  3. Parking Sensor & DHT22 combinated
9 Posts 4 Posters 2.9k Views 4 Watching
  • ghislainG
    ghislainG
    ghislain
    wrote on last edited by ghislain
    Hi all,
    I'm trying to do a sketch with both combinated parking sensor and dht22 but i'm failed.
    Each sketch is working separetely but when i 'm trying together, dht22 values are bad.
    This is my sketch :
    * Version 1.0 - Created by Henrik Ekblad
    * Parking sensor using a neopixel led ring and distance sensor (HC-SR04).
    * Configure the digital pins used for distance sensor and neopixels below.
    * NOTE! Remeber to feed leds and distance sensor serparatly from your Arduino.
    * It will probably not survive feeding more than a couple of LEDs. You
    * can also adjust intesity below to reduce the power requirements.
    * Sends parking status to the controller as a DOOR sensor if SEND_STATUS_TO_CONTROLLER
    * is defined below. You can also use this _standalone_ without any radio by
    * removing the SEND_STATUS_TO_CONTROLLER define.
    #define SEND_STATUS_TO_CONTROLLER  // Put a comment on this line for standalone mode
    #include <Adafruit_NeoPixel.h>
    #include <NewPing.h>
    #ifdef SEND_STATUS_TO_CONTROLLER
    // Enable and select radio type attached Disabled
    // Noeud de l'objet / Object Node
    #define MY_NODE_ID 1
    #define DHTPIN 3
    #define DHTTYPE DHT22
    #define NEO_PIN      8 // NeoPixels input pin
    #define TRIGGER_PIN  6  // Arduino pin tied to trigger pin on the ultrasonic sensor.
    #define ECHO_PIN     5  // Arduino pin tied to echo pin on the ultrasonic sensor.
    #define NUMPIXELS      24 // Number of nexpixels in ring/strip
    #define MAX_INTESITY   5 // Intesity of leds (in percentage). Remember more intesity requires more power.
    // The maximum rated measuring range for the HC-SR04 is about 400-500cm.
    #define MAX_DISTANCE 150 // Max distance we want to start indicating green (in cm)
    #define PANIC_DISTANCE 15 // Mix distance we red warning indication should be active (in cm)
    #define PARKED_DISTANCE 100 // Distance when "parked signal" should be sent to controller (in cm)
    #define PARK_OFF_TIMEOUT 30000 // Number of milliseconds until turning off light when parked.
    // Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest
    // example for more information on possible values.
    Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, NEO_PIN, NEO_GRB + NEO_KHZ800);
    NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
    #define CHILD_ID_TEMP 0
    #define CHILD_ID_HUM 1
    #define CHILD_ID 2
    float lastTemp;
    float lastHum;
    boolean metric = true;
    unsigned long sendInterval = 90000;  // Send park status at maximum every 5 second.
    unsigned long lastSend;
    int oldParkedStatus=-1;
    unsigned long blinkInterval = 100; // blink interval (milliseconds)
    unsigned long lastBlinkPeriod;
    bool blinkColor = true;
    // To make a fading motion on the led ring/tape we only move one pixel/distDebounce time
    unsigned long distDebounce = 30;
    unsigned long lastDebouncePeriod;
    int numLightPixels=0;
    int skipZero=0;
     Serial.println("Starting distance sensor");
     pixels.begin(); // This initializes the NeoPixel library.
     Serial.println("Neopixels initialized");
    void presentation()  {
     sendSketchInfo("Parking & Temperature & Humidity Sensor", "1.0");
     present(CHILD_ID_HUM, S_HUM);
     present(CHILD_ID, S_DOOR, "Parking Status");
     unsigned long now = millis();
     unsigned int fullDist = (sonar.ping_median() / US_ROUNDTRIP_CM);
      //Serial.println(fullDist);
     int displayDist = min(fullDist, MAX_DISTANCE);
     if (displayDist == 0 && skipZero<10) {
       // Try to filter zero readings
       skipZero++;
     return;
     // Check if it is time to alter the leds
     if (now-lastDebouncePeriod > distDebounce) {
       lastDebouncePeriod = now;
       // Update parked status
       int parked = displayDist != 0 && displayDist<PARKED_DISTANCE;
       if (parked != oldParkedStatus && now-lastSend > sendInterval) {
         if (parked)
           Serial.println("Car Parked");
           Serial.println("Car Gone");
         send(msg.set(parked));
         oldParkedStatus = parked;
         lastSend = now;
       if (parked && now-lastSend > PARK_OFF_TIMEOUT) {
         // We've been parked for a while now. Turn off all pixels
         for(int i=0;i<NUMPIXELS;i++){
           pixels.setPixelColor(i, pixels.Color(0,0,0));
         if (displayDist == 0) {
           // No reading from sensor, assume no object found
           numLightPixels--;
           skipZero = 0;
           int newLightPixels = NUMPIXELS - (NUMPIXELS*(displayDist-PANIC_DISTANCE)/(MAX_DISTANCE-PANIC_DISTANCE));
           if (newLightPixels>numLightPixels) {
             // Fast raise
             numLightPixels += max((newLightPixels - numLightPixels) / 2, 1);
           } else if (newLightPixels<numLightPixels) {
             // Slow decent
             numLightPixels--;
         if (numLightPixels>=NUMPIXELS) {
           // Do some intense red blinking
           if (now-lastBlinkPeriod > blinkInterval) {
             blinkColor = !blinkColor;
             lastBlinkPeriod = now;
           for(int i=0;i<numLightPixels;i++){
             pixels.setPixelColor(i, pixels.Color(blinkColor?255*MAX_INTESITY/100:0,0,0));
             int r = 255 * i/NUMPIXELS;
             int g = 255 - r;
             // pixels.Color takes RGB values, from 0,0,0 up to 255,255,255
             pixels.setPixelColor(i, pixels.Color(r*MAX_INTESITY/100,g*MAX_INTESITY/100,0));
           // Turn off the rest
           for(int i=numLightPixels;i<NUMPIXELS;i++){
       pixels.show(); // This sends the updated pixel color to the hardware.
