  3. What's the best PIR sensor?
45 Posts 13 Posters 34.2k Views 9 Watching
    Visonic sells the 2000C/PC PIR sensor, which consumes 4uA at 9v but costs around $65 plus shipping. It's a fully built sensor though and so hookup would be very easy. Likewise the Opotex EX-35R claims to consume 3.5uA while in standby (http://www.securitywarehouse.co.uk/brochure/EX_35 series.pdf) It can be had for about $40 plus shipping. Or there's the VX-402R, which I've previously owned (the plastic yellowed markedly from sun UV) for >$100 and it claims to consume <10uA: https://www.google.com/search?q=vx-402r&newwindow=1&biw=1280&bih=554&tbm=isch&source=lnms&sa=X&ved=0CHsQ_AUoAWoVChMIjLKC567WxwIVwpMNCh2jagOS#imgrc=V9ZE8BKtwmzC5M%3A
    Here's a youtube on how to connect the VX-402R wirelessly: https://www.youtube.com/watch?v=30G5iMZ6sxQ
      Here's another one to add to the list: IRS-B340ST02
      Used here: http://advanceddevices.com/sites/default/files/documents/AN311_MOTION_SENSOR_BASED_ON_STM300.pdf
      In addition, Honeywell claims up to a 7 year battery life (from just one CR123 3v Lithium battery) for its PIR: http://library.ademconet.com/MWT/fs2/5800PIR-RES/5800PIR-Series-Data-sheet.PDF
      Not bad.
      • pyrodetectorP
        pyrodetectorP
        pyrodetector
        Hello.
        It is not a question which PIR sensor is the best. The question is that who will sell it to you? There are a number of manufacturers which produce high-end pyroelectric detectors, but they don't sell them to private persons. Good quality lithium tantalate pyroelectric detector which you can use in instrumentation, costs approximately from 150 to 500 USD, and even higher. I know one supplier who sells their products worldwide. That is
        http://silverlight.ch/order_detectors.php
        Choose the last detector Model 446M2-3 and you will be happy. This is a "BMW" pyroelectric detector. If you have a bag of money, you, probably, can order "BMW" detectors from these people
        http://www.scitec.uk.com/infrared_detectors/irsensors_ordering.php?Submit1=Buy+Now
        In general, lithium tantalate pyroelectric detectors are not sold to private persons. Mouser, Farnell, and other distributors do not sell such things. They can sell only cheap detectors based on ceramics that are unable to be used in instrumentation.
        If you have questions about pyroelectric detectors, I may try to help you. Contact me at
        https://sites.google.com/site/pyrodetector/
        My research relates to mathematical modelling of pyroelectric detectors. I develop simulators for "BMW" detectors.
        I hope, this helps.
        Kind regards.
        • alexsh1A
          alexsh1A
          alexsh1
          By far the best PIR is Panasonic EKMB1201111 - 2uA
          The problem is the price
            the good question would be "what is the best pir sensor with an affordable price" that can be used for DIY :)
            • pyrodetectorP
              pyrodetectorP
              pyrodetector
              If you want to do a thing by yourself, with a PIR sensor being cheap, you had better choose a PIR sensor from this manufacturer
              http://kube.ch/pyroelectric/index.php
              Read how they test their PIR sensors under humid environmental conditions
              http://kube.ch/downloads/pdf/kube_sensors_stability.pdf
              If a sensor is extremely cheap and is not sealed properly, moisture when comes in, just short-circuit the high-megohm pyroelectric sensitive element. No need to explain further...
              You can buy a high-quality ceramic PIR sensor from KUBE for less than 10 euro. Lower price (10 euro for a bag full of PIR sensors) will give the low quality. You will be upset from the low quality longer than happy from the low price.
              alexsh1A 1 Reply Last reply
              • pyrodetectorP pyrodetector
                alexsh1A
                alexsh1A
                alexsh1
                @pyrodetector it is €50 for a demonstrator
                Wow! I'll stick to Panasonic :-)
                gohanG pyrodetectorP 2 Replies Last reply
                • alexsh1A alexsh1
                  @alexsh1 Panasonic is around 20€ just for sensor, then you will have to build the pcb with all components, right?
