  3. US decora style wall switch
40 Posts 10 Posters 24.3k Views 12 Watching
  • TD22057T TD22057
    Very interesting designs @enterprised and @dbemowsk. I've also been working on my own version of decora switch and relay system. It's designed to use empty keystone switch plates with 1, 2, or 3 switches and uses keystone jack fillers as the switch covers so they look almost commercial. It's a 3 PCB system. The front PCB has the switches, LED's, reset button, CPU, and an RFM69 or NRF radio. The middle PCB has a MeanWell IRM-02 or HLK AC->DC converter (with fuse, thermal fuse, and varistor), a replaceable fused 10A AC relay with opto-coupler isolation, 5V and 3.3V rails and a 2 wire temperature probe to measure the temp of the PSU module. The back PCB is just a cover to insure no sharp solder points are in an electrical box. I decided that since this will be in my walls, I would only use name brand parts (from digikey and mouser) on the high voltage side which increases costs but should reduce the risk of fire (or at least make me feel better).
    I've designed the PCB and checked them over but we're in the middle of buying a house and moving so I haven't ordered any yet. Here's the 3D rendering of the PSU and CPU boards together and a one of the PSU board.
    dbemowskD
    dbemowskD
    @TD22057 Excellent design. I like the fact that you used the Recom PSU. I have used the Recom ones and they are very well built, but they are slightly larger than the HLK-PM01s. The price is a bit higher too, but I figured for what mine would be doing, the HLK-PM01 will be sufficient. I plan to also use a thermal fuse with an MOV and fuse for good protection. Mine at this point is a bit bulky to fit relays in right now, but it would work well for a nice scene controller node or a direct control for another node.
    • dbemowskD dbemowsk
      @enterprised For my design, I am hoping to use an HLK-PM01 power supply. Comparing to the one you have listed it has a few advantages:
      • Enclosed components vs exposed components on yours
      • Continuous output current of 600mA vs 200mA on yours
      • 50mV or less of ripple on the output vs 100mA on yours
      Having the components sealed will protect more against short circuits on the high voltage side. As for the current, I probably wouldn't need 600mA, but using a supply that is rated a bit higher I figure will be less stress on the components and cut down on heat. Plus I have to do 3.3 volt regulation for the radio, so I figure I am covered for that too. And last, the better the ripple on the output, the less filtering that will be needed for a more stable radio.
      The other thing that I like about my design is that it is modular. You would be able to have a number of different switches, sensors or LEDs as the faceplate while having one arduino/radio board and one power supply board. As mentioned in one of my previous posts, the current design is a bit bulky, but with a better PCB design, I think I can compress the layers quite a bit more. Looking at your pics, yours looks like a nice design too.
      enterprisedE
      enterprisedE
      enterprised
      wrote on last edited by enterprised
      @dbemowsk
      Oops, attached the wrong link.
      I'm using the 400ma version of this PSU. The design uses 200ma max with 4 switches/LED's/SSR's, so plenty of overhead. I actually stepped away from the HLK-PM01 due to the very poor reliability of these modules, too many that failed within a few months.
      I use an LE33 in TO92 package to create and regulate the 3.3v for the radio
      The ripple is a non issue as I have 7 module of the previous design installed and working around the house.
      I'm enclosing the entire module with a hot vacuum formed custom enclosure, so the entire circuit is fully protected. Amazing what you can do with a sheet of plastic, some wood, vacuum cleaner and a oven.
      My design is also using multiple PCB's. There is a second PCB sitting on top containing 2 SSR's and related components
      This was my previous design using relays not SSR but all other components are the same.
      • dbemowskD
        dbemowskD
        So for my latest update on this, I have finished the power supply board. One thing I learned in making this that I didn't even think of at first was that when I soldered on the thermal relay, the heat from the soldering was enough to blow the relay. Thus, my initial test did not work. I was finally able to get a fuse installed and working. I would have preferred it to be more centered on the side of the Hi-Link module, but I am thinking that it should still be effective.
