  2. Announcements
  • Erik TammingaE Erik Tamminga
    Can I use pin 18 (GPIO 24) on my RPi3 for IRQ usage? Should I?
    If I compile with --my-rf24-irq-pin=18, no date is received when the gateway starts.
    I Cannot use pin 15 because that pin is covered by my Z-wave.me board.
    Regards,
    Erik
    marceloaqno
    Code Contributor
    @Erik-Tamminga Some pins may have some restrictions, I couldn't find any good info about that. Try using another pin (GPIO 25).
    • M marceloaqno
      @OliverDog Which controller are you using(or are planning to use)?
      OliverDogO
      OliverDogO
      OliverDog
      @marceloaqno I already use Home Assistant with a Serial Gateway connected on pi USB.
      • OliverDogO OliverDog
        marceloaqno
        Code Contributor
        @OliverDog Home Assistant supports ethernet gateways, I recommend you go with that.
        ./configure --my-gateway=ethernet --my-transport=nrf24
        (The default settings is to use ethernet and nrf24, so you could omit them)
        and add to it any of your custom options.
        • MadhiasM
          MadhiasM
          Madhias
          wrote on last edited by Madhias
          #347
          I have a question regarding the --my-serial-groupname option: since I start the gateway under an user account with sudo, the gateway device ([EDIT] symlink) will be created with ownership root:root. Shouldn't it be created with root:dialout (as I chose dialout as group in my case)?
          [DELETED]
          • MadhiasM Madhias
            [DELETED]
            marceloaqno
            Code Contributor
            @Madhias /dev/pts/2 it's the one who holds the specified group ownership
            MadhiasM 1 Reply Last reply
            • M marceloaqno
              MadhiasM
              MadhiasM
              Madhias
              @marceloaqno OK, many thanks for that hint!
              I was wrong from the beginning on, since I thought my configuration for the gateway was correct because of --my-serial-groupname=dialout - but that was not compiled. I edited now the mysgw.cpp manually (there was tty instead of dialout; and of course there was all the time the warning when compiling...). Now it works! Without chmod, or chowning anything later!
                macvictor
                @marceloaqno Thank's for you help. I have other question.. general I try configure my gateway to work with security & signing, but they doesn't work. Where is problem? On the bottom i send point what it do it:
                Gateway:
                2. make
                3. sudo make install
                10. sudo mysgw --gen-aes-key
                Node:
                #define USE_SOFT_SIGNING
                #define STORE_SOFT_KEY
                #define USER_SOFT_KEY
                #define STORE_SOFT_SERIAL
                #define STORE_AES_KEY
                #define USER_AES_KEY
                EEPROM configuration:
                // Enable NRF24L01 radio type
                // Select soft signing
                #define MY_SIGNING_SOFT
                // Enable node whitelisting
                #define MY_REPEATER_FEATURE
                #define BUTTON_PIN  3   // Arduino Digital I/O pin number for button
                #define CHILD_ID 1      // Id of the sensor child
                #define RELAY_ON 1
                #define RELAY_OFF 0
                Bounce debouncer = Bounce();
                int oldValue = 0;
                bool state;
                  // Setup the button
                  pinMode(BUTTON_PIN, INPUT);
                  // Activate internal pull-up
                  debouncer.attach(BUTTON_PIN);
                  debouncer.interval(5);
                  pinMode(RELAY_PIN, OUTPUT);
                  state = loadState(CHILD_ID);
                  digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);
                void presentation()  {
                  debouncer.update();
                  // Get the update value
                  int value = debouncer.read();
                //  oldValue = value;
                  delay(5000);
                  if (message.isAck()) {
                    // Change relay state
                    state = message.getBool();
                    // Store state in eeprom
                4 TSM:INIT
                5 TSF:WUR:MS=0
                11 TSM:INIT:TSP OK
                13 TSF:SID:OK,ID=105
                15 TSM:FPAR
                2065 !TSM:FPAR:NO REPLY
                2067 TSM:FPAR
                4117 !TSM:FPAR:NO REPLY
                4119 TSM:FPAR
                6169 !TSM:FPAR:NO REPLY
                6171 TSM:FPAR
                8221 !TSM:FPAR:FAIL
                8222 TSM:FAIL:CNT=1
                8224 TSM:FAIL:PDT
                and in gateway i see:
                sudo mysgw -d
                mysgw: Starting gateway...
                mysgw: TSF:LRT:OK
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: TSM:INIT:TSP OK
                mysgw: TSM:INIT:GW MODE
                mysgw: MCO:REG:NOT NEEDED
                mysgw: MCO:BGN:STP
                mysgw: MCO:BGN:INIT OK,TSP=1
                mysgw: connected to 127.0.0.1
                mysgw: MQTT connected
                mysgw: !TSF:MSG:PVER,3=2
                mysgw: !TSF:MSG:PVER,1=2
                mysgw: TSF:MSG:REL MSG
                mysgw: !TSF:RTE:240 UNKNOWN
                mysgw: !TSF:MSG:PVER,0=2
                mysgw: !TSF:RTE:233 UNKNOWN
                mysgw: !TSF:RTE:51 UNKNOWN
                Where is problem?
