  3. EasyIoT server - Mysensors Raspberry Pi controller
automationraspberrycontroller
32 Posts 13 Posters 32.2k Views 7 Watching
  • EasyIoTE
    EasyIoTE
    EasyIoT
    I didn't decided yet, but anyway for noncommercial use is current version for free. It works with Mysensors BinarySwitchSensor Example (http://mysensors.org/build/binary) so you can use it to remotely monitor your doors/windows.
    EasyIoT framework http://iot-playground.com
    • EasyIoTE EasyIoT
      New controller on raspberry supports mysensors v1.4. Download: http://iot-playground.com/
      EasyIoTE
      EasyIoTE
      EasyIoT
      Added new MySensors Driver options. Now you can set Base Radio Id, Data Rate and Power Amplifier level.
      • Johnny B GoodJ
        Johnny B GoodJ
        Johnny B Good
        Hi dopustko,
        Nice project, but it's not working here :-(
        Tryed both server versions, no result, only get error :
        [CODE]
        pi@homecontrol ~/easyiot $ sudo mono EasyIoT.exe
        2014-10-18T19:39:59.7112500+02:00 INFO System System started
        2014-10-18T19:40:03.0918930+02:00 Web service started
        Listening...
        2014-10-18T19:40:04.3352370+02:00 DEBUG MySensors MySensors Connect
        ================ SPI Configuration ================
        CSN Pin = CE0 (PI Hardware Driven)
        CE Pin = Custom GPIO25
        Clock Speed = 8 Mhz
        ================ NRF Configuration ================
        STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
        RX_ADDR_P0-1 = 0xa8a8e1fc00 0xa8a8e1fc00
        RX_ADDR_P2-5 = 0xff 0xc4 0xc5 0xc6
        TX_ADDR = 0xe7e7e7e7e7
        RX_PW_P0-6 = 0x20 0x20 0x20 0x00 0x00 0x00
        EN_AA = 0x3b
        EN_RXADDR = 0x07
        RF_CH = 0x7b
        RF_SETUP = 0x27
        CONFIG = 0x0e
        DYNPD/FEATURE = 0x3f 0x06
        Data Rate = 250KBPS
        Model = nRF24L01+
        CRC Length = 16 bits
        PA Power = PA_MAX
        2014-10-18T19:40:04.5087040+02:00 DEBUG MySensors Mysensors Start driver.
        2014-10-18T19:40:07.7276770+02:00 192.168.178.19 admin Authorization successful.
        2014-10-18T19:40:12.7053630+02:00 DEBUG MySensors Read: 0-26-0 s=255,c=3,t=17,pt=0,l=0:
        2014-10-18T19:40:12.7249430+02:00 DEBUG MySensors Version mismatch
        2014-10-18T19:40:12.7496780+02:00 DEBUG MySensors Read: 0-10-35 s=255,c=3,t=6,pt=0,l=0:
        2014-10-18T19:40:12.7546600+02:00 DEBUG MySensors Version mismatch
        2014-10-18T19:40:14.6999310+02:00 DEBUG MySensors Read: 0-106-3 s=255,c=3,t=11,pt=0,l=0:
        2014-10-18T19:40:14.7087720+02:00 DEBUG MySensors Version mismatch
        2014-10-18T19:40:14.7226980+02:00 DEBUG MySensors Read: 0-26-3 s=255,c=3,t=12,pt=0,l=0:
        2014-10-18T19:40:14.7287360+02:00 DEBUG MySensors Version mismatch
        2014-10-18T19:40:14.7437120+02:00 DEBUG MySensors Read: 0-26-0 s=3,c=3,t=0,pt=0,l=0:
        2014-10-18T19:40:14.7480090+02:00 DEBUG MySensors Version mismatch
        2014-10-18T19:40:14.7627190+02:00 DEBUG MySensors Read: 0-26-0 s=4,c=3,t=0,pt=0,l=0:
        2014-10-18T19:40:14.7688800+02:00 DEBUG MySensors Version mismatch
        2014-10-18T19:40:14.7825070+02:00 DEBUG MySensors Read: 0-26-0 s=4,c=3,t=0,pt=0,l=0:
        2014-10-18T19:40:14.7875390+02:00 DEBUG MySensors Version mismatch
        2014-10-18T19:40:14.8016840+02:00 DEBUG MySensors Read: 0-26-0 s=4,c=3,t=0,pt=0,l=0:
        2014-10-18T19:40:14.8071940+02:00 DEBUG MySensors Version mismatch
        2014-10-18T19:40:14.8225130+02:00 DEBUG MySensors Read: 0-26-0 s=4,c=3,t=0,pt=0,l=0:
        2014-10-18T19:40:14.8278380+02:00 DEBUG MySensors Version mismatch
        2014-10-18T19:40:14.8415230+02:00 DEBUG MySensors Read: 0-26-0 s=4,c=3,t=0,pt=0,l=0:
        2014-10-18T19:40:14.8460490+02:00 DEBUG MySensors Version mismatch
        2014-10-18T19:40:14.8605280+02:00 DEBUG MySensors Read: 0-26-0 s=4,c=3,t=0,pt=0,l=0:
        2014-10-18T19:40:14.8647580+02:00 DEBUG MySensors Version mismatch
        2014-10-18T19:40:14.8786940+02:00 DEBUG MySensors Read: 0-18-65 s=4,c=3,t=16,pt=0,l=0:
        2014-10-18T19:40:14.8828440+02:00 DEBUG MySensors Version mismatch
        [/CODE]
        -= GreetingZzz and may the sensors be with you =-
        • EasyIoTE
          EasyIoTE
          EasyIoT
          wrote on last edited by EasyIoT
          Hi, Johnny B Good. I've checked in my code and you are right. It doesn't work with current V1.4 mysensors protocol, beacuse I'm using old message header structure. It looks like they changed message structure (file MyMessage.h). I will fix that in next release.
