  2. Announcements
  • MadhiasM Madhias
    I have a question regarding the --my-serial-groupname option: since I start the gateway under an user account with sudo, the gateway device ([EDIT] symlink) will be created with ownership root:root. Shouldn't it be created with root:dialout (as I chose dialout as group in my case)?
    [DELETED]
    marceloaqno
    Code Contributor
    @Madhias /dev/pts/2 it's the one who holds the specified group ownership
    MadhiasM 1 Reply Last reply
    • M marceloaqno
      MadhiasM
      MadhiasM
      Madhias
      @marceloaqno OK, many thanks for that hint!
      I was wrong from the beginning on, since I thought my configuration for the gateway was correct because of --my-serial-groupname=dialout - but that was not compiled. I edited now the mysgw.cpp manually (there was tty instead of dialout; and of course there was all the time the warning when compiling...). Now it works! Without chmod, or chowning anything later!
        macvictor
        @marceloaqno Thank's for you help. I have other question.. general I try configure my gateway to work with security & signing, but they doesn't work. Where is problem? On the bottom i send point what it do it:
        Gateway:
        2. make
        3. sudo make install
        10. sudo mysgw --gen-aes-key
        Node:
        #define USE_SOFT_SIGNING
        #define STORE_SOFT_KEY
        #define USER_SOFT_KEY
        #define STORE_SOFT_SERIAL
        #define STORE_AES_KEY
        #define USER_AES_KEY
        EEPROM configuration:
        // Enable NRF24L01 radio type
        // Select soft signing
        #define MY_SIGNING_SOFT
        // Enable node whitelisting
        #define MY_REPEATER_FEATURE
        #define BUTTON_PIN  3   // Arduino Digital I/O pin number for button
        #define CHILD_ID 1      // Id of the sensor child
        #define RELAY_ON 1
        #define RELAY_OFF 0
        Bounce debouncer = Bounce();
        int oldValue = 0;
        bool state;
          // Setup the button
          pinMode(BUTTON_PIN, INPUT);
          // Activate internal pull-up
          debouncer.attach(BUTTON_PIN);
          debouncer.interval(5);
          pinMode(RELAY_PIN, OUTPUT);
          state = loadState(CHILD_ID);
          digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);
        void presentation()  {
          debouncer.update();
          // Get the update value
          int value = debouncer.read();
        //  oldValue = value;
          delay(5000);
          if (message.isAck()) {
            // Change relay state
            state = message.getBool();
            // Store state in eeprom
        4 TSM:INIT
        5 TSF:WUR:MS=0
        11 TSM:INIT:TSP OK
        13 TSF:SID:OK,ID=105
        15 TSM:FPAR
        2065 !TSM:FPAR:NO REPLY
        2067 TSM:FPAR
        4117 !TSM:FPAR:NO REPLY
        4119 TSM:FPAR
        6169 !TSM:FPAR:NO REPLY
        6171 TSM:FPAR
        8221 !TSM:FPAR:FAIL
        8222 TSM:FAIL:CNT=1
        8224 TSM:FAIL:PDT
        and in gateway i see:
        sudo mysgw -d
        mysgw: Starting gateway...
        mysgw: TSF:LRT:OK
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: TSM:INIT:TSP OK
        mysgw: TSM:INIT:GW MODE
        mysgw: MCO:REG:NOT NEEDED
        mysgw: MCO:BGN:STP
        mysgw: MCO:BGN:INIT OK,TSP=1
        mysgw: connected to 127.0.0.1
        mysgw: MQTT connected
        mysgw: !TSF:MSG:PVER,3=2
        mysgw: !TSF:MSG:PVER,1=2
        mysgw: TSF:MSG:REL MSG
        mysgw: !TSF:RTE:240 UNKNOWN
        mysgw: !TSF:MSG:PVER,0=2
        mysgw: !TSF:RTE:233 UNKNOWN
        mysgw: !TSF:RTE:51 UNKNOWN
        Where is problem?
        M pepsonP rajeev2301R 5 Replies Last reply
        • M macvictor
          Gateway:
          2. make
          Node:
          #define RELAY_ON 1
          #define RELAY_OFF 0
          int oldValue = 0;
          bool state;
            // Setup the button
            debouncer.update();
            delay(5000);
          4 TSM:INIT
          5 TSF:WUR:MS=0
          11 TSM:INIT:TSP OK
          15 TSM:FPAR
          2067 TSM:FPAR
          4119 TSM:FPAR
          6171 TSM:FPAR
          8221 !TSM:FPAR:FAIL
          8222 TSM:FAIL:CNT=1
          8224 TSM:FAIL:PDT
          sudo mysgw -d
          mysgw: TSF:LRT:OK
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: MCO:BGN:STP
          Where is problem?
