  2. Announcements
  3. 💬 Power Meter Pulse Sensor
183 Posts 40 Posters 93.0k Views 37 Watching
  • moumout31M moumout31
    @mfalkvidd void receive(const MyMessage &message) is in the code.
    MySensors library is installed, I already use it in other nodes.
    It's strange because it works in another computer...
    The full error messages, in french beacause I'm french are :
    Arduino : 1.8.0 (Windows 7), Carte : "Arduino Pro or Pro Mini, ATmega328 (3.3V, 8 MHz)"
    _02_Main_loop:271: error: 'MyMessage' does not name a type
    In file included from C:\Users\Anne-Laure\Documents\Arduino\libraries\arduino_759467/MySensors.h:257:0,
                     from C:\Users\Anne-Laure\Dropbox\Maison\A récupérer sur OneDrive\my_teleinfo_light\_02_Main_loop.ino:118:
    C:\Users\Anne-Laure\Documents\Arduino\libraries\arduino_759467/core/MyTransport.cpp: In function 'void transportProcessMessage()':
    C:\Users\Anne-Laure\Documents\Arduino\libraries\arduino_759467/core/MyTransport.cpp:745:14: error: cannot resolve overloaded function 'receive' based on conversion to type 'bool'
       if (receive) {
    C:\Users\Anne-Laure\Documents\Arduino\libraries\arduino_759467/core/MyTransport.cpp:811:15: error: cannot resolve overloaded function 'receive' based on conversion to type 'bool'
        if (receive) {
    exit status 1
    Bibliothèque non valide trouvée dans C:\Users\Anne-Laure\Documents\Arduino\libraries\MySensors : C:\Users\Anne-Laure\Documents\Arduino\libraries\MySensors
    Ce rapport pourrait être plus détaillé avec
    l'option "Afficher les résultats détaillés de la compilation"
    activée dans Fichier -> Préférences.
    Thanks for your help
    @moumout31 My guess is that MyMessage is defined in your sketch, overriding the definition in the MySensors library. Could you post your sketch?
    moumout31M 1 Reply Last reply
      moumout31M
      moumout31M
      moumout31
      @mfalkvidd It's strange... It works with an older version of Arduino software... Thus, the problem is solved ! Thanks
      • moumout31M
        moumout31M
        moumout31
        I don't understand why, but my power meter sensor gives a higher index than the real power meter index after 2 days.
        I think that it counts more pulses than pulses provided by the power meter...
        Does anybody encounter this problem ?
        Can it be cause to bounce for example ?
        Thank you
        gohanG F 2 Replies Last reply
          Thank you
          @moumout31
          could it be getting some light from another source?
            Thank you
            F
            F
            flopp
            @moumout31
            I had same issue, check here for my solution
            https://forum.mysensors.org/topic/4716/two-energy-meter/4
            • Fat FlyF
              Fat FlyF
              Fat Fly
              Hei.
              How to connect arduino to electricity meter pulse out. Not to led.
                @moumout31
                moumout31M
                moumout31M
                moumout31
                @gohan No, the light is always switched off in this room and I tried, when I switch on the light, there is no pulse from the sensor.
                @flopp Thanks for your help. What I see in your topic is that you increase from 10000µs to 40000µs the interval to avoid corrupted interrupts, is that correct ?
                Thank you
                F 1 Reply Last reply
                  Thank you
                  F
                  F
                  flopp
                  @moumout31
                  Yes correct.
                  When I checked with Serial Monitor and some serial.print in different places I could see that arduino registered double interrupts
                  moumout31M 3 Replies Last reply
                  • F flopp
                    @moumout31
                    Yes correct.
                    moumout31M
                    moumout31M
                    moumout31
                    @flopp Thanks a lot, I will try this solution and check if it's better !
                    • F flopp
                      @moumout31
                      Yes correct.
                      moumout31M
                      moumout31M
                      moumout31
                      @flopp It seems to work, index on Domoticz is still consistent with the real index... I will see in a few days if it's still the case.
                      Thanks a lot for your help !
                      • F flopp
                        @moumout31
                        Yes correct.
                        moumout31M
                        moumout31M
                        moumout31
                        @flopp After a few days, I confirm you that the index is consistent with power meter index.
