  3. Another simple (No SMT) relay actuator
42 Posts 8 Posters 16.0k Views 6 Watching
  • dpressleD dpressle
    Thanks for the comments, wow what a great forum we have here :disappointed_relieved:
    @dpressle said in Another simple (No SMT) relay actuator:
    you're welcome
      Since i dont think humans should solder SMT devices :stuck_out_tongue_winking_eye: i made this nice little non SMT board with 3 SSR relays, Hi-Link power supply, atmega328P and separated fuses for PSU and load, in a 5X5 CM board.
      So far its working great, i did not put a temp fuse in the design mainly because i dont see any commercial in wall units using one, so for me i think its safe enough to not use it.
      I would appreciate your comments on it, Thanks.
      Main goals are:
      • No SMT
      • 5X5 CM board
      • Safe for in wall use
      • Simple and cheep
      Top side design:
      Bottom side design:
      breimannB
      breimannB
      breimann
      @dpressle This is an impressive unit!
      I love the neatness and non SMT. Fantastic.
      Do you have an idea of the pricing all up?
      • dpressleD
        dpressleD
        dpressle
        Thanks, should be under 10USD in parts.
        BTW, same design but for roller shutter is on the way
        breimannB 1 Reply Last reply
        • Nca78N
          nice design with some care for safety !
          If possible, I would suggest to connect A4/A5 to the connector, so it would be possible to use (for example) an i2c touchpad, to command the 3 relays and more, for example mpr121 can manage a mix of touchpads and leds. In case of managing leds, of course a Vcc connector would be necessary too as the last input pins would not provide enough current.
          Analog pins A0-A5 can be used as digital pins if needed so it could still work as you designed it at the moment with physical switches.
          On thing that is annoying me also with some designs, is that when you want to use in ceiling to connect directly to ligh bulbs, you need to use connectors/wago to "duplicate" neutral because the board only provides live. If possible you should move J1 to the right, and put holes to add extra 2x connector on the left if people want to have neutral without external connectors, it will give a much cleaner result when connected instead of a mess of wires. I think it's possible to do it if you move the varistor to the left, and change orientation of F2.
          dpressleD 1 Reply Last reply
          • Nca78N Nca78
            dpressleD
            dpressleD
            dpressle
            @Nca78 Thanks for the tips, i understand what you are saying about the neutral and it is a good idea, my intentions were to put it in the switch box and not in the light fixture itself, but i might add it to the next release.
              breimannB
              breimannB
              breimann
              @dpressle nice!
              • breimannB breimann
                @dpressle nice!
                dpressleD
                dpressleD
                dpressle
                @breimann Thanks, does any one want link to dirtypcbs?
                gusG 1 Reply Last reply
                • A
                  artipi
                  Hi, dpressle. Thanks for your work?
                  One Question. Can i connect a normal light switch to it? So that i can turn on the lights with the switch and this node?
                  • A artipi
                    dpressleD
                    dpressleD
                    dpressle
                    @artipi Sure you can that is the whole point of the D5, D6, D7 connection.
                    You just need to take the GND and each of these digital inputs and connect them to the switch (NO high voltage in the switch only GND and digital input), each one of then controls one relay.
                      gusG
                      gusG
                      gus
                      Hi!
                      Yes, please send links, really good design!
                      Regards Rickard
                      • gusG gus
                        Hi!
                        Regards Rickard
                        dpressleD
                        dpressleD
                        dpressle
                        @gus Dirtypcbs
                          @gus Dirtypcbs
                          gusG
                          gusG
                          gus
                          @gus Dirtypcbs
                            MLs
                            Where can you find the code?
                            • M MLs
                              dpressleD
                              dpressleD
                              dpressle
                              @MLs Its in the OpenHardware page see the Source Code tab:
                              OpenHardware
                              Note its intended to work with "Home Assistant" HA, some depending on your controller some changes might be needed.
                                OpenHardware
                                MLs
                                @dpressle
                                Ok tanks
                                Do you have a bootloader with OTA enable
                                //Mattias
                                • M MLs
                                  @dpressle
                                  Ok tanks
                                  //Mattias
                                  dpressleD
                                  dpressleD
                                  dpressle
                                  @MLs Yes sure
                                    @MLs Yes sure
                                    MLs
                                    wrote on last edited by MLs
                                    @dpressle
                                    Can you email it to me or maybe add it to your project.
                                    //Mattias
                                    • M MLs
                                      @dpressle
                                      //Mattias
                                      dpressleD
                                      dpressleD
                                      dpressle
                                      @MLs I am using the one from here link text
                                        MLs
                                        @dpressle
                                        Does the bootloader use the internal 8 MHz clock?
                                        //Mattias
                                        • M MLs
                                          @dpressle
                                          //Mattias
                                          dpressleD
                                          dpressleD
                                          dpressle
                                          @MLs yes it does.
