  3. Vera
  4. [solved] new controller with ethernet Gateway on UI7 - unable to enter inclusion mode
11 Posts 3 Posters 4.8k Views 3 Watching
    Did you enable the inclusion mode feature in the gateway sketch?
    • P
      P
      pls90
      I think it is enabled by default.
      This is how I compiled it
      // Enable inclusion mode
      So only inclusion by button press on the gw is disabled?
      • P
        P
        pls90
        I realized there is a new version 2.1.1, I had used 2.1.0
        I flashed both gw and sensor node with the new version.
        Now on vera gui in the Mysensor plugin both plugin version and lib version are shown correctly.
        Debug output from gw shows communication to the node is ok.
        Still, no inclusion mode.
          Sorry I can't help you more. I still run UI5 on my Vera... making the upgrade with all other plugin dependencies is just too fragile (without risking distress in the family) ;)
          • P
            P
            pls90
            Na, I would't mess with my system either :blush:
            I had mysensors running nicely on ui5, too.
            That changed when Vera Plus moved in.;-)
            Tried building a pi gw, but face the problem. No chance to enter inclusion mode.
            korttomaK 1 Reply Last reply
            • P pls90
              korttomaK
              korttomaK
              korttoma
              @pls90 I have a few Ethernet GWs working on UI7 so I think it should work also for you.
              Maybe you could try rebooting your Vera, then after that also do a few Lua Engine restarts and then finally you do a Ctrl + F5 to get a browser refresh.
              Then try the inclusion again.
              Maybe you could also post your complete GW sketch so I can compare with some of the once I'm using.
              Please also check your Arduino IDE version and AVR Boards Version.
              • Tomas
              • P
                P
                pls90
                @korttoma Thank you for taking your time to have a look.
                I did as you suggested abd did the vera dance (vera reboot, reload luup engine, clear browser cache) to no avail.
                Here's my gw sketch (should be nearly unchanged from the template)
                #define MY_GATEWAY_W5100
                //#define MY_W5100_SPI_EN 4
                // radio on the same spi bus.
                #define MY_SOFTSPI
                #ifndef MY_RF24_CE_PIN
                #define MY_RF24_CE_PIN 5
                #ifndef MY_RF24_CS_PIN
                #define MY_RF24_CS_PIN 6
                // Enable to UDP
                //#define MY_USE_UDP
                #define MY_IP_ADDRESS 192,168,2,155   // If this is disabled, DHCP is used to retrieve address
                #define MY_PORT 5003
                #define MY_MAC_ADDRESS  0xFE, 0xED, 0xDE, 0xAD, 0xBE, 0xEF
                // Set blinking period
                // Flash leds on rx/tx/err
                #if defined(MY_USE_UDP)
                #include <EthernetUdp.h>
                #include <Ethernet.h>
                Which lib version are you currently using?
                • P
                  P
                  pls90
                  I did some more testing.
                  I downloaded lib version 1.5 and flashed the gateway and sensor node again.
                  Inclusion worked right away, but it took me numerous attempts to get the sensor node to include. After it did that communication between the node and gw broke down a couple of times (I am look at the debug output of sensor and gw). The sensor should report temp and lux level, which it has not done so far.
                  On 2.1.1 communication seemed to be solid.
                  Now I a stuck between 2.1.1 which will not allow inclusion of nodes but has good communication, and 1.5 which created the devices but doesn't update them because of comm issues.
                  Sigh.
                  • korttomaK
                    korttomaK
                    korttoma
                    On the SensebenderGW I have used 2.1.1 (Arduino IDE 1.6.11, AVR board 1.6.11)
                    On one ESP8266RFM69 GW I have also 2.1.1 (Arduino IDE 1.6.11, AVR board 1.6.11)
                    On another NRF24 Ethernet GW I have used 2.0.0 (Don't remember IDE/AVR version)
                    On an RFM69 Ethernet GW I have used 2.1.0 (Don't remember IDE/AVR version)
                    All of them are currently in use and working with different sketches of course.
                    Sensebender GW sketch:
                     * Version 1.0 - Henrik EKblad
                     * LED purposes:
                    #define MY_SOFTSPI
                    // Enable to UDP
                    #define MY_IP_ADDRESS 192,168,1,100   // If this is disabled, DHCP is used to retrieve address
                    #define MY_GATEWAY_MAX_CLIENTS 3
                    #define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xFE
                    Please check your IDE and AVR versions.
                    • Tomas
                    • P
                      P
                      pls90
                      As you confirmed you had your gw / sensors running on 2.x I gave it another try and started from scratch, and wiped the eeproms on both my gw and node.
                      New Install of Arduino IDE, new MySensors Library install. I used the ethernet gw sketch example and a temperature sensor node sketch.
                      This time it worked, I was able to finally include the sensor, what I can tell from the debug output communication seems to be working flawless.
                      Even when cutting power from gw or sensor and powering up again communication is recovering.
                      Now I will work on adapting my old sensor node sketch on lib 1.4 to new 2.1 requirements.
                      Thank you so much for taking the time to help me get this going :smiley:
