  3. why mysensors is based on nrf24?
65 Posts 13 Posters 21.9k Views 11 Watching
  • N
    N
    napo7
    You're not totally right :
    RFM69 can be used with a raspberry pi, you must use a usb (serial) gateway.
    That's what I'm doing, and I've got very good results : My house is made of outside concrete walls; with my gateway in the middle of my house, I can walk outside 60-70 meters before starting to loose some packets.
    And that's only with a dirty cheap 8cm wire antenna. I'm sure that a better antenna (see GPA-Ground Plane Antenna on internet) will allow some meters better...
    Some people are talking about +1Km ranges with propers antenna.
    I didn't go the NRF24 way because I wanted to use sensors outside the house, and without repeaters that wasn't possible.
    PS : I use 868Mhz RFM modules : using 433 could also rise the range.
    • R Reza
      @hek
      i am trying for PCB design . when i do then share better pic.
      sundberg84S
      sundberg84S
      @Reza - I have currently atleast 30+ nodes based on MySensors and Nrf24l01+ and it works fine!
      Its DIY and sometimes I have to debug and change something - but it works so good I have my house alarm motion sensors using Nrf24l01+ radios. I have nodes which I have not touched for 1 year + and still works great. Compared to any commercial system (which I have to pay 10times as much) im so happy about this!
      Sometimes you get bad radios, and you have to debug and try different capacitors - but thats the fun about it! If someoen wants a quick, plug and play sollution - I would not suggest MySensors because thats not what MySensors are about,
      • alowhumA
        alowhumA
        alowhum
        So far no one has mentioned:
        • MySensors can bridge larger distances by using repeaters.
        • There are high-powered long-range NRF24 radios available. I'm using just one in low-power mode on the gateway, and it's already covering my entire house.
        • C
          C
          chbla
          Why based on nrf24? I came to the party late, but started with RFM69/433 - you are not bound to 2.4ghz in any way, it's just what people used to start with.
          • R
            R
            Reza
            hi all friends . thank you for answer .
            i mean about this , i think the combine mysensors network and domoticz controller is the best home automation . even better than fibaro , vera and etc...
            In addition to the "cheap cost" reason , we are build every thing which we like. build sensors and devices that is not in brands for example my multi sensors. i can increase or decrease my multi sensor with every sensors in one node and one device.... for example i want have a gas and motion in one room and have gas and motion and temp/hum in other room...
            these is excellent feature that there is not in home automation brands...
            so i mean that is with this excellent features , with many trying from mysensors team(for design mysensors core) and members, why there is some weak in connection between !? i dont told nrf is bad ( i use this in my network several model but just a expensive model is work well for me and this is worthy for mysensors library :) other model work a few distance ) but with this excellent library and this excellent idea, nrf is not excellent choise .
            why base of mysensors is not Mhz frequency (315 , 433) ? for report sensors or send command to relay and ack... are we need to Ghz frequency ?
            i dont use RFM69 until now , but if RFM is better than nrf why mysensors is based on nrf? with RFM we are broader scope? with wall and more distance? RFM have repeater feature?and other feature?
            • C
              C
              chbla
              It is not based, you can use a RFM69
              R 1 Reply Last reply
              • R
                R
                Reza
                we can build a network but this is not very easy and choose desired place for our nodes . or we must choose special place for better connection and signaling, or we must use repeater in special place ( perhaps there was not good place or wire power and etc... for repeater) also we must use a arduino and a radio for repeater just for weak in connection. so is this better that we have a connection with for example 20 meter in home with wall and if we want use more than 20 meter we must use repeater...?
                now if i want have just 5 sensor in each corner in my home , for example i need 5 repeater or more :) :)
                now domoticz have a excellent connection with each wifi device. for example milight and etc... so this is worthy that connection in mysensors network will be excellent even if cost will be more ( A little) :)
                • C chbla
                  R
                  R
                  Reza
                  @chbla
                  do you use RFM69? this is work better than nrf? about distance and wall
                  RFM support repeater feature? and we can choose different channel ?
                  • C
                    C
                    chbla
                    I'm using RFM69 yes, and it has no problems.
                    I don't need repeaters at the moment, as far as I know it's software based?
                    AnticimexA 1 Reply Last reply
                    • C chbla
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @chbla you are correct. The radio is fully supported and the repeater feature is a library feature, not a radio feature. It is a feature of the MySensors protocol.
                      • R
                        R
                        Reza
                        thank you friends for answer.
                        about channel? MY_RF24_CHANNEL
                        can we use several channel with RFM ?
                        generally RFM work better than NRF ?
                        AnticimexA C 2 Replies Last reply
                        • R Reza
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @Reza how about you read MyConfig.h?
                          • R Reza
                            C
                            C
                            chbla
                            @Reza it depends on the use case I think, peope are using both, both are working. NRF24 is easier to set up and seems to have more support. Just try it :)
                            • R
                              R
                              Reza
                              wrote on last edited by Reza
                              #29
                              for help to my friends that use NRF. i test several model. but most are not really range.this model was best of NRF. with this model i have connect with 60cm wall and 10meter distance.
                              if you want have a good connection, so use this model:
                              but i think NRF is not worthy mysensors and efforts of mysensors team :pray:
                              • AnticimexA Anticimex
                                R
                                R
                                Reza
                                #30
                                @Anticimex said in why mysensors is based on nrf24?:
                                i am weak in english sorry i know repeater feature is in mysensors library, but i think about channel i think this is just for nrf. is that right ?
                                @chbla i am very happy with mysensors. i have very sensors and relay and every day i am try to build a new sensor and a new devices :) if there was a stronge and good and easy connection so this was very more intresting
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  I think you have missed a couple of details @Reza
                                  When mysensors started out, the cheapest / best approach was to use the nRF24L01, rfm69hw was not available. So the project evolved around this radio. The RFM69 came in at a later time.
                                  Unfortunately a lot of Chinese saw easy money, with counterfeit chips, and started to create less than optimal fake versions. That will probably also happen to rfm69hw (and are probably already there).
                                  So we keep nrf, as it is there in the core.. It's up to you and other hackers, to decide what you want to use
                                    hey dear friend,
                                    be like water ;)
                                    • R Reza
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @Reza If you read MySensors.h you will find what configuration possibilities the various radios have. Try looking for information instead of just begging for it all the time.
                                      • tbowmoT tbowmo
                                        R
                                        R
                                        Reza
                                        @tbowmo
                                        oh thank you for explain :pray: and thank you all mysensors team. really thank you. mysensors is intresting really. i try to found best and easy and without any trouble of solution for connection . we are easy to build all sensors and relay(with mysensors library) so this is intresting more to easy , very easy connection between rooms... :)
                                        again thank you all mysensors team and hero members :pray:
                                        • R Reza
                                          @tbowmo
                                          @Reza so, topic closed?
