  3. fody weather station, wind sensor
windwinddirectiongusthyt221weatherwindspeedfodyhytht01dweather station
36 Posts 7 Posters 16.5k Views 7 Watching
  • F flopp
    [[topic:post-is-deleted]]
    @flopp are you still using old library version? Are you going to make it a battery powered node or else? I noticed you didn't use any sleep in the code
    F 1 Reply Last reply
      F
      F
      flopp
      wrote on last edited by flopp
      @gohan said in fody weather station, wind sensor:
      Yes, this is for 1.5
      Are you going to make it a battery powered node or else?I noticed you didn't use any sleep in the code
      This is powered from a PC, not battery. I want data very often that's why it is not battery powered. I can also change the code if something is wrong.
      • F
        F
        flopp
        • F flopp
          sundberg84S
          sundberg84S
          @flopp - any more images? :)
          • sundberg84S sundberg84
            F
            F
            flopp
            @sundberg84
            Can upload some later today.
            I found that I have some problem with the NRf, so I need to open it up.
            Will upload new code later today, as well.
            • F
              F
              flopp
              • F
                F
                flopp
                some pictures
                0_1493054883191_20170424_160412832_iOS.jpg 0_1493054891231_20170424_160402858_iOS.jpg 0_1493054901570_20170424_160025939_iOS.jpg 0_1493054908764_20170424_160020368_iOS.jpg
                • F
                  F
                  flopp
                  I am using this water proof connector for USB connection.
                  https://www.aliexpress.com/item/Free-Shipping-3-Sets-All-New-4-Pin-Waterproof-Electrical-Wire-Connector-Plug-HID-Male-female/32264045957.html
                  in sweden you can buy it at Biltema
                  • F
                    F
                    flopp
                    I have not verify all the code yet.
                    Wind direction is correct.
                    Temp is little bit higher then another temp that I have on shadow so maybe the radiation shield is not working 100%
                    Hum: my other sensor that I have outdoor broke a few weeks ago, so nothing to compare with
                    Wind Speed: I want to verify with an RPM tool. I get some extra indication from reeed switch.
                    Every second indication is below 1000 micros which is 1 millisecond, which is 1000m/s
                    Rain: lucky or unlucky I have not had any rain when the mast was up and running
                      Maybe you need a better heat shield, did you try some aluminum foil?
                        F
                        F
                        flopp
                        Good idea :)
                        Should I have the foil inside the shield or outside?
                        Any pics if you done it yourself?
                        I think I need some air through the shield so it can cool down.
                          I haven't done anything yet, I'm just trying to apply some cheap physics 😀
                          I'd start from the outside and see what happens
                            F
                            F
                            flopp
                            @gohan
                            Ok, thanks.
                            I will try it tomorrow
                            • F
                              F
                              flopp
                              #23
                              New code again :frowning:
                              Wind speed: it compare between two interrupts if it is too quick, if more than 100000 micros it will not use it
                              #define WIND_CHILD 0
                              #define TEMP_CHILD 1
                              #define HUM_CHILD 2
                              #define RAIN_CHILD 3
                              MyMessage WSMsg(WIND_CHILD, V_WIND);
                              MyMessage WGMsg(WIND_CHILD, V_GUST);
                              MyMessage WDMsg(WIND_CHILD, V_DIRECTION);
                              MyMessage TempMsg(TEMP_CHILD, V_TEMP);
                              MyMessage HumMsg(HUM_CHILD, V_HUM);
                              MyMessage RainMsg(RAIN_CHILD, V_RAIN);
                              MyMessage RainCounterMsg(RAIN_CHILD,V_VAR1);
                              //Wind Speed
                              volatile unsigned long lastPulse = 0;
                              volatile unsigned long intervalSum;
                              unsigned long lastInterval = 0;
                              unsigned long looptime;
                              float WS = 0;
                              float WG = 0;
                              int WScount = 0;
                              //Wind Direction
                              int WDarray[8] = {0,45,90,135,180,225,270,315};
                              int WD;
                              //Rain
                              volatile float hwRainVolume = 0;   // Current rainvolume calculated in hardware.
