  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 257.0k Views 53 Watching
  • D Dany
    There are example program for W5100? The original GatewayW5100 program uses SOFTSPI, different NRF CE/CSN pins? Will work with this hardware properly?
    tbowmoT
    tbowmoT
    tbowmo
    @Dany
    The standard GatewayW5100 example sketch will work on the sensebender gateway. There are conditional compile statements in that sketch, that disables softspi when compiling to the gateway target, and use a hardware SPI instead.
    Remember to choose the correct target in your Arduino IDE
      #166
      @MLs
      Okay, simpler, forget what i told you, and follow my steps below. I've unstalled mine to show you ;)
      Then if it can be useful for others. Nothing fancy here, it can be used for lot of others drivers.
      Step 1: plugin the GW, as you can see it's not detected, and no additional com port.
      Step 2: right clic, and update driver
      Step 3: click on the 2nd option for searching a driver on your machine
      Step 4: Again 2nd option here (you want to search for a driver on your computer)
      Step 5: This is a Virtual Serial Com port needed for the GW. So choose COM/LPT for the driver type
      Step 6: Now it is asking where the driver (.inf) is stored
      Step 7: You can now see that Windows knows what this is about. And tells you this driver is not "signed". No problem we know @tbowmo has done a great job. So, Next!
      Step 8: Windows here warns again, saying he doesn't know this driver, so it may not work well. No way, it will work well ;) Click "Yes" to install it.
      Step 9: Looks good
      Step 10: Tada! Here you can see now the GW is well detected and setup on COM port 24
      I can't do better!
      I think you'll get it :)
      • scalzS scalz
        @MLs
        Step 9: Looks good
        I can't do better!
        MLs
        wrote on last edited by MLs
        #167
        @scalz
        Thanks for a super instruction but it is the file itself that the computer says from. It says that the folder contains the no driver
        And the driver in the folder I chose I downloaded here
        https://github.com/mysensors/ArduinoHwSAMD/blob/master/driver/mysensors-samd.inf
        // Mattias
        • M MLs
          @scalz
          // Mattias
          MLs
          @MLs
          When I downloaded the drivers so I make the following step.
          Right-click at the file and save target as.
          //Mattias
            On the raw file?
            https://raw.githubusercontent.com/mysensors/ArduinoHwSAMD/master/driver/mysensors-samd.inf
              On the raw file?
              MLs
              @hek
              https://github.com/mysensors/ArduinoHwSAMD/tree/master/driver
              I click on the link below the folder drivers
              //Mattias
                No, that will download a github html page.
                Use the link I posted (and save as). It will be the raw content.
                M 2 Replies Last reply
                  MLs
                  @hek
                  I'll try it tomorrow is not so strange that it did not work for me then.
                  //Mattias
                    MLs
                    @hek
                    Now, I also got the computer to recognize the card. Thanks for all help.
                    The problem was that even when I used save as, the computer renaming the file as a .txt file "mysensors-samd.inf.txt" and not a "mysensors-samd.inf"
                    Again, thanks for all the help.
                    //Mattias
                      meddie
                      Hi together,
                      i have some questions to you! I bought a sensebender gateway and a w5100 Ethernet Modul, but i cant get it to work. When i upload the Gateway5100 Sketch and put my yip address in it, then the GW is booting up i get some Data on the serial port but i cant ping the configured ip address. Then i tried to config via DHCP and see that the GW dont get an IP Address.
                      And when i connect the NRF24 Modul then it seems that the GW is not bootin up anymore because i dont get any data on serial port.
                      i need your help. Thanks a lot in advance
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @meddie
                        Could you please post the logs that you get on the serial port, when the W5100 is attached?
                        Do you get anything on the serial port if you configure the sensebender to be a serial gateway, and only add a NRF24 module to it?
