  3. Node dont connect to RaspBerry gateway
28 Posts 4 Posters 7.1k Views 4 Watching
  • keldandorinK Offline
    keldandorin
    Hi.
    Need som help here to. I have a Rpi gateway up and running without own sensors. output in Debug mode looks like this.
    pi@RPI:~/MySensors $ sudo mysgw -d
    mysgw: Starting gateway...
    mysgw: MCO:BGN:INIT GW,CP=RNNG--Q,VER=2.2.0-beta
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    mysgw: New connection from 10.1.15.182
    mysgw: Client 0 connected
    mysgw: TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:FPAR REQ,ID=255
    mysgw: TSF:PNG:SEND,TO=0
    mysgw: TSF:CKU:OK
    mysgw: TSF:MSG:GWL OK
    mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    mysgw: TSF:MSG:BC
    mysgw: TSF:CKU:OK,FCTRL
    mysgw: TSF:MSG:BC
    No problem connecting with MYScontroller.
    But I cant get my nodes to connect. I do know they work sins they connected to my Arduino GW with no problem. Need som help here to figure out whats wrong
    Thx
    /Håkan
      https://www.mysensors.org/build/debug
      I'd start from here. Also why are you using beta version instead of the stable one?
        keldandorin
        Node says it cant find parent. And Rpi says everything is ok. Its like it dosent awnser the Node for som reason.
        Is it possible to connect radio module in the wrong way and startup will still initiate OK?
          Have you tried with stable 2.1.1?
          keldandorinK 1 Reply Last reply
            keldandorin
            @gohan hmm why did I get 2.0.0 Beta
            doing
            But still gets Beta version...Sorry n00b to Linux and Rpi is there a better way to get the updateed version?
              It downloaded the development branch instead of the stable one. @hek is it normal?
              • H Offline
                H Offline
                Yes, development is the default branch (and the only one accepting PRs etc).
                If you want to switch to master after cloning the repo, do:
                git checkout master
                  Could be worth adding that command to the guide 😉
                  • H Offline
                    H Offline
                    @gohan
                    What guide?
                    The rpi guide checks out master: https://www.mysensors.org/build/raspberry
                    The contribution guide is focused on creating pull requests, so it naturally uses the default (development).
                      Ah my bad, I didn't see the - - branch master at the end of the line as I'm on mobile 😌
                      • Jeff WilleckeJ Offline
                        Jeff Willecke
                        Try assigning a node ID. Sometimes controllers will provide an ID but the gateway will not. Currently it is using the ID of 255. I think the line of code to add to the sketch is
                        #define node_ID #
                        Where the # at the end is the number of your node. Any value between 1 and 254 should work.
                          keldandorin
                          @gohan hehe N00b misstake thougt --branch Master was referens that the rest downloaded master...have just started to try out git :)
                            keldandorin
                            OK got version 2.1.1 on place on Rpi deffined Node Id but still no luck connecting to Rpi GW :cry:
                            GW Log
                            mysgw: TSF:LRT:OK
                            mysgw: TSM:INIT
                            mysgw: TSF:WUR:MS=0
                            mysgw: MCO:BGN:STP
                            mysgw: TSF:MSG:BC
                            mysgw: TSF:CKU:OK
                            mysgw: TSF:MSG:BC
                            Node Log:
                            3 TSM:INIT
                            4 TSF:WUR:MS=0
                            11 TSM:INIT:TSP OK
                            13 TSM:FPAR
                            15 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            2022 !TSM:FPAR:NO REPLY
                            2024 TSM:FPAR
                            2026 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            4034 !TSM:FPAR:NO REPLY
                            4036 TSM:FPAR
                            4038 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            6046 !TSM:FPAR:NO REPLY
                            6048 TSM:FPAR
                            6050 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            8058 !TSM:FPAR:FAIL
                            8059 TSM:FAIL:CNT=1
                            8061 TSM:FAIL:PDT
                            Going to replace radio and try again.
