  3. Air Quality: CO2 Sensor MH-Z14
gas sensorair qualityco2
28 Posts 12 Posters 31.6k Views 13 Watching
  • R
    R
    roy
    @epierre ,can you please send your email again, it maybe spammed by my server .
      mortommy
      wrote on last edited by mortommy
      Hi @epierre ,
      the CO2 sensor is not available anymore in the store page. On aliexpress there are sensors from 25$ to 80$; did you test the cheapest one? Or in the meantime you have any other suggestion? I'd like to order one and make my CO2 sensor node.
      Thank you.
      Regards.
      epierreE alexsh1A 2 Replies Last reply
      • M mortommy
        Hi @epierre ,
        Thank you.
        Regards.
        epierreE
        epierreE
        epierre
        @mortommy the €23 is the same I have (I paid $70 at the time...)
        z-wave - Vera -> Domoticz
        • M mortommy
          Hi @epierre ,
          Thank you.
          Regards.
          alexsh1A
          alexsh1A
          alexsh1
          @mortommy I'd strongly suggest you go for this sensor. It is expensive, but very-very precise and reliable. You can go for MQ-135 - this is what I did at the beginning. It is utterly useless and can probably be used in enclosed premises, but not in normal houses/flats as its reading are just jumping up and down.
          You can go for the MH-Z19 sensor - it is not much cheaper than MH-Z14 (or MH-Z14A).
          http://www.aliexpress.com/item/FREE-SHIPPING-MH-Z19-CO2-detection-sensor-module/32576013283.html?spm=2114.30010308.3.21.cLSnEB&ws_ab_test=searchweb201556_10,searchweb201602_5_10037_10017_507_10032,searchweb201603_2&btsid=ce733a29-ca27-4f2a-b438-95e3abc647b0
          epierreE 1 Reply Last reply
            mortommy
            thank you guys. :thumbsup:
            • alexsh1A alexsh1
              epierreE
              epierreE
              epierre
              agreed ! that comes with experience !
              it is now $3 difference
              • F
                F
                flopp
                I am playing with a MH-Z19 and found this thread and the link in the first post is not working.
                This is the correct link
                https://github.com/empierre/arduino/blob/master/AirQuality-CO2-MH-Z14.ino
                • alowhumA
                  alowhumA
                  alowhum
                  Does the MH-Z14 code work for the MH-Z19 as well?
                  D 1 Reply Last reply
                  • alowhumA alowhum
                    Daniel Linder
                    @alowhum. Yes it does. I've built a combined Co2, humidity and temp sensor using mh-z19 and dht22. it shows current values on an oled and reports back to openhab. will use a number of these for ventilation control.If anyone is interested I'll post the complete build when done (currently waiting for more components from China).
                    solaS 1 Reply Last reply
                    • alowhumA
                      alowhumA
                      alowhum
                      #22
                      The downside is that it uses pulse-width modulation to get the data out. This isn't a problem, but it soes mean that you are taking a digital value, turning it into an analog voltage reading that analog voltage with Arduino, and turning it back into a digital value.
                      I scraped together some code for the MH-Z19 that uses a serial connection to talk to the sensor instead. The sketch can be found here.
                      I also highly recommend getting the BME280 sensor for your humidity needs. It even gives you barometric data, so you can have your own weather prediction. A sketch that uses that sensor, and that is very easy to combine with the MH-Z19 sketch I just posted to, can be found here.
                      If you also want to integrate the best-buy dust sensor, have a look at this sketch that already combines the MH-Z19 Co2 sensor and the PMS-7003 air quality (fine dust) sensor.
                      • D
                        Daniel Linder
                        HI,
                        I'll try your serial interface code later.
                        It seems to be an accurate sensor, however - the values are a bit "bouncy". I'll incorporate a "running average" on the measurements - to calm it down.
                        I am always tempted to add more sensors to the nodes, but in this case it is not possible.
                        My casing design would not even allow for one additional resistor... ;-)
                        • D Daniel Linder
                          solaS
                          solaS
                          sola
                          @Daniel-Linder Hi Daniel,
                          I would be quite interested in your Mh-z19 and DHT22 sensor node, I am building a similar one.
                          Please post the build if you still have it.
                          Many thanks.
                          R 1 Reply Last reply
                          • solaS sola
                            Many thanks.
                            R
                            R
                            reinhold
                            FWIW, some weeks ago I ported the MH-Z19 code (the serial interface, by default connected to digital pins 6 and 7) to NodeManager for use in my own little gas detection node (MH-Z19 and four MQ-... sensors). The MH-Z19 code is included in the 1.6 release of NodeManager, so if you are using NodeManager for your nodes, the MH-Z19 sensor should be really easy to set up and use.
                            • solaS
                              solaS
                              sola
                              @reinhold said in Air Quality: CO2 Sensor MH-Z14:
                              Many thanks, I will check out NodeManager, looks like some really cool stuff.
                              • G
                                G
                                Gelisob
                                Hello guys, could somebody clear up, what sensor to prefer. MH-Z14A vs MH-Z19 ?
                                Their price is very similar and kinda meh in comparison but which should one prefer and when?
                                I can see Z19 having some response time lower but power consumption higher...
                                Maybe someone here already made the comparisons and can share that useful information into this thread, so that others would also know what to pick and why?
                                • alowhumA
                                  alowhumA
                                  alowhum
                                  Go with the Z19. Here's some ready made code:
                                  https://forum.mysensors.org/topic/6528/mh-z19-co2-sensor/5
                                  12.5k
