  3. reporting battery to domoticZ
47 Posts 5 Posters 15.9k Views 6 Watching
  • fhenrycoF Offline
    fhenrycoF Offline
    fhenryco
    Re: Reporting Battery Level
    Hello, i'm using the sketch given here https://www.mysensors.org/build/battery without modification to report battery level to domoticZ. obviously i can't use the Vcc library because the voltage i'm monitoring is the battery voltage, while the arduino is fed through the step up regulator at a stable 3.3V.
    I 'm not sure to understand then why domoticz shows 60% battery when my battery level is actually at about 3V so i would expect 3/3.44 = 87% .
    So i'm suspecting that sendBatteryLevel(batteryPcnt); does not actually send batteryPcnt as computed in the sketch but a rescaled percentage in order to match 0% when the battery will be at about 2.7V .... can someone confirm ? where can i read the actual void sendBatteryLevel() to understand what it is doing exactly ?
    S 1 Reply Last reply
    • fhenrycoF fhenryco
      @fhenryco said in reporting battery to domoticZ:
      Domoticz: https://github.com/domoticz/domoticz/blob/3741a530c2260cea2f337a095aa9477847fc00cb/hardware/MySensorsBase.cpp#L444
      MySensors: https://github.com/mysensors/MySensors/blob/9041c8ba3d896484b6d9dca6e8ff5e81a828ffa3/core/MySensorsCore.cpp#L308
      Maybe you can show us your sketch code? I have this working with Domoticz just fine.
      fhenrycoF 1 Reply Last reply
      • S sundberg84
        fhenrycoF Offline
        fhenrycoF Offline
        fhenryco
        @sundberg84 thank you but as i said i did no modification to the sketch in https://www.mysensors.org/build/battery appart merging it with a DHT11 sketch. However i did notice something strange: when i switch on the arduino (sensor side) the first percentage i get in DomoticZ was 102%, then at the next update it fell to 60% and has not changed since then. I'm suspecting there is something wrong measuring the battery level from A0 pin just after sending a temperature value ??
        Insert Code Here/**
         * Version 1.0: Henrik EKblad
         * sensor using a DHT11/DHT-22.
        // Enable debug prints
        //#define MY_RS485
        #define DHT_DATA_PIN 3
        #define SENSOR_TEMP_OFFSET 0
        static const uint64_t UPDATE_INTERVAL = 600000;
        int oldBatteryPcnt = 0;
        #define CHILD_ID_HUM 0
        #define CHILD_ID_TEMP 1
        float lastTemp;
        float lastHum;
        uint8_t nNoUpdatesTemp;
        uint8_t nNoUpdatesHum;
        bool metric = true;
        DHT dht;
          sendSketchInfo("TemperatureAndHumidity", "1.1");
          sendSketchInfo("Battery Meter", "1.0");
          present(CHILD_ID_HUM, S_HUM);
            analogReference(INTERNAL1V1);
            analogReference(INTERNAL);
          // get the battery Voltage
        #ifdef MY_DEBUG
            Serial.println(sensorValue);
        #ifdef MY_DEBUG
            Serial.print(batteryV);
            Serial.println(" V");
            Serial.print(batteryPcnt);
            Serial.println(" %");
                // Power up radio after sleep
                oldBatteryPcnt = batteryPcnt;
          dht.readSensor(true);
          if (isnan(temperature)) {
            lastTemp = temperature;
            if (!metric) {
            // Reset no updates counter
            nNoUpdatesTemp = 0;
            #ifdef MY_DEBUG
            Serial.print("T: ");
            nNoUpdatesTemp++;
          if (isnan(humidity)) {
            lastHum = humidity;
            nNoUpdatesHum = 0;
            #ifdef MY_DEBUG
            Serial.print("H: ");
            Serial.println(humidity);
            nNoUpdatesHum++;
          sleep(UPDATE_INTERVAL);
          Insert Code Here/**
          //#define MY_RS485
          float lastTemp;
          float lastHum;
          bool metric = true;
          DHT dht;
          #ifdef MY_DEBUG
          #ifdef MY_DEBUG
              if (!metric) {
              nNoUpdatesTemp = 0;
              #ifdef MY_DEBUG
              nNoUpdatesTemp++;
              lastHum = humidity;
              nNoUpdatesHum = 0;
              #ifdef MY_DEBUG
              nNoUpdatesHum++;
          @fhenryco - if you are experience changes it might help adding a wait(); or delay(); to get a more stable reading. If something is using power just as you read it might be strange values.