                              Double check node ID, I don't see it in node log
                                keldandorin
                                @gohan Changed radio on Rpi
                                and node log looks like this now, Forgot MY_ before node :smile:
                                3 TSM:INIT
                                4 TSF:WUR:MS=0
                                11 TSM:INIT:TSP OK
                                13 TSM:INIT:STATID=2
                                18 TSF:SID:OK,ID=2
                                19 TSM:FPAR
                                55 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                2063 !TSM:FPAR:NO REPLY
                                2065 TSM:FPAR
                                2101 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                4108 !TSM:FPAR:NO REPLY
                                4110 TSM:FPAR
                                4146 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                6153 !TSM:FPAR:NO REPLY
                                6155 TSM:FPAR
                                6191 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                8198 !TSM:FPAR:FAIL
                                8199 TSM:FAIL:CNT=1
                                8201 TSM:FAIL:PDT
                                • keldandorinK keldandorin
                                  3 TSM:INIT
                                  4 TSF:WUR:MS=0
                                  11 TSM:INIT:TSP OK
                                  18 TSF:SID:OK,ID=2
                                  19 TSM:FPAR
                                  2065 TSM:FPAR
                                  4110 TSM:FPAR
                                  6155 TSM:FPAR
                                  8198 !TSM:FPAR:FAIL
                                  8199 TSM:FAIL:CNT=1
                                  8201 TSM:FAIL:PDT
                                  keldandorin
                                  @keldandorin Looks like I get som data to GW now but it dosent connect. Node has ID 3
                                  mysgw: TSF:MSG:BC
                                  mysgw: TSF:MSG:FPAR REQ,ID=3
                                  mysgw: !TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                                  mysgw: TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                  mysgw: TSF:MSG:BC
                                    Do you have cap on the radio?
                                      keldandorin
                                      @gohan yes
                                        @gohan yes
                                        keldandorin
                                        @keldandorin If I pars log from GW it says
                                        Sent Message
                                        Sender: 0
                                        Last Node: 0
                                        Next Node: 3
                                        Destination: 3
                                        Sensor Id: 255
                                        Command: INTERNAL
                                        Message Type:I_FIND_PARENT_RESPONSE
                                        Payload Type: P_BYTE
                                        Payload Length: 1
                                        Signing: 0
                                        Failed uplink counter: 0
                                        Status: NACK (OK=success, NACK=no radio ACK received)
                                        Payload: 0
                                        Just like its acctualy responding to Node !
                                        But the node dosent like the awnser
                                          keldandorin
                                          Hi guys, realy need som help here. Got my Rpi gateway up and running and logfile looks ok, see below.
                                          have a working Node running with DTH22. (know its working sins its conenct to my Arduino GW)
                                          Tryed to onfigured Node Id on node. Connecting to my RpiGW with MYScontroller and can see the gateway but no nodes connect.
                                          Log on PRI looks like this
                                          mysgw: TSF:LRT:OK
                                          mysgw: TSM:INIT
                                          mysgw: TSF:WUR:MS=0
                                          mysgw: MCO:BGN:STP
                                          mysgw: TSF:MSG:BC
                                          Log on Node like this
                                          3 TSM:INIT
                                          4 TSF:WUR:MS=0
                                          11 TSM:INIT:TSP OK
                                          13 TSM:INIT:STATID=3
                                          14 TSF:SID:OK,ID=3
                                          16 TSM:FPAR
                                          52 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          2059 !TSM:FPAR:NO REPLY
                                          2061 TSM:FPAR
                                          2097 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          4104 !TSM:FPAR:NO REPLY
                                          4106 TSM:FPAR
                                          4142 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          6149 !TSM:FPAR:NO REPLY
                                          6151 TSM:FPAR
                                          6187 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          8194 !TSM:FPAR:FAIL
                                          8195 TSM:FAIL:CNT=1
                                          8197 TSM:FAIL:PDT
                                          From my basic understanding it looks like the GW dont responding in the correct way or the node dont like the awnser. Anyone with more experince out there that can give me some ideas how to fix this.
                                          Thx
                                          /Håkan
                                          12.2k
