  2. Announcements
    macvictor
    @marceloaqno Thank's for you help. I have other question.. general I try configure my gateway to work with security & signing, but they doesn't work. Where is problem? On the bottom i send point what it do it:
    Gateway:
    2. make
    3. sudo make install
    10. sudo mysgw --gen-aes-key
    Node:
    #define USE_SOFT_SIGNING
    #define STORE_SOFT_KEY
    #define USER_SOFT_KEY
    #define STORE_SOFT_SERIAL
    #define STORE_AES_KEY
    #define USER_AES_KEY
    EEPROM configuration:
    // Enable NRF24L01 radio type
    // Select soft signing
    #define MY_SIGNING_SOFT
    // Enable node whitelisting
    #define MY_REPEATER_FEATURE
    #define BUTTON_PIN  3   // Arduino Digital I/O pin number for button
    #define CHILD_ID 1      // Id of the sensor child
    #define RELAY_ON 1
    #define RELAY_OFF 0
    Bounce debouncer = Bounce();
    int oldValue = 0;
    bool state;
      // Setup the button
      pinMode(BUTTON_PIN, INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      pinMode(RELAY_PIN, OUTPUT);
      state = loadState(CHILD_ID);
      digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);
    void presentation()  {
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
    //  oldValue = value;
      delay(5000);
      if (message.isAck()) {
        // Change relay state
        state = message.getBool();
        // Store state in eeprom
    4 TSM:INIT
    5 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    13 TSF:SID:OK,ID=105
    15 TSM:FPAR
    2065 !TSM:FPAR:NO REPLY
    2067 TSM:FPAR
    4117 !TSM:FPAR:NO REPLY
    4119 TSM:FPAR
    6169 !TSM:FPAR:NO REPLY
    6171 TSM:FPAR
    8221 !TSM:FPAR:FAIL
    8222 TSM:FAIL:CNT=1
    8224 TSM:FAIL:PDT
    and in gateway i see:
    sudo mysgw -d
    mysgw: Starting gateway...
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    mysgw: connected to 127.0.0.1
    mysgw: MQTT connected
    mysgw: !TSF:MSG:PVER,3=2
    mysgw: !TSF:MSG:PVER,1=2
    mysgw: TSF:MSG:REL MSG
    mysgw: !TSF:RTE:240 UNKNOWN
    mysgw: !TSF:MSG:PVER,0=2
    mysgw: !TSF:RTE:233 UNKNOWN
    mysgw: !TSF:RTE:51 UNKNOWN
    Where is problem?
    M pepsonP rajeev2301R 5 Replies Last reply
    • M macvictor
      Gateway:
      2. make
      Node:
      #define RELAY_ON 1
      #define RELAY_OFF 0
      int oldValue = 0;
      bool state;
        // Setup the button
        debouncer.update();
        delay(5000);
      4 TSM:INIT
      5 TSF:WUR:MS=0
      11 TSM:INIT:TSP OK
      15 TSM:FPAR
      2067 TSM:FPAR
      4119 TSM:FPAR
      6171 TSM:FPAR
      8221 !TSM:FPAR:FAIL
      8222 TSM:FAIL:CNT=1
      8224 TSM:FAIL:PDT
      sudo mysgw -d
      mysgw: TSF:LRT:OK
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: MCO:BGN:STP
      Where is problem?
      marceloaqno
      Code Contributor
      @macvictor Did you also enable encryption on your node? (#define MY_RF24_ENABLE_ENCRYPTION)
        macvictor
        @marceloaqno Thanks for help :+1: This was my problem 😀
          how do I set user and password to access the mqtt broker? I tried do add --my-mqtt-password=PASS --my-mqtt-user=USER other parameters but they get ignored
            macvictor
            @gohan edit configure file and add this code:
            --my-mqtt-user=*)
                CPPFLAGS="-DMY_MQTT_USER=\\\"${optarg}\\\" $CPPFLAGS"
            --my-mqtt-password=*)
                CPPFLAGS="-DMY_MQTT_PASSWORD=\\\"${optarg}\\\" $CPPFLAGS"
            after this code:
            --my-signing-request-gw-signatures-from-all*)
                    signing_request_signatures=true
                    CPPFLAGS="-DMY_SIGNING_GW_REQUEST_SIGNATURES_FROM_ALL $CPPFLAGS"
            this is about 408 number line and use flag --my-mqtt-password and --my-mqtt-client-id when you run configure, thats all. =)
            blaceyB gohanG 2 Replies Last reply
            • M macvictor
              --my-mqtt-user=*)
              after this code:
              blaceyB
              blaceyB
              blacey
              wrote on last edited by blacey
              #355
              @macvictor It would be great if you would submit this as a GitHub Pull Request. If you aren't comfortable with that, then I would encourage you to at least open a MySensors issue to add these RPI configuration options.
              • TeknorT
                TeknorT
                Teknor
                wrote on last edited by Teknor
                #356
                When using RPI as a GW for MySensors, the CPU load increases from 18% to around 80 %. I am using a RPI II model B. I'd love the have the GW running on the Raspberry, and avoid a USB connected Arduino.
                Does somebody else experience the same?
                M carlylerC 2 Replies Last reply
                • TeknorT Teknor
                  macvictor
                  @Teknor I use RPI III as GW and all node connect with gw used nRF24L01. My CPU now usage 5-10%, but I installed "Home Assistance" + homebridge + some plugins.
                  TeknorT 1 Reply Last reply
                  • M macvictor
                    TeknorT
                    TeknorT
                    Teknor
                    #358
                    @macvictor Thanks. My RPI 2 is running Domoticz, RFXcom GW and 2x 3MP cameras with motion detection using Motioneye. Might be something wrong with my MySensors GW setup...
