  3. What's the best PIR sensor?
45 Posts 13 Posters 34.2k Views 9 Watching
    Here's another one to add to the list: IRS-B340ST02
    Used here: http://advanceddevices.com/sites/default/files/documents/AN311_MOTION_SENSOR_BASED_ON_STM300.pdf
    In addition, Honeywell claims up to a 7 year battery life (from just one CR123 3v Lithium battery) for its PIR: http://library.ademconet.com/MWT/fs2/5800PIR-RES/5800PIR-Series-Data-sheet.PDF
    Not bad.
    • pyrodetectorP
      pyrodetectorP
      pyrodetector
      Hello.
      It is not a question which PIR sensor is the best. The question is that who will sell it to you? There are a number of manufacturers which produce high-end pyroelectric detectors, but they don't sell them to private persons. Good quality lithium tantalate pyroelectric detector which you can use in instrumentation, costs approximately from 150 to 500 USD, and even higher. I know one supplier who sells their products worldwide. That is
      http://silverlight.ch/order_detectors.php
      Choose the last detector Model 446M2-3 and you will be happy. This is a "BMW" pyroelectric detector. If you have a bag of money, you, probably, can order "BMW" detectors from these people
      http://www.scitec.uk.com/infrared_detectors/irsensors_ordering.php?Submit1=Buy+Now
      In general, lithium tantalate pyroelectric detectors are not sold to private persons. Mouser, Farnell, and other distributors do not sell such things. They can sell only cheap detectors based on ceramics that are unable to be used in instrumentation.
      If you have questions about pyroelectric detectors, I may try to help you. Contact me at
      https://sites.google.com/site/pyrodetector/
      My research relates to mathematical modelling of pyroelectric detectors. I develop simulators for "BMW" detectors.
      I hope, this helps.
      Kind regards.
      • alexsh1A
        alexsh1A
        alexsh1
        By far the best PIR is Panasonic EKMB1201111 - 2uA
        The problem is the price
          the good question would be "what is the best pir sensor with an affordable price" that can be used for DIY :)
          • pyrodetectorP
            pyrodetectorP
            pyrodetector
            If you want to do a thing by yourself, with a PIR sensor being cheap, you had better choose a PIR sensor from this manufacturer
            http://kube.ch/pyroelectric/index.php
            Read how they test their PIR sensors under humid environmental conditions
            http://kube.ch/downloads/pdf/kube_sensors_stability.pdf
            If a sensor is extremely cheap and is not sealed properly, moisture when comes in, just short-circuit the high-megohm pyroelectric sensitive element. No need to explain further...
            You can buy a high-quality ceramic PIR sensor from KUBE for less than 10 euro. Lower price (10 euro for a bag full of PIR sensors) will give the low quality. You will be upset from the low quality longer than happy from the low price.
            alexsh1A 1 Reply Last reply
            • pyrodetectorP pyrodetector
              alexsh1A
              alexsh1A
              alexsh1
              @pyrodetector it is €50 for a demonstrator
              Wow! I'll stick to Panasonic :-)
              gohanG pyrodetectorP 2 Replies Last reply
              • alexsh1A alexsh1
                @alexsh1 Panasonic is around 20€ just for sensor, then you will have to build the pcb with all components, right?
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @gohan sure, I got mine for $19 plus components and the case. And if you consider a good quality 3D printed case l, it is alone can be €15-20.
                  However, my PIR is nowhere near €50 given that all other components are cheap. I am only using it indoors. All I'm trying to say is that €50 is a level of z-wave devices. Aeon Multisensor is €55 - you get 6-in-1 sensor and not just PIR
                    Agreed, over 50€ is price range for commercial zwave (or similar) products and you would not even get near the level of compactness with a DIY cheaper solution
                      @gohan
                      depends what you mean by diy ;)
                      if this is using cheap ali modules and stacking them, i agree. Else, soon, let me show how it can be more tiny :) That said rev1 of my multisensors is already tiny.
