  2. Announcements
  3. 💬 Power Meter Pulse Sensor
183 Posts 40 Posters 93.0k Views 37 Watching
    The guide specifies LM393 Light Sensor or the tsl250r-lf so I thought it was the same since the same name.
    Since the node will be powered with it's power supply, I don't have any battery drain problem in this case. But why did you use a transistor? Can't you just check for a threshold value in the analog input to count as a pulse?
      sundberg84S
      sundberg84S
      #58
      Ok, all I can see is that it doesnt look the same at all.
      @gohan - I tried, and I thought that should work - but for some reason I could not get it to trigger the interupt on the atmega :(
      Looking the the voltage thresholds it was supposed to work but it didnt. I was thinking it was to low uA but i dont know really.
      gohanG 1 Reply Last reply
      • F
        F
        flopp
        This is what I use togeheter with LM393
        https://www.kjell.com/se/sortiment/el-verktyg/elektronik/optokomponenter/ir-dioder-fototransistorer/fototransistor-p90042
        • sundberg84S sundberg84
          wrote on last edited by gohan
          #60
          @sundberg84
          Instead of the 10k resistor, do you think I could use a potentiometer to "adjust" sensitivity? I would like to avoid messing up the readings with lights entering when opening the cabinet door where the meter is located
          @flopp
          Do you mind sharing your wiring? 940nm, isn't it infrared?
          sundberg84S F 2 Replies Last reply
            @sundberg84
            @flopp
            sundberg84S
            sundberg84S
            @gohan - a potentiometer is just a variable resistor so why not? Good idea if you have one laying around.
            As i said before though, the try with the transistor is just a try - im not that good with transistors yet and dont know how they work exactly. After this i read somewhere that the base resistor should be bigger to protect the transistor... dont know how to calculate that.
              @sundberg84
              @flopp
              F
              F
              flopp
              wrote on last edited by flopp
              #62
              @gohan said in 💬 Power Meter Pulse Sensor:
              @sundberg84
              @flopp
              I connected the photo resistor directly to the LM393.
              I don't know if that is IR.
              • moumout31M
                moumout31M
                moumout31
                First, thanks for this tutorial !
                I used the code defined in tutorial but I have the following message for "void receive(const MyMessage &message)" :
                'MyMessage' does not name a type
                Do you know what can be the cause of this error please ?
                Thanks in advance for your help
                • moumout31M moumout31
                  #64
                  @moumout31 do you have void receive(const MyMessage &message) somewhere in your code or where does it come from?
                  Could you post the full error message?
                  Have you installed the MySensors library?
                  moumout31M 1 Reply Last reply
                    moumout31M
                    moumout31M
                    moumout31
                    wrote on last edited by moumout31
                    #65
                    @mfalkvidd void receive(const MyMessage &message) is in the code.
                    MySensors library is installed, I already use it in other nodes.
                    It's strange because it works in another computer...
                    The full error messages, in french beacause I'm french are :
                    Arduino : 1.8.0 (Windows 7), Carte : "Arduino Pro or Pro Mini, ATmega328 (3.3V, 8 MHz)"
                    _02_Main_loop:271: error: 'MyMessage' does not name a type
                    In file included from C:\Users\Anne-Laure\Documents\Arduino\libraries\arduino_759467/MySensors.h:257:0,
                                     from C:\Users\Anne-Laure\Dropbox\Maison\A récupérer sur OneDrive\my_teleinfo_light\_02_Main_loop.ino:118:
                    C:\Users\Anne-Laure\Documents\Arduino\libraries\arduino_759467/core/MyTransport.cpp: In function 'void transportProcessMessage()':
                    C:\Users\Anne-Laure\Documents\Arduino\libraries\arduino_759467/core/MyTransport.cpp:745:14: error: cannot resolve overloaded function 'receive' based on conversion to type 'bool'
                       if (receive) {
                    C:\Users\Anne-Laure\Documents\Arduino\libraries\arduino_759467/core/MyTransport.cpp:811:15: error: cannot resolve overloaded function 'receive' based on conversion to type 'bool'
                        if (receive) {
                    exit status 1
                    Bibliothèque non valide trouvée dans C:\Users\Anne-Laure\Documents\Arduino\libraries\MySensors : C:\Users\Anne-Laure\Documents\Arduino\libraries\MySensors
                    Ce rapport pourrait être plus détaillé avec
                    l'option "Afficher les résultats détaillés de la compilation"
                    activée dans Fichier -> Préférences.
                    Thanks for your help
                         if (receive) {
                          if (receive) {
                      exit status 1
                      @moumout31 My guess is that MyMessage is defined in your sketch, overriding the definition in the MySensors library. Could you post your sketch?
                        moumout31M
                        moumout31M
                        moumout31
                        @mfalkvidd It's strange... It works with an older version of Arduino software... Thus, the problem is solved ! Thanks
                        • moumout31M
                          moumout31M
                          moumout31
                          I don't understand why, but my power meter sensor gives a higher index than the real power meter index after 2 days.
                          I think that it counts more pulses than pulses provided by the power meter...
                          Does anybody encounter this problem ?
                          Can it be cause to bounce for example ?
                          Thank you
                          gohanG F 2 Replies Last reply
                            Thank you
                            @moumout31
                            could it be getting some light from another source?
                              Thank you
                              F
                              F
                              flopp
                              @moumout31
                              I had same issue, check here for my solution
                              https://forum.mysensors.org/topic/4716/two-energy-meter/4
                              • Fat FlyF
                                Fat FlyF
                                Fat Fly
                                Hei.
                                How to connect arduino to electricity meter pulse out. Not to led.
                                  @moumout31
                                  moumout31M
                                  moumout31M
                                  moumout31
                                  @gohan No, the light is always switched off in this room and I tried, when I switch on the light, there is no pulse from the sensor.
                                  @flopp Thanks for your help. What I see in your topic is that you increase from 10000µs to 40000µs the interval to avoid corrupted interrupts, is that correct ?
                                  Thank you
                                  F 1 Reply Last reply
                                    Thank you
                                    F
                                    F
                                    flopp
                                    @moumout31
                                    Yes correct.
                                    When I checked with Serial Monitor and some serial.print in different places I could see that arduino registered double interrupts
                                    moumout31M 3 Replies Last reply
                                    • F flopp
                                      @moumout31
                                      Yes correct.
                                      moumout31M
                                      moumout31M
                                      moumout31
                                      @flopp Thanks a lot, I will try this solution and check if it's better !
                                      • F flopp
                                        @moumout31
                                        Yes correct.
                                        moumout31M
                                        moumout31M
                                        moumout31
                                        @flopp It seems to work, index on Domoticz is still consistent with the real index... I will see in a few days if it's still the case.
                                        Thanks a lot for your help !
                                        • F flopp
                                          @moumout31
                                          Yes correct.
                                          moumout31M
                                          moumout31M
                                          moumout31
                                          @flopp After a few days, I confirm you that the index is consistent with power meter index.
                                          However, instant power in watt is not correcly calculated.
                                          For example, when power meter indicates 550W, about 1500W is calculated by the sketch. Do you know how I can resolve this problem please ?
                                          Thanks a lot !
