  2. Announcements
    how do I set user and password to access the mqtt broker? I tried do add --my-mqtt-password=PASS --my-mqtt-user=USER other parameters but they get ignored
    macvictor
    @gohan edit configure file and add this code:
    --my-mqtt-user=*)
        CPPFLAGS="-DMY_MQTT_USER=\\\"${optarg}\\\" $CPPFLAGS"
    --my-mqtt-password=*)
        CPPFLAGS="-DMY_MQTT_PASSWORD=\\\"${optarg}\\\" $CPPFLAGS"
    after this code:
    --my-signing-request-gw-signatures-from-all*)
            signing_request_signatures=true
            CPPFLAGS="-DMY_SIGNING_GW_REQUEST_SIGNATURES_FROM_ALL $CPPFLAGS"
    this is about 408 number line and use flag --my-mqtt-password and --my-mqtt-client-id when you run configure, thats all. =)
    blaceyB gohanG 2 Replies Last reply
    • M macvictor
      --my-mqtt-user=*)
      after this code:
      blaceyB
      blaceyB
      blacey
      wrote on last edited by blacey
      #355
      @macvictor It would be great if you would submit this as a GitHub Pull Request. If you aren't comfortable with that, then I would encourage you to at least open a MySensors issue to add these RPI configuration options.
      • TeknorT
        TeknorT
        Teknor
        wrote on last edited by Teknor
        #356
        When using RPI as a GW for MySensors, the CPU load increases from 18% to around 80 %. I am using a RPI II model B. I'd love the have the GW running on the Raspberry, and avoid a USB connected Arduino.
        Does somebody else experience the same?
        M carlylerC 2 Replies Last reply
        • TeknorT Teknor
          macvictor
          @Teknor I use RPI III as GW and all node connect with gw used nRF24L01. My CPU now usage 5-10%, but I installed "Home Assistance" + homebridge + some plugins.
          TeknorT 1 Reply Last reply
          • M macvictor
            TeknorT
            TeknorT
            Teknor
            #358
            @macvictor Thanks. My RPI 2 is running Domoticz, RFXcom GW and 2x 3MP cameras with motion detection using Motioneye. Might be something wrong with my MySensors GW setup...
            • TeknorT Teknor
              carlylerC
              carlylerC
              carlyler
              @Teknor I tend to agree something is wrong, but I think it really on depends how many nodes and how often you're sending data.
              rpi3 + GPIO nrf24l01 + openhab2 + 8 nodes + packet received, on average 1 / 5s :
              top - 06:29:37 up 2 days, 22:33,  2 users,  load average: 0.26, 0.24, 0.19
              KiB Mem:    947732 total,   903420 used,    44312 free,   175364 buffers
              KiB Swap:   102396 total,     4496 used,    97900 free.   391360 cached Mem
                681 root      20   0  208840  56532  23684 S   8.9  6.0 214:23.60 Xorg
                527 root      20   0   39448  21532  11264 S   4.3  2.3  69:34.28 vncserver-x11-c
               1154 pi        20   0   50548  17628  12196 S   3.0  1.9  64:05.96 lxterminal
              30426 openhab   20   0  441764 197592  14960 S   1.6 20.8 284:18.70 java
               2467 root      20   0   20024   2456   2300 S   1.3  0.3  62:55.17 mysgw
              25634 root      20   0       0      0      0 S   1.0  0.0   0:00.21 kworker/u8:0
                688 root      20   0   13720   9432   8828 S   0.7  1.0   2:04.96 vncagent
              25855 pi        20   0    5232   2584   2140 R   0.7  0.3   0:00.49 top
                  7 root      20   0       0      0      0 S   0.3  0.0   9:15.35 rcu_sched
                 78 root     -51   0       0      0      0 S   0.3  0.0   5:16.50 irq/92-mmc1
                967 pi        20   0   95656  17716  12028 S   0.3  1.9   6:41.87 lxpanel
                  1 root      20   0   24620   4688   2716 S   0.0  0.5   0:13.08 systemd
                  2 root      20   0       0      0      0 S   0.0  0.0   0:00.27 kthreadd
              • M macvictor
                --my-mqtt-user=*)
                after this code:
                @macvictor
                That worked, thanks. But to configure channel, power, AES key, and so on, do you think it is better to use command line like you posted above or customize myconfig.h?
                  @macvictor
                  marceloaqno
                  Code Contributor
                  @gohan You can also set mqtt username and password in examples_linux/mysgw.cpp
                  gohanG 1 Reply Last reply
                  • M marceloaqno
                    @marceloaqno
                    I'm trying to understand where is the best place to avoid file gets overwritten in case of upgrades
                      @marceloaqno
                      marceloaqno
                      Code Contributor
                      @gohan There is a open github pull request very similar to what @macvictor proposed, but for now I recommend using the examples_linux/mysgw.cpp file.
                      • M marceloaqno
                        @marceloaqno
                        Ok I can you that file, but where is the best place to set Power Level and channel ?
