  3. [SOLVED] Sleep dont run
51 Posts 8 Posters 16.6k Views 7 Watching
    @mar.conte the node is unable to connect to your gateway so it never enters loop() and therefore never reaches the sleep statement.
    mar.conteM
    mar.conteM
    mar.conte
    @mfalkvidd
    infact i the gw not exist, i try with gw and test again tanks
    M.C.
      mar.conteM
      mar.conteM
      mar.conte
      @mfalkvidd
      what example in mysensors library i try?
      M.C.
      • AWIA AWI
        @mar.conte I did some testing and I am experiencing a similar thing.
        The node powers down (8 uA)with sleep( 5000 ); // sleep only
        but with
        sleep(INTERRUPT1, CHANGE, INTERRUPT2, CHANGE, 0 ); // sleep and wait for motion
        or
        sleep(INTERRUPT1, FALLING, INTERRUPT2, FALLING, 0 ); // sleep and wait for motion
        it doesn't (2.5 mA)
        I will do some additional testing ...:confused:
        @AWI See @tekka post here
        "For indefinite sleeping, only level IRQ triggers are permitted (see AVR datasheet)."
        Could you give that a try?
        AWIA 1 Reply Last reply
        • mar.conteM mar.conte
          @mfalkvidd
          4 TSM:INIT
          4 TSF:WUR:MS=0
          8 TSM:INIT:TSP OK
          10 TSM:FPAR
          141 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          2148 !TSM:FPAR:NO REPLY
          2150 TSM:FPAR
          2281 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          4288 !TSM:FPAR:NO REPLY
          4290 TSM:FPAR
          4421 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          6430 !TSM:FPAR:NO REPLY
          6432 TSM:FPAR
          6563 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          8574 !TSM:FPAR:FAIL
          8577 TSM:FAIL:CNT=1
          8579 TSM:FAIL:PDT
          @mar.conte remember to set node ID
          mar.conteM 1 Reply Last reply
            mar.conteM
            mar.conteM
            mar.conte
            @gohan
            one example to set node id in motion sketch?
            M.C.
            • mar.conteM
              mar.conteM
              mar.conte
              wrote on last edited by mar.conte
              RESOLVED
              I HAVE JUST ONE GATEWAY CONFIGURED WITH RFM69 ON BOARD, THEN I HAVE CONNECTED TO NODE ID MCU WITH PIR AND EVERYTHING WORKS, WHEN THE PIR IS HIGH CURRENT CONSUMED is 2.25 MAH, WHEN IN SLEEP MODE ONLY 30 microamps.
              THANKS TO ALL THAT I HAVE HELPED
              NODE
               * Version 1.0 - Henrik Ekblad
              // Enable debug prints
              #define MY_NODE_ID 1
              //#define MY_RADIO_NRF24
              #define MY_RADIO_RFM69
              unsigned long SLEEP_TIME = 0; // Sleep time between reports (in milliseconds)
              // Initialize motion message
              	present(CHILD_ID, S_MOTION);
              	// Read digital motion value
              	bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
              	Serial.println(tripped);
              GATEWAY
              * LEDs (OPTIONAL):
              * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
              // Enable serial gateway
              #define MY_GATEWAY_SERIAL
              #if F_CPU == 8000000L
              #define MY_BAUD_RATE 38400
              // Enable inclusion mode
              // Set blinking period
              // Flash leds on rx/tx/err
              SERIAL OUTPUT NODE
              4 TSM:INIT
              4 TSF:WUR:MS=0
              8 TSM:INIT:TSP OK
              10 TSM:INIT:STATID=1
              12 TSF:SID:OK,ID=1
              14 TSM:FPAR
              145 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              1044 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
              1050 TSF:MSG:FPAR OK,ID=0,D=1
              2152 TSM:FPAR:OK
              2152 TSM:ID
              2154 TSM:ID:OK
              2156 TSM:UPL
              2164 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              2199 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
              2205 TSF:MSG:PONG RECV,HP=1
              2207 TSM:UPL:OK
              2209 TSM:READY:ID=1,PAR=0,DIS=1
              2263 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              2287 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              2344 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
              2404 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
              4421 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=OK:Motion Sensor
              4483 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
              4542 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
              4548 MCO:REG:REQ
              4601 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
              4626 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
              4630 MCO:PIM:NODE REG=1
              4634 MCO:BGN:STP
              4636 MCO:BGN:INIT OK,TSP=1
              4689 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
              4698 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
              4702 MCO:SLP:TPD
              4704 MCO:SLP:WUP=1
              4714 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:0
              4722 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
              4726 MCO:SLP:TPD
              4728 MCO:SLP:WUP=1
              4739 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
              4747 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
              4751 MCO:SLP:TPD
              4753 MCO:SLP:WUP=1
              4763 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:0
              4771 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
              4775 MCO:SLP:TPD
              SERIAL OUTPUT GATEWAY
              0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGA--,VER=2.1.1
              0;255;3;0;9;TSM:INIT
              0;255;3;0;9;TSF:WUR:MS=0
              0;255;3;0;9;TSM:INIT:TSP OK
              0;255;3;0;9;TSM:INIT:GW MODE
              0;255;0;0;18;2.1.1
              0;255;3;0;9;MCO:BGN:STP
              0;255;3;0;9;TSF:MSG:READ,1-1-0,s=1,c=1,t=16,pt=0,l=1,sg=0:1
              1;1;1;0;16;1
              TANKS VERY VERY VERY TO ALL
              M.C.