                              float bucketSize = 0.4;   // mm per tip
                              boolean pcReceived = false;
                              volatile unsigned long lastSend = 0;
                              // Temperature/Humidity
                              double hum = 0;
                              double temp = 0;
                                Wire.begin();   //start i2c
                                gw.begin(incomingMessage, AUTO, false);
                                gw.sendSketchInfo("WeatherMast", "170427");
                                gw.present(WIND_CHILD, S_WIND);
                                gw.present(TEMP_CHILD, S_TEMP);
                                gw.present(HUM_CHILD, S_HUM);
                                gw.present(RAIN_CHILD, S_RAIN);
                                gw.request(RAIN_CHILD, V_VAR1);
                                gw.wait(5000);
                                //pin 2 is rain, pin 3 is wind speed
                                //pin 4-8, 14-16 is wind direction
                                //configure pin 2-8 as an input and enable the internal pull-up resistor
                                for (int i=2 ; i < 9 ; i++) {
                                  pinMode(i, INPUT_PULLUP);
                                //configure pin 14-16(A0-A2) as an input and enable the internal pull-up resistor
                                for (int i=14 ; i < 17 ; i++) {
                                attachInterrupt(0, Rain, FALLING);    //rain
                                attachInterrupt(1, WindSpeed, FALLING);   //wind speed
                                gw.wait(60000);
                                detachInterrupt(1);
                                looptime = micros();
                                readTempHum();    //read temperature and humidity
                                readWindDirection();    //read wind direction
                                resend((WSMsg.set(WS, 1)),3);
                                WS = 0;  //reset wind speed, useful if there is no wind otherwise old value will be sent to Controller
                                resend((WGMsg.set(WG, 1)),3);
                                WG = 0;   //reset gust
                                resend((WDMsg.set(WD, 1)),3);
                                resend((RainMsg.set((float)hwRainVolume,2)),3);
                                resend((TempMsg.set(temp, 1)),3);
                                resend((HumMsg.set(hum, 1)),3);
                                lastPulse += micros() - looptime;
                              void readWindDirection()
                                //check in what direction the wind is. First sensor that have light will be the direction
                                int i = 4;
                                for (i; i < 9 ; i++){
                                  if (!digitalRead(i)){
                                    WD = WDarray[i-4];
                                    return;
                                i = 14;
                                for (i; i < 17 ; i++){
                                    WD = WDarray[i-9];
                                    return;
                              void Rain()
                                unsigned long currentTime = millis();
                                if (!pcReceived) {
                                  Serial.println("Request rainCount");
                                  return;
                                if (currentTime - lastSend > 5000) {
                                hwRainVolume = hwRainVolume + bucketSize;
                                resend((RainCounterMsg.set(hwRainVolume,2)),3);
                                lastSend=currentTime;
                              void WindSpeed()
                                detachInterrupt(1);
                                volatile unsigned long newPulse = micros();
                                unsigned long interval = newPulse-lastPulse;
                                if (interval<16000L) { // Sometimes we get wrong interrupt. 16000L = ~30 m/s
                                  lastPulse = newPulse;
                                  return;
                                long a = interval-lastInterval;
                                a = abs(a);
                                lastInterval = interval;
                                if (a > 100000) {
                                  return;
                                else {
                                  WS = (0.4775/(interval/1000000.0));
                                  if (WS > WG) {
                                    WG = WS;
                              void readTempHum()
                                Wire.beginTransmission(0x28);   // Begin transmission with given device on I2C bus
                                Wire.requestFrom(0x28, 4);      // Request 4 bytes
                                if(Wire.available() == 4) {
                                  int b1 = Wire.read();
                                  int b2 = Wire.read();
                                  int b3 = Wire.read();
                                  int b4 = Wire.read();
                                  Wire.endTransmission();           // End transmission and release I2C bus
                                  // combine humidity bytes and calculate humidity
                                  int rawHumidity = b1 << 8 | b2;
                                  // compound bitwise to get 14 bit measurement first two bits
                                  // are status/stall bit (see intro text)
                                  rawHumidity =  (rawHumidity &= 0x3FFF);
                                  hum = 100.0 / pow(2,14) * rawHumidity;
                                  // combine temperature bytes and calculate temperature
                                  b4 = (b4 >> 2); // Mask away 2 least significant bits see HYT 221 doc
                                  int rawTemperature = b3 << 6 | b4;
                                  temp = 165.0 / pow(2,14) * rawTemperature - 40;
                              void incomingMessage(const MyMessage &message)
                                if (message.type==V_VAR1) {
                                  hwRainVolume = message.getFloat();
                                  pcReceived = true;
                                  Serial.print("Received last pulse count from gw: ");
                                  Serial.println(hwRainVolume,2);
                              void resend(MyMessage &msg, int repeats)
                                int repeat = 1;
                                int repeatdelay = 0;
                                boolean sendOK = false;
                                while ((sendOK == false) and (repeat < repeats)) {
                                  if (gw.send(msg)) {
                                    sendOK = true;
                                  else {
                                    sendOK = false;
                                    Serial.print("Error ");
                                    Serial.println(repeat);
                                    repeatdelay += 500;
                                  repeat++; delay(repeatdelay);
                              EDIT: added
                              WS = 0;
                              in loop
                                So, how is the hacking going? :)
                                  F
                                  F
                                  flopp
                                  @gohan
                                  Thanks for asking :)
                                  It is working good, but I don't trust the wind speed. I have lots of "ghost" indications from the reed
                                  switch, I tried to remove it with code in two different ways but anyway I get some high values. I will order a wind speed meter and check against that one. I also record a slow-mo video when it spins in front of a fan(2.5m/s) and it is correct but it is difficult to test it with 10 m/s,
                                  If anyone are inreseted what's inside the receiver that was included from Fody. It look like this
                                  • F
                                    F
                                    flopp
                                    suddenly it stopped sending data, after power-off-power-on it started to work again
                                    gohanG 1 Reply Last reply
                                      I got an Uno as ethernet gateway with a DHT sensors and sometimes it hangs too after several days
                                      • F flopp
                                        @flopp I'll need to look at the watchdog timers and see if it may help
                                        • F
                                          F
                                          flopp
                                          it stopped working again, this morning. This time it started to work again just after opening Serial monitoring in Arduino IDE
