  3. reporting battery to domoticZ
47 Posts 5 Posters 17.7k Views 6 Watching
  • R
    R
    Rene046
    @ fhenryco
    Cant get it to work, if you have time could help with my sketch.
    // Enable debug prints
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_BATTERY 4
    unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
    #define SKETCH_NAME "Temp_Hum_Batt"        // Change to a fancy name you like
    #define SKETCH_VERSION "2.1"                    // Your version
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
    MyMessage msgbatt(CHILD_ID_BATTERY, V_VOLTAGE);
    //MyMessage msgbatt(CHILD_ID_BATTERY, V_TEXT);
    #define VBAT_PER_BITS 0.0041055718475073313782991202346
    #define VMIN 3.6                                  //  Vmin (radio Min Volt)=1.9V (564v)
    #define VMAX 4.2                                  //  Vmax = (2xAA bat)=3.0V (892v)
      present(CHILD_ID_BATTERY, S_INFO);
      //present(CHILD_ID_BATTERY, S_CUSTOM);
      present(CHILD_ID_HUM, S_HUM);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
      batM();
       delay(500);
       // Battery monitoring reading
       delay(500);
       // Calculate the battery in %
       if (batLoop > 2) {
       if (batteryPcnt > 100) {
         batteryPcnt=100;
           msgbatt.set(batteryPcnt ,1);
           batLoop = 0;
         batLoop++;
    My sketch is not working 100% my voltage is not precise, giving me even 221 in percentage while  lipo is at this moment 3.7 volt (simulated with a variable power supply)
    im running it on a nano on 1 lipo cell and a dc dc powerup to 5 volt measuring the lipo voltage with a  divider 1M/470K
    Hope to add a soil moisture sensor and baro sensor in future.
    p.s. any one with some better idea sketch its ver welcome. im just started to experiment with Mysensor
    R fhenrycoF 2 Replies Last reply
    • R Rene046
      @ fhenryco
      DHT dht;
      float lastTemp;
      float lastHum;
          if (!metric) {
            lastHum = humidity;
        batM();
         delay(500);
         delay(500);
         if (batLoop > 2) {
           batteryPcnt=100;
             batLoop = 0;
           batLoop++;
      R
      R
      Rene046
      O i forget to tell im running the latest gateway from Mysensor.
      • R Rene046
        @ fhenryco
        DHT dht;
        float lastTemp;
        float lastHum;
            if (!metric) {
              lastHum = humidity;
          batM();
           delay(500);
           delay(500);
           if (batLoop > 2) {
             batteryPcnt=100;
               batLoop = 0;
             batLoop++;
        fhenrycoF
        fhenrycoF
        fhenryco
        @Rene046
        not
        but
        send(msgbatt.set(batteryPcnt ,1));
        also may be better to use S_MULTIMETER and V_VOLTAGE (rather than S_INFO and V_TEXT) as adviced by AWI and also 2 decimals hence
        send(msgbatt.set(batteryPcnt ,2));
        • R
          R
          Rene046
          thx i got a voltage log only giving me now -44.000 volt and 212 prct at battery level while measuring 3.7 volt battery and voltage on A0 1.3 volts
          DHT dht;
          float lastTemp;
          float lastHum;
          #define VBAT_PER_BITS 0.0041055718475073313782991202346  // 4.20/1023 volt
          #define VMIN 3.6                                  //  Vmin = 3.6 lipo empty
          #define VMAX 4.2                                  //  Vmax = 4.2 volt lipo full
              if (!metric) {
                lastHum = humidity;
            batM();
             delay(500);
             delay(500);
             if (batLoop > 2) {
               batteryPcnt=100;
                 batLoop = 0;
               batLoop++;
          R AWIA Arnold ŠlepetisA 3 Replies Last reply
          • R Rene046
            DHT dht;
            float lastTemp;
            float lastHum;
                if (!metric) {
                  lastHum = humidity;
              batM();
               delay(500);
               delay(500);
               if (batLoop > 2) {
                 batteryPcnt=100;
                   batLoop = 0;
                 batLoop++;
            R
            R
            Rene046
            And my serial monitor is going wild .lol
            41815 MCO:SLP:WUP=-1
            Battery percent: 95 %
            Battery Average (Send): -12 %
            45359 !TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=NACK:244
            45403 !TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=1,st=NACK:-12.00
            45410 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
            45415 MCO:SLP:TPD
            45417 MCO:SLP:WUP=-1
            47962 !TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=2,st=NACK:20.0
            T: 20.00
            48007 !TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=3,st=NACK:49.6
            H: 49.60
            Battery percent: -49 %
            49014 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
            49020 MCO:SLP:TPD
            49022 MCO:SLP:WUP=-1
            51567 !TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=4,st=NACK:49.2
            H: 49.20
            Battery percent: -26 %
            52575 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
            52582 MCO:SLP:TPD
            • R
              R
              Rene046
              And it seems like instead of real voltage i seen percentage in the log
              • R Rene046
                DHT dht;
                float lastTemp;
                float lastHum;
                    if (!metric) {
                      lastHum = humidity;
                  batM();
                   delay(500);
                   delay(500);
                   if (batLoop > 2) {
                     batteryPcnt=100;
                       batLoop = 0;
                     batLoop++;
                AWIA
                AWIA
                AWI
                @Rene046 if you send V_VOLTAGE you should use the voltage level not the percentage.
