  3. Another simple (No SMT) relay actuator
42 Posts 8 Posters 15.6k Views 6 Watching
  • breimannB breimann
    @dpressle nice!
    dpressleD Offline
    dpressleD Offline
    dpressle
    @breimann Thanks, does any one want link to dirtypcbs?
    gusG 1 Reply Last reply
    • A Offline
      A Offline
      artipi
      Hi, dpressle. Thanks for your work?
      One Question. Can i connect a normal light switch to it? So that i can turn on the lights with the switch and this node?
      dpressleD 1 Reply Last reply
      • A artipi
        dpressleD Offline
        dpressleD Offline
        dpressle
        @artipi Sure you can that is the whole point of the D5, D6, D7 connection.
        You just need to take the GND and each of these digital inputs and connect them to the switch (NO high voltage in the switch only GND and digital input), each one of then controls one relay.
        • dpressleD dpressle
          gusG Offline
          gusG Offline
          gus
          @dpressle said in Another simple (No SMT) relay actuator:
          Hi!
          Yes, please send links, really good design!
          Regards Rickard
          • gusG gus
            Hi!
            Regards Rickard
            dpressleD Offline
            dpressleD Offline
            dpressle
            @gus Dirtypcbs
              @gus Dirtypcbs
              gusG Offline
              gusG Offline
              gus
              @gus Dirtypcbs
              • M Offline
                M Offline
                MLs
                Where can you find the code?
                • M MLs
                  dpressleD Offline
                  dpressleD Offline
                  dpressle
                  @MLs Its in the OpenHardware page see the Source Code tab:
                  OpenHardware
                  Note its intended to work with "Home Assistant" HA, some depending on your controller some changes might be needed.
                    OpenHardware
                    M Offline
                    M Offline
                    MLs
                    @dpressle
                    Ok tanks
                    Do you have a bootloader with OTA enable
                    //Mattias
                    • M MLs
                      @dpressle
                      Ok tanks
                      //Mattias
                      dpressleD Offline
                      dpressleD Offline
                      dpressle
                      @MLs Yes sure
                        @MLs Yes sure
                        M Offline
                        M Offline
                        MLs
                        wrote on last edited by MLs
                        @dpressle
                        Can you email it to me or maybe add it to your project.
                        //Mattias
                        • M MLs
                          @dpressle
                          //Mattias
                          dpressleD Offline
                          dpressleD Offline
                          dpressle
                          @MLs I am using the one from here link text
                            M Offline
                            M Offline
                            MLs
                            @dpressle
                            Does the bootloader use the internal 8 MHz clock?
                            //Mattias
                            • M MLs
                              @dpressle
                              //Mattias
                              dpressleD Offline
                              dpressleD Offline
                              dpressle
                              @MLs yes it does.
                                @MLs yes it does.
                                M Offline
                                M Offline
                                MLs
                                #23
                                @dpressle
                                Feeling a bit confused how do you know that a bootloader uses the internal clock?
                                Because I used another bootloader after installing your card, I did not get the Atmega circuit to run. But if I used this bootloader, I started the Atmega circuit and everything worked.
                                Https://forum.mysensors.org/topic/3018/tutorial-how-to-burn-1mhz-8mhz-bootloader-using-arduino-ide-1-6-5-r5
                                But what makes the internal clock in used?
                                I use a UNO when I'm burning bootloader and do not know if you can change fuses and clock option.
                                • M MLs
                                  @dpressle
                                  dpressleD Offline
                                  dpressleD Offline
                                  dpressle
                                  @MLs I think i lost you there, if there is no external osc how would it work? it is clear (at list to me) that its using the internal clock. Maybe you mean the f_cpu parameter? it is in the board text file.
                                  I also use a nano to burn the bootloader, you can set the fuses as you wish in the boards page exactly as the link you gave is describing.
                                  If you dont care of OTA you can use any other bootloader (like optiboot), i did it as well with this board.
                                  I want to help you more but i need more info and pictures of your exact setup and files, can you share it?
                                  Also some times your atmega328p-pu comes with 16Mhz bootloader pre-installed so you do need to set it up with 16Mhz osc for the first 8Mhz bootloader burn, after that you can remove it.
                                    M Offline
                                    M Offline
                                    MLs
                                    @dpressle
                                    Ok first, I have to say that I have no problem getting your project to work. It connects directly to HA. What I get a little confused about is that according to the link I linked to it says.
                                    Be sure to select "ATmega328 on a breadboard (8 MHz internal clock)" when burning the bootloader.(If you select the wrong item and configure the microcontroller to use an external clock, it won't work unless you connect one.)
                                    And as I interpret your post, you can take whatever bootloader you want (8 MHz).
                                    And if I understand you right now, all settings iis n the board.txt file?
                                    //Mattias
                                    • M MLs
                                      @dpressle
                                      //Mattias
                                      dpressleD Offline
                                      dpressleD Offline
                                      dpressle
                                      @MLs When i said "what ever bootloader you want" i meant MYS OTA bootloader or optiboot or breadboard bootloader etc.
                                      They all have 8 Mhz version.
                                      In any way this is my boards.txt settings if it helps:
                                      MYSBL13.name=ATmega328 8MHz (RC, BOD1V8)
                                      MYSBL13.upload.maximum_size=30720
                                      MYSBL13.upload.maximum_data_size=2048
                                      MYSBL13.upload.speed=38400
                                      MYSBL13.upload.tool=arduino:avrdude
                                      MYSBL13.upload.protocol=arduino
                                      MYSBL13.bootloader.low_fuses=0xE2
                                      MYSBL13.bootloader.high_fuses=0xDA
                                      MYSBL13.bootloader.extended_fuses=0xfe
                                      MYSBL13.bootloader.file=MYSBootloader/MYSBL13pre_atmega328_8Mhz.hex
                                      MYSBL13.bootloader.unlock_bits=0x3F
                                      MYSBL13.bootloader.lock_bits=0x0F
                                      MYSBL13.bootloader.tool=arduino:avrdude
                                      MYSBL13.build.mcu=atmega328p
                                      MYSBL13.build.f_cpu=8000000L
                                      MYSBL13.build.core=arduino:arduino
                                      MYSBL13.build.variant=arduino:standard
                                      Then in the IDE i select:
                                      0_1492961529679_upload-deb53bb0-390b-413f-9955-809e20e902b7
                                        M Offline
                                        M Offline
                                        MLs
                                        #27
                                        @dpressle
                                        I do not get Atmel to run with Mysbootloader 8MHz.
                                        Seems like it does not use the internal clock
                                        Also tried to put your text into the board.txt file without any difference.
                                        But if I use the bottloader ATmega328 on a breadboard (8 MHz internal clock it work.
                                        • M MLs
                                          @dpressle
                                          dpressleD Offline
                                          dpressleD Offline
                                          dpressle
                                          @MLs as i said, i can only try to help if you get me more information about your environment and pictures and then i can compare it to mine.
