  3. OTA flash types for MySensors
64 Posts 23 Posters 36.4k Views 20 Watching
  • L LastSamurai
    @LastSamurai said:
    AT25DF512C-SSHN-B
    Thanks, but both have shipping costs of abount 20€ (if you pay <50€ overall). Or is there a way around it?
    I also found SST25VF020B‑80‑4I‑SAE and 25VF512A33-4C-SA flash modules in german stores though. Would they work too?
    jbjallingJ
    jbjallingJ
    jbjalling
    @LastSamurai Yes, thats true. My order is always above the "free shipping" limit :-)
    I'll give the datasheets a look, of the devices you mentioned.
    BR Jonas
    • D
      Dirk_H
      @LastSamurai The SST25VF020B... should work fine with the 2.0 developversion and #define MY_SPIFLASH_SST25TYPE set. It seems to be very close to the SST25PF020B I used. However keep an eye on the even more limited voltage range of the SST25VF Type which needs at least 2,7V which would be a problem if you want to power your circuit directly by 2xNiMH Batteries.
      The SST25VF512 needs also 2,7V but additionally does not support the 64k erase command (see my comments on that issue some posts above where I wrote something about the AT25F512).
      • X
        X
        XavTroniC
        wrote on last edited by XavTroniC
        #34
        Hi all,
        A question, why don't use an EPPROM SPI 25AA020A or 25AA512?
        They works between 1.8 and 5.5V.
        BR
        Xavier
        S 1 Reply Last reply
        • alexsh1A
          alexsh1A
          alexsh1
          #35
          I have AT25512N-SH-T SOIC-8 -> http://www.mouser.com/ds/2/36/Atmel-5165-SEEPROM-AT25512-Datasheet-476711.pdf
          Anyone knows if it is fully interchangeable with AT25DF512C? I cannot see any difference from the datasheet. The pinout is the same.
          • X
            X
            XavTroniC
            Hi all,
            Any news with the EEPROM compatibility and the new Mysensors version 2.0?
            BR,
            Xavier
            • tbowmoT
              tbowmoT
              tbowmo
              @XavTroniC
              It's the bootloader that sets the limit on which flash / eeprom you can use, not the library. So the support in 2.0.0 is the same as for 1.5.x
                mardah
                Would AT45DB041E be a good choice as a OTA flash? I see it's in the schematics for the new Sensebender Micro mk2.
                https://www.adestotech.com/wp-content/uploads/doc8783.pdf
                BR
                Martin
                tbowmoT S 2 Replies Last reply
                • M mardah
                  BR
                  Martin
                  tbowmoT
                  tbowmoT
                  tbowmo
                  @mardah
                  I can't remember if I just dumped components in there at the moment, or if I actually looked at the datasheets :)
                  • X XavTroniC
                    Hi all,
                    BR
                    Xavier
                    shabba
                    @XavTroniC said in OTA flash types for MySensors:
                    25AA512
                    Seems these are only 2K in size.
                    I would like something similar though!
                    tbowmoT 1 Reply Last reply
                    • S shabba
                      25AA512
                      tbowmoT
                      tbowmoT
                      tbowmo
                      @shabba
                      It's a 512kbit device, which is 64 kbytes
                      • M mardah
                        BR
                        Martin
                        Samuel235
                        #42
                        @mardah said in OTA flash types for MySensors:
                        Did you ever figure out if this works with Optiboot for OTA flashing?
                        I must admit that i'm very confused at this thread, it was setup to advise of other Flash IC's for us to use but there seems to be no 'solid' alternatives that you guys have suggested. For me, living in the UK, its near impossible to grab any of the AT25DF512C-SSHN-B without paying through the roof for shipping.
                        I can see that AT45DB041E is JEDEC compliant but that is as far as i can go with knowing if it will work. Flash architecture is way out of my depth right now.
                        MySensors 2.1.1
                        KoreshK 1 Reply Last reply
                        • S Samuel235
                          KoreshK
                          KoreshK
                          Koresh
                          wrote on last edited by Koresh
                          #43
                          @Samuel235 said in OTA flash types for MySensors:
                          AT45DB041E
                          Hello. This chip (AT45DB041E) has no erase 32kb command (0x52), status read command has a strange opcode too (D7h). So it is no trivial task to use this chip.
                          I can suggest Micron M25P40 as widespread IC. But it requires one trick and I will try to describe it. This chip has no erase 32kb command (0x52) too. It means OTA code will not erase memory and update will be failed. We (me and Yury) bumped into this problem when we started intensive tests of my nodes before production (we use micron M25P40). Moreover, when I try to investigate inexpensive avaliable chips I find an interesting thing. Chips with 64kb erase option (0xD8 opcode) are more common than chips with 32kb erase option (which support 64kb erase option too). So it can be worth adapting mysensors for use of any flash chip which supports 64kb erase option. To adapt your sketches you should do only two things
                          1. Add this code into your sketch after including mysensors.h
                          #define SPIFLASH_BLOCKERASE_32K   0xD8
                          So OTA library will call erase 64kb command instead of erase 32kb command. It is very easy.