                R 1 Reply Last reply
                • AWIA AWI
                  R
                  R
                  Rene046
                  @AWI
                  hi could you explain how..
                  • R
                    R
                    Rene046
                    I still cant get it to work, No voltage reading or logging.
                    I there nobody trying to build a equal sensor.
                    maybe someone who could rework my sketch. or having a working sketch where i could delete some sensors from.
                    kind regards and greetings from the Netherlands.
                    AWIA 1 Reply Last reply
                    • R Rene046
                      AWIA
                      AWIA
                      AWI
                      @Rene046 I would be happy to help you but need some information on your circuit:
                      • How are you powering your Arduino? Through an (onboard) regulator or directly from battery?
                      • The internal reference can only be used up to 1.1V, you seem to be having a voltage divider which has a resulting voltage of > 1.1 V ?
                      • I do not understand your averaging algorithm, why are you not taking an average of the latest x readings?
                      My suggestion would be to use a different external reference (output of the dc-dc boost converter/ Vcc?) to measure the voltage.
                      • R
                        R
                        Rene046
                        Hi Awi
                        Thanks that you want to help,
                        Im powering it by a lipo battery 1 cell using an dc-dc boost converter to get 5 volts
                        i would like to see what this lipo is doing during a day. this lipo will be charged by an solar panel 6 volt 300ma still waiting for that panel.
                        You are absolutely right with my voltage divider it's at 1.9 volt while lipo is at 4.2 volt
                        I'm not a hero in elektronics , just starting to play with it. so to start i should make an voltage divider that gives me aprox 1,1 volt max at 4,2 volt.
                        I changed the voltages divider now from 270k-100k
                        giving me 1.07 volt at 4.2 volt lipo
                        i'm totally open for any other design you could give, i just used some code from others that was excepted by demoticz.
                        If you like you could send me an sample how you would do it or change my sketch ..
                        today i also received my BMP180 and BH1750 i want to include in the future..
                        • R
                          R
                          Rene046
                          wrote on last edited by AWI
                          #28
                          my serial monitor is now making a bit more cense voltage is about 0,10 volt off
                          but maybe i do something wrong with calculation.
                          percentage is still something wrong with
                          by the way i'm not shure with the low voltage of an 16850 lipo at 3.6 volt ...
                          20412 MCO:SLP:WUP=-1
                          22921 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:17.8
                          T: 17.80
                          22929 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:35.4
                          H: 35.40
                          23939 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.53
                          Battery voltage: 3.53 V
                          Battery percent: -10 %
                          23946 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                          23954 MCO:SLP:TPD
                          23955 MCO:SLP:WUP=-1
                          26465 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:36.1
                          H: 36.10
                          27473 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.52
                          Battery voltage: 3.52 V
                          Battery percent: -12 %
                          27481 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                          27489 MCO:SLP:TPD
                          and here the latest sketch
                          DHT dht;
                          float lastTemp;
                          float lastHum;
                              if (!metric) {
                                lastHum = humidity;
                            batM();
                             delay(500);
                             delay(500);
                             send(msgbatt.set(Vbat ,2));
                             Serial.print("Battery voltage: "); Serial.print(Vbat); Serial.println(" V");
                             if (batLoop > 2) {
                               batteryPcnt=100;
                                 batLoop = 0;
                               batLoop++;
                          • R Rene046
                            T: 17.80
                            H: 35.40
                            23954 MCO:SLP:TPD
                            H: 36.10
                            27489 MCO:SLP:TPD
                            DHT dht;
                            float lastTemp;
                            float lastHum;
                                if (!metric) {
                                  lastHum = humidity;
                              batM();
                               delay(500);
                               delay(500);
                               if (batLoop > 2) {
                                 batteryPcnt=100;
                                   batLoop = 0;
                                 batLoop++;
                            R
                            R
                            Rene046
                            #29
                            @Rene046 said in reporting battery to domoticZ:
                            im feeding with 3.60 volts at that moment.
                            • R Rene046
                              AWIA
                              AWIA
                              AWI
                              #30
                              @Rene046 The 1.1V internal reference is not calibrated and can be 10% off, So you need to do some calibration yourself.
                              (b.t.w. I cleaned your postings a little. Please make sure you use the code markings in the right way, i.e. put them on a new line). To get you going I rewrote the battery routine. Changes:
                              • no real need to average the readings if you give it time to stabilize.
                              • got rid of the "volt per bit" constant
                              • added a "reference value:" for calibration, you can calculate it from the measured voltage and reported voltage.