          marceloaqno
          Code Contributor
          @macvictor Did you also enable encryption on your node? (#define MY_RF24_ENABLE_ENCRYPTION)
            macvictor
            @marceloaqno Thanks for help :+1: This was my problem 😀
              how do I set user and password to access the mqtt broker? I tried do add --my-mqtt-password=PASS --my-mqtt-user=USER other parameters but they get ignored
                macvictor
                @gohan edit configure file and add this code:
                --my-mqtt-user=*)
                    CPPFLAGS="-DMY_MQTT_USER=\\\"${optarg}\\\" $CPPFLAGS"
                --my-mqtt-password=*)
                    CPPFLAGS="-DMY_MQTT_PASSWORD=\\\"${optarg}\\\" $CPPFLAGS"
                after this code:
                --my-signing-request-gw-signatures-from-all*)
                        signing_request_signatures=true
                        CPPFLAGS="-DMY_SIGNING_GW_REQUEST_SIGNATURES_FROM_ALL $CPPFLAGS"
                this is about 408 number line and use flag --my-mqtt-password and --my-mqtt-client-id when you run configure, thats all. =)
                blaceyB gohanG 2 Replies Last reply
                • M macvictor
                  --my-mqtt-user=*)
                  after this code:
                  blaceyB
                  blaceyB
                  blacey
                  wrote on last edited by blacey
                  #355
                  @macvictor It would be great if you would submit this as a GitHub Pull Request. If you aren't comfortable with that, then I would encourage you to at least open a MySensors issue to add these RPI configuration options.
                  • TeknorT
                    TeknorT
                    Teknor
                    wrote on last edited by Teknor
                    #356
                    When using RPI as a GW for MySensors, the CPU load increases from 18% to around 80 %. I am using a RPI II model B. I'd love the have the GW running on the Raspberry, and avoid a USB connected Arduino.
                    Does somebody else experience the same?
                    M carlylerC 2 Replies Last reply
                    • TeknorT Teknor
                      macvictor
                      @Teknor I use RPI III as GW and all node connect with gw used nRF24L01. My CPU now usage 5-10%, but I installed "Home Assistance" + homebridge + some plugins.
                      TeknorT 1 Reply Last reply
                      • M macvictor
                        TeknorT
                        TeknorT
                        Teknor
                        #358
                        @macvictor Thanks. My RPI 2 is running Domoticz, RFXcom GW and 2x 3MP cameras with motion detection using Motioneye. Might be something wrong with my MySensors GW setup...
                        • TeknorT Teknor
                          carlylerC
                          carlylerC
                          carlyler
                          @Teknor I tend to agree something is wrong, but I think it really on depends how many nodes and how often you're sending data.
                          rpi3 + GPIO nrf24l01 + openhab2 + 8 nodes + packet received, on average 1 / 5s :
                          top - 06:29:37 up 2 days, 22:33,  2 users,  load average: 0.26, 0.24, 0.19
                          KiB Mem:    947732 total,   903420 used,    44312 free,   175364 buffers
                          KiB Swap:   102396 total,     4496 used,    97900 free.   391360 cached Mem
                            681 root      20   0  208840  56532  23684 S   8.9  6.0 214:23.60 Xorg
                            527 root      20   0   39448  21532  11264 S   4.3  2.3  69:34.28 vncserver-x11-c
                           1154 pi        20   0   50548  17628  12196 S   3.0  1.9  64:05.96 lxterminal
                          30426 openhab   20   0  441764 197592  14960 S   1.6 20.8 284:18.70 java
                           2467 root      20   0   20024   2456   2300 S   1.3  0.3  62:55.17 mysgw
                          25634 root      20   0       0      0      0 S   1.0  0.0   0:00.21 kworker/u8:0
                            688 root      20   0   13720   9432   8828 S   0.7  1.0   2:04.96 vncagent
                          25855 pi        20   0    5232   2584   2140 R   0.7  0.3   0:00.49 top
                              7 root      20   0       0      0      0 S   0.3  0.0   9:15.35 rcu_sched
                             78 root     -51   0       0      0      0 S   0.3  0.0   5:16.50 irq/92-mmc1
                            967 pi        20   0   95656  17716  12028 S   0.3  1.9   6:41.87 lxpanel
                              1 root      20   0   24620   4688   2716 S   0.0  0.5   0:13.08 systemd
                              2 root      20   0       0      0      0 S   0.0  0.0   0:00.27 kthreadd
                          • M macvictor
                            --my-mqtt-user=*)
                            after this code:
                            @macvictor
                            That worked, thanks. But to configure channel, power, AES key, and so on, do you think it is better to use command line like you posted above or customize myconfig.h?
                              @macvictor
                              marceloaqno
                              Code Contributor
                              @gohan You can also set mqtt username and password in examples_linux/mysgw.cpp
                              gohanG 1 Reply Last reply
                              • M marceloaqno
                                @marceloaqno
                                I'm trying to understand where is the best place to avoid file gets overwritten in case of upgrades
                                  @marceloaqno
                                  marceloaqno
                                  Code Contributor
                                  @gohan There is a open github pull request very similar to what @macvictor proposed, but for now I recommend using the examples_linux/mysgw.cpp file.
                                  • M marceloaqno
                                    @marceloaqno
                                    Ok I can you that file, but where is the best place to set Power Level and channel ?
                                      @marceloaqno
                                      marceloaqno
                                      Code Contributor
                                      @gohan There isn't exactly the best place to set things, it really depends on your preferences.
                                        I just copied the myconfig file from the arduino and set the rest from the command line and from debug it looks like it's working, the problem is now to get domoticz talk to the mqtt.
                                          After updating domoticz to beta version I finally have the MQTT working with controller and I can see the sensor node seding in data: my question now is how to I debug the gateway if it is running as a service on the RPI without messing things up?
