  3. [SOLVED] Sleep dont run
51 Posts 8 Posters 16.6k Views 7 Watching
  • T
    torfinn
    Hi ! Just wanted to add that this also solved it for me. I had problem with properly registering on the gateway ( due to chips was used on old version earlier ). After finding this post I tried the https://www.mysensors.org/build/debug#clearing-eeprom and it fixed problem. Looking at 40uA sleeping now :-)
    • YveauxY Yveaux
      @AWI See @tekka post here
      "For indefinite sleeping, only level IRQ triggers are permitted (see AVR datasheet)."
      Could you give that a try?
      AWIA
      AWIA
      AWI
      @Yveaux said in [SOLVED] Sleep dont run:
      Thanks @Yveaux I thought I was losing it...:relaxed: Tried different options:
      sleep(INTERRUPT1, LOW, 0 ); // sleep and wait for motion :+1:
      sleep(INTERRUPT1, LOW, 5000 ); // sleep and wait for 5 secs :+1:
      sleep(INTERRUPT1, CHANGE, 0 ); // sleep and wait for motion :-1:
      but for the last op tion @mar-conte reported succes :confused: how come?
      My understanding is:
      • deep sleep: only LOW
      • timed sleep: LOW, CHANGE, RISING, FALLING
        or...?
      • mar.conteM
        mar.conteM
        mar.conte
        Hello everyone, I do not understand why ATmega328 powered with an Arduino board without MCU with 3v3 volts when ba consumes 30 microamps in sleep imvece atmega if the power is two batteries 1,5 knows when he goes to sleep consumes 420 microamps, I'm not understanding nothing seemed that just consumed my project with pir and ATMEga
        M.C.
        AWIA 1 Reply Last reply
        • mar.conteM mar.conte
          AWIA
          AWIA
          AWI
          @mar.conte I'm sorry but can you try to rephrase your question?
          • mar.conteM
            mar.conteM
            mar.conte
            Why the same configuration atmega+pir+rfm69 with ftdi power consumption is 30 microampere and with 2 1,5 AA is 420 microampere?
            M.C.
            gohanG 1 Reply Last reply
              @mar.conte how did you made the measurements?
              mar.conteM 1 Reply Last reply
                mar.conteM
                mar.conteM
                mar.conte
                wrote on last edited by mar.conte
                #29
                @gohan
                one thing I did not say that I have changed the gateway before it was all right (30 microah) when the gateway
                was a esp Olimex evb, now I
                downloaded the same sketch "gateway" on
                esp8266 nodemecu dev kit and the node consumes me 420 microah !!
                GATEWAY
                 * Version 1.0 - Henrik Ekblad
                 * The ESP8266 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
                 * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
                 * LED purposes:
                 * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch
                 * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
                 * nRF24L01+  ESP8266
                 * VCC        VCC
                 * CE         GPIO4
                 * CSN/CS     GPIO15
                 * SCK        GPIO14
                 * MISO       GPIO12
                 * MOSI       GPIO13
                  * Inclusion mode button:
                #define MY_BAUD_RATE 9600
                //#define MY_RADIO_NRF24
                #define MY_RADIO_RFM69
                //#define MY_REPEATER_FEATURE
                #ifdef ESP8266
                #define MY_RFM69_FREQUENCY RF69_868MHZ // Set your frequency here
                #define MY_IS_RFM69HW // Omit if your RFM is not "H"
                #define MY_RF69_IRQ_PIN D1
                #define MY_RF69_SPI_CS D8 // NSS
                #define MY_GATEWAY_ESP8266
                //#define MY_MQTT_PUBLISH_TOPIC_PREFIX "mygateway1-out"
                //#define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mygateway1-in"
                #define MY_MQTT_PUBLISH_TOPIC_PREFIX "domoticz/in/MyMQTT"
                #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "domoticz/out/MyMQTT"
                // Set MQTT client id
                //#define MY_MQTT_USER "mosquitto"
                //#define MY_MQTT_PASSWORD ""
                // Set WIFI SSID and password
                #define MY_ESP8266_SSID "TP-LINK_B541"
                #define MY_ESP8266_PASSWORD "xxxxxx"
                #define MY_ESP8266_HOSTNAME "mqtt-sensor-gateway"
                #define MY_IP_ADDRESS 192,168,1,77
                // MQTT broker ip address.