          For now you can try compile with older version of 1.4 MySensor library. You can download library here: MySensors
          Johnny B GoodJ 1 Reply Last reply
          • EasyIoTE EasyIoT
            Johnny B GoodJ
            Johnny B GoodJ
            Johnny B Good
            @dopustko Thanx, it works now :-)
            Are there coming more posabilities soon instead of S_DOOR and V_TRIPPED ?
            Great site, and great going with the NRF24L01+ on the Raspberry directly :+1:
            GreetZz John
            EasyIoTE 2 Replies Last reply
            • Johnny B GoodJ Johnny B Good
              GreetZz John
              EasyIoTE
              EasyIoTE
              EasyIoT
              @Johnny-B-Good nice to hear that now it works. I even did't know that it doesn't work with latest version of MySensors - thx to noticing me.
              Yes, right now I'm preparing new version with (hope this week):
              • fix for mysensors library
              • add S_HUM, V_HUM and S_TEMP, V_TEMP
              • add database support - you will be able to see chart for each sensor
              In the near future expect support for more sensors and access to Raspberry Pi GPIO, SMS interface to MySensors network...
                GreetZz John
                EasyIoTE
                EasyIoTE
                EasyIoT
                @Johnny-B-Good in new version of EasyIoT server I added new MySensor types: S_HUM, V_HUM and S_TEMP, V_TEMP. Now MySensor driver works with latest MySensor 1.4 library from Githib. I also added logging and displaying sensor data.
                  Looks good @dopustko!
                  • K
                    K
                    kihotx
                    very nice! i'll test it in this weekend. Any chance for RGB sliders?
                    EasyIoTE 1 Reply Last reply
                    • K kihotx
                      EasyIoTE
                      EasyIoTE
                      EasyIoT
                      @kihotx which message type is RGB slider? In next release I will implement S_LIGHT V_LIGHT (http://mysensors.org/build/relay example) .
                      • D
                        Dany
                        V_DIMMER would be great!
                        • K
                          K
                          kihotx
                          which modules are supported now?
                          • K kihotx
                            EasyIoTE
                            EasyIoTE
                            EasyIoT
                            @Dany I will also implement V_DIMMER in future.
                            @kihotx EasyIoT server controller at the moment supports S_DOOR, V_TRIPPED, S_HUM, V_HUM and S_TEMP and V_TEMP. In the new release I will add GPIO support (so you can control also Raspberry Pi GPIO ports) and in MySensor driver I will add S_LIGHT an V_LIGHT
                            • K
                              K
                              kihotx
                              perferct! when you planning next relesase?
                              • K kihotx
                                EasyIoTE
                                EasyIoTE
                                EasyIoT
                                @kihotx I hope next week...
                                • J
                                  J
                                  jilldris
                                  Have tested this now and it works really well! Any news on planned updates? More sensors, ex power/energy meter would be nice.
                                  • J jilldris
                                    EasyIoTE
                                    EasyIoTE
                                    EasyIoT
                                    @jilldris Thx. I will add more sensors in future and also new protocols. Implementing new sensor type in protocol part is easy, hard part is implementing logic and visualization in web UI interface.
                                    In new release I've added S_LIGHT an V_LIGHT. It works with mysensors relay example.. In new version I've also added Raspberry Pi GPIO driver to control GPIO pins.
                                    • EasyIoTE EasyIoT
                                      EasyIoTE
                                      EasyIoTE
                                      EasyIoT
                                      New version of EasyIoT server supports MySensors S_MOTION and V_TRIPPED. All supported MySensors types in EasyIoT server are:
                                      S_DOOR, V_TRIPPED,
                                      S_HUM, V_HUM,
                                      S_TEMP,V_TEMP,
                                      S_LIGHT and V_LIGHT,
                                      Now is also supported ESP8266 WiFi module.
                                      • EasyIoTE
                                        EasyIoTE
                                        EasyIoT
                                        New version of EasyIoT server is released. Supported MySensor data types are:
                                        S_DOOR, V_TRIPPED,
                                        S_HUM, V_HUM,
                                        S_TEMP,V_TEMP,
                                        I_TIME
                                        S_DIMMER, V_DIMMER, V_LIGHT
                                        S_LIGHT_LEVEL, V_LIGHT_LEVEL
                                        S_BARO, V_PRESSURE, V_FORECAST
                                        We also added automation functions and SMS gateway (control and monitor your network with SMS).
                                        EasyIoT server download link
                                        • EasyIoTE EasyIoT
                                          S_DOOR, V_TRIPPED,
                                          S_HUM, V_HUM,
                                          S_TEMP,V_TEMP,
                                          I_TIME
                                          EasyIoTE
                                          EasyIoTE
                                          EasyIoT
                                          New beta 0_7b1 is out for testing. New MySensor supported data types are:
                                          S_DISTANCE, V_DISTANCE
                                          S_DUST, V_DUST_LEVEL
                                          S_POWER, V_WATT, V_KWH
                                          S_WATER, V_FLOW, V_VOLUME
                                          S_UV, V_UV
                                          S_MOTION, V_TRIPPED - > also supports motion detector