                        However, instant power in watt is not correcly calculated.
                        For example, when power meter indicates 550W, about 1500W is calculated by the sketch. Do you know how I can resolve this problem please ?
                        Thanks a lot !
                          Thanks a lot !
                          F
                          F
                          flopp
                          @moumout31
                          Watt calculation is using time between two interrupts.
                          How often do you send watt?
                          Did you measure watt with a measurement tool How did you get 500 watts from power meter?
                          When you send watt you need to measure exact same second otherwise it will not be correct.
                          • F flopp
                            @moumout31
                            moumout31M
                            moumout31M
                            moumout31
                            @flopp Watt is sent every 20 seconds (as done in the original sketch).
                            500 watts is the power indicated on the screen of the power meter.
                            • NiklasON
                              NiklasON
                              NiklasO
                              wrote on last edited by NiklasO
                              #79
                              Just changed from 1-wire counter to MySensors for logging my power consumption. Using the same LED detector as I did when using 1-wire. Also changed watt limit to 20 000 (my heat pump likes to use 9-10kW sometimes). The wires from the old 1-wire net now provide power for the new MySensors-sensor. I have 10 000 led blinks per kWh. Had som crazy counter values with 1-wire that totally messed up the graphs and haven't seen anything like that with this sketch. Let's hope it stays that way. ;) Dumping data to Domoticz. This sensor gives me higher resolution as a bonus. The 1-wire counter was read every minute, this every 20-sec. ;-)
                              My old 1-wire counter with one crazy value messing upp all the graphs:
                              I know that you can hold shift and click the value that is crazy to make the graphs show up good but you loose the data for the full day. That's not good. ;-)
                              henninneH 1 Reply Last reply
                                Samuel235
                                I seem to be getting a connection to my gateway, while monitoring the two topics for the gateway i only seem to see any activity regarding this sensor on the gateway-out topic, and it keeps sending out a type 2 message (req). The serial monitor of the sensors is showing:
                                104198 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                                114199 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                                124200 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                                134201 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                                144202 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                                154203 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                                164204 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                                174205 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                                184206 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                                194207 TSF:MSG:SEND,16-16-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                                So it seems to be sending a request package, but i don't see it on the gateway-in topic and i see other sensors sending data to the gateway-in topic so i'm not subscribed to the wrong one. Is this a structural request message or is this the feature that requests the last known message from the gateway? Either way, there doesn't seem to be any sensor data being sent from the node to the gateway.
                                MySensors 2.1.1
                                • S Samuel235
                                  sundberg84S
                                  sundberg84S
                                  #81
                                  @Samuel235 said in 💬 Power Meter Pulse Sensor:
                                  I dont know if I dont understand you, but it seems like your node is requesting the last pulse counter. I have mentioned this in several threads I have a problem with this (both this thread and rain sensor thread). Im using an ethernet gw and the request reaches the gw but there my error led blinks and it fails to send it back (or recieve it on the node) so it re-request it.
                                  I have never been able to pinpoint it due to repeaters in between.
                                  https://forum.mysensors.org/topic/2116/hard-to-grab-time-and-value-sent-from-controller/ (old).
                                  S 1 Reply Last reply
                                  • sundberg84S sundberg84
                                    Samuel235
                                    @sundberg84 - You do understand me correctly :). I made a thread on the troubleshooting section of the forum for this simply because i suspected it was normal behaviour, however. It seems that the node isn't sending any other data to the gateway at all and it can not get the previous value as there isn't one. So, my post here and on the troubleshooting section was me aiming to get to this point and then troubleshoot the actual node to see what can be done to get it to send data.
                                    MySensors 2.1.1
                                      Samuel235
                                      Has anyone came across their pulse meter not sending the message for WATT, the other two messages are being sent perfectly fine. My WATT message has been working all day and suddenly stopped.
                                      MySensors 2.1.1
                                      • NiklasON
                                        NiklasON
                                        NiklasO
                                        Make sure that you don't reach your wattage limit in the sketch.
                                        • NiklasON NiklasO
                                          Samuel235
                                          @NiklasO - Where is this value stored? I've cleared the EEPROM and the MQTT topic too, but it still refuses to send the watt value.
                                          MySensors 2.1.1
                                          NiklasON 1 Reply Last reply