                #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1,200
                #define MY_PORT 1883
                // Enable inclusion mode
                // Set blinking period
                // Flash leds on rx/tx/err
                #include <ESP8266WiFi.h>
                #define RELAY_1  5  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                void before()
                        pinMode(pin, OUTPUT);
                    sendSketchInfo("Relay", "1.0");
                        present(sensor, S_BINARY);
                    if (message.type==V_STATUS) {
                        // Change relay state
                        // Store state in eeprom
                NODE
                // Enable debug prints
                #define MY_NODE_ID 1
                unsigned long SLEEP_TIME = 0; // Sleep time between reports (in milliseconds)
                // Initialize motion message
                	present(CHILD_ID, S_MOTION);
                	// Read digital motion value
                	bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
                	Serial.println(tripped);
                	sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR),CHANGE, SLEEP_TIME);
                M.C.
                AWIA YveauxY 2 Replies Last reply
                  @gohan
                  GATEWAY
                   * LED purposes:
                   * nRF24L01+  ESP8266
                   * VCC        VCC
                   * CE         GPIO4
                   * CSN/CS     GPIO15
                   * SCK        GPIO14
                   * MISO       GPIO12
                   * MOSI       GPIO13
                  #ifdef ESP8266
                  void before()
                  NODE
                  AWIA
                  AWIA
                  AWI
                  wrote on last edited by AWI
                  #30
                  @mar.conte My best guess is that your node does not really "sleep" but that you are measuring an average current from the node (refer to my question to @Yveaux ). The power consumption during a "sleep" cannot be related to the gateway as there is no communication.
                  Differences between two gateways during transmission are probably related to communication issues (i.e. resends of information).
                  You can test the behaviour by putting your node in a "timed sleep": sleep(5000) // sleep 5 seconds and check power consumption.
                    @gohan
                    GATEWAY
                     * LED purposes:
                     * nRF24L01+  ESP8266
                     * VCC        VCC
                     * CE         GPIO4
                     * CSN/CS     GPIO15
                     * SCK        GPIO14
                     * MISO       GPIO12
                     * MOSI       GPIO13
                    #ifdef ESP8266
                    void before()
                    NODE
                    @mar.conte I wouldn't worry about sub mA power consumption of a gateway, as it isn't supposed to sleep at all.
                    Furthermore you shouldn't blindly compare usage of different boards, as there are more components (e.g. power regulator) that influence the total consumption.
                    • YveauxY Yveaux
                      AWIA
                      AWIA
                      AWI
                      #32
                      @Yveaux I think @mar-conte is talking about the consumption of the (battery powered) node, not the gateway..
                      • AWIA AWI
                        mar.conteM
                        mar.conteM
                        mar.conte
                        @AWI
                        Ok i try with sleep(5000) this afternoon,
                        One thing i dont say, the difference of consumption (30 micro or 420 micro) is if i power breadboard with atmega with arduino without mcu(usb 30micro); if I power same arduino mcu with jack 12 volt or I power breadboard with only 2 aa 1,5 the consumption is 420 micro
                        M.C.
                          @AWI
                          AWIA
                          AWIA
                          AWI
                          @mar.conte Just to be sure... only if you remove the Arduino/ atmega328p/ mcu (e.g. no processor) the rest of components take 30 uA? :confused:
                          • AWIA AWI
                            @AWI I think I'll stop responding to this thread...
                            Too complicated for a simple guy like me :confused:
                            • AWIA AWI
                              mar.conteM
                              mar.conteM
                              mar.conte
                              @AWI
                              Configuration hardware is: arduino without mcu (with usb power) wire(3,3,gnd,reset,txrx)betwin this and breadboard (atmega+pir+rfm69): consumption 30micro; the same configuration with no usb power but with jack 12 volt consumption 420 micro.