                        If you can make a comparable multisensor like the fibaro motion sensor with a 2 years battery life, I'm happy for you :D
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @gohan yeah, major limitation for me is designing and printing a nice enclosure. I have recently finished a Geiger sensor. Cost of parts is not massive. The most expensive was the Geiger-Muller tube - £15. Printing an enclosure in SLS was £55. Ouch!!!
                          It does look nice, but the cost is just prohibitive
                          gohanG 1 Reply Last reply
                          • alexsh1A alexsh1
                            @alexsh1 agreed, with today's cost of a rather cheap 3D printer, you could repay it within 15-20 printed boxes :D
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @gohan not in SLS. If you have to have a final product, the cost of printer is way too high. Needless to say that it looks like Xerox back in the 1980s :-)
                                Over here we are mostly talking about DIY stuff, and many times don't even have a box, so an ABS 3D printed box is close enough for a final product :D
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @gohan perhaps it is me, but I'm perfectionist. If I have a node, it has to be perfect. And as a final product, that's the way it should be. When designing a prototype, ABS/PLA is fine, but it does not look like a finished product. Sorry
                                  • alexsh1A alexsh1
                                    pyrodetectorP
                                    pyrodetectorP
                                    pyrodetector
                                    @alexsh1 Why do you need a 50 euro demonstrator? A PIR sensor has 3 outputs: +, output, common. There is a 47K resistor between output and common. The circuit of an alarm sensor is very simple. Next, you can either make an alarm sensor using a circuit for example taken from here
                                    http://unhas.ac.id/tahir/BAHAN-KULIAH/ELIN/NEW/AlarmSensorandSecurityCircuitCookbook.pdf
                                    page 230 (you can use any ceramic PIR sensor instead of Model 5192 on lithium tantalate described by the author), or connect it directly to an A/D converter, and "play digits".
                                    You can order good quality dual ceramic PIR sensors at kube.ch or
                                    http://www.excelitas.com/Pages/Product/Pyroelectric-Detectors-and-Sensors.aspx
                                    Remember that no name manufacturers give no name quality.
                                    Want to know more about how PIR sensors work? Feel free to ask me.
                                    If I am skilled (if your question relates to a PIR sensor itself), I will help. Otherwise, I may try to help you, at least, by saying what I think about your problem. Good luck:)
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      #28
                                      @pyrodetector that was exactly my point. Way too expensive
                                      I have checked the web-site your provided and I can see their prices for PIRs are not too bad (exVAT and exWorks):
                                      http://kube.ch/downloads/pdf/kube_pricelist.pdf
                                      pyrodetectorP 1 Reply Last reply
                                      • alexsh1A alexsh1
                                        pyrodetectorP
                                        pyrodetectorP
                                        pyrodetector
                                        @alexsh1 Happy to been helpful:) But, remember if you want to apply a PIR sensor in instrumentation, you have to use lithium tantalate pyroelectric detector rather than simple ceramic one. Ask me before.
                                          Here are two with allegedly low quiescent currents:
                                          1. Allegedly <50ua. http://www.ebay.com/itm/Adjust-IR-Pyroelectric-Infrared-IR-PIR-Motion-Sensor-Detector-Module-HC-SR501-/310574919531?pt=LH_DefaultDomain_0&hash=item484fb52f6b&tfrom=201385366787&tpos=unknow&ttype=price&talgo=origal
                                          2. Allegedly <60ua. http://www.ebay.com/itm/HC-SR505-Mini-Infrared-PIR-Motion-Sensor-Precise-Infrared-Detector-Module-/201322916809?pt=LH_DefaultDomain_0&hash=item2edfc7ebc9&tfrom=201385366787&tpos=unknow&ttype=price&talgo=origal
                                          Other PIR sensors?
                                          Anyone have experience with either one? Any opinions as to which of the two is the better PIR sensor?
                                          mar.conteM
                                          mar.conteM
                                          mar.conte
                                          Hi
                                          I just ordered a pir of panasonic Papirs series and even a parallax'll let you know
                                          M.C.
