  3. fody weather station, wind sensor
windwinddirectiongusthyt221weatherwindspeedfodyhytht01dweather station
36 Posts 7 Posters 16.5k Views 7 Watching
  • F
    F
    flopp
    wrote on last edited by flopp
    gohanG 1 Reply Last reply
    • F flopp
      [[topic:post-is-deleted]]
      @flopp are you still using old library version? Are you going to make it a battery powered node or else? I noticed you didn't use any sleep in the code
      F 1 Reply Last reply
        F
        F
        flopp
        @gohan said in fody weather station, wind sensor:
        Yes, this is for 1.5
        Are you going to make it a battery powered node or else?I noticed you didn't use any sleep in the code
        This is powered from a PC, not battery. I want data very often that's why it is not battery powered. I can also change the code if something is wrong.
        • F
          F
          flopp
          • F flopp
            sundberg84S
            sundberg84S
            @flopp - any more images? :)
            • sundberg84S sundberg84
              F
              F
              flopp
              @sundberg84
              Can upload some later today.
              I found that I have some problem with the NRf, so I need to open it up.
              Will upload new code later today, as well.
              • F
                F
                flopp
                • F
                  F
                  flopp
                  some pictures
                  0_1493054883191_20170424_160412832_iOS.jpg 0_1493054891231_20170424_160402858_iOS.jpg 0_1493054901570_20170424_160025939_iOS.jpg 0_1493054908764_20170424_160020368_iOS.jpg
                  • F
                    F
                    flopp
                    I am using this water proof connector for USB connection.
                    https://www.aliexpress.com/item/Free-Shipping-3-Sets-All-New-4-Pin-Waterproof-Electrical-Wire-Connector-Plug-HID-Male-female/32264045957.html
                    in sweden you can buy it at Biltema
                    • F
                      F
                      flopp
                      I have not verify all the code yet.
                      Wind direction is correct.
                      Temp is little bit higher then another temp that I have on shadow so maybe the radiation shield is not working 100%
                      Hum: my other sensor that I have outdoor broke a few weeks ago, so nothing to compare with
                      Wind Speed: I want to verify with an RPM tool. I get some extra indication from reeed switch.
                      Every second indication is below 1000 micros which is 1 millisecond, which is 1000m/s
                      Rain: lucky or unlucky I have not had any rain when the mast was up and running
                        Maybe you need a better heat shield, did you try some aluminum foil?
                          F
                          F
                          flopp
                          Good idea :)
                          Should I have the foil inside the shield or outside?
                          Any pics if you done it yourself?
                          I think I need some air through the shield so it can cool down.
                            I haven't done anything yet, I'm just trying to apply some cheap physics 😀
                            I'd start from the outside and see what happens
                              F
                              F
                              flopp
                              @gohan
                              Ok, thanks.
                              I will try it tomorrow
                              • F
                                F
                                flopp
                                #23
                                New code again :frowning:
                                Wind speed: it compare between two interrupts if it is too quick, if more than 100000 micros it will not use it
                                #define WIND_CHILD 0
                                #define TEMP_CHILD 1
                                #define HUM_CHILD 2
                                #define RAIN_CHILD 3
                                MyMessage WSMsg(WIND_CHILD, V_WIND);
                                MyMessage WGMsg(WIND_CHILD, V_GUST);
                                MyMessage WDMsg(WIND_CHILD, V_DIRECTION);
                                MyMessage TempMsg(TEMP_CHILD, V_TEMP);
                                MyMessage HumMsg(HUM_CHILD, V_HUM);
                                MyMessage RainMsg(RAIN_CHILD, V_RAIN);
                                MyMessage RainCounterMsg(RAIN_CHILD,V_VAR1);
                                //Wind Speed
                                volatile unsigned long lastPulse = 0;
                                volatile unsigned long intervalSum;
                                unsigned long lastInterval = 0;
                                unsigned long looptime;
                                float WS = 0;
                                float WG = 0;
                                int WScount = 0;
                                //Wind Direction
                                int WDarray[8] = {0,45,90,135,180,225,270,315};
                                int WD;
                                //Rain
                                volatile float hwRainVolume = 0;   // Current rainvolume calculated in hardware.