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @gohan sure, I got mine for $19 plus components and the case. And if you consider a good quality 3D printed case l, it is alone can be €15-20.
                    However, my PIR is nowhere near €50 given that all other components are cheap. I am only using it indoors. All I'm trying to say is that €50 is a level of z-wave devices. Aeon Multisensor is €55 - you get 6-in-1 sensor and not just PIR
                      Agreed, over 50€ is price range for commercial zwave (or similar) products and you would not even get near the level of compactness with a DIY cheaper solution
                        @gohan
                        depends what you mean by diy ;)
                        if this is using cheap ali modules and stacking them, i agree. Else, soon, let me show how it can be more tiny :) That said rev1 of my multisensors is already tiny.
                          If you can make a comparable multisensor like the fibaro motion sensor with a 2 years battery life, I'm happy for you :D
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @gohan yeah, major limitation for me is designing and printing a nice enclosure. I have recently finished a Geiger sensor. Cost of parts is not massive. The most expensive was the Geiger-Muller tube - £15. Printing an enclosure in SLS was £55. Ouch!!!
                            It does look nice, but the cost is just prohibitive
                            gohanG 1 Reply Last reply
                            • alexsh1A alexsh1
                              @alexsh1 agreed, with today's cost of a rather cheap 3D printer, you could repay it within 15-20 printed boxes :D
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @gohan not in SLS. If you have to have a final product, the cost of printer is way too high. Needless to say that it looks like Xerox back in the 1980s :-)
                                  Over here we are mostly talking about DIY stuff, and many times don't even have a box, so an ABS 3D printed box is close enough for a final product :D
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @gohan perhaps it is me, but I'm perfectionist. If I have a node, it has to be perfect. And as a final product, that's the way it should be. When designing a prototype, ABS/PLA is fine, but it does not look like a finished product. Sorry
                                    • alexsh1A alexsh1
                                      pyrodetectorP
                                      pyrodetectorP
                                      pyrodetector
                                      @alexsh1 Why do you need a 50 euro demonstrator? A PIR sensor has 3 outputs: +, output, common. There is a 47K resistor between output and common. The circuit of an alarm sensor is very simple. Next, you can either make an alarm sensor using a circuit for example taken from here
                                      http://unhas.ac.id/tahir/BAHAN-KULIAH/ELIN/NEW/AlarmSensorandSecurityCircuitCookbook.pdf
                                      page 230 (you can use any ceramic PIR sensor instead of Model 5192 on lithium tantalate described by the author), or connect it directly to an A/D converter, and "play digits".
                                      You can order good quality dual ceramic PIR sensors at kube.ch or
                                      http://www.excelitas.com/Pages/Product/Pyroelectric-Detectors-and-Sensors.aspx
                                      Remember that no name manufacturers give no name quality.
                                      Want to know more about how PIR sensors work? Feel free to ask me.
                                      If I am skilled (if your question relates to a PIR sensor itself), I will help. Otherwise, I may try to help you, at least, by saying what I think about your problem. Good luck:)
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        #28
                                        @pyrodetector that was exactly my point. Way too expensive
                                        I have checked the web-site your provided and I can see their prices for PIRs are not too bad (exVAT and exWorks):
                                        http://kube.ch/downloads/pdf/kube_pricelist.pdf
                                        pyrodetectorP 1 Reply Last reply
                                        • alexsh1A alexsh1
                                          pyrodetectorP
                                          pyrodetectorP
                                          pyrodetector
                                          @alexsh1 Happy to been helpful:) But, remember if you want to apply a PIR sensor in instrumentation, you have to use lithium tantalate pyroelectric detector rather than simple ceramic one. Ask me before.