                M pepsonP rajeev2301R 5 Replies Last reply
                • M macvictor
                  Gateway:
                  2. make
                  Node:
                  #define RELAY_ON 1
                  #define RELAY_OFF 0
                  int oldValue = 0;
                  bool state;
                    // Setup the button
                    debouncer.update();
                    delay(5000);
                  4 TSM:INIT
                  5 TSF:WUR:MS=0
                  11 TSM:INIT:TSP OK
                  15 TSM:FPAR
                  2067 TSM:FPAR
                  4119 TSM:FPAR
                  6171 TSM:FPAR
                  8221 !TSM:FPAR:FAIL
                  8222 TSM:FAIL:CNT=1
                  8224 TSM:FAIL:PDT
                  sudo mysgw -d
                  mysgw: TSF:LRT:OK
                  mysgw: TSM:INIT
                  mysgw: TSF:WUR:MS=0
                  mysgw: MCO:BGN:STP
                  Where is problem?
                  marceloaqno
                  Code Contributor
                  @macvictor Did you also enable encryption on your node? (#define MY_RF24_ENABLE_ENCRYPTION)
                    macvictor
                    @marceloaqno Thanks for help :+1: This was my problem 😀
                      how do I set user and password to access the mqtt broker? I tried do add --my-mqtt-password=PASS --my-mqtt-user=USER other parameters but they get ignored
                        macvictor
                        @gohan edit configure file and add this code:
                        --my-mqtt-user=*)
                            CPPFLAGS="-DMY_MQTT_USER=\\\"${optarg}\\\" $CPPFLAGS"
                        --my-mqtt-password=*)
                            CPPFLAGS="-DMY_MQTT_PASSWORD=\\\"${optarg}\\\" $CPPFLAGS"
                        after this code:
                        --my-signing-request-gw-signatures-from-all*)
                                signing_request_signatures=true
                                CPPFLAGS="-DMY_SIGNING_GW_REQUEST_SIGNATURES_FROM_ALL $CPPFLAGS"
                        this is about 408 number line and use flag --my-mqtt-password and --my-mqtt-client-id when you run configure, thats all. =)
                        blaceyB gohanG 2 Replies Last reply
                        • M macvictor
                          --my-mqtt-user=*)
                          after this code:
                          blaceyB
                          blaceyB
                          blacey
                          wrote on last edited by blacey
                          #355
                          @macvictor It would be great if you would submit this as a GitHub Pull Request. If you aren't comfortable with that, then I would encourage you to at least open a MySensors issue to add these RPI configuration options.
                          • TeknorT
                            TeknorT
                            Teknor
                            wrote on last edited by Teknor
                            #356
                            When using RPI as a GW for MySensors, the CPU load increases from 18% to around 80 %. I am using a RPI II model B. I'd love the have the GW running on the Raspberry, and avoid a USB connected Arduino.
                            Does somebody else experience the same?
                            M carlylerC 2 Replies Last reply
                            • TeknorT Teknor
                              macvictor
                              @Teknor I use RPI III as GW and all node connect with gw used nRF24L01. My CPU now usage 5-10%, but I installed "Home Assistance" + homebridge + some plugins.
                              TeknorT 1 Reply Last reply
                              • M macvictor
                                TeknorT
                                TeknorT
                                Teknor
                                #358
                                @macvictor Thanks. My RPI 2 is running Domoticz, RFXcom GW and 2x 3MP cameras with motion detection using Motioneye. Might be something wrong with my MySensors GW setup...
                                • TeknorT Teknor
                                  carlylerC
                                  carlylerC
                                  carlyler
                                  @Teknor I tend to agree something is wrong, but I think it really on depends how many nodes and how often you're sending data.
                                  rpi3 + GPIO nrf24l01 + openhab2 + 8 nodes + packet received, on average 1 / 5s :
                                  top - 06:29:37 up 2 days, 22:33,  2 users,  load average: 0.26, 0.24, 0.19
                                  KiB Mem:    947732 total,   903420 used,    44312 free,   175364 buffers
                                  KiB Swap:   102396 total,     4496 used,    97900 free.   391360 cached Mem
                                    681 root      20   0  208840  56532  23684 S   8.9  6.0 214:23.60 Xorg
                                    527 root      20   0   39448  21532  11264 S   4.3  2.3  69:34.28 vncserver-x11-c
                                   1154 pi        20   0   50548  17628  12196 S   3.0  1.9  64:05.96 lxterminal
                                  30426 openhab   20   0  441764 197592  14960 S   1.6 20.8 284:18.70 java
                                   2467 root      20   0   20024   2456   2300 S   1.3  0.3  62:55.17 mysgw
                                  25634 root      20   0       0      0      0 S   1.0  0.0   0:00.21 kworker/u8:0
                                    688 root      20   0   13720   9432   8828 S   0.7  1.0   2:04.96 vncagent
                                  25855 pi        20   0    5232   2584   2140 R   0.7  0.3   0:00.49 top
                                      7 root      20   0       0      0      0 S   0.3  0.0   9:15.35 rcu_sched
                                     78 root     -51   0       0      0      0 S   0.3  0.0   5:16.50 irq/92-mmc1
                                    967 pi        20   0   95656  17716  12028 S   0.3  1.9   6:41.87 lxpanel
                                      1 root      20   0   24620   4688   2716 S   0.0  0.5   0:13.08 systemd
                                      2 root      20   0       0      0      0 S   0.0  0.0   0:00.27 kthreadd
                                  • M macvictor
                                    --my-mqtt-user=*)
                                    after this code:
                                    @macvictor
                                    That worked, thanks. But to configure channel, power, AES key, and so on, do you think it is better to use command line like you posted above or customize myconfig.h?
                                      @macvictor
                                      marceloaqno
                                      Code Contributor
                                      @gohan You can also set mqtt username and password in examples_linux/mysgw.cpp
                                      gohanG 1 Reply Last reply
                                      • M marceloaqno
                                        @marceloaqno
                                        I'm trying to understand where is the best place to avoid file gets overwritten in case of upgrades
                                          @marceloaqno
                                          marceloaqno
                                          Code Contributor
                                          @gohan There is a open github pull request very similar to what @macvictor proposed, but for now I recommend using the examples_linux/mysgw.cpp file.
