  3. Vera
  4. [solved] new controller with ethernet Gateway on UI7 - unable to enter inclusion mode
11 Posts 3 Posters 4.8k Views 3 Watching
  • P
    P
    pls90
    wrote on last edited by pls90
    After moving all my devices from my Vera light UI5 to a Vera Plus with UI7 today I flashed my controller that was working fine on ui5 with the latest mysensors software 2.1.
    I created a MySensor plugin device but seem to be unable to enter inclusion mode. A simple light level node is not included.
    Could you please advise me as to how I could get this going again?
    This is in the log
    ![0_1492806723766_upload-ef244203-7a28-411a-8d39-fb7e4892dea8](/assets/uploads/files/1492806697033-upload-ef244203-7a28-411a-8d39-fb7e4892dea8-resized.png) Insert Code Here
    ```JobHandler_LuaUPnP::HandleActionRequest device: 202 service: urn:upnp-arduino-cc:serviceId:arduino1 action: StartInclusion <0x7057a520>
    JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=202 <0x7057a520>
    JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:upnp-arduino-cc:serviceId:arduino1 <0x7057a520>
    JobHandler_LuaUPnP::HandleActionRequest argument action=StartInclusion <0x7057a520>
    luup_log:202: Arduino: Sending: 0;0;3;0;5;1 <0x77270320>
    <Job ID="19" Name="" Device="202" Created="2017-04-21 22:18:22" Started="2017-04-21 22:18:22" Completed="2017-04-21 22:18:22" Duration="0.1657000" Runtime="0.1329000" Status="Successful" LastNote=""/> <0x77270320>
    IOPort::Run RecvFailed 131 close 23 <0x6fff7520>
    Edit:
    I built a completely new gw module (uno with 5100 shield) with a diferent IP address and mac address.
    Changed ip settings in the vera plugin.
    reloaded luup engine.
    No errors in lua startup, but still the same problem with inclusion mode.
    I then did some testing on the gw side.
    The debug output from gw seems to be fine:
    output on startup of the gw:
    0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.0
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    IP: 192.168.2.155
    0;255;3;0;9;MCO:BGN:STP
    output when I start inclusion mode from vera ui
    0;255;3;0;9;Eth: connect
    IP: 192.168.2.155
    output when I stop inclusion from vera ui
    IP: 192.168.2.155
    so vera IS communicating with the gw.
    this is the output after starting inclusion mode from vera gui and powering up a new node (measuring light level).
    0;255;3;0;9;TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSF:MSG:BC
    0;255;3;0;9;TSF:MSG:FPAR REQ,ID=1
    0;255;3;0;9;TSF:CKU:OK,FCTRL
    0;255;3;0;9;TSF:MSG:GWL OK
    0;255;3;0;9;!TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    IP: 192.168.2.155
    So the light level node is also talking to the gw.
    I assume the problem is on the vera/ plugin side.
    The mysensors plugin device on Vera UI7 shows only the plugin version, the line for lib is empty.
    Any pointers are highly appreciated!
      Did you enable the inclusion mode feature in the gateway sketch?
      • P
        P
        pls90
        I think it is enabled by default.
        This is how I compiled it
        // Enable inclusion mode
        So only inclusion by button press on the gw is disabled?
        • P
          P
          pls90
          I realized there is a new version 2.1.1, I had used 2.1.0
          I flashed both gw and sensor node with the new version.
          Now on vera gui in the Mysensor plugin both plugin version and lib version are shown correctly.
          Debug output from gw shows communication to the node is ok.
          Still, no inclusion mode.
            Sorry I can't help you more. I still run UI5 on my Vera... making the upgrade with all other plugin dependencies is just too fragile (without risking distress in the family) ;)
            • P
              P
              pls90
              Na, I would't mess with my system either :blush:
              I had mysensors running nicely on ui5, too.
              That changed when Vera Plus moved in.;-)
              Tried building a pi gw, but face the problem. No chance to enter inclusion mode.
              korttomaK 1 Reply Last reply
              • P pls90
                korttomaK
                korttomaK
                korttoma
                @pls90 I have a few Ethernet GWs working on UI7 so I think it should work also for you.
