  3. reporting battery to domoticZ
47 Posts 5 Posters 17.7k Views 6 Watching
  • R Rene046
    i would like to ask something to ,
    Now i have the battery level showing up in Domoticz what can i do to log the voltage in volts, should i add something inside the sketch or something in domoticz..
    AWIA
    AWIA
    AWI
    @Rene046 The "royal" way to report battery level is to define it as S_MULTIMETER and use it to report voltage. Domoticz will take the voltage and can graph it. i.e.
    definitions: MyMessage voltageMsg(VOLTAGE_CHILD_ID, V_VOLTAGE);
    in presentation: present(VOLTAGE_CHILD_ID, S_MULTIMETER, "Battery level" );
    sending: send(voltageMsg.set(lastVoltage,2)); //send battery in Volt 2 decimal places
    • R
      R
      Rene046
      @ fhenryco
      Cant get it to work, if you have time could help with my sketch.
      // Enable debug prints
      #define CHILD_ID_HUM 0
      #define CHILD_ID_TEMP 1
      #define CHILD_ID_BATTERY 4
      unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
      #define SKETCH_NAME "Temp_Hum_Batt"        // Change to a fancy name you like
      #define SKETCH_VERSION "2.1"                    // Your version
      DHT dht;
      float lastTemp;
      float lastHum;
      boolean metric = true;
      MyMessage msgbatt(CHILD_ID_BATTERY, V_VOLTAGE);
      //MyMessage msgbatt(CHILD_ID_BATTERY, V_TEXT);
      #define VBAT_PER_BITS 0.0041055718475073313782991202346
      #define VMIN 3.6                                  //  Vmin (radio Min Volt)=1.9V (564v)
      #define VMAX 4.2                                  //  Vmax = (2xAA bat)=3.0V (892v)
        present(CHILD_ID_BATTERY, S_INFO);
        //present(CHILD_ID_BATTERY, S_CUSTOM);
        present(CHILD_ID_HUM, S_HUM);
        if (isnan(temperature)) {
          lastTemp = temperature;
          if (!metric) {
          Serial.print("T: ");
        if (isnan(humidity)) {
            lastHum = humidity;
            Serial.print("H: ");
            Serial.println(humidity);
        batM();
         delay(500);
         // Battery monitoring reading
         delay(500);
         // Calculate the battery in %
         if (batLoop > 2) {
         if (batteryPcnt > 100) {
           batteryPcnt=100;
             msgbatt.set(batteryPcnt ,1);
             batLoop = 0;
           batLoop++;
      My sketch is not working 100% my voltage is not precise, giving me even 221 in percentage while  lipo is at this moment 3.7 volt (simulated with a variable power supply)
      im running it on a nano on 1 lipo cell and a dc dc powerup to 5 volt measuring the lipo voltage with a  divider 1M/470K
      Hope to add a soil moisture sensor and baro sensor in future.
      p.s. any one with some better idea sketch its ver welcome. im just started to experiment with Mysensor
      R fhenrycoF 2 Replies Last reply
      • R Rene046
        @ fhenryco
        DHT dht;
        float lastTemp;
        float lastHum;
            if (!metric) {
              lastHum = humidity;
          batM();
           delay(500);
           delay(500);
           if (batLoop > 2) {
             batteryPcnt=100;
               batLoop = 0;
             batLoop++;
        R
        R
        Rene046
        O i forget to tell im running the latest gateway from Mysensor.
        • R Rene046
          @ fhenryco
          DHT dht;
          float lastTemp;
          float lastHum;
              if (!metric) {
                lastHum = humidity;
            batM();
             delay(500);
             delay(500);
             if (batLoop > 2) {
               batteryPcnt=100;
                 batLoop = 0;
               batLoop++;
          fhenrycoF
          fhenrycoF
          fhenryco
          @Rene046
          not
          but
          send(msgbatt.set(batteryPcnt ,1));
          also may be better to use S_MULTIMETER and V_VOLTAGE (rather than S_INFO and V_TEXT) as adviced by AWI and also 2 decimals hence
          send(msgbatt.set(batteryPcnt ,2));
          • R
            R
            Rene046
            thx i got a voltage log only giving me now -44.000 volt and 212 prct at battery level while measuring 3.7 volt battery and voltage on A0 1.3 volts
            DHT dht;
            float lastTemp;
            float lastHum;
            #define VBAT_PER_BITS 0.0041055718475073313782991202346  // 4.20/1023 volt
            #define VMIN 3.6                                  //  Vmin = 3.6 lipo empty
            #define VMAX 4.2                                  //  Vmax = 4.2 volt lipo full
                if (!metric) {
                  lastHum = humidity;
              batM();
               delay(500);
               delay(500);
               if (batLoop > 2) {
                 batteryPcnt=100;
                   batLoop = 0;
                 batLoop++;
            R AWIA Arnold ŠlepetisA 3 Replies Last reply
            • R Rene046
              DHT dht;
              float lastTemp;
              float lastHum;
                  if (!metric) {
                    lastHum = humidity;
                batM();
                 delay(500);
                 delay(500);
                 if (batLoop > 2) {
                   batteryPcnt=100;
                     batLoop = 0;
                   batLoop++;
              R
              R
              Rene046
              And my serial monitor is going wild .lol
              41815 MCO:SLP:WUP=-1
              Battery percent: 95 %
              Battery Average (Send): -12 %
              45359 !TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=NACK:244
              45403 !TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=1,st=NACK:-12.00
              45410 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
              45415 MCO:SLP:TPD
              45417 MCO:SLP:WUP=-1
              47962 !TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=2,st=NACK:20.0
              T: 20.00
              48007 !TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=3,st=NACK:49.6
              H: 49.60
              Battery percent: -49 %
              49014 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
              49020 MCO:SLP:TPD
              49022 MCO:SLP:WUP=-1
              51567 !TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=4,st=NACK:49.2
              H: 49.20
              Battery percent: -26 %
              52575 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
              52582 MCO:SLP:TPD
              • R
                R
                Rene046
                And it seems like instead of real voltage i seen percentage in the log
                • R Rene046
                  DHT dht;
                  float lastTemp;
                  float lastHum;
                      if (!metric) {
                        lastHum = humidity;
                    batM();
                     delay(500);
                     delay(500);
                     if (batLoop > 2) {
                       batteryPcnt=100;
                         batLoop = 0;
                       batLoop++;
                  AWIA
                  AWIA
                  AWI
                  @Rene046 if you send V_VOLTAGE you should use the voltage level not the percentage.
                  R 1 Reply Last reply
                  • AWIA AWI
                    R
                    R
                    Rene046
                    @AWI
                    hi could you explain how..
                    • R
                      R
                      Rene046
                      I still cant get it to work, No voltage reading or logging.
                      I there nobody trying to build a equal sensor.
                      maybe someone who could rework my sketch. or having a working sketch where i could delete some sensors from.
                      kind regards and greetings from the Netherlands.
                      AWIA 1 Reply Last reply
                      • R Rene046
                        AWIA
                        AWIA
                        AWI
                        @Rene046 I would be happy to help you but need some information on your circuit:
                        • How are you powering your Arduino? Through an (onboard) regulator or directly from battery?
                        • The internal reference can only be used up to 1.1V, you seem to be having a voltage divider which has a resulting voltage of > 1.1 V ?
                        • I do not understand your averaging algorithm, why are you not taking an average of the latest x readings?
                        My suggestion would be to use a different external reference (output of the dc-dc boost converter/ Vcc?) to measure the voltage.
                        • R
                          R
                          Rene046
                          Hi Awi
                          Thanks that you want to help,
                          Im powering it by a lipo battery 1 cell using an dc-dc boost converter to get 5 volts
                          i would like to see what this lipo is doing during a day. this lipo will be charged by an solar panel 6 volt 300ma still waiting for that panel.
                          You are absolutely right with my voltage divider it's at 1.9 volt while lipo is at 4.2 volt
                          I'm not a hero in elektronics , just starting to play with it. so to start i should make an voltage divider that gives me aprox 1,1 volt max at 4,2 volt.
                          I changed the voltages divider now from 270k-100k
                          giving me 1.07 volt at 4.2 volt lipo
                          i'm totally open for any other design you could give, i just used some code from others that was excepted by demoticz.
                          If you like you could send me an sample how you would do it or change my sketch ..
                          today i also received my BMP180 and BH1750 i want to include in the future..
                          • R
                            R
                            Rene046
                            wrote on last edited by AWI
                            #28
                            my serial monitor is now making a bit more cense voltage is about 0,10 volt off
                            but maybe i do something wrong with calculation.
                            percentage is still something wrong with
                            by the way i'm not shure with the low voltage of an 16850 lipo at 3.6 volt ...
                            20412 MCO:SLP:WUP=-1
                            22921 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:17.8
                            T: 17.80
                            22929 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:35.4
                            H: 35.40
                            23939 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.53
                            Battery voltage: 3.53 V
                            Battery percent: -10 %
                            23946 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                            23954 MCO:SLP:TPD
                            23955 MCO:SLP:WUP=-1
                            26465 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:36.1
                            H: 36.10
                            27473 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.52
                            Battery voltage: 3.52 V
                            Battery percent: -12 %
                            27481 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                            27489 MCO:SLP:TPD
                            and here the latest sketch
                            DHT dht;
                            float lastTemp;
                            float lastHum;
                                if (!metric) {
                                  lastHum = humidity;
                              batM();
                               delay(500);
                               delay(500);
                               send(msgbatt.set(Vbat ,2));
                               Serial.print("Battery voltage: "); Serial.print(Vbat); Serial.println(" V");
                               if (batLoop > 2) {
                                 batteryPcnt=100;
                                   batLoop = 0;
                                 batLoop++;
                            • R Rene046
                              T: 17.80
                              H: 35.40
                              23954 MCO:SLP:TPD
                              H: 36.10
                              27489 MCO:SLP:TPD
                              DHT dht;
                              float lastTemp;
                              float lastHum;
                                  if (!metric) {
                                    lastHum = humidity;
                                batM();
                                 delay(500);
                                 delay(500);
                                 if (batLoop > 2) {
                                   batteryPcnt=100;
                                     batLoop = 0;
                                   batLoop++;
                              R
                              R
                              Rene046
                              #29
                              @Rene046 said in reporting battery to domoticZ:
                              im feeding with 3.60 volts at that moment.