                                float bucketSize = 0.4;   // mm per tip
                                boolean pcReceived = false;
                                volatile unsigned long lastSend = 0;
                                // Temperature/Humidity
                                double hum = 0;
                                double temp = 0;
                                  Wire.begin();   //start i2c
                                  gw.begin(incomingMessage, AUTO, false);
                                  gw.sendSketchInfo("WeatherMast", "170427");
                                  gw.present(WIND_CHILD, S_WIND);
                                  gw.present(TEMP_CHILD, S_TEMP);
                                  gw.present(HUM_CHILD, S_HUM);
                                  gw.present(RAIN_CHILD, S_RAIN);
                                  gw.request(RAIN_CHILD, V_VAR1);
                                  gw.wait(5000);
                                  //pin 2 is rain, pin 3 is wind speed
                                  //pin 4-8, 14-16 is wind direction
                                  //configure pin 2-8 as an input and enable the internal pull-up resistor
                                  for (int i=2 ; i < 9 ; i++) {
                                    pinMode(i, INPUT_PULLUP);
                                  //configure pin 14-16(A0-A2) as an input and enable the internal pull-up resistor
                                  for (int i=14 ; i < 17 ; i++) {
                                  attachInterrupt(0, Rain, FALLING);    //rain
                                  attachInterrupt(1, WindSpeed, FALLING);   //wind speed
                                  gw.wait(60000);
                                  detachInterrupt(1);
                                  looptime = micros();
                                  readTempHum();    //read temperature and humidity
                                  readWindDirection();    //read wind direction
                                  resend((WSMsg.set(WS, 1)),3);
                                  WS = 0;  //reset wind speed, useful if there is no wind otherwise old value will be sent to Controller
                                  resend((WGMsg.set(WG, 1)),3);
                                  WG = 0;   //reset gust
                                  resend((WDMsg.set(WD, 1)),3);
                                  resend((RainMsg.set((float)hwRainVolume,2)),3);
                                  resend((TempMsg.set(temp, 1)),3);
                                  resend((HumMsg.set(hum, 1)),3);
                                  lastPulse += micros() - looptime;
                                void readWindDirection()
                                  //check in what direction the wind is. First sensor that have light will be the direction
                                  int i = 4;
                                  for (i; i < 9 ; i++){
                                    if (!digitalRead(i)){
                                      WD = WDarray[i-4];
                                      return;
                                  i = 14;
                                  for (i; i < 17 ; i++){
                                      WD = WDarray[i-9];
                                      return;
                                void Rain()
                                  unsigned long currentTime = millis();
                                  if (!pcReceived) {
                                    Serial.println("Request rainCount");
                                    return;
                                  if (currentTime - lastSend > 5000) {
                                  hwRainVolume = hwRainVolume + bucketSize;
                                  resend((RainCounterMsg.set(hwRainVolume,2)),3);
                                  lastSend=currentTime;
                                void WindSpeed()
                                  detachInterrupt(1);
                                  volatile unsigned long newPulse = micros();
                                  unsigned long interval = newPulse-lastPulse;
                                  if (interval<16000L) { // Sometimes we get wrong interrupt. 16000L = ~30 m/s
                                    lastPulse = newPulse;
                                    return;
                                  long a = interval-lastInterval;
                                  a = abs(a);
                                  lastInterval = interval;
                                  if (a > 100000) {
                                    return;
                                  else {
                                    WS = (0.4775/(interval/1000000.0));
                                    if (WS > WG) {
                                      WG = WS;
                                void readTempHum()
                                  Wire.beginTransmission(0x28);   // Begin transmission with given device on I2C bus
                                  Wire.requestFrom(0x28, 4);      // Request 4 bytes
                                  if(Wire.available() == 4) {
                                    int b1 = Wire.read();
                                    int b2 = Wire.read();
                                    int b3 = Wire.read();
                                    int b4 = Wire.read();
                                    Wire.endTransmission();           // End transmission and release I2C bus
                                    // combine humidity bytes and calculate humidity
                                    int rawHumidity = b1 << 8 | b2;
                                    // compound bitwise to get 14 bit measurement first two bits
                                    // are status/stall bit (see intro text)
                                    rawHumidity =  (rawHumidity &= 0x3FFF);
                                    hum = 100.0 / pow(2,14) * rawHumidity;
                                    // combine temperature bytes and calculate temperature
                                    b4 = (b4 >> 2); // Mask away 2 least significant bits see HYT 221 doc
                                    int rawTemperature = b3 << 6 | b4;
                                    temp = 165.0 / pow(2,14) * rawTemperature - 40;
                                void incomingMessage(const MyMessage &message)
                                  if (message.type==V_VAR1) {
                                    hwRainVolume = message.getFloat();
                                    pcReceived = true;
                                    Serial.print("Received last pulse count from gw: ");
                                    Serial.println(hwRainVolume,2);
                                void resend(MyMessage &msg, int repeats)
                                  int repeat = 1;
                                  int repeatdelay = 0;
                                  boolean sendOK = false;
                                  while ((sendOK == false) and (repeat < repeats)) {
                                    if (gw.send(msg)) {
                                      sendOK = true;
                                    else {
                                      sendOK = false;
                                      Serial.print("Error ");
                                      Serial.println(repeat);
                                      repeatdelay += 500;
                                    repeat++; delay(repeatdelay);
                                EDIT: added
                                WS = 0;
                                in loop
                                  So, how is the hacking going? :)
                                    F
                                    F
                                    flopp
                                    @gohan
                                    Thanks for asking :)
                                    It is working good, but I don't trust the wind speed. I have lots of "ghost" indications from the reed
                                    switch, I tried to remove it with code in two different ways but anyway I get some high values. I will order a wind speed meter and check against that one. I also record a slow-mo video when it spins in front of a fan(2.5m/s) and it is correct but it is difficult to test it with 10 m/s,
                                    If anyone are inreseted what's inside the receiver that was included from Fody. It look like this
                                    • F
                                      F
                                      flopp
                                      suddenly it stopped sending data, after power-off-power-on it started to work again
                                        I got an Uno as ethernet gateway with a DHT sensors and sometimes it hangs too after several days
                                        • F flopp
                                          @flopp I'll need to look at the watchdog timers and see if it may help