                RESOLVED
                NODE
                GATEWAY
                * LEDs (OPTIONAL):
                SERIAL OUTPUT NODE
                4 TSM:INIT
                4 TSF:WUR:MS=0
                8 TSM:INIT:TSP OK
                12 TSF:SID:OK,ID=1
                14 TSM:FPAR
                2152 TSM:FPAR:OK
                2152 TSM:ID
                2154 TSM:ID:OK
                2156 TSM:UPL
                2207 TSM:UPL:OK
                4548 MCO:REG:REQ
                4634 MCO:BGN:STP
                4702 MCO:SLP:TPD
                4704 MCO:SLP:WUP=1
                4726 MCO:SLP:TPD
                4728 MCO:SLP:WUP=1
                4751 MCO:SLP:TPD
                4753 MCO:SLP:WUP=1
                4775 MCO:SLP:TPD
                0;255;0;0;18;2.1.1
                1;1;1;0;16;1
                @mar.conte Great to hear you nailed it!
                For others to learn: what did you change to make things work?
                gohanG 1 Reply Last reply
                • YveauxY Yveaux
                  @Yveaux I think he added the gateway as he wasn't using one
                    mar.conteM
                    mar.conteM
                    mar.conte
                    @gohan
                    Yes of course, add gateway and the loop end , the node attachinterrupt with pir go to sleep when gateway receive
                    Tanks
                    M.C.
                    • T
                      torfinn
                      Hi ! Just wanted to add that this also solved it for me. I had problem with properly registering on the gateway ( due to chips was used on old version earlier ). After finding this post I tried the https://www.mysensors.org/build/debug#clearing-eeprom and it fixed problem. Looking at 40uA sleeping now :-)
                      • YveauxY Yveaux
                        AWIA
                        AWIA
                        AWI
                        @Yveaux said in [SOLVED] Sleep dont run:
                        Thanks @Yveaux I thought I was losing it...:relaxed: Tried different options:
                        sleep(INTERRUPT1, LOW, 0 ); // sleep and wait for motion :+1:
                        sleep(INTERRUPT1, LOW, 5000 ); // sleep and wait for 5 secs :+1:
                        sleep(INTERRUPT1, CHANGE, 0 ); // sleep and wait for motion :-1:
                        but for the last op tion @mar-conte reported succes :confused: how come?
                        My understanding is:
                        • deep sleep: only LOW
                        • timed sleep: LOW, CHANGE, RISING, FALLING
                          or...?
                        • mar.conteM
                          mar.conteM
                          mar.conte
                          Hello everyone, I do not understand why ATmega328 powered with an Arduino board without MCU with 3v3 volts when ba consumes 30 microamps in sleep imvece atmega if the power is two batteries 1,5 knows when he goes to sleep consumes 420 microamps, I'm not understanding nothing seemed that just consumed my project with pir and ATMEga
                          M.C.
                            AWIA
                            AWIA
                            AWI
                            @mar.conte I'm sorry but can you try to rephrase your question?
                            • mar.conteM
                              mar.conteM
                              mar.conte
                              Why the same configuration atmega+pir+rfm69 with ftdi power consumption is 30 microampere and with 2 1,5 AA is 420 microampere?
                              M.C.
                                @mar.conte how did you made the measurements?
                                  mar.conteM
                                  mar.conteM
                                  mar.conte
                                  #29
                                  @gohan
                                  one thing I did not say that I have changed the gateway before it was all right (30 microah) when the gateway
                                  was a esp Olimex evb, now I
                                  downloaded the same sketch "gateway" on
                                  esp8266 nodemecu dev kit and the node consumes me 420 microah !!