        0_1485103640004_upload-1ea7b909-45be-45d6-8a6d-73c512594442
        On the bottom side of the board you can see the LM1117 3.3v regulator. For the high voltage side, I have hot glue over all traces for safety in testing.
        0_1485103278566_upload-fb75fd43-a5c5-4650-a9e1-91cbf7168f51
        I used a 22uf cap on the 5 volt output and a 10uf cap on the 3.3 volt output. I have also added hot glue to the incoming hot and neutral leads to provide some strain relief on the wire as it attaches to the board.
        0_1485103583785_upload-304f96de-a193-4f3b-944b-edc2ba5fbda3
        0_1485103854338_upload-3791a57f-89c6-44a8-bc1c-6c372c718b8b
        The last thing I want to do is fabricate a plastic cover to put over everything that will fit into the wall box. I think I am going to need a deep wall box to house the connections and the module.
        I did connect this and have it paired with my Vera. Each row is OFF, ON and status LED to indicate the ON state. I have debated on having the LED on when the switch is off to give better visibility to the switch when it is dark. In Vera, I can tie the switches to devices using scenes.
        Overall, this proof of concept design is working well.
        enterprisedE sundberg84S 2 Replies Last reply
          enterprisedE
          enterprisedE
          enterprised
          @dbemowsk
          I think that with a little effort the switch and middle PCB can become one in a custom designed PCB. You'll end up with switches and LED's on one side and the Arduino and radio etc on the other side. That's what I did. This will make your design a lot more compact.
          I used https://easyeda.com/ to design and manufacture my PCB's.
          dbemowskD 1 Reply Last reply
            sundberg84S
            sundberg84S
            #22
            @dbemowsk - Nice work!
            Here is a discussion and more links about safety in designing a PCB with AC power that might come in handy:
            https://forum.mysensors.org/topic/4175/clearance-creepage-and-other-safety-aspects-in-mysensors-pcbs.
            Also if you dont want to completley redesign a PCB you can take some of my designs and redesign them to your purpose.
            • dbemowskD
              dbemowskD
              So I have had my prototype version of this switch installed for a few weeks now and it seems to be performing well with my Vera setup. This week I added a new tool to my arsenal. I purchased an Anet A8 3D printer kit. I just got it put together yesterday. I ordered a roll of ABS which came yesterday. It was supposed to be white, but they sent transparent (Grrrr....). Trying to work with the ebay seller on this.
              Anyway, I wanted a project to try that would be useful, but not super difficult. I decided to build a better switch plate to improve my prototype of this switch. I knew that one of the big places to go for 3D stuff to print was thingiverse.com. I did a search on the site and someone had a 3d file for a decora blank wall plate. I decided to download the files and see what I could do. I had never done anything in any kind of CAD program, but thought, how bad can it be. I ended up finding OpenSCAD. Drawing objects in the software is done much like a structured programming language. Within a day of teaching myself some things in it, I came up with this:
              0_1487452255103_upload-26f0a10c-2ae9-417e-899e-a1b718de58a2
              0_1487452474777_upload-cdb19c24-d12c-4607-8507-e92e0c34ed44
              I have not printed this yet since I am still trying to resolve my filament issue with the ebay seller,. but as soon as I get that figured out, I will give this a test. Before printing I may still look at adding some reliefs in the 4 corner tabs to save at least a little bit of plastic, but overall I think it looks good. I'll post more here as I get it done.
              • sundberg84S
                sundberg84S
                Looking forward to pictures :) Keep up the good work!
                • dbemowskD
                  dbemowskD
                  I think this 3D printer is going to help a lot with my HA hobby. Now I will be able to make custom enclosures and things and not have to search the web to say, "ehh, that will kinda fit". I just have to get used to using OpenSCAD.
                  blaceyB 1 Reply Last reply
                  • dbemowskD
                    dbemowskD
                    Here is the updated part.
