  3. [SOLVED] Sleep dont run
51 Posts 8 Posters 16.6k Views 7 Watching
  • AWIA AWI
    @Yveaux I think @mar-conte is talking about the consumption of the (battery powered) node, not the gateway..
    @AWI I think I'll stop responding to this thread...
    Too complicated for a simple guy like me :confused:
    • AWIA AWI
      @mar.conte Just to be sure... only if you remove the Arduino/ atmega328p/ mcu (e.g. no processor) the rest of components take 30 uA? :confused:
      mar.conteM
      mar.conteM
      mar.conte
      @AWI
      Configuration hardware is: arduino without mcu (with usb power) wire(3,3,gnd,reset,txrx)betwin this and breadboard (atmega+pir+rfm69): consumption 30micro; the same configuration with no usb power but with jack 12 volt consumption 420 micro.
      If i power breadboard without Arduino mculess but with 2 aa consumption 420 micro
      M.C.
      • AWIA AWI
        @Yveaux said in [SOLVED] Sleep dont run:
        "For indefinite sleeping, only level IRQ triggers are permitted (see AVR datasheet)."
        Thanks @Yveaux I thought I was losing it...:relaxed: Tried different options:
        sleep(INTERRUPT1, LOW, 0 ); // sleep and wait for motion :+1:
        sleep(INTERRUPT1, LOW, 5000 ); // sleep and wait for 5 secs :+1:
        sleep(INTERRUPT1, CHANGE, 0 ); // sleep and wait for motion :-1:
        but for the last op tion @mar-conte reported succes :confused: how come?
        My understanding is:
        • deep sleep: only LOW
        • timed sleep: LOW, CHANGE, RISING, FALLING
          or...?
        #37
        This information is outdated. An error in the ATMega328P datasheet has been confirmed. See https://forum.mysensors.org/topic/6572/sleep-with-interrupt-only-works-with-level-low
        @AWI Ok, last reply :simple_smile:
        I'll have to dwell a little to explain how the AVR works and what its limitations are regarding sleeping, and how the MySensors library handles it.
        For AVR architecture, the MySensors library uses the 'Power-Down mode' when sleeping.
        I'll focus on ATMega328P here, for which the datasheet states the possible wake-up sources:
        0_1490722068118_upload-b2cbd80d-2c88-4e52-8bae-c46adb341c4f
        So in our case that's INT and WDT (TWI Address match is for i2c slave implementations).
        When a timeout parameter is passed to a sleep() function of the MySensors library the watchdog (WDT) will be used to wake after the specified timeout. If timeout is set to 0 (and wake-up from interrupts is specified) the watchdog will be completely disabled to save some more power.
        When an interrupt source is passed to a sleep() function of the library it will configure INT0 and/or INT1 to wake up the ATMega328.
        Note point 3, as only level interrupts (more precise LOW in case of ATMega328, thanks @AWI for reminding me) can be used as a wake-up source.
        Many posts here use RISING/FALLING/CHANGE as wake-up source for ATMega328 which is not supported by the ATMega328P and thus not supported by the MySensors library. Although people claim it is working for them you are on your own when using the chip out of spec and can expect strange behavior!
        The datasheet continues in detail on the power-down mode:
        0_1490721842267_upload-e4216667-02ab-4505-989f-e2b14c8edfaf
        The MySensors library disables brown-out to save some power. Serial interface address match and pin change interrupt are not used by the library.
        Pay special attention to the note: Waking the AVR from a INT0/INT1 interrupt will require the LOW level to remain for the startup-time, or the interrupt will not trigger. This means that only when the level is held long enough the library will be able to detect it woke from the external interrupt. If the level is not held at least the startup-time, it will assume it woke because of the total sleep time expired, and return MY_WAKE_UP_BY_TIMER (value -1).
        This start-up time depends on the clock frequency and fuse bits, which for e.g. an 8MHz Arduino Pro Mini comes down to 2ms.
        So just remember: In the MySensors library, only use LOW level interrupts to wake an ATMega328 from sleep and assure the interrupt level remains constant for at least the start-up time!