          This is one of my sketches (DHT + Bat): https://github.com/sundberg84/MySensors2.0.0/blob/master/NorrHumAs/NorrHumAs.ino and im using the voltage divider to A0 to measure the battery.
          • S sundberg84
            fhenrycoF Offline
            fhenrycoF Offline
            fhenryco
            @sundberg84 thanks,
            the delay 500 has a big effect , now i get 116% hence a battery voltage=3.5V, while the multimeter gives it 3V ! may be the internal reference is not 1.1V in my low cost chinese pro mini 3.3v .
            BTW i did not understand why you have also a delay 500 after reading the analog pin, i would have thought that a delay before reading the analog pin is sufficient ... (?)
              @sundberg84 thanks,
              @fhenryco - could be the delay before is sufficient.
              • fhenrycoF Offline
                fhenrycoF Offline
                fhenryco
                wrote on last edited by fhenryco
                this morning , i get 102% , much closer to the actual value ... assuming that the ADC activity did not discharge my battery at an unprecedented level (i had this sketch working for two monthes with very little discharge of the battery before adding this battery monitoring functionality). I will know for sure if the battery level does not drop further in the coming days...i'm concerned that the delay 500 might produce non negligible battery consumption
                  @fhenryco Its hard to reach a 100% correct value on the chinese clones. I get a 5% off probably all the time. Because of that I have added an average so I collect three values every 20min into an array and send the average every hour.
                  • fhenrycoF Offline
                    fhenrycoF Offline
                    fhenryco
                    ok, thanks again, something else i v been wondering about is why domoticz will show the temp + humidity sensor as a single sensor even though there are separate instructions
                    for the presentation :
                    and for the messages themselves
                    what should be modified if i want domoticZ to treat the two sensors separately ? (this is for Yana, a speech recognition software that has a plugin for domoticZ, but apparantly is not able to handle several values for a given sensor).
                    is it the sendSketchInfo("TemperatureAndHumidity", "1.1"); that needs to be replaced by two sendSketchInfo, one for temp and one for humidity ?
                      fhenrycoF Offline
                      fhenrycoF Offline
                      fhenryco
                      @fhenryco apparantly something like send(msgTemp.setSensor(CHILD_ID_TEMP).set(temperature,1));
                      send(msgHum.setSensor(CHILD_ID_HUM).set(humidity,1));
                      should do the job ! going to try that
                      but i'm surprised this is not done by default since msgHum and msgTemp are defined separately for each sensor Id
                        fhenrycoF Offline
                        fhenrycoF Offline
                        fhenryco
                        @fhenryco it did nothing different ... still have a single sensor temp+hum don't understand why ...
                          @fhenryco - Yes, and there is a trick to seperate them... and i if I remembe right @AWI is the one to ask.
                          Edit, found his post here: https://forum.mysensors.org/topic/5132/ds18b20-ans-sht31-d-show-up-as-combined-sensors-on-domoticz/13
                          • fhenrycoF Offline
                            fhenrycoF Offline
                            fhenryco
                            using V_text and S_info is a workaround to avoid grouping
                            • R Offline
                              R Offline
                              Rene046
                              i would like to ask something to ,
                              Now i have the battery level showing up in Domoticz what can i do to log the voltage in volts, should i add something inside the sketch or something in domoticz..
                              fhenrycoF A 2 Replies Last reply
                              • R Rene046
                                fhenrycoF Offline
                                fhenrycoF Offline
                                fhenryco
                                @Rene046
                                This is the instruction in your sketch which allows to see the battery level of devices in domoticZ
                                But as you noticed , this is not reported in the logs. One possibility to see it in the Log is to as well send this batteryPcnt information with a send(msgbatt.set(batteryPcnt ,1);
                                provided you have defined
                                MyMessage msgbatt(CHILD_ID_BATT, V_TEXT);
                                In other words you send the battery info as if it was the info of an additional sensor sending text type info
                                which you also need to present in the presentation void with
                                present(CHILD_ID_BATT, S_INFO);
                                For instance if you already have two sensors in you sketch let's say temp and hum with ID =0 and 1 respectively you would give the battery level the next unused ID
                                CHILD_ID_BATT=2
                                There might be a simpler and more natural way but i don't know it .
                                • R Rene046
                                  A Offline
                                  A Offline
                                  AWI
                                  @Rene046 The "royal" way to report battery level is to define it as S_MULTIMETER and use it to report voltage. Domoticz will take the voltage and can graph it. i.e.