                    0_1487513892212_upload-f963e107-b10a-47f3-9424-768f5c1766ee
                    • dbemowskD
                      dbemowskD
                      So even though I only have transparent ABS to work with at the moment, I decided to do a test print of this (I actually did 2 test prints). The results were in my eyes only fair. Though the outside didn't look bad, the inside is a bit messy. I think I could clean it up and make it usable, but I think it could be better. I printed it with the ears down and the face up. The print may come out better if I print it with the face down. The ears may be a little stringy, but that is a little less of an issue because the ears are hidden by the faceplate. I had to increase the hole size in the face where the buttons come through for the buttons to fit (this was the reason for the second test print). With the first print, the buttons were a little snug in the holes.
                      Without further ado, here are the pics:
                      0_1487645138378_upload-e913e68a-e229-471a-b637-dbb822b4c276 0_1487645152819_upload-f3219ab8-315b-4a82-bccd-ca9f000e9b03
                      0_1487645166139_upload-1e6e6140-dd06-4466-8d61-e09e7431c9a0
                      These two pics show how it fits in the faceplate.
                      0_1487645183984_upload-8b62d489-5fef-4657-b00c-f070b0aee885 0_1487645196357_upload-1cecec11-4324-4547-8350-d1a68462c067
                      • dbemowskD
                        dbemowskD
                        If anyone is interested, I posted the 3D design files for this switch plate out on thingiverse.com. Included is the OpenSCAD file and .stl files for making modifications if you'd like.
                        http://www.thingiverse.com/thing:2136094
                        Enjoy...
                          blaceyB
                          blaceyB
                          blacey
                          wrote on last edited by blacey
                          #29
                          @dbemowsk said in US decora style wall switch:
                          You should give FreeCAD a shot. Open source and runs on Windows, macOS and Windows and you can download the releases from GitHub
                          • blaceyB blacey
                            dbemowskD
                            dbemowskD
                            @blacey Though I do own a windows laptop, my main desktop is a linux machine. Don't have time now, but I'll see if they have it ported to linux. Thanks for the tip.
                              blaceyB
                              blaceyB
                              blacey
                              @dbemowsk Linux is the primary platform used by the FreeCAD devs so Linux is very well-supported.
                              There is a PPA for stable and a PPA for daily developer builds.
                              For example, to install the latest stable:
                              sudo add-apt-repository ppa:freecad-maintainers/freecad-stable
                              sudo apt-get update
                              sudo apt-get upgrade
                              sudo apt-get install freecad freecad-doc
                              More details here - https://www.freecadweb.org/wiki/Install_on_Unix
                              • blaceyB blacey
                                sudo apt-get update
                                dbemowskD
                                dbemowskD
                                @blacey Thanks for the tip. Just installed it on my Fedora 23 box.
                                sudo dnf install freecad
                                It did not find a package called freecad-doc, but that's what the online docs and youtube is for.
                                  blaceyB
                                  blaceyB
                                  blacey
                                  Excellent! Also, there is a pretty vibrant community behind FreeCAD so feel free to introduce yourself and ask questions on the FreeCAD forums - everyone is very helpful.
                                  • dbemowskD
                                    dbemowskD
                                    Just an update on this. I gave the wall switch another spin on the design. I made a version of this with nice rocker switches. I think this design looks a bit more professional.
                                    0_1490417693163_upload-0ee6eb29-3f96-46ab-a046-7a6b227a5ce8
                                    Because of having the rocker switches I have added one more piece to the design which is a rocker support for the switches to prevent both the on and off buttons for a switch to be activated simultaneously.
                                    Here is a view of the prototype with the rocker support in place.
                                    The LEDs that I currently have installed are 3mm white LEDs. I went with 10k resistors on them so as not to make them too bright since at full brightness these can be a bit blinding. I chose those because they are what I had available in my parts bin. Red or green LEDs might be a better fit for this. Choose a resistor value that gives whatever LEDs you choose suitable brightness as this can vary between LEDs.
                                    For anyone interested I posted the 3D design files on thingiverse. Everything you need to make this switch board is posted there.
                                    http://www.thingiverse.com/thing:2202434
                                    • dbemowskD
                                      dbemowskD
                                      #35
                                      So, I have added yet one more variation of this to my line of switches. This is a dual rocker switch with customizable text for each on/off switch. You can have just the plain ON / OFF button style or you can choose to add 6 to 7 characters of text above the ON / OFF text. In the images below you can see that I have created one of these for use with a light/ceiling fan combo.
