BLUE, LED_GREEN etc. defines (or even just LED_1, LED_2..) in your sketch, to access the different LED's on board the gateway. That is, if you are using the SenseBender GW hardware support files in arduino (installation instructions are here https://github.com/mysensors/ArduinoBoards)
                    Also, look at the board definition files, located here https://github.com/mysensors/ArduinoHwSAMD/blob/master/variants/mysensors_gw/variant.cpp
                    and here https://github.com/mysensors/ArduinoHwSAMD/blob/master/variants/mysensors_gw/variant.h
                    alexsh1A 1 Reply Last reply
                    • tbowmoT tbowmo
                      @alexsh1
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @tbowmo Excellent links, many thanks. BTW the board is working with the standard arduino samd, the problem I suppose comes with things LEDs.
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @alexsh1
                        You might be able to compile with the standard arduino zero BSP files. But the IO mapping is not the same at all.. I have swapped some pins to make routing a bit easier. Also the SPI channels are configured a bit differently than the standard arduino, if I remember right. So I will advise to use the mysensors gateway BSP files..
                        • tbowmoT tbowmo
                          @alexsh1
                          alexsh1A
                          alexsh1A
                          alexsh1
                          #107
                          @tbowmo it is already done. Thanks to your link I have now Sensebender Gateway board added.
                          Waiting for an ethernet board now, it has stuck in the post
                          • F
                            F
                            Fabien
                            @tbowmo : Did you try to use this board with platformio ?
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              @Fabien
                              No, platformio is still on my bucketlist.. There is just not hours enough for everything :)
                              • tbowmoT tbowmo
                                @Fabien
                                F
                                F
                                Fabien
                                @tbowmo Ok I will install arduino IDE to upgrade it to 2.1.1
                                Please post here iwhen you have more information. I think I will try but I have no experience with this architecture.
                                • delivereathD
                                  delivereathD
                                  delivereath
                                  Has anyone designed a case for the sensebender gateway ?
                                  • delivereathD delivereath
                                    tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @delivereath
                                    I designed one in freecad for the GW and a nrf24l01 with lna/pa and external antenna.
                                    But I still have some fine tuning to do before releasing it, as the lid locking mechanism didn't turn out like expected.
                                      #113
                                      Tea time..
                                      Here is my custom box for your RFM69 Sensebender GW ! Beautiful board though ;)
                                      No nail no screw :)
                                      Last final minor check and i release the files, sure! (i've done one for nrf too in case..)
                                      alexsh1A F 2 Replies Last reply
                                      • scalzS scalz
                                        Tea time..
                                        No nail no screw :)
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        @scalz beautiful box!!!
                                        Looking forward to print it too as soon as you publish it, but mine will be with nrf24l01+. Having been running both networks, I'm so much in favour of rfm69. It just works. No more caps to stabilise power or any other rf issues.
                                        I have decided to use Moteino Mega with a built-in antenna as rfm69 gateway though - it is very small and goes inside into an RPi box. And has got more memory than atmega328p
                                        • scalzS scalz
                                          Tea time..
                                          No nail no screw :)
                                          F
                                          F
                                          Fabien
                                          @scalz Yeah ! I will print this one.