                                  definitions: MyMessage voltageMsg(VOLTAGE_CHILD_ID, V_VOLTAGE);
                                  in presentation: present(VOLTAGE_CHILD_ID, S_MULTIMETER, "Battery level" );
                                  sending: send(voltageMsg.set(lastVoltage,2)); //send battery in Volt 2 decimal places
                                  • R Offline
                                    R Offline
                                    Rene046
                                    @ fhenryco
                                    Cant get it to work, if you have time could help with my sketch.
                                    #define CHILD_ID_BATTERY 4
                                    unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
                                    #define SKETCH_NAME "Temp_Hum_Batt"        // Change to a fancy name you like
                                    #define SKETCH_VERSION "2.1"                    // Your version
                                    DHT dht;
                                    float lastTemp;
                                    float lastHum;
                                    boolean metric = true;
                                    MyMessage msgbatt(CHILD_ID_BATTERY, V_VOLTAGE);
                                    //MyMessage msgbatt(CHILD_ID_BATTERY, V_TEXT);
                                    #define VBAT_PER_BITS 0.0041055718475073313782991202346
                                    #define VMIN 3.6                                  //  Vmin (radio Min Volt)=1.9V (564v)
                                    #define VMAX 4.2                                  //  Vmax = (2xAA bat)=3.0V (892v)
                                      present(CHILD_ID_BATTERY, S_INFO);
                                      //present(CHILD_ID_BATTERY, S_CUSTOM);
                                        if (!metric) {
                                          lastHum = humidity;
                                      batM();
                                       delay(500);
                                       // Battery monitoring reading
                                       delay(500);
                                       // Calculate the battery in %
                                       if (batLoop > 2) {
                                       if (batteryPcnt > 100) {
                                         batteryPcnt=100;
                                           batLoop = 0;
                                         batLoop++;
                                    My sketch is not working 100% my voltage is not precise, giving me even 221 in percentage while  lipo is at this moment 3.7 volt (simulated with a variable power supply)
                                    im running it on a nano on 1 lipo cell and a dc dc powerup to 5 volt measuring the lipo voltage with a  divider 1M/470K
                                    Hope to add a soil moisture sensor and baro sensor in future.
                                    p.s. any one with some better idea sketch its ver welcome. im just started to experiment with Mysensor
                                    R fhenrycoF 2 Replies Last reply
                                    • R Rene046
                                      @ fhenryco
                                      DHT dht;
                                      float lastTemp;
                                      float lastHum;
                                          if (!metric) {
                                            lastHum = humidity;
                                        batM();
                                         delay(500);
                                         delay(500);
                                         if (batLoop > 2) {
                                           batteryPcnt=100;
                                             batLoop = 0;
                                           batLoop++;
                                      R Offline
                                      R Offline
                                      Rene046
                                      O i forget to tell im running the latest gateway from Mysensor.
                                      • R Rene046
                                        @ fhenryco
                                        DHT dht;
                                        float lastTemp;
                                        float lastHum;
                                            if (!metric) {
                                              lastHum = humidity;
                                          batM();
                                           delay(500);
                                           delay(500);
                                           if (batLoop > 2) {
                                             batteryPcnt=100;
                                               batLoop = 0;
                                             batLoop++;
                                        fhenrycoF Offline
                                        fhenrycoF Offline
                                        fhenryco
                                        @Rene046
                                        not
                                        but
                                        send(msgbatt.set(batteryPcnt ,1));
                                        also may be better to use S_MULTIMETER and V_VOLTAGE (rather than S_INFO and V_TEXT) as adviced by AWI and also 2 decimals hence
                                        send(msgbatt.set(batteryPcnt ,2));
                                        • R Offline
                                          R Offline
                                          Rene046
                                          thx i got a voltage log only giving me now -44.000 volt and 212 prct at battery level while measuring 3.7 volt battery and voltage on A0 1.3 volts
                                          DHT dht;
                                          float lastTemp;
                                          float lastHum;
                                          #define VBAT_PER_BITS 0.0041055718475073313782991202346  // 4.20/1023 volt
                                          #define VMIN 3.6                                  //  Vmin = 3.6 lipo empty
                                          #define VMAX 4.2                                  //  Vmax = 4.2 volt lipo full
                                              if (!metric) {
                                                lastHum = humidity;
                                            batM();
                                             delay(500);
                                             delay(500);
                                             if (batLoop > 2) {
                                               batteryPcnt=100;
                                                 batLoop = 0;
                                               batLoop++;
                                          R A Arnold ŠlepetisA 3 Replies Last reply
                                          12.0k