                                      0_1491021454166_decora_dual_rocker_switch_assembled_top_view_fan_light.jpg 0_1491021458990_decora_dual_rocker_switch_assembled_top_view_on_off.jpg
                                      The OpenSCAD and .stl files for this switch variation can be found on thingiverse. http://www.thingiverse.com/thing:2219319
                                      • enterprisedE enterprised
                                        @dbemowsk
                                        dbemowskD
                                        dbemowskD
                                        #36
                                        So I was playing a bit with the online schematic and PCB tool that @enterprised mentioned called EasyEDA to create boards for my in-wall switches. For now I stuck with the design that I have a few prototypes of, which consists of 3 boards, a switch board with LED indicators, a main board with arduino and radio and a power supply board. This is what I have so far.
                                        The power supply board is pretty simple and straight forward. Based on an HLK-PM01 with both a standard fuse and a thermal fuse for safety. J7 and J8 are the 110V AC inputs. The output is filtered with 10uf electrolytic and 0.01uf creamic capacitors:
                                        0_1495937431315_upload-613f689c-162c-4b11-b251-6265f25ec69f
                                        The main board too is pretty simple. It will use a 3.3v pro mini with an nRF24L01+ radio and 2 header connectors for attaching the switch board:
                                        0_1495937748575_upload-3b37d2b1-8733-4050-93f3-4abd31674f80
                                        I went a bit complex on the switch board design for flexibility. The design looks a bit busy, but once you understand the idea behind it it makes perfect sense. The board will be able to handle configurations for my original 8 button design (4 on/off switches), my 4 button design (2 on/off switches) and also a standard decora paddle type design. All designs would have LED indicators for each row of buttons. For the 8 button / 4 on/off switch design, you would populate SW-1 through SW-8 and use LED1 through LED4 with R1 through R4. For the 4 button / 2 on/off switch design, SW-9 through SW-12 would be populated and use LED5 and LED6 with R1 and R2. Lastly for the standard paddle design, SW-13 and SW-14 are used with LED7 and R1. This eliminates the need for 3 separate switch board designs. I can have some boards in the parts bin and depending on the type of switch I need, I populate what I need. I went with SMD LEDs and resistors because I thought the through hole ones seemed a bit bulky. I can then print clear lenses for the LEDs to shine through.
                                        0_1495938500150_upload-c10ec24c-08f8-40f6-aaf9-ed84a3b6bcd7
                                        One thing that I don't have in the design shown that I will probably add before sending it off for printing is a 3.3V and possibly even 5V positive power connections to one of the header connectors going to the switch board. Having that would allow me to build other sensor boards that could plug on top of the main board for even more flexibility. I currently have a ground, 6 digital IO and 4 analog IO lines being passed to the switch board which would allow for a lot of additional design possibilities.
                                        I am open to comments and suggestions on the design so far.
                                        • dbemowskD
                                          dbemowskD
                                          So, one of my big days is here. My first ever fabricated PCBs that I designed are here. A slight change in the switch board from what's shown above, I did a design of one that used through hole components instead of the SMT components shown above. Really the only thing that I did as SMT in the above design were the LEDs and resistors, the switches were still through hole. Anyways, are some pics of the top and bottom sides of the finished product.
                                          0_1496872600633_upload-185bf16e-c44f-43c9-b67f-87f633cb9943
                                          0_1496872607779_upload-460c8e0e-3045-4cae-94d4-19f5cd5cc742
                                          I designed them and ordered them through the EasyEDA website. I got 5 each of the boards, so 15 total, for $24.63 plus $18.41 for DHL shipping to the US which comes out to $2.87 per board. For a small test run, I thought that wasn't too bad.
                                          Tonight I plan to assemble one of the switches to see about how long it takes. I also received my new batch of thermal fuses needed for the new boards, so I should have everything I need. Once done, I will do another post showing a finished and assembled switch.