                          @marceloaqno
                          marceloaqno
                          Code Contributor
                          @gohan There isn't exactly the best place to set things, it really depends on your preferences.
                            I just copied the myconfig file from the arduino and set the rest from the command line and from debug it looks like it's working, the problem is now to get domoticz talk to the mqtt.
                              After updating domoticz to beta version I finally have the MQTT working with controller and I can see the sensor node seding in data: my question now is how to I debug the gateway if it is running as a service on the RPI without messing things up?
                              • M marceloaqno
                                @hawk_2050 same for you guys who helped, thank you for all the feedback.
                                @jerseyguy1996 I don't see anything wrong with your config.Try to add a small delay() after the first send() and before the sendBattery().
                                @annegerben This looks like a wire problem. I updated the guide, check the wire section again.
                                marlin
                                @marceloaqno I am trying to get a Pi 3 working with MySensors 2.1.1 and nrf24l01 and using your updated wire guide, but all I get as output is the following:
                                mysgw: Starting gateway...
                                mysgw: TSF:LRT:OK
                                mysgw: TSM:INIT
                                mysgw: TSF:WUR:MS=0
                                mysgw: !TSM:INIT:TSP FAIL
                                mysgw: TSM:FAIL:CNT=1
                                mysgw: TSM:FAIL:PDT
                                [The output repeats itself, increasing the CNT every time, while at the same time one of the cores on the Pi 3 is running at full CPU utilization.]
                                By reading earlier comments I assume this is a wiring problem. One possible cause is inconsistency between
                                0_1488723559852_upload-e3165792-1f42-4663-8e68-efd96bd275f8
                                and
                                0_1488723638471_upload-d7048ef8-8a33-4214-9935-0356cf9291c2
                                where the first picture indicates that pin 24 and pin 26 should be used, while the second indicates pins 22 and 24 should be used. However, I have tried both options but I still get the same output (I used different nrf24's for the different setups, in case the nrf24 got burned from the first setup).
                                I have VCC from nrf24 connected to pin 17 on the Pi 3 and GND connect to pin 25.
                                Any suggestions on what to try next?
                                [The Pi 3 is running Raspbian with Pixel. For information, I already have a running Arduino with MySensors MQTT GW and a simple node with MySensors and DHT22. From this I know that by nrf24 chips works when being fed with 3.3V.]
                                G keldandorinK 2 Replies Last reply
                                  I have connected my nrf24 like the secon table you posted and it is working but I am using an "adapter" for nrf24 with a socket and has voltage regulator + capacitors, so if you don't have any cap on the radio module, I'd suggest you put one on (try from a 4.7 uF up to 47 and see if anything changes)
                                    marlin
                                    @gohan Thanks! You were correct. I also had one of those "adapters" lying around which I did not need for my Arduino nodes with MySensors, though it came into use for the Rp3.
                                      G
                                      G
                                      Grubstake
                                      @gohan said in 💬 Building a Raspberry Pi Gateway:
                                      I have my gateway on a headless pi 3, no monitor, GUI or keyboard. (I don't care for the nest of wires connection to the pi.) I also use MQTT which is very reliable.
                                      An easy way to see the full MQTT traffic is to not start (or kill if it starts on boot) the MQTT server in the background, and start it in the console you can monitor. This won't impact Domotics one bit. In my case I do this by invoking "mosquitto -d" in the terminal
                                      A simple way to monitor MQTT once its up and running is to look at the Domotics Log on the Setup menu.
                                      Another way to watch it is to, in a terminal window such as running ssh from your computer, use MQTT "sub" in your terminal to see the MQTT traffic both ways to and from Domotics. If this isn't familiar, you need to learn it, (read the MQTT docs) and it's quite simple. Example might be "ssh pi@rpi.local" or "ssh <IP address>" from a computer on the local network, assuming the user is named pi and the pi is named "rpi"
                                      Your MQTT topic must match what is in the sensor node sketch, the gateway sketch, and the domotics MQTT config. In my case I use "mosquitto_sub -d -v -t domoticz" and everything starts showing in real time in the terminal window.
                                      MQTT is a bit more fiddly to set up but it's nice that different environments can push sensor data into the same MQTT server, in my case MySensors and ESP Easy.
                                      Tim
                                      • M marlin
                                        mysgw: TSF:LRT:OK
                                        mysgw: TSM:INIT
                                        mysgw: TSF:WUR:MS=0
                                        mysgw: TSM:FAIL:PDT
                                        and
                                        G
                                        G
                                        Grubstake
                                        @marlin said in 💬 Building a Raspberry Pi Gateway:
                                        Be careful because the wiring page shows two pinout diagrams, one for the Pi 1, another for the Pi 2&3, but which is which is not inside the graphic itself. Please don't ask how I know. ;-)
                                        Tim
                                        • G Grubstake
                                          Tim
                                          @Grubstake
                                          I am using mqtt fx from pc and subscribing to topic # so I get the full traffic of what is going on, but I haven't had time lately to compare if you get same log details as the myscontroller connected to ethernet gateway or starting the gateway on rpi with debug flag
