  3. What's the best PIR sensor?
45 Posts 13 Posters 34.2k Views 9 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    By far the best PIR is Panasonic EKMB1201111 - 2uA
    The problem is the price
      the good question would be "what is the best pir sensor with an affordable price" that can be used for DIY :)
      • pyrodetectorP
        pyrodetectorP
        pyrodetector
        If you want to do a thing by yourself, with a PIR sensor being cheap, you had better choose a PIR sensor from this manufacturer
        http://kube.ch/pyroelectric/index.php
        Read how they test their PIR sensors under humid environmental conditions
        http://kube.ch/downloads/pdf/kube_sensors_stability.pdf
        If a sensor is extremely cheap and is not sealed properly, moisture when comes in, just short-circuit the high-megohm pyroelectric sensitive element. No need to explain further...
        You can buy a high-quality ceramic PIR sensor from KUBE for less than 10 euro. Lower price (10 euro for a bag full of PIR sensors) will give the low quality. You will be upset from the low quality longer than happy from the low price.
        alexsh1A 1 Reply Last reply
        • pyrodetectorP pyrodetector
          alexsh1A
          alexsh1A
          alexsh1
          @pyrodetector it is €50 for a demonstrator
          Wow! I'll stick to Panasonic :-)
          gohanG pyrodetectorP 2 Replies Last reply
          • alexsh1A alexsh1
            @alexsh1 Panasonic is around 20€ just for sensor, then you will have to build the pcb with all components, right?
              alexsh1A
              alexsh1A
              alexsh1
              @gohan sure, I got mine for $19 plus components and the case. And if you consider a good quality 3D printed case l, it is alone can be €15-20.
              However, my PIR is nowhere near €50 given that all other components are cheap. I am only using it indoors. All I'm trying to say is that €50 is a level of z-wave devices. Aeon Multisensor is €55 - you get 6-in-1 sensor and not just PIR
                Agreed, over 50€ is price range for commercial zwave (or similar) products and you would not even get near the level of compactness with a DIY cheaper solution
                  @gohan
                  depends what you mean by diy ;)
                  if this is using cheap ali modules and stacking them, i agree. Else, soon, let me show how it can be more tiny :) That said rev1 of my multisensors is already tiny.
                    If you can make a comparable multisensor like the fibaro motion sensor with a 2 years battery life, I'm happy for you :D
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @gohan yeah, major limitation for me is designing and printing a nice enclosure. I have recently finished a Geiger sensor. Cost of parts is not massive. The most expensive was the Geiger-Muller tube - £15. Printing an enclosure in SLS was £55. Ouch!!!
                      It does look nice, but the cost is just prohibitive
                      gohanG 1 Reply Last reply
                      • alexsh1A alexsh1
                        @alexsh1 agreed, with today's cost of a rather cheap 3D printer, you could repay it within 15-20 printed boxes :D
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @gohan not in SLS. If you have to have a final product, the cost of printer is way too high. Needless to say that it looks like Xerox back in the 1980s :-)
                            Over here we are mostly talking about DIY stuff, and many times don't even have a box, so an ABS 3D printed box is close enough for a final product :D
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @gohan perhaps it is me, but I'm perfectionist. If I have a node, it has to be perfect. And as a final product, that's the way it should be. When designing a prototype, ABS/PLA is fine, but it does not look like a finished product. Sorry
                              • alexsh1A alexsh1
                                pyrodetectorP
                                pyrodetectorP
                                pyrodetector
                                @alexsh1 Why do you need a 50 euro demonstrator? A PIR sensor has 3 outputs: +, output, common. There is a 47K resistor between output and common. The circuit of an alarm sensor is very simple. Next, you can either make an alarm sensor using a circuit for example taken from here
                                http://unhas.ac.id/tahir/BAHAN-KULIAH/ELIN/NEW/AlarmSensorandSecurityCircuitCookbook.pdf
                                page 230 (you can use any ceramic PIR sensor instead of Model 5192 on lithium tantalate described by the author), or connect it directly to an A/D converter, and "play digits".
                                You can order good quality dual ceramic PIR sensors at kube.ch or
                                http://www.excelitas.com/Pages/Product/Pyroelectric-Detectors-and-Sensors.aspx
                                Remember that no name manufacturers give no name quality.
                                Want to know more about how PIR sensors work? Feel free to ask me.
                                https://sites.google.com/site/pyrodetector/
                                If I am skilled (if your question relates to a PIR sensor itself), I will help. Otherwise, I may try to help you, at least, by saying what I think about your problem. Good luck:)
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  #28
                                  @pyrodetector that was exactly my point. Way too expensive
                                  I have checked the web-site your provided and I can see their prices for PIRs are not too bad (exVAT and exWorks):
                                  http://kube.ch/downloads/pdf/kube_pricelist.pdf
                                  pyrodetectorP 1 Reply Last reply
                                  • alexsh1A alexsh1
                                    pyrodetectorP
                                    pyrodetectorP
                                    pyrodetector
                                    @alexsh1 Happy to been helpful:) But, remember if you want to apply a PIR sensor in instrumentation, you have to use lithium tantalate pyroelectric detector rather than simple ceramic one. Ask me before.
                                      Here are two with allegedly low quiescent currents:
                                      1. Allegedly <50ua. http://www.ebay.com/itm/Adjust-IR-Pyroelectric-Infrared-IR-PIR-Motion-Sensor-Detector-Module-HC-SR501-/310574919531?pt=LH_DefaultDomain_0&hash=item484fb52f6b&tfrom=201385366787&tpos=unknow&ttype=price&talgo=origal
                                      2. Allegedly <60ua. http://www.ebay.com/itm/HC-SR505-Mini-Infrared-PIR-Motion-Sensor-Precise-Infrared-Detector-Module-/201322916809?pt=LH_DefaultDomain_0&hash=item2edfc7ebc9&tfrom=201385366787&tpos=unknow&ttype=price&talgo=origal
                                      Other PIR sensors?
                                      Anyone have experience with either one? Any opinions as to which of the two is the better PIR sensor?
                                      mar.conteM
                                      mar.conteM
                                      mar.conte
                                      Hi
                                      I just ordered a pir of panasonic Papirs series and even a parallax'll let you know
                                      M.C.
                                      • mar.conteM mar.conte
                                        Hi
                                        @mar.conte
                                        Great!
                                        • Nca78N
                                          I have received:
                                          • AM312 based complete PIR sensors, basic sensor with Vcc, GND and output. Claimed consumption on datasheet 20µA.
                                          • AM612 PIR sensors (sensors only). This include all the circuitry in the metal cap, so you only have to add basic components like caps and resistors to set parameters: sensibility, trigger duration. Claimed consumption on datasheet: 15uA.
                                          I'll try to test them this week to first see if the claims are true (or at least, not too optimistic :D ) on power consumption, then I'll make some basic sensors to check range and stability for a while.
