  3. Reporting Battery Level
23 Posts 6 Posters 12.8k Views 8 Watching
  • Fat FlyF
    Fat FlyF
    Fat Fly
    How to add to sketch this feature? I use Domoticz controller and serial gateway. Nodes is Arduino mini pro 3,3V with batteries. Today i use door open/close sensor, elecricity meter, moisture sensor.
    AWIA 1 Reply Last reply
    • bjacobseB
      bjacobseB
      bjacobse
      wrote on last edited by bjacobse
      I don't have my sketch available, but I used this code below for measuring 2xAA. I have changed #define MIN_V 1900 (milliVolt) since I have disabled BOD, so Arduino runs to 1,8V, bur NRF24L01+ is working down t0 1,9V
      NOTE: This is only showing battery measuring, it's not a full sketch...
        #define MIN_V 2700
        #define MAX_V 3200
        int batteryPcnt = min(map(readVcc(), MIN_V, MAX_V, 0, 100), 100); // Convert voltage to percentage
        gw.sendBatteryLevel(batteryPcnt); // Send battery percentage to gateway
        long readVcc() {
          #if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
            ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
          #elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
            ADMUX = _BV(MUX5) | _BV(MUX0);
          #elif defined (__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__)
            ADMUX = _BV(MUX3) | _BV(MUX2);
          #else
          long result = (high<<8) | low;
      • Fat FlyF
        Fat FlyF
        Fat Fly
        Okay. I understand but how to add this piece from software to each sketch? Each what arduino powerted from batteryes.
        • Fat FlyF Fat Fly
          AWIA
          AWIA
          AWI
          @Fat-Fly Easiest way is to use the Vcc library by @Yveaux
          • Fat FlyF
            Fat FlyF
            Fat Fly
            This is better. I need cut off Arduino voltage regulator and power led ?
            • Fat FlyF Fat Fly
              AWIA
              AWIA
              AWI
              @Fat-Fly To save power you can... but not needed for the Vcc library to work if you power your pro-mini from the vcc pin ;-)
              • Fat FlyF
                Fat FlyF
                Fat Fly
                Ok. I try to write sketch.
                • Fat FlyF
                  Fat FlyF
                  Fat Fly
                  wrote on last edited by AWI
                   * Simple binary switch example
                   * Connect button or door/window reed switch between
                   * digitial I/O pin 3 (BUTTON_PIN below) and GND.
                   * http://www.mysensors.org/build/binary
                  #include <Bounce2.h>
                  #include <Vcc.h>
                  #define CHILD_ID 3
                  #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
                  Bounce debouncer = Bounce();
                  int oldValue=-1;
                  //battery voltage
                  const float VccExpected   = 3.0;
                  const float VccCorrection = 2.860/2.92;  // Measured Vcc by multimeter divided by reported Vcc
                  Vcc vcc(VccCorrection);
                  static int oldBatteryPcnt = 0;
                    gw.begin();
                   // Setup the button
                    pinMode(BUTTON_PIN,INPUT);
                    // Activate internal pull-up
                    debouncer.attach(BUTTON_PIN);
                    debouncer.interval(5);
                    gw.present(CHILD_ID, S_DOOR);
                    debouncer.update();
                    // Get the update value
                    int value = debouncer.read();
                    if (value != oldValue) {
                       // Send in the new value
                       gw.send(msg.set(value==HIGH ? 1 : 0));
                       oldValue = value;
                      int batteryPcnt = (int)vcc.Read_Perc(VccExpected);
                      if (oldBatteryPcnt != batteryPcnt)
                          oldBatteryPcnt = batteryPcnt;
                  • Fat FlyF
                    Fat FlyF
                    Fat Fly
                    Verification successful says codebender. I do not know working this or not. I can't try. Only in home after working day.
                    • Fat FlyF
                      Fat FlyF
                      Fat Fly
                      https://codebender.cc/sketch:337094 This is modified electricity meter sketch with battery level .
                      NuubiN 1 Reply Last reply
                      • Fat FlyF Fat Fly
                        NuubiN
                        NuubiN
                        Nuubi
                        @Fat-Fly Nice, interested to try this also.
                        Any idea how long the batteries will last? Electricity meters tend to blink quite often, so not that much sleep..
                        • Fat FlyF
                          Fat FlyF
                          Fat Fly
                          wrote on last edited by Fat Fly
                          At the moment i try this with 2xAA recargeable batteryes but no luck. Gnd and vcc pin. Not working , not reported. if i find batterys.... I search. All remotes is AAA :( 2.68volts from recargeable AA's. where is the fish ?
                          • Fat FlyF
                            Fat FlyF
                            Fat Fly
                            From recargeable 2x AA and 2,68V not working.
                            • Fat FlyF
                              Fat FlyF
                              Fat Fly
                              I bought 2AA batteries. Working.Domoticz devices page report battery level 3. How to see battery level graph ?
                              • Fat FlyF Fat Fly
                                AWIA
                                AWIA
                                AWI
                                @Fat-Fly to report battery voltage you have to create a S_MULTIMETER sensor and send the voltage with V_VOLTAGE.
                                Sendbatterylevel only changes the battery level in Domoticz in % and can not be shown separate.
                                Tot use your arduino with low voltages you need to change the fuse settings (BOD) with an ISP programmer.
                                • Fat FlyF
                                  Fat FlyF
                                  Fat Fly
                                  How to i do this ?
                                  • Fat FlyF Fat Fly
                                    How to i do this ?
                                    AWIA
                                    AWIA
                                    AWI
                                    @Fat-Fly I will post some code later when I get to a pc. :eyes:
                                    Fat FlyF 1 Reply Last reply
                                    • AWIA AWI
                                      Fat FlyF
                                      Fat FlyF
                                      Fat Fly
                                      This is great. I do not find from google search. My mother tongue is Estonian :)
                                      • Fat FlyF Fat Fly
                                        AWIA
                                        AWIA
                                        AWI
                                        @Fat-Fly "Estonia: Between East, West and the World" ;-)
                                        These are the lines of code which should do the trick... you need to put them in the right spot yourself
                                        #define VOLTAGE_CHILD_ID 		5
                                        MyMessage voltageMsg(VOLTAGE_CHILD_ID, V_VOLTAGE);	// Node voltage
                                        gw.present(VOLTAGE_CHILD_ID, S_MULTIMETER, "Battery " );
                                        float voltage = vcc.Read_Volts() ;
                                        gw.send(voltageMsg.set(voltage,2));				//send battery in Volt
                                        • Fat FlyF
                                          Fat FlyF
                                          Fat Fly
                                          Estonia between world and russia. :)