                                  GATEWAY
                                   * The ESP8266 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
                                   * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
                                   * LED purposes:
                                   * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch
                                   * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
                                   * nRF24L01+  ESP8266
                                   * VCC        VCC
                                   * CE         GPIO4
                                   * CSN/CS     GPIO15
                                   * SCK        GPIO14
                                   * MISO       GPIO12
                                   * MOSI       GPIO13
                                    * Inclusion mode button:
                                  #define MY_BAUD_RATE 9600
                                  //#define MY_REPEATER_FEATURE
                                  #ifdef ESP8266
                                  #define MY_RFM69_FREQUENCY RF69_868MHZ // Set your frequency here
                                  #define MY_IS_RFM69HW // Omit if your RFM is not "H"
                                  #define MY_RF69_IRQ_PIN D1
                                  #define MY_RF69_SPI_CS D8 // NSS
                                  #define MY_GATEWAY_ESP8266
                                  //#define MY_MQTT_PUBLISH_TOPIC_PREFIX "mygateway1-out"
                                  //#define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mygateway1-in"
                                  #define MY_MQTT_PUBLISH_TOPIC_PREFIX "domoticz/in/MyMQTT"
                                  #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "domoticz/out/MyMQTT"
                                  // Set MQTT client id
                                  //#define MY_MQTT_USER "mosquitto"
                                  //#define MY_MQTT_PASSWORD ""
                                  // Set WIFI SSID and password
                                  #define MY_ESP8266_SSID "TP-LINK_B541"
                                  #define MY_ESP8266_PASSWORD "xxxxxx"
                                  #define MY_ESP8266_HOSTNAME "mqtt-sensor-gateway"
                                  #define MY_IP_ADDRESS 192,168,1,77
                                  // MQTT broker ip address.
                                  #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1,200
                                  #define MY_PORT 1883
                                  #include <ESP8266WiFi.h>
                                  #define RELAY_1  5  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                                  void before()
                                          pinMode(pin, OUTPUT);
                                      sendSketchInfo("Relay", "1.0");
                                          present(sensor, S_BINARY);
                                      if (message.type==V_STATUS) {
                                          // Change relay state
                                          // Store state in eeprom
                                  NODE
                                  	sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR),CHANGE, SLEEP_TIME);
                                  M.C.
                                  AWIA YveauxY 2 Replies Last reply
                                    @gohan
                                    GATEWAY
                                     * LED purposes:
                                     * nRF24L01+  ESP8266
                                     * VCC        VCC
                                     * CE         GPIO4
                                     * CSN/CS     GPIO15
                                     * SCK        GPIO14
                                     * MISO       GPIO12
                                     * MOSI       GPIO13
                                    #ifdef ESP8266
                                    void before()
                                    NODE
                                    AWIA
                                    AWIA
                                    AWI
                                    wrote on last edited by AWI
                                    #30
                                    @mar.conte My best guess is that your node does not really "sleep" but that you are measuring an average current from the node (refer to my question to @Yveaux ). The power consumption during a "sleep" cannot be related to the gateway as there is no communication.
                                    Differences between two gateways during transmission are probably related to communication issues (i.e. resends of information).
                                    You can test the behaviour by putting your node in a "timed sleep": sleep(5000) // sleep 5 seconds and check power consumption.
                                      @gohan
                                      GATEWAY
                                       * LED purposes:
                                       * nRF24L01+  ESP8266
                                       * VCC        VCC
                                       * CE         GPIO4
                                       * CSN/CS     GPIO15
                                       * SCK        GPIO14
                                       * MISO       GPIO12
                                       * MOSI       GPIO13
                                      #ifdef ESP8266
                                      void before()
                                      NODE
                                      @mar.conte I wouldn't worry about sub mA power consumption of a gateway, as it isn't supposed to sleep at all.
                                      Furthermore you shouldn't blindly compare usage of different boards, as there are more components (e.g. power regulator) that influence the total consumption.
                                      • YveauxY Yveaux
                                        AWIA
                                        AWIA
                                        AWI
                                        #32
                                        @Yveaux I think @mar-conte is talking about the consumption of the (battery powered) node, not the gateway..
                                        • AWIA AWI
                                          mar.conteM
                                          mar.conteM
                                          mar.conte
                                          @AWI
                                          Ok i try with sleep(5000) this afternoon,
                                          One thing i dont say, the difference of consumption (30 micro or 420 micro) is if i power breadboard with atmega with arduino without mcu(usb 30micro); if I power same arduino mcu with jack 12 volt or I power breadboard with only 2 aa 1,5 the consumption is 420 micro
                                          M.C.