                          meddie
                          Hi tbowmo,
                          with the gatewayw5100 Sketch i get every 10 seconds 5 lines output on serial monitor:
                          The sketch is default i changed only the ip adress
                          0;255;3;0;9;TSM:FAIL:RE-INIT
                          0;255;3;0;9;TSM:INIT
                          0;255;3;0;9;TSM:FAIL:CNT=3
                          0;255;3;0;9;TSM:FAIL:PDT
                          0;255;3;0;9;TSM:FAIL:CNT=4
                          0;255;3;0;9;TSM:FAIL:CNT=5
                          0;255;3;0;9;
                          i dont know why, but i just uploaded the sensebenderserialgateway sketch and now i get this output:
                          0;255;3;0;9;TSF:LRT:OK
                          0;255;3;0;9;TSF:WUR:MS=0
                          0;255;3;0;9;TSM:INIT:TSP OK
                          0;255;3;0;9;TSM:INIT:GW MODE
                          0;255;0;0;18;2.1.1
                          0;255;3;0;9;MCO:BGN:STP
                          0;255;3;0;9;
                          the NRF Module is connected! Now i need to get the w5100 module to work.
                            meddie
                            wrote on last edited by meddie
                            #177
                            Ok i just connected the W5100 and NRF24 Module and uploaded the GatewayW5100 Sketch and when the upload is done after reset i dont get any output on serial monitor.
                            The orange, green and red led are lighting.
                            When i upload the SensebenderGatewaySerial then i get output on serial monitor. It think the problem must be the w5100. But what going wrong?
                            alexsh1A 1 Reply Last reply
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              @meddie
                              Is it the standard GatewayW5100 sketch, without modifications, from the mysensors examples?
                              If you have done any modifications to the sketch, then please post your modified sketch here.
                                meddie
                                i have only changed the ip adress
                                here is the sketch:
                                 * Version 1.0 - Henrik EKblad
                                 * LED purposes:
                                #define MY_GATEWAY_W5100
                                //#define MY_W5100_SPI_EN 4
                                // radio on the same spi bus.
                                #define MY_SOFTSPI
                                #ifndef MY_RF24_CE_PIN
                                #define MY_RF24_CE_PIN 5
                                #ifndef MY_RF24_CS_PIN
                                #define MY_RF24_CS_PIN 6
                                // Enable to UDP
                                //#define MY_USE_UDP
                                #define MY_IP_ADDRESS 10,0,0,253   // If this is disabled, DHCP is used to retrieve address
                                #define MY_PORT 5003
                                // Enable inclusion mode
                                // Set blinking period
                                // Flash leds on rx/tx/err
                                #if defined(MY_USE_UDP)
                                #include <EthernetUdp.h>
                                #include <Ethernet.h>
                                J 1 Reply Last reply
                                • M meddie
                                  here is the sketch:
                                   * LED purposes:
                                  #define MY_SOFTSPI
                                  // Enable to UDP
                                  J
                                  J
                                  jeti
                                  So I think i have a maybe already solved issue, but I can not get int working...
                                  In Arduino IDE 1.8.1 this is the error during compiling:
                                  "Local\Arduino15\packages\arduino\hardware\samd\1.6.12\cores\arduino/Arduino.h:48:17: fatal error: sam.h: No such file or directory"
                                  • I have the MySensors SAMD boards installed, so Sensbender Gateway is availabe
                                  • Arduino SAMD boards are also installed
                                  • I have installed the "M0" boards
                                  • Running windows 10 so no need for the inf file, is this correct?
                                  what am I missing?
                                  thanks in advance!
                                  tekkaT 1 Reply Last reply
                                  • J jeti
                                    what am I missing?
                                    thanks in advance!
                                    tekkaT
                                    tekkaT
                                    tekka
                                    wrote on last edited by tekka
                                    #181
                                    @jeti SAMD board defs 1.6.12 are currently not supported (PR filed) - you need to downgrade to 1.6.11 until the PR is merged.
                                    • tekkaT tekka
                                      J
                                      J
                                      jeti
                                      @tekka thanks! that did the trick!
                                      • J jeti
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @jeti MySensors SAMD board defs updated to 1.0.5, supporting SAMD board defs 1.6.12
                                        • TheoLT
                                          TheoLT
                                          TheoL
                                          It's has been a long time since I've posted on this forum.Today I received a note form the postal service that a package from a foreign country has arrived at my local postal office. Can't wait until tomorrow, just to see this beauty.
                                          Now I have to find some time to get it running ;-(