                Maybe you could try rebooting your Vera, then after that also do a few Lua Engine restarts and then finally you do a Ctrl + F5 to get a browser refresh.
                Then try the inclusion again.
                Maybe you could also post your complete GW sketch so I can compare with some of the once I'm using.
                Please also check your Arduino IDE version and AVR Boards Version.
                • Tomas
                • P
                  P
                  pls90
                  @korttoma Thank you for taking your time to have a look.
                  I did as you suggested abd did the vera dance (vera reboot, reload luup engine, clear browser cache) to no avail.
                  Here's my gw sketch (should be nearly unchanged from the template)
                  #define MY_GATEWAY_W5100
                  //#define MY_W5100_SPI_EN 4
                  // radio on the same spi bus.
                  #define MY_SOFTSPI
                  #ifndef MY_RF24_CE_PIN
                  #define MY_RF24_CE_PIN 5
                  #ifndef MY_RF24_CS_PIN
                  #define MY_RF24_CS_PIN 6
                  // Enable to UDP
                  //#define MY_USE_UDP
                  #define MY_IP_ADDRESS 192,168,2,155   // If this is disabled, DHCP is used to retrieve address
                  #define MY_PORT 5003
                  #define MY_MAC_ADDRESS  0xFE, 0xED, 0xDE, 0xAD, 0xBE, 0xEF
                  // Set blinking period
                  // Flash leds on rx/tx/err
                  #if defined(MY_USE_UDP)
                  #include <EthernetUdp.h>
                  #include <Ethernet.h>
                  Which lib version are you currently using?
                  • P
                    P
                    pls90
                    I did some more testing.
                    I downloaded lib version 1.5 and flashed the gateway and sensor node again.
                    Inclusion worked right away, but it took me numerous attempts to get the sensor node to include. After it did that communication between the node and gw broke down a couple of times (I am look at the debug output of sensor and gw). The sensor should report temp and lux level, which it has not done so far.
                    On 2.1.1 communication seemed to be solid.
                    Now I a stuck between 2.1.1 which will not allow inclusion of nodes but has good communication, and 1.5 which created the devices but doesn't update them because of comm issues.
                    Sigh.
                    • korttomaK
                      korttomaK
                      korttoma
                      On the SensebenderGW I have used 2.1.1 (Arduino IDE 1.6.11, AVR board 1.6.11)
                      On one ESP8266RFM69 GW I have also 2.1.1 (Arduino IDE 1.6.11, AVR board 1.6.11)
                      On another NRF24 Ethernet GW I have used 2.0.0 (Don't remember IDE/AVR version)
                      On an RFM69 Ethernet GW I have used 2.1.0 (Don't remember IDE/AVR version)
                      All of them are currently in use and working with different sketches of course.
                      Sensebender GW sketch:
                       * Version 1.0 - Henrik EKblad
                       * LED purposes:
                      #define MY_SOFTSPI
                      // Enable to UDP
                      #define MY_IP_ADDRESS 192,168,1,100   // If this is disabled, DHCP is used to retrieve address
                      #define MY_GATEWAY_MAX_CLIENTS 3
                      #define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xFE
                      Please check your IDE and AVR versions.
                      • Tomas
                      • P
                        P
                        pls90
                        As you confirmed you had your gw / sensors running on 2.x I gave it another try and started from scratch, and wiped the eeproms on both my gw and node.
                        New Install of Arduino IDE, new MySensors Library install. I used the ethernet gw sketch example and a temperature sensor node sketch.
                        This time it worked, I was able to finally include the sensor, what I can tell from the debug output communication seems to be working flawless.
                        Even when cutting power from gw or sensor and powering up again communication is recovering.
                        Now I will work on adapting my old sensor node sketch on lib 1.4 to new 2.1 requirements.
                        Thank you so much for taking the time to help me get this going :smiley:
