  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 256.7k Views 53 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @FotoFieber
    Well, you need to hack the core anyways, if you want to accomplish your goal.
    You could also help out with the core development, so we can get support for multiple transport on one gateway ;)
    • tbowmoT tbowmo
      @FotoFieber
      FotoFieberF
      FotoFieberF
      FotoFieber
      @tbowmo
      No, I don't have to hack the core. I use the serial API. From an architectural point of view, I don't see the need to change anything in MySensors. A serial controller can be built for under 20€ Including the radio. Why should I add complexity to support more than one radio support with one cpu in MySensors, if I can have the functipnality with the abstraction layer of the serial API? Please keep MySensors s simple as possible.
      AnticimexA tbowmoT alexsh1A 3 Replies Last reply
      • FotoFieberF FotoFieber
        @tbowmo
        AnticimexA
        AnticimexA
        Anticimex
        @FotoFieber simple for who? Simplicity also involve maintenance and code complexity. What about testability and regression testing? Nobody gets paid for maintaining mysensors.
          @tbowmo
          tbowmoT
          tbowmoT
          tbowmo
          @FotoFieber
          But you ditched the sensebender Gateway, as it doesn't support multiple radios at the same time? Now you are saying that you would keep it as one radio per gateway?
          This doesn't make sense :)
          • tbowmoT tbowmo
            @FotoFieber
            FotoFieberF
            FotoFieberF
            FotoFieber
            @tbowmo
            Maybe the design of the sensebender gateway doesn't make sense to my architectural viewpoint....
              @alexsh1
              The question is: will the software restriction be solved? If not, I do not care if it is a software or a hardware restriction. :)
              alexsh1A
              alexsh1A
              alexsh1
              @FotoFieber This is a question for the MySensors dev team. Sensebender can handle both radios. Currently, there is a software restriction.
                @tbowmo
                alexsh1A
                alexsh1A
                alexsh1
                #98
                @FotoFieber No, you do have to hack the core if you want both radios to be handled properly, i.e. to handle message queues with corresponding radios. For example, sending a message is done via rfm69 only and not via nrf24l01+
                • AnticimexA
                  AnticimexA
                  Anticimex
                  The architecture we use would place this kind of situation to the controller to solve. One gw per network. So one gw for nrf and one for rfm.
                  HW is cheap, and library should be kept simple.
                  • AnticimexA Anticimex
                    FotoFieberF
                    FotoFieberF
                    FotoFieber
                    @Anticimex
                    One gateway per radio, that is what I think is best. :+1:
                    What I try to do, is to implement a controller with arduino due for up to three serial gateways. If there would be a solution for ethernet&rfm69 I may not have invested time in this. :laughing:
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @FotoFieber
                      Well sensebender GW supports rfm69 with ethernet ;)
                      FotoFieberF alexsh1A 2 Replies Last reply
                      • tbowmoT tbowmo
                        @FotoFieber
                        FotoFieberF
                        FotoFieberF
                        FotoFieber
                        @tbowmo
                        Yes, that is really nice. :+1:
                        My other goal was to have a new MQTTClientGateway, as it existed with MySensors 1.1 (which is not only a gateway, but a controller too). It would have been really painful to add it to MySensors 2.1.x, as I would have to patch core files. It is much easier, to throw hardware at it. :laughing:
                        • tbowmoT tbowmo
                          @FotoFieber
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @tbowmo More practical question. I have received the GW and it already has MySensors 2.1.0 software. Excellent service by Itead. Can you please help me how to map LEDs in the GW sketch? I can see that they are connected to pins 38, 41, 42, 39, 40 as LED1, LED2, LED3, LED4 and LED5. Thanks
                          tbowmoT 1 Reply Last reply
                          • alexsh1A alexsh1
                            tbowmoT
                            tbowmoT
                            tbowmo
                            #104
                            @alexsh1
                            you should be able to use LED_BLUE, LED_GREEN etc. defines (or even just LED_1, LED_2..) in your sketch, to access the different LED's on board the gateway. That is, if you are using the SenseBender GW hardware support files in arduino (installation instructions are here https://github.com/mysensors/ArduinoBoards)
                            Also, look at the board definition files, located here https://github.com/mysensors/ArduinoHwSAMD/blob/master/variants/mysensors_gw/variant.cpp
                            and here https://github.com/mysensors/ArduinoHwSAMD/blob/master/variants/mysensors_gw/variant.h
                            alexsh1A 1 Reply Last reply
                            • tbowmoT tbowmo
                              @alexsh1
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @tbowmo Excellent links, many thanks. BTW the board is working with the standard arduino samd, the problem I suppose comes with things LEDs.
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @alexsh1
                                You might be able to compile with the standard arduino zero BSP files. But the IO mapping is not the same at all.. I have swapped some pins to make routing a bit easier. Also the SPI channels are configured a bit differently than the standard arduino, if I remember right. So I will advise to use the mysensors gateway BSP files..
                                • tbowmoT tbowmo
                                  @alexsh1
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  #107
                                  @tbowmo it is already done. Thanks to your link I have now Sensebender Gateway board added.
                                  Waiting for an ethernet board now, it has stuck in the post
                                  • F
                                    F
                                    Fabien
                                    @tbowmo : Did you try to use this board with platformio ?
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @Fabien
                                      No, platformio is still on my bucketlist.. There is just not hours enough for everything :)
                                      • tbowmoT tbowmo
                                        @Fabien
                                        F
                                        F
                                        Fabien
                                        @tbowmo Ok I will install arduino IDE to upgrade it to 2.1.1
                                        Please post here iwhen you have more information. I think I will try but I have no experience with this architecture.
                                        • delivereathD
                                          delivereathD
                                          delivereath
                                          Has anyone designed a case for the sensebender gateway ?