        @AWI Your third example is out-of spec (CHANGE interrupt) and behavior is therefore undefined. If it seems to work, you're lucky...
        mar.conteM gohanG tonnerre33T 3 Replies Last reply
        • YveauxY Yveaux
          mar.conteM
          mar.conteM
          mar.conte
          @Yveaux
          thanks for the lesson, really complete, tomorrow I will try to put into practice the advice then I put "high" and will default interrupt with a 10k resistor input pir sull'interrupt 1. Thanks'll let you know
          M.C.
          • YveauxY Yveaux
            @Yveaux how do you handle a pir sensor if you can't use the Change interrupt?
              @gohan If you sensor signal goes HIGH the moment it detects movement one would sleep until the interrupt has HIGH level.
              After sending a message it is important to wait until the signal goes low again before sleeping, otherwise the sensor will wake immediately.
              gohanG 1 Reply Last reply
              • YveauxY Yveaux
                @Yveaux sure, but I would like to avoid having a sleeping node that wakes only with motion and then reports "no motions" only when sleep timeout is reached
                • YveauxY Yveaux
                  tonnerre33T
                  tonnerre33T
                  tonnerre33
                  Are you saying that the example posted here https://www.mysensors.org/build/motion contains mistakes ?
                  • tonnerre33T tonnerre33
                    @tonnerre33 yes
                      @gohan I don't get your problem...
                      I suppose my suggestion will solve both waking from motion and sleep timeout.
                        If you have a motion sensor it will immediately wake when motion is detected but it will report pir sensor change to "no motion" only at sleep timeout, and if timeout is like 30 minutes then the controller will have "motion detected" on for 30 minutes. So unless you make an if statement with two sleep function, one with short sleep if pir sensor is on and one with long sleep if pir sensor is off, you will not be quickly notified of pir state changes
                          #46
                          @gohan How about this ?
                          I think it covers the regular use-case (untested :baby:):
                          unsigned long SLEEP_TIME = 10000;
                          #define PIN_PIR (3)
                              pinMode(PIN_PIR, INPUT);
                              // Configure what to send in case the PIR trips
                              msg.set("1");
                              present(CHILD_ID, S_MOTION);
                              // Sleep until woken by PIR motion, or timeout
                              switch( sleep(digitalPinToInterrupt(PIN_PIR), LOW, SLEEP_TIME) )
                                  case MY_WAKE_UP_BY_TIMER:
                                      Serial.println("Woke up by timer -- do something smart ;-)")
                                  case MY_SLEEP_NOT_POSSIBLE:
                                      Serial.println("Unable to sleep ;-(")
                                  default:
                                      Serial.println("Woke up by PIR -- sound the alarm!")
                                      send(msg);
                                      // Wait until PIR signal goes low again; poll every 100ms.
                                      while( digitalRead(DIGITAL_INPUT_SENSOR) == HIGH )
                                          sleep(100);
                          Note the LOW level to wake the ATMega. Regular PIRs will generate a HIGH level on motion.
                          • mar.conteM
                            mar.conteM
                            mar.conte
                            I can not solve the problem !!
                            I interrupt stabilized with 10k resistor, rewired everything but if my atmga + hcr501 +rfm69 with ftdi sleep in the consumption is 30 micro, if power with aa battery consumption is 420 micro help
                            M.C.
                            AWIA 1 Reply Last reply
                            • mar.conteM mar.conte
                              AWIA
                              AWIA
                              AWI
                              @mar.conte The hcr501 will become unstable below 3V. So if you are powering it with 2AA you can expect problems.
                              mar.conteM 2 Replies Last reply
                              • AWIA AWI
                                mar.conteM
                                mar.conteM
                                mar.conte
                                @AWI
                                I have order 3,6 aa battery 2600 mah and try , i think what you say infact i have imagined this Tanks
                                M.C.
                                • AWIA AWI
                                  mar.conteM
                                  mar.conteM
                                  mar.conte
                                  @AWI
                                  But I was thinking if it is true this should not works rather well the system works fine without false alarms and detection pir is precisely why?
                                  M.C.
                                  • mar.conteM
                                    mar.conteM
                                    mar.conte
                                    SOLVED
                                    HI
                                    FOR 3volt power i have insert jumper in the pin H of hcr501 and my project in sleep mode consumption is 30 micro Tanks for you suggesrion
                                    By
                                    M.C.