                              • R Rene046
                                AWIA
                                AWIA
                                AWI
                                #30
                                @Rene046 The 1.1V internal reference is not calibrated and can be 10% off, So you need to do some calibration yourself.
                                (b.t.w. I cleaned your postings a little. Please make sure you use the code markings in the right way, i.e. put them on a new line). To get you going I rewrote the battery routine. Changes:
                                • no real need to average the readings if you give it time to stabilize.
                                • got rid of the "volt per bit" constant
                                • added a "reference value:" for calibration, you can calculate it from the measured voltage and reported voltage.
                                // battery calculations
                                void batM(){
                                	const float vRef = 4.2/ 1.1 ;							// actual value for max reading, adjust with help of measured voltage
                                	delay(500);
                                	int sensorValue = analogRead(BATTERY_SENSE_PIN);   		// sensorValue is 0..1023 where 1023 == vRef
                                	float vBat = sensorValue * vRef / 1024 ;
                                	send(msgbatt.set(vBat ,2));
                                	Serial.print("Battery voltage: "); Serial.print(vBat); Serial.println(" V");
                                	int batteryPcnt = static_cast<int>(((vBat-VMIN)/(VMAX-VMIN))*100.);
                                	sendBatteryLevel( batteryPcnt) ;
                                • R
                                  R
                                  Rene046
                                  Thanks that looks way better.
                                  I just changed
                                  into
                                  const float vRef = 4.2/ 1.07 ;
                                  because this is what i measure with my multimeter with 4.2 volt battery and measuring my voltage divider i have 1.07 volt
                                  Giving me strange results something must be bad ..... my multimeter ?? it should be closer to 4.2 ? i guess
                                  Battery voltage: 3.92 V
                                  14842 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:53
                                  Battery percent: 53 %
                                  14850 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                  14856 MCO:SLP:TPD
                                  14858 MCO:SLP:WUP=-1
                                  17367 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:19.4
                                  T: 19.40
                                  17376 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:48.5
                                  H: 48.50
                                  17885 TSF:MSG:SEND,2-2-0-0,s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.92
                                  17893 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:53
                                  17900 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                  17906 MCO:SLP:TPD```
                                  • R Rene046
                                    I just changed
                                    into
                                    14856 MCO:SLP:TPD
                                    T: 19.40
                                    H: 48.50
                                    AWIA
                                    AWIA
                                    AWI
                                    @Rene046 You should still compensate for the 1.1 offset. What you should do is calculate the vRef from the measured battery voltage and the real voltage.
                                    • R Rene046
                                      DHT dht;
                                      float lastTemp;
                                      float lastHum;
                                          if (!metric) {
                                            lastHum = humidity;
                                        batM();
                                         delay(500);
                                         delay(500);
                                         if (batLoop > 2) {
                                           batteryPcnt=100;
                                             batLoop = 0;
                                           batLoop++;
                                      Arnold ŠlepetisA
                                      Arnold ŠlepetisA
                                      Arnold Šlepetis
                                      wrote on last edited by Arnold Šlepetis
                                      #33
                                      @Rene046 what resistors do you use to measure battery. VBAT_PER_BITS is not just 4.2/1023. Personally I am using 1m and 300k it gives me up to 4.77V
                                      • Arnold ŠlepetisA Arnold Šlepetis
                                        R
                                        R
                                        Rene046
                                        @Arnold-Šlepetis
                                        Hi im using at this moment what i had.
                                        270k-100k giving me 1.07 volt at 4.2 battery
                                        So i stay save , but ok reading is not giving my wanted 4.2 volt but around 3.92 volt
                                        My nano is feeded by an dc -dc boost converter giving me 5 volt from this 4.2 battery.
                                        @AWI
                                        Sorry im still a noob in this, just understood how to make a voltage diver using 3:1 divider
                                        Could you please give me a simple example how do this calculation.
                                        Arnold ŠlepetisA AWIA 2 Replies Last reply
                                        • R Rene046
                                          @Arnold-Šlepetis
                                          @AWI
                                          Arnold ŠlepetisA
                                          Arnold ŠlepetisA
                                          Arnold Šlepetis
                                          @Rene046
                                          As I understand correct VBAT_PER_BITS is not just 4.2/1032. This depends what resistors do you use. If you use 1m and 470k VBAT_PER_BITS=0.003363075 made from formula and it will never reads more 3.44v.
                                          #define VMIN and #define VMAX 4.2 used only for formula int batteryPcnt = static_cast<int>(((Vbat-VMIN)/(VMAX-VMIN))*100.);
                                          If you use 270k and 100k maximum is 4.07V so will be VBAT_PER_BITS=0.0039784946236559 and not like in your sketch 0.0041055718475073313782991202346
                                          12.5k