                              // battery calculations
                              void batM(){
                              	const float vRef = 4.2/ 1.1 ;							// actual value for max reading, adjust with help of measured voltage
                              	delay(500);
                              	int sensorValue = analogRead(BATTERY_SENSE_PIN);   		// sensorValue is 0..1023 where 1023 == vRef
                              	float vBat = sensorValue * vRef / 1024 ;
                              	send(msgbatt.set(vBat ,2));
                              	Serial.print("Battery voltage: "); Serial.print(vBat); Serial.println(" V");
                              	int batteryPcnt = static_cast<int>(((vBat-VMIN)/(VMAX-VMIN))*100.);
                              	sendBatteryLevel( batteryPcnt) ;
                              • R
                                R
                                Rene046
                                Thanks that looks way better.
                                I just changed
                                into
                                const float vRef = 4.2/ 1.07 ;
                                because this is what i measure with my multimeter with 4.2 volt battery and measuring my voltage divider i have 1.07 volt
                                Giving me strange results something must be bad ..... my multimeter ?? it should be closer to 4.2 ? i guess
                                Battery voltage: 3.92 V
                                14842 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:53
                                Battery percent: 53 %
                                14850 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                14856 MCO:SLP:TPD
                                14858 MCO:SLP:WUP=-1
                                17367 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:19.4
                                T: 19.40
                                17376 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:48.5
                                H: 48.50
                                17885 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.92
                                17893 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:53
                                17900 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                17906 MCO:SLP:TPD```
                                • R Rene046
                                  I just changed
                                  into
                                  14856 MCO:SLP:TPD
                                  T: 19.40
                                  H: 48.50
                                  AWIA
                                  AWIA
                                  AWI
                                  @Rene046 You should still compensate for the 1.1 offset. What you should do is calculate the vRef from the measured battery voltage and the real voltage.
                                  • R Rene046
                                    DHT dht;
                                    float lastTemp;
                                    float lastHum;
                                        if (!metric) {
                                          lastHum = humidity;
                                      batM();
                                       delay(500);
                                       delay(500);
                                       if (batLoop > 2) {
                                         batteryPcnt=100;
                                           batLoop = 0;
                                         batLoop++;
                                    Arnold ŠlepetisA
                                    Arnold ŠlepetisA
                                    Arnold Šlepetis
                                    wrote on last edited by Arnold Šlepetis
                                    #33
                                    @Rene046 what resistors do you use to measure battery. VBAT_PER_BITS is not just 4.2/1023. Personally I am using 1m and 300k it gives me up to 4.77V
                                    • Arnold ŠlepetisA Arnold Šlepetis
                                      R
                                      R
                                      Rene046
                                      @Arnold-Šlepetis
                                      Hi im using at this moment what i had.
                                      270k-100k giving me 1.07 volt at 4.2 battery
                                      So i stay save , but ok reading is not giving my wanted 4.2 volt but around 3.92 volt
                                      My nano is feeded by an dc -dc boost converter giving me 5 volt from this 4.2 battery.
                                      @AWI
                                      Sorry im still a noob in this, just understood how to make a voltage diver using 3:1 divider
                                      Could you please give me a simple example how do this calculation.
                                      Arnold ŠlepetisA AWIA 2 Replies Last reply
                                      • R Rene046
                                        @Arnold-Šlepetis
                                        @AWI
                                        Arnold ŠlepetisA
                                        Arnold ŠlepetisA
                                        Arnold Šlepetis
                                        @Rene046
                                        As I understand correct VBAT_PER_BITS is not just 4.2/1032. This depends what resistors do you use. If you use 1m and 470k VBAT_PER_BITS=0.003363075 made from formula and it will never reads more 3.44v.
                                        #define VMIN and #define VMAX 4.2 used only for formula int batteryPcnt = static_cast<int>(((Vbat-VMIN)/(VMAX-VMIN))*100.);
                                        If you use 270k and 100k maximum is 4.07V so will be VBAT_PER_BITS=0.0039784946236559 and not like in your sketch 0.0041055718475073313782991202346
                                        • R Rene046
                                          @Arnold-Šlepetis
                                          @AWI
                                          AWIA
                                          AWIA
                                          AWI
                                          @Rene046 You making it complex. The steps)
                                          • Make sure that the input voltage is within the range of the reference. You did that with the voltage divider (max 1.07 V) :+1:
                                          • set vRefin the sketch to an expected value (4.2 / 1 , where 1 is the calibration value). You did (4.2/1.07) :+1:
                                          • Now you need to calibrate in the software:
                                          1. Measure the battery voltage (batteryVoltage) (not the voltage divider) with the multimeter. You did (4.2 Volt) :+1:
                                          2. Look at the voltage level reported by the sketch (reportedVoltage). You did (3.92 Volt) :+1:
                                          3. Calculate the calibration value and adjust vRef. It needs to report 4.2V now it reports 3.92V so you are off by 1.07. => (4.2/1.07) * 1.07 = 4.2 => set vRef to (4.2/ 1.0) and you will be fine.
                                          There are a few reasons why you need to calibrate:
                                          • The internal reference of the Arduino (1.1V) is not calibrated (can roughly vary from 1V to 1.2V)
                                          • Your voltage divider is not always precise.
                                          • Most multimeters are far more accurate...
                                          12.5k