    DHT dht(DHTPIN, DHTTYPE,3); // Creation d'un objet dht dans la loop sinon les valeurs ne sont pas mesurées au réveil
     float temperature = dht.readTemperature();
     float humidity = dht.readHumidity();
     if (isnan(temperature)) {
         Serial.println("Impossible de lire la temperature sur le DHT");
       if (temperature != lastTemp) {
         lastTemp = temperature;
         if (!metric) {
           temperature = dht.readTemperature(true);
         Serial.print("T: ");
         Serial.print(temperature);
         Serial.print(" | H: ");
         Serial.println(humidity);
         Serial.println("Temperature identique => on force l'envoi");
    Somebody could help me ?
    Thank you some much guys
    S 1 Reply Last reply
    • ghislainG ghislain
      Hi all,
      This is my sketch :
      #define DHTPIN 3
      #define CHILD_ID 2
      float lastTemp;
      float lastHum;
      int skipZero=0;
         skipZero++;
       return;
           if (parked)
           lastSend = now;
             numLightPixels--;
             skipZero = 0;
               // Fast raise
               // Slow decent
               numLightPixels--;
               int g = 255 - r;
           if (!metric) {
      sja
      @ghislain
      The example sketch on this site has some code for the dht in setup() https://www.mysensors.org/build/humidity
      Maybe you 've forgotten to copy this in your dht script?
        Seems strange to initialise the DHT all the time in your loop function. You also seem to spam your gateway with humidity-messages. Check your if-statements.
        • ghislainG
          ghislainG
          ghislain
          Hi, i'm very bad in code. So i tryied to assemble 2 sketches.
          Gateway is spammed yes...
          I think i need to store value of temperature and humidity, store value of parking sensor (car gone or car parked) and send everything together. It would be more clean. But i have no idea to do that.
          I'm not familiar neither with void loop / setup....
          • ghislainG
            ghislainG
            ghislain
            This is much better, but too much temperature and humidity value sended
             * Version 1.0 - Compilation of DhtTemperature & Parking Sensor
            #define DHT_DATA_PIN 3
            #define SENSOR_TEMP_OFFSET 0
            static const uint64_t UPDATE_INTERVAL = 5000;
            #define CHILD_ID_HUM 0
            #define CHILD_ID_TEMP 1
            #define CHILD_ID 2
            float lastTemp;
            float lastHum;
            uint8_t nNoUpdatesTemp;
            uint8_t nNoUpdatesHum;
            DHT dht;
            unsigned long sendInterval = 5000;  // Send park status at maximum every 5 second.
            int skipZero=0;
              sendSketchInfo("ParkingTemperatureAndHumiditySensor", "1.0");
              dht.readSensor(true);
                if (!metric) {
                // Reset no updates counter
                nNoUpdatesTemp = 0;
                #ifdef MY_DEBUG
                nNoUpdatesTemp++;
              if (isnan(humidity)) {
                lastHum = humidity;
                nNoUpdatesHum = 0;
                #ifdef MY_DEBUG
                Serial.print("H: ");
                nNoUpdatesHum++;
             // sleep(UPDATE_INTERVAL);
                skipZero++;
              return;
                  if (parked)
                  lastSend = now;
                    numLightPixels--;
                    skipZero = 0;
                      // Fast raise
                      // Slow decent
                      numLightPixels--;
                      int g = 255 - r;
            How can i get out value of temp and hum out of the loop ?
            I can't put delay because the led ring need to be refreshed very fastly.
              There is a minimum time before you can read values from dht, so you could set a check to read dht every 30000 millis so this way you can have the blinking leds and some delay between temp readings
              • ghislainG
                ghislainG
                ghislain
                Yes, thanks guys.
                static const uint64_t UPDATE_INTERVAL = 90000;
                static const uint16_t FORCE_UPDATE_N_READS = 60000;
                #define CHILD_ID 2
                float lastTemp;
                char lastHum;
                DHT dht;
                int skipZero=0;
                       if (!metric) {
                    nNoUpdatesTemp = 0;
                      else {
                    nNoUpdatesTemp++;
                  char humidity = dht.getHumidity();
                    lastHum = humidity;
                    nNoUpdatesHum = 0;
                    send(msgHum.set(humidity, 0));
                      else {
                    nNoUpdatesHum++;
                    skipZero++;
                  return;
                      if (parked)
                      lastSend = now;
                        numLightPixels--;
                        skipZero = 0;
                          // Fast raise
                          // Slow decent
                          numLightPixels--;
                          int g = 255 - r;
                This code is working. Variables was declared on 8b so max value at 255. Counter and timer can't take value above 255... Stupid.
                How can i do to only send new value if new value is just more or less 0.2°C for example ?
                  Actually the code already checks if last temperature is different from current (see the first "else if" in the loop) but if you want you can change the condition to whatever you prefer in order to send only when difference is over a certain threshold or after a specific amount of time.
                  • ghislainG
                    ghislainG
                    ghislain
                    I make this sketch, it is working, code may be cleaner but it's working...
                    Available on github : https://github.com/Gis70/MySensors/tree/master/ParkingTempHum_sensor
                    12.5k