                    • TeknorT Teknor
                      carlylerC
                      carlylerC
                      carlyler
                      @Teknor I tend to agree something is wrong, but I think it really on depends how many nodes and how often you're sending data.
                      rpi3 + GPIO nrf24l01 + openhab2 + 8 nodes + packet received, on average 1 / 5s :
                      top - 06:29:37 up 2 days, 22:33,  2 users,  load average: 0.26, 0.24, 0.19
                      KiB Mem:    947732 total,   903420 used,    44312 free,   175364 buffers
                      KiB Swap:   102396 total,     4496 used,    97900 free.   391360 cached Mem
                        681 root      20   0  208840  56532  23684 S   8.9  6.0 214:23.60 Xorg
                        527 root      20   0   39448  21532  11264 S   4.3  2.3  69:34.28 vncserver-x11-c
                       1154 pi        20   0   50548  17628  12196 S   3.0  1.9  64:05.96 lxterminal
                      30426 openhab   20   0  441764 197592  14960 S   1.6 20.8 284:18.70 java
                       2467 root      20   0   20024   2456   2300 S   1.3  0.3  62:55.17 mysgw
                      25634 root      20   0       0      0      0 S   1.0  0.0   0:00.21 kworker/u8:0
                        688 root      20   0   13720   9432   8828 S   0.7  1.0   2:04.96 vncagent
                      25855 pi        20   0    5232   2584   2140 R   0.7  0.3   0:00.49 top
                          7 root      20   0       0      0      0 S   0.3  0.0   9:15.35 rcu_sched
                         78 root     -51   0       0      0      0 S   0.3  0.0   5:16.50 irq/92-mmc1
                        967 pi        20   0   95656  17716  12028 S   0.3  1.9   6:41.87 lxpanel
                          1 root      20   0   24620   4688   2716 S   0.0  0.5   0:13.08 systemd
                          2 root      20   0       0      0      0 S   0.0  0.0   0:00.27 kthreadd
                      • M macvictor
                        --my-mqtt-user=*)
                        after this code:
                        @macvictor
                        That worked, thanks. But to configure channel, power, AES key, and so on, do you think it is better to use command line like you posted above or customize myconfig.h?
                          @macvictor
                          marceloaqno
                          Code Contributor
                          @gohan You can also set mqtt username and password in examples_linux/mysgw.cpp
                          gohanG 1 Reply Last reply
                          • M marceloaqno
                            @marceloaqno
                            I'm trying to understand where is the best place to avoid file gets overwritten in case of upgrades
                              @marceloaqno
                              marceloaqno
                              Code Contributor
                              @gohan There is a open github pull request very similar to what @macvictor proposed, but for now I recommend using the examples_linux/mysgw.cpp file.
                              • M marceloaqno
                                @marceloaqno
                                Ok I can you that file, but where is the best place to set Power Level and channel ?
                                  @marceloaqno
                                  marceloaqno
                                  Code Contributor
                                  @gohan There isn't exactly the best place to set things, it really depends on your preferences.
                                    I just copied the myconfig file from the arduino and set the rest from the command line and from debug it looks like it's working, the problem is now to get domoticz talk to the mqtt.
                                      After updating domoticz to beta version I finally have the MQTT working with controller and I can see the sensor node seding in data: my question now is how to I debug the gateway if it is running as a service on the RPI without messing things up?
                                      • M marceloaqno
                                        @hawk_2050 same for you guys who helped, thank you for all the feedback.
                                        @jerseyguy1996 I don't see anything wrong with your config.Try to add a small delay() after the first send() and before the sendBattery().
                                        @annegerben This looks like a wire problem. I updated the guide, check the wire section again.
                                        marlin
                                        @marceloaqno I am trying to get a Pi 3 working with MySensors 2.1.1 and nrf24l01 and using your updated wire guide, but all I get as output is the following:
                                        mysgw: TSF:LRT:OK
                                        mysgw: TSM:INIT
                                        mysgw: TSF:WUR:MS=0
                                        mysgw: !TSM:INIT:TSP FAIL
                                        mysgw: TSM:FAIL:CNT=1
                                        mysgw: TSM:FAIL:PDT
                                        [The output repeats itself, increasing the CNT every time, while at the same time one of the cores on the Pi 3 is running at full CPU utilization.]
                                        By reading earlier comments I assume this is a wiring problem. One possible cause is inconsistency between
                                        0_1488723559852_upload-e3165792-1f42-4663-8e68-efd96bd275f8
                                        and
                                        0_1488723638471_upload-d7048ef8-8a33-4214-9935-0356cf9291c2
                                        where the first picture indicates that pin 24 and pin 26 should be used, while the second indicates pins 22 and 24 should be used. However, I have tried both options but I still get the same output (I used different nrf24's for the different setups, in case the nrf24 got burned from the first setup).
                                        I have VCC from nrf24 connected to pin 17 on the Pi 3 and GND connect to pin 25.
                                        Any suggestions on what to try next?
                                        [The Pi 3 is running Raspbian with Pixel. For information, I already have a running Arduino with MySensors MQTT GW and a simple node with MySensors and DHT22. From this I know that by nrf24 chips works when being fed with 3.3V.]
                                        G keldandorinK 2 Replies Last reply
                                          I have connected my nrf24 like the secon table you posted and it is working but I am using an "adapter" for nrf24 with a socket and has voltage regulator + capacitors, so if you don't have any cap on the radio module, I'd suggest you put one on (try from a 4.7 uF up to 47 and see if anything changes)
