  3. Help with a project sending images
10 Posts 4 Posters 3.3k Views 3 Watching
  • E Offline
    E Offline
    ecabanas
    wrote on last edited by ecabanas
    I did a project that sends images to a webservice through 3g dongle.
    I used a Raspberry and works perfect, but the problem is the rasp has to be in the middle of a field without energy. I tried to use a solar panel, but the high consumption makes this configuration not viable.
    I want to do it with an arduino, anybody has experience doing that? maybe could help to us and making a small budget because is a concept proof and we do not have an enterprise budget. ;-)
    Thank's
    Eduard
    • hekH Offline
      hekH Offline
      You have conserve power and accumulate energy in combination with large-enough solar panels.
      A quick googling:
      https://www.jeffgeerling.com/blogs/jeff-geerling/raspberry-pi-zero-conserve-energy
      http://www.voltaicsystems.com/blog/powering-a-raspberry-pi-from-solar-power/
        Yes, rpi is low power but still not battery friendly. Better look at pi zero or even lower power consumption. Then it all depends on how big you can make your project (size of solar panel and battery)
        • E Offline
          E Offline
          ecabanas
          @gohan said in Help with a project sending images:
          Yes, we could find a pi with low consumption, the problem is how to put the system in sleep mode for example at night...to reduce even more the consumption
          Thank's every one
          Eduard
            You could just shutdown the rpi and have a timer that cuts the power to the rpi, in the morning the same timer can restore power to the rpi and you are good to go. Then it's up to you how to choose or make the timer
            • E Offline
              E Offline
              ecabanas
              s
              Hi @gohan how did you do a timer? I have no idea how to do it.
              Thank's
              • M Offline
                M Offline
                Mrlynx
                Maybe look at AI-thinker A6c module that has direct camera interface and sends pictures as MMS over GSM.
                http://www.sa2avr.se
                  I don't know how much MMS cost in your country, but over here they are like 0,5/0,6 € each :)
                  • E Offline
                    E Offline
                    ecabanas
                    Any one knows how it works A6? any example or sketch? I have one but I have no idea how it works.
                    Thank's again guys
                    • M Offline
                      M Offline
                      Mrlynx
                      have a look at
                      https://raymondtunning.wordpress.com/2016/09/08/best-wireless-cam-solution-a6c/
