  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 256.7k Views 53 Watching
  • M MLs
    @Disca
    Where did you find the drivers for sensebender GW for Windows 7?
    //Mattias
    tbowmoT
    tbowmoT
    tbowmo
    @MLs
    Check the product page on mysensors.org
    https://www.mysensors.org/hardware/sensebender-gateway
    • tbowmoT
      tbowmoT
      tbowmo
      @Fabien
      D5 is used by arduino to signal USB serial rx/TX activity.
      Can you post the log lines from dmesg, from when you insert the usb cable, to after you have pressed the reset button?
      • tbowmoT tbowmo
        @MLs
        MLs
        @tbowmo
        I tried to update the drivers in Device Manager / sense bender GW but it failed to install the computer said.
        Therefore, I asked one who wrote that he was using Windows 7
        //Mattias
          #161
          @MLs
          I'm also still using win7 x64 for my dev and that worked for me.
          Auto install through the Device Manager does not work, nor right-clicking and installing the .inf through Explorer.
          You have to force the install and select the location of the .inf in Device Manager. Then it will ask you if you agree about the driver supplier. Of course you're! And you should be able to see it in Device Manager.
          • D
            Dany
            There are example program for W5100? The original GatewayW5100 program uses SOFTSPI, different NRF CE/CSN pins? Will work with this hardware properly?
            tbowmoT 1 Reply Last reply
            • scalzS scalz
              @MLs
              MLs
              @scalz
              Heh've tried both in the device manager and manually. Device Manager, I get an error message.
              And manually, nothing happens.
              //Mattias
                #164
                @MLs
                yep that's what i explained.
                you need to force it in Device Manager. How you're doing in Device manager actually is rather auto, imho ;)
                You can try in Device manager to right click on the bad detected device, here Sensebender Gw, and in properties, update driver. At a moment, it should prompt an "Open file" Dialog box (you need to choose the right option in the dialog) and then select your .inf file. And it will ask if you're ok to install a driver from a third party.
                • D Dany
                  tbowmoT
                  tbowmoT
                  tbowmo
                  @Dany
                  The standard GatewayW5100 example sketch will work on the sensebender gateway. There are conditional compile statements in that sketch, that disables softspi when compiling to the gateway target, and use a hardware SPI instead.
                  Remember to choose the correct target in your Arduino IDE
                    #166
                    @MLs
                    Okay, simpler, forget what i told you, and follow my steps below. I've unstalled mine to show you ;)
                    Then if it can be useful for others. Nothing fancy here, it can be used for lot of others drivers.
                    Step 1: plugin the GW, as you can see it's not detected, and no additional com port.
                    Step 2: right clic, and update driver
                    Step 3: click on the 2nd option for searching a driver on your machine
                    Step 4: Again 2nd option here (you want to search for a driver on your computer)
                    Step 5: This is a Virtual Serial Com port needed for the GW. So choose COM/LPT for the driver type
                    Step 6: Now it is asking where the driver (.inf) is stored
                    Step 7: You can now see that Windows knows what this is about. And tells you this driver is not "signed". No problem we know @tbowmo has done a great job. So, Next!
                    Step 8: Windows here warns again, saying he doesn't know this driver, so it may not work well. No way, it will work well ;) Click "Yes" to install it.
                    Step 9: Looks good
                    Step 10: Tada! Here you can see now the GW is well detected and setup on COM port 24
                    I can't do better!
                    I think you'll get it :)
                    • scalzS scalz
                      @MLs
                      Step 9: Looks good
                      I can't do better!
                      MLs
                      wrote on last edited by MLs
                      #167
                      @scalz
                      Thanks for a super instruction but it is the file itself that the computer says from. It says that the folder contains the no driver
                      And the driver in the folder I chose I downloaded here
                      https://github.com/mysensors/ArduinoHwSAMD/blob/master/driver/mysensors-samd.inf
                      // Mattias
                      • M MLs
                        @scalz
                        // Mattias
                        MLs
                        @MLs
                        When I downloaded the drivers so I make the following step.
                        Right-click at the file and save target as.
                        //Mattias
                          On the raw file?
                          https://raw.githubusercontent.com/mysensors/ArduinoHwSAMD/master/driver/mysensors-samd.inf
                            On the raw file?
                            MLs
                            @hek
                            https://github.com/mysensors/ArduinoHwSAMD/tree/master/driver
                            I click on the link below the folder drivers
                            //Mattias
                              No, that will download a github html page.
                              Use the link I posted (and save as). It will be the raw content.
                              M 2 Replies Last reply
                                MLs
                                @hek
                                I'll try it tomorrow is not so strange that it did not work for me then.
                                //Mattias
                                  MLs
                                  @hek
                                  Now, I also got the computer to recognize the card. Thanks for all help.
                                  The problem was that even when I used save as, the computer renaming the file as a .txt file "mysensors-samd.inf.txt" and not a "mysensors-samd.inf"
                                  Again, thanks for all the help.
                                  //Mattias
                                    meddie
                                    Hi together,
                                    i have some questions to you! I bought a sensebender gateway and a w5100 Ethernet Modul, but i cant get it to work. When i upload the Gateway5100 Sketch and put my yip address in it, then the GW is booting up i get some Data on the serial port but i cant ping the configured ip address. Then i tried to config via DHCP and see that the GW dont get an IP Address.
                                    And when i connect the NRF24 Modul then it seems that the GW is not bootin up anymore because i dont get any data on serial port.
                                    i need your help. Thanks a lot in advance
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @meddie
                                      Could you please post the logs that you get on the serial port, when the W5100 is attached?
                                      Do you get anything on the serial port if you configure the sensebender to be a serial gateway, and only add a NRF24 module to it?
                                        meddie
                                        Hi tbowmo,
                                        with the gatewayw5100 Sketch i get every 10 seconds 5 lines output on serial monitor:
                                        The sketch is default i changed only the ip adress
                                        0;255;3;0;9;TSM:FAIL:RE-INIT
                                        0;255;3;0;9;TSM:INIT
                                        0;255;3;0;9;TSM:FAIL:CNT=3
                                        0;255;3;0;9;TSM:FAIL:PDT
                                        0;255;3;0;9;TSM:FAIL:CNT=4
                                        0;255;3;0;9;TSM:FAIL:CNT=5
                                        0;255;3;0;9;
                                        i dont know why, but i just uploaded the sensebenderserialgateway sketch and now i get this output:
                                        0;255;3;0;9;TSF:LRT:OK
                                        0;255;3;0;9;TSF:WUR:MS=0
                                        0;255;3;0;9;TSM:INIT:TSP OK
                                        0;255;3;0;9;TSM:INIT:GW MODE
                                        0;255;0;0;18;2.1.1
                                        0;255;3;0;9;MCO:BGN:STP
                                        0;255;3;0;9;
                                        the NRF Module is connected! Now i need to get the w5100 module to work.
                                          meddie
                                          wrote on last edited by meddie
                                          #177
                                          Ok i just connected the W5100 and NRF24 Module and uploaded the GatewayW5100 Sketch and when the upload is done after reset i dont get any output on serial monitor.
                                          The orange, green and red led are lighting.
                                          When i upload the SensebenderGatewaySerial then i get output on serial monitor. It think the problem must be the w5100. But what going wrong?
                                          alexsh1A 1 Reply Last reply