                              If i power breadboard without Arduino mculess but with 2 aa consumption 420 micro
                              M.C.
                              • AWIA AWI
                                  or...?
                                #37
                                This information is outdated. An error in the ATMega328P datasheet has been confirmed. See https://forum.mysensors.org/topic/6572/sleep-with-interrupt-only-works-with-level-low
                                @AWI Ok, last reply :simple_smile:
                                I'll have to dwell a little to explain how the AVR works and what its limitations are regarding sleeping, and how the MySensors library handles it.
                                For AVR architecture, the MySensors library uses the 'Power-Down mode' when sleeping.
                                I'll focus on ATMega328P here, for which the datasheet states the possible wake-up sources:
                                0_1490722068118_upload-b2cbd80d-2c88-4e52-8bae-c46adb341c4f
                                So in our case that's INT and WDT (TWI Address match is for i2c slave implementations).
                                When a timeout parameter is passed to a sleep() function of the MySensors library the watchdog (WDT) will be used to wake after the specified timeout. If timeout is set to 0 (and wake-up from interrupts is specified) the watchdog will be completely disabled to save some more power.
                                When an interrupt source is passed to a sleep() function of the library it will configure INT0 and/or INT1 to wake up the ATMega328.
                                Note point 3, as only level interrupts (more precise LOW in case of ATMega328, thanks @AWI for reminding me) can be used as a wake-up source.
                                Many posts here use RISING/FALLING/CHANGE as wake-up source for ATMega328 which is not supported by the ATMega328P and thus not supported by the MySensors library. Although people claim it is working for them you are on your own when using the chip out of spec and can expect strange behavior!
                                The datasheet continues in detail on the power-down mode:
                                0_1490721842267_upload-e4216667-02ab-4505-989f-e2b14c8edfaf
                                The MySensors library disables brown-out to save some power. Serial interface address match and pin change interrupt are not used by the library.
                                Pay special attention to the note: Waking the AVR from a INT0/INT1 interrupt will require the LOW level to remain for the startup-time, or the interrupt will not trigger. This means that only when the level is held long enough the library will be able to detect it woke from the external interrupt. If the level is not held at least the startup-time, it will assume it woke because of the total sleep time expired, and return MY_WAKE_UP_BY_TIMER (value -1).
                                This start-up time depends on the clock frequency and fuse bits, which for e.g. an 8MHz Arduino Pro Mini comes down to 2ms.
                                So just remember: In the MySensors library, only use LOW level interrupts to wake an ATMega328 from sleep and assure the interrupt level remains constant for at least the start-up time!
                                @AWI Your third example is out-of spec (CHANGE interrupt) and behavior is therefore undefined. If it seems to work, you're lucky...
                                mar.conteM gohanG tonnerre33T 3 Replies Last reply
                                • YveauxY Yveaux
                                  mar.conteM
                                  mar.conteM
                                  mar.conte
                                  @Yveaux
                                  thanks for the lesson, really complete, tomorrow I will try to put into practice the advice then I put "high" and will default interrupt with a 10k resistor input pir sull'interrupt 1. Thanks'll let you know
                                  M.C.
                                  • YveauxY Yveaux
                                    @Yveaux how do you handle a pir sensor if you can't use the Change interrupt?
                                      @gohan If you sensor signal goes HIGH the moment it detects movement one would sleep until the interrupt has HIGH level.
                                      After sending a message it is important to wait until the signal goes low again before sleeping, otherwise the sensor will wake immediately.
                                      • YveauxY Yveaux
                                        @Yveaux sure, but I would like to avoid having a sleeping node that wakes only with motion and then reports "no motions" only when sleep timeout is reached
                                        • YveauxY Yveaux
                                          tonnerre33T
                                          tonnerre33T
                                          tonnerre33
                                          Are you saying that the example posted here https://www.mysensors.org/build/motion contains mistakes ?
