Help with a project sending images
I did a project that sends images to a webservice through 3g dongle.
I used a Raspberry and works perfect, but the problem is the rasp has to be in the middle of a field without energy. I tried to use a solar panel, but the high consumption makes this configuration not viable.
I want to do it with an arduino, anybody has experience doing that? maybe could help to us and making a small budget because is a concept proof and we do not have an enterprise budget. ;-)
Thank's
Eduard
You have conserve power and accumulate energy in combination with large-enough solar panels.
A quick googling:
https://www.jeffgeerling.com/blogs/jeff-geerling/raspberry-pi-zero-conserve-energy
http://www.voltaicsystems.com/blog/powering-a-raspberry-pi-from-solar-power/ -
@gohan said in Help with a project sending images:
r even lower power consumption. Then it all depends on how big you
Yes, we could find a pi with low consumption, the problem is how to put the system in sleep mode for example at night...to reduce even more the consumption
Thank's every one
Eduard
Maybe look at AI-thinker A6c module that has direct camera interface and sends pictures as MMS over GSM.
