  3. What's the best PIR sensor?
45 Posts 13 Posters 34.2k Views 9 Watching
  • pyrodetectorP pyrodetector
    "what is the best pir sensor with an affordable price" that can be used for DIY
    If you want to do a thing by yourself, with a PIR sensor being cheap, you had better choose a PIR sensor from this manufacturer
    http://kube.ch/pyroelectric/index.php
    Read how they test their PIR sensors under humid environmental conditions
    http://kube.ch/downloads/pdf/kube_sensors_stability.pdf
    If a sensor is extremely cheap and is not sealed properly, moisture when comes in, just short-circuit the high-megohm pyroelectric sensitive element. No need to explain further...
    You can buy a high-quality ceramic PIR sensor from KUBE for less than 10 euro. Lower price (10 euro for a bag full of PIR sensors) will give the low quality. You will be upset from the low quality longer than happy from the low price.
    alexsh1A
    alexsh1A
    alexsh1
    @pyrodetector it is €50 for a demonstrator
    Wow! I'll stick to Panasonic :-)
    gohanG pyrodetectorP 2 Replies Last reply
    • alexsh1A alexsh1
      @alexsh1 Panasonic is around 20€ just for sensor, then you will have to build the pcb with all components, right?
      alexsh1A 1 Reply Last reply
        alexsh1A
        alexsh1A
        alexsh1
        @gohan sure, I got mine for $19 plus components and the case. And if you consider a good quality 3D printed case l, it is alone can be €15-20.
        However, my PIR is nowhere near €50 given that all other components are cheap. I am only using it indoors. All I'm trying to say is that €50 is a level of z-wave devices. Aeon Multisensor is €55 - you get 6-in-1 sensor and not just PIR
          Agreed, over 50€ is price range for commercial zwave (or similar) products and you would not even get near the level of compactness with a DIY cheaper solution
            @gohan
            depends what you mean by diy ;)
            if this is using cheap ali modules and stacking them, i agree. Else, soon, let me show how it can be more tiny :) That said rev1 of my multisensors is already tiny.
              If you can make a comparable multisensor like the fibaro motion sensor with a 2 years battery life, I'm happy for you :D
                alexsh1A
                alexsh1A
                alexsh1
                @gohan yeah, major limitation for me is designing and printing a nice enclosure. I have recently finished a Geiger sensor. Cost of parts is not massive. The most expensive was the Geiger-Muller tube - £15. Printing an enclosure in SLS was £55. Ouch!!!
                It does look nice, but the cost is just prohibitive
                gohanG 1 Reply Last reply
                • alexsh1A alexsh1
                  @alexsh1 agreed, with today's cost of a rather cheap 3D printer, you could repay it within 15-20 printed boxes :D
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @gohan not in SLS. If you have to have a final product, the cost of printer is way too high. Needless to say that it looks like Xerox back in the 1980s :-)
                      Over here we are mostly talking about DIY stuff, and many times don't even have a box, so an ABS 3D printed box is close enough for a final product :D
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @gohan perhaps it is me, but I'm perfectionist. If I have a node, it has to be perfect. And as a final product, that's the way it should be. When designing a prototype, ABS/PLA is fine, but it does not look like a finished product. Sorry
                        • alexsh1A alexsh1
                          pyrodetectorP
                          pyrodetectorP
                          pyrodetector
                          @alexsh1 Why do you need a 50 euro demonstrator? A PIR sensor has 3 outputs: +, output, common. There is a 47K resistor between output and common. The circuit of an alarm sensor is very simple. Next, you can either make an alarm sensor using a circuit for example taken from here
                          http://unhas.ac.id/tahir/BAHAN-KULIAH/ELIN/NEW/AlarmSensorandSecurityCircuitCookbook.pdf
                          page 230 (you can use any ceramic PIR sensor instead of Model 5192 on lithium tantalate described by the author), or connect it directly to an A/D converter, and "play digits".
                          You can order good quality dual ceramic PIR sensors at kube.ch or
                          http://www.excelitas.com/Pages/Product/Pyroelectric-Detectors-and-Sensors.aspx
                          Remember that no name manufacturers give no name quality.
                          Want to know more about how PIR sensors work? Feel free to ask me.
                          https://sites.google.com/site/pyrodetector/
                          If I am skilled (if your question relates to a PIR sensor itself), I will help. Otherwise, I may try to help you, at least, by saying what I think about your problem. Good luck:)
                            alexsh1A
                            alexsh1A
                            alexsh1
                            #28
                            @pyrodetector that was exactly my point. Way too expensive
                            I have checked the web-site your provided and I can see their prices for PIRs are not too bad (exVAT and exWorks):
                            http://kube.ch/downloads/pdf/kube_pricelist.pdf
                            pyrodetectorP 1 Reply Last reply
                            • alexsh1A alexsh1
                              pyrodetectorP
                              pyrodetectorP
                              pyrodetector
                              @alexsh1 Happy to been helpful:) But, remember if you want to apply a PIR sensor in instrumentation, you have to use lithium tantalate pyroelectric detector rather than simple ceramic one. Ask me before.
                                Here are two with allegedly low quiescent currents:
                                1. Allegedly <50ua. http://www.ebay.com/itm/Adjust-IR-Pyroelectric-Infrared-IR-PIR-Motion-Sensor-Detector-Module-HC-SR501-/310574919531?pt=LH_DefaultDomain_0&hash=item484fb52f6b&tfrom=201385366787&tpos=unknow&ttype=price&talgo=origal
                                2. Allegedly <60ua. http://www.ebay.com/itm/HC-SR505-Mini-Infrared-PIR-Motion-Sensor-Precise-Infrared-Detector-Module-/201322916809?pt=LH_DefaultDomain_0&hash=item2edfc7ebc9&tfrom=201385366787&tpos=unknow&ttype=price&talgo=origal
                                Other PIR sensors?
                                Anyone have experience with either one? Any opinions as to which of the two is the better PIR sensor?
                                mar.conteM
                                mar.conteM
                                mar.conte
                                Hi
                                I just ordered a pir of panasonic Papirs series and even a parallax'll let you know
                                M.C.
                                • mar.conteM mar.conte
                                  Hi
                                  @mar.conte
                                  Great!
                                  • Nca78N
                                    I have received:
                                    • AM312 based complete PIR sensors, basic sensor with Vcc, GND and output. Claimed consumption on datasheet 20µA.
                                    • AM612 PIR sensors (sensors only). This include all the circuitry in the metal cap, so you only have to add basic components like caps and resistors to set parameters: sensibility, trigger duration. Claimed consumption on datasheet: 15uA.
                                    I'll try to test them this week to first see if the claims are true (or at least, not too optimistic :D ) on power consumption, then I'll make some basic sensors to check range and stability for a while.
                                    • pyrodetectorP
                                      pyrodetectorP
                                      pyrodetector
                                      I have published the brochure in which I tested the eleven pyroelectric detectors from different manufacturers, pyroelectric materials, and electrical connections - both parallel and serial. I tested them under the same conditions. I hope this helps. Feel free to ask the questions:)
                                        @pyrodetector said in What's the best PIR sensor?:
                                        For the TL;DR, which one did you like the best?
                                          pyrodetectorP
                                          pyrodetectorP
                                          pyrodetector
                                          @NeverDie said in What's the best PIR sensor?:
                                          Dear NeverDie!
                                          What is "TL;DR", please?
                                          Every sensor is good for its application. Among a set of sensors the best two sensors or more are those having similar characteristics.
