  3. Air Quality: CO2 Sensor MH-Z14
gas sensorair qualityco2
28 Posts 12 Posters 31.6k Views 13 Watching
  • epierreE
    epierreE
    epierre
    There are projects and projects... Here I provide code for many already available sensors, and on Particle/Spark.io we are building hardware that would facilitate IAQ devices building, but it is always the end user that has to order the device, which is thus an important point.
    The MOQ is thus irrelevant except if people group themselves to reach the minimum order quantity, but before that we need to make some prototypes so the code will be tested and validated for people to use it anywhere.
    Tell me if this is possible to get samples in this optic,
    Emmanuel
    z-wave - Vera -> Domoticz
    • R
      R
      roy
      Positive answer , we can provide samples . see available types in attachment .Which one do you preferred ?Choose the output interface and I can send communication protocol in advacne .
      Just need your information to send products ,your company ,shipping address , contact name , contact phone number .Air Quality Sensor Module Product List (Wuhan Cubic-V2015.1).pdf
      Regards
      Roy Lee
      ruyi.li@gassensor.com.cn
      • epierreE
        epierreE
        epierre
        @roy any news ? I've sent you an email but did not get any answer so far...
        • R
          R
          roy
          @epierre ,can you please send your email again, it maybe spammed by my server .
            mortommy
            wrote on last edited by mortommy
            Hi @epierre ,
            the CO2 sensor is not available anymore in the store page. On aliexpress there are sensors from 25$ to 80$; did you test the cheapest one? Or in the meantime you have any other suggestion? I'd like to order one and make my CO2 sensor node.
            Thank you.
            Regards.
            epierreE alexsh1A 2 Replies Last reply
            • M mortommy
              Hi @epierre ,
              Thank you.
              Regards.
              epierreE
              epierreE
              epierre
              @mortommy the €23 is the same I have (I paid $70 at the time...)
              • M mortommy
                Hi @epierre ,
                Thank you.
                Regards.
                alexsh1A
                alexsh1A
                alexsh1
                @mortommy I'd strongly suggest you go for this sensor. It is expensive, but very-very precise and reliable. You can go for MQ-135 - this is what I did at the beginning. It is utterly useless and can probably be used in enclosed premises, but not in normal houses/flats as its reading are just jumping up and down.
                You can go for the MH-Z19 sensor - it is not much cheaper than MH-Z14 (or MH-Z14A).
                http://www.aliexpress.com/item/FREE-SHIPPING-MH-Z19-CO2-detection-sensor-module/32576013283.html?spm=2114.30010308.3.21.cLSnEB&ws_ab_test=searchweb201556_10,searchweb201602_5_10037_10017_507_10032,searchweb201603_2&btsid=ce733a29-ca27-4f2a-b438-95e3abc647b0
                epierreE 1 Reply Last reply
                  mortommy
                  thank you guys. :thumbsup:
                  • alexsh1A alexsh1
                    epierreE
                    epierreE
                    epierre
                    agreed ! that comes with experience !
                    it is now $3 difference
                    • F
                      F
                      flopp
                      I am playing with a MH-Z19 and found this thread and the link in the first post is not working.
                      This is the correct link
                      https://github.com/empierre/arduino/blob/master/AirQuality-CO2-MH-Z14.ino
                      • alowhumA
                        alowhumA
                        alowhum
                        Does the MH-Z14 code work for the MH-Z19 as well?
                        D 1 Reply Last reply
                        • alowhumA alowhum
                          Daniel Linder
                          @alowhum. Yes it does. I've built a combined Co2, humidity and temp sensor using mh-z19 and dht22. it shows current values on an oled and reports back to openhab. will use a number of these for ventilation control.If anyone is interested I'll post the complete build when done (currently waiting for more components from China).
                          solaS 1 Reply Last reply
                          • alowhumA
                            alowhumA
                            alowhum
                            #22
                            The downside is that it uses pulse-width modulation to get the data out. This isn't a problem, but it soes mean that you are taking a digital value, turning it into an analog voltage reading that analog voltage with Arduino, and turning it back into a digital value.
                            I scraped together some code for the MH-Z19 that uses a serial connection to talk to the sensor instead. The sketch can be found here.
                            I also highly recommend getting the BME280 sensor for your humidity needs. It even gives you barometric data, so you can have your own weather prediction. A sketch that uses that sensor, and that is very easy to combine with the MH-Z19 sketch I just posted to, can be found here.
                            If you also want to integrate the best-buy dust sensor, have a look at this sketch that already combines the MH-Z19 Co2 sensor and the PMS-7003 air quality (fine dust) sensor.
                            • D
                              Daniel Linder
                              HI,
                              I'll try your serial interface code later.
                              It seems to be an accurate sensor, however - the values are a bit "bouncy". I'll incorporate a "running average" on the measurements - to calm it down.
                              I am always tempted to add more sensors to the nodes, but in this case it is not possible.
                              My casing design would not even allow for one additional resistor... ;-)
                              • D Daniel Linder
                                solaS
                                solaS
                                sola
                                @Daniel-Linder Hi Daniel,
                                I would be quite interested in your Mh-z19 and DHT22 sensor node, I am building a similar one.
                                Please post the build if you still have it.
                                Many thanks.
                                R 1 Reply Last reply
                                • solaS sola
                                  Many thanks.
                                  R
                                  R
                                  reinhold
                                  FWIW, some weeks ago I ported the MH-Z19 code (the serial interface, by default connected to digital pins 6 and 7) to NodeManager for use in my own little gas detection node (MH-Z19 and four MQ-... sensors). The MH-Z19 code is included in the 1.6 release of NodeManager, so if you are using NodeManager for your nodes, the MH-Z19 sensor should be really easy to set up and use.
                                  • solaS
                                    solaS
                                    sola
                                    @reinhold said in Air Quality: CO2 Sensor MH-Z14:
                                    Many thanks, I will check out NodeManager, looks like some really cool stuff.
                                    • G
                                      G
                                      Gelisob
                                      Hello guys, could somebody clear up, what sensor to prefer. MH-Z14A vs MH-Z19 ?
                                      Their price is very similar and kinda meh in comparison but which should one prefer and when?
                                      I can see Z19 having some response time lower but power consumption higher...
                                      Maybe someone here already made the comparisons and can share that useful information into this thread, so that others would also know what to pick and why?
                                      • alowhumA
                                        alowhumA
                                        alowhum
                                        Go with the Z19. Here's some ready made code:
                                        https://forum.mysensors.org/topic/6528/mh-z19-co2-sensor/5
                                        12.5k