                          2) You should use Bootloader which calls erase 64kb command instead of 32kb command.
                          Bad news. It is not an easy task and you should recompile dual optiboot and burn it. :anguished:
                          Good news. I've recompliled dual optiboot and all my nodes will burn with it by default. :yum:
                          My changes in bootloader are very simple but it sutable for my boards. We update it many many times and the process is absolutely bulletproof (especially after Tekka's update :+1: ).
                          But how about a more universal solution? I think it is not too hard to modify dual optiboot to check flash first 10 bytes (OTA flag) after 32kb erase command call and try another command? I will try this idea later but may be someone will do it faster :smiley:
                          S alexsh1A 2 Replies Last reply
                          • KoreshK Koresh
                            AT45DB041E
                            Samuel235
                            @Koresh - Thank you for explaining this to me. I think i understand this a little more clearly now. Like i said, i've never dealt with flash so its all a grey area for myself.
                            I'm currently looking at recompiling MYSBootloader for use with an 8Mhz crystal instead of this work around. The whole reasoning behind me asking this question is simply because i wanted OTA updates on a battery powered node. Now, this means i need OTA updates on 3.3v, but my MYSBootloader nodes require 16Mhz crystal to work. So its either use 16Mhz on 3.3v (while it works, its not the correct solution) OR to get a bootloader working with an 8Mhz crystal setup. I chose the later, and therefor its either recompile MYSBootloader to work with 8Mhz OR to get a flash IC on the board to allow for Dual Optiboot.
                            At the moment i'm toying with the idea of going the software issue route and attempting to recompile MYSBootloader for 8Mhz (just need to workout what to change for the recompiled version). Seems a little easier and cheaper than going the route of flash considering my location and not being able to get my hands on the recommended/mostly used flash IC.
                            MySensors 2.1.1
                            • KoreshK Koresh
                              AT45DB041E
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @Koresh what about Winbond W25X40CLSNIG - the same used by Moteino? It seems to me this could be a good match?
                              https://www.winbond.com/resource-files/w25x40cl_e01.pdf
                              @tbowmo Thomas, what do you think?
                              • alexsh1A alexsh1
                                KoreshK
                                KoreshK
                                Koresh
                                #46
                                @alexsh1 It seems suitable at first sight :wink:
                                alexsh1A 1 Reply Last reply
                                • KoreshK Koresh
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  #47
                                  @Koresh I have just tried it and it works nicely.
                                  Start...Init OK!
                                  DeviceID: EF30
                                  Flash content:
                                  FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.
                                  WriteByte(1)
                                  WriteByte(2)
                                  WriteByte(3)
                                  WriteByte(4)
                                  WriteByte(5)Flash content:
                                  FF.BB.BB.BB.AA.BB.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.FF.
                                  Erasing Flash chip ... DONE
                                  The only disadvantage to me is voltage given that nrf24l01+ can run down to 1.9V
                                  Features
                                  • 2.3V to 3.6V supply
                                  • 1mA active current,
                                  • <1μA Power-down
                                  Aliexpress: $0.25 a piece + postage ($2.50 to Europe)
                                    manutremo
                                    wrote on last edited by manutremo
                                    #48
                                    I found the following one which is now offered in a breakout board.
                                    http://www.ebay.es/itm/2Pcs-W25q32b-Module-De-Memoire-Haute-Capacite-Module-De-Memoire-Interface-Spi-W-/132248126492?hash=item1eca9a441c:g:EukAAOSw4GVYI2CY
                                    I read the datasheet and compared the characteristics and instruction set with the ones for W25X40CLSNIG. I also checked against the SPIFlash.h file in github.
                                    Datasheet: http://www.elinux.org/images/f/f5/Winbond-w25q32.pdf
                                    To me everything seems consistent and am planning to order one to check. Does anyone see something what might prevent it from working?
                                    I'll report on what I find - it will be in some weeks since the delivery time is long.
                                    Nca78N 1 Reply Last reply
                                      What do you think would be the best solution to fit a flash chip on the easypcb board?
                                      • M manutremo
                                        @manutremo you can save nearly 40% of your money on AliExpress for those:
                                        https://www.aliexpress.com/item/Memory-Module-W25Q32B-High-Capacity-SPI-Interface-Flash-Memory-32M/32767512974.html
                                        • Nca78N Nca78
                                          manutremo
                                          @Nca78 Thanks for the hint. I actually purchased from this seller who is chaper:
                                          http://www.ebay.es/itm/Module-De-Memoire-Dinterface-1Pcs-Spi-W25q32b-Haute-Capacite-Ic-Nouveau-K-/162656857086?hash=item25df1aabfe:g:1Z8AAOSwSblZqs0q
                                          While the ebay seller shipped for free, Aliexpress would charge me 1.24€ for shipping to my country so the total price would be 2.63, significantly more expensive.
                                          Many thanks anyways!
                                          J 1 Reply Last reply
