  3. Minimal design thoughts
299 Posts 34 Posters 275.9k Views 17 Watching
    Sounds very interesting! Though personally I'd rather have a good regulator / boost (even if it is in a separate module) than having to source particular components that will run at 1.8V.
    How do you plan to integrate the nrf24? The "standard" or the "mini" version?
    I would love it if the MySensors web site could have a department of open source pcb schematics just like it has models for 3D printing.
    Soldering sounds tricky, you'd either have to reflow or heat the underside of the DFN6 on the pcb. With extra flux and paste.
    Yes, I would gladly create a section for this on the main site. But maybe we could start a pinned thread linking the once available?
    • T Tibus
      @tbowmo
      Yes there is a TGnd Pad in the middle :
      http://www.silabs.com/Support Documents/TechnicalDocs/Si7021.pdf
      page 26... But I'll buy a Hot Air soldering station, i'll be easier to solder no?
      bjornhallbergB
      bjornhallbergB
      bjornhallberg
      wrote on last edited by bjornhallberg
      #24
      @Tibus Or perhaps you have a hot air gun in the toolbox. Not as elegant but it might do.
      I'd much rather not try hot air (only have this at my disposal) and instead try to get at the pad from the backside of the pcb:
      http://www.eevblog.com/forum/projects/soldering-dfn-and-qfn-devices/
      With flux and paste possibly it should be quite easy. And besides, you'd need flux and/or paste for hot air reflow as well.
      • tbowmoT
        tbowmoT
        tbowmo
        #25
        Schematic as it is at the moment:
        And the board as it is right now
        I know it says eeprom for IC2, but the footprint is the same for SPI flashes.
        the eeprom is placed on the bottom layer. Also, the nrf24 is placed on the bottom (so the eeprom is "in the middle of the sandwich". The dimensions of the total board will be about 15x30mm. This is the same size as the radio module. The empty area on the top is the area below the antenna.
        Still need to make changes to the DFN package (upper right). and make a footprint for a bmp180 barometric sensor (and find a good home for it on the board).
        Also, need to tidy up the routing, I used the autorouter which is very bad at placing the traces (haven't got any better since I used eagle the last time 11 years ago..) So maybe I just end rip everything up and hand route it by hand (this is the fun part of pcb designs, trying to mingle everything in to place :) thinking about the things my teacers told me 20 years ago about PCB design (oh f*ck I feel like an old geezer now! :))
        Oh yeah, btw. there is also made room for a crystal (32Khz) on there.
        • tbowmoT
          tbowmoT
          tbowmo
          And yes, I know i'm missing pull ups on i2c bus, and decoupling capacitors on the 328
            This will be a very small board indeed! Not an expert but couldn't the radio interfere with MCU at these short distances?
            • tbowmoT
              tbowmoT
              tbowmo
              @hek
              It would be more the other way arround. The MCU is making trouble for the receive path of the radio module. But the radio module has a large gnd plane on the bottom towards the mcu board, so it should be shielded.
              • tbowmoT
                tbowmoT
                tbowmo
                A new schematic / layout
                I'm almost ready for sending it off to China, and get some boards back :)
                Changes since last:
                2 LED's added (figured debug output could be nice)
                pullups added on i2c bus
                caps changed to 0603 footprint
                added a couple of extra caps for decoupling (MCU)
                Added BMP180 barometric sensor (only need 1 node with this one though)
                Moved components arround, squeezing things a little bit more together.
                Routed manually this time, not that big a board, so no need to use the autorute function
                Testpads on upper right corner of the pcba is GND, RXD/TXD and VCC, again nice to have serial available for debugging the first couple of boards.
                Board is designed with dirtypcbs.com in mind for production (Used their DRU file in eagle to check things).
                Schematic:
                and pcb layout:
                • bjornhallbergB
                  bjornhallbergB
                  bjornhallberg
                  Fantastic! But I agree that is is perhaps a bit odd to have a footprint for a BMP180 on every board. You'll get a lot of boards when ordering 10x 5x5cm PCBs.
                  0603 ... time to get soldering. Haha. But those solder pads look pretty big actually. Is this the issue where Eagle actually makes 0603 caps more solderable than 0805 by making the pads longer?
                  tbowmoT 1 Reply Last reply
                    tbowmoT
                    tbowmoT
                    tbowmo
                    I know, but I thought that I just as well could put one in there when I was designing the pcb. Otherwise I would have to get it on an external pcb (sparkfun sells bmp180 breakut boards). And there was room for it :)
                    Don't know, last time I used eagle (about 10 years ago) I made layouts with 0805 components, (and an atmega8). Actually I think that the board I made back then is still being used in production.
                    /Thomas
                    • bjornhallbergB
                      bjornhallbergB
                      bjornhallberg
                      #32
                      Any thoughts on how to panelize it? You'd get like six boards on a 5x5 if those dimensions hold? Perhaps you could do some alternative layouts for different sensors? I understand dirtypcbs no longer do grooving (if they ever did) ... how much pcb space is lost to routing typically?
                      In case anyone else is wondering about dirtypcbs, they seem to do an ok job typically:
                      http://lab.kjlr.dk/p/handystick
                      http://hackers.gallery/236/electronics/pcb-itead-studio-vs-dirtypcbs
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        The full size is 16x31 mm at the moment. So it's almost the same size as the normal nrf24 modules on ebay. So if I panelize them i can get 4 modules in total on a single 5x5 area.
                        Let's see when i come around to order them. I just like the dirty pcb as it reminds me of a song from my favorite rockband (ac/dc) :)
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          #34
                          Arh.. just found out that the pinheader for the radio was turned 180 degrees, so instead of the 2 boards being on top of eatch other, they would "go in two different directions". Had to rip up most of the board, and re-arrange things again.
                          only changes on the schematic, is that the LED's are moved to a couple of other pins.
                          / Thomas
                          • N
                            N
                            NotYetRated
                            Very interesting, this one board would cover all that I need for the majority of my sensors. Would need a couple of sensors with IR, and a couple of others. Is the reason for this the reduced foot print, a reduced cost over arduino pro's, or something else?
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              @NotYetRated
                              One of the reasons is that I wanted to go with battery, without all the extra "cruft" that is on standard arduino boards (like regulators etc.),
                              Also I want to make it as clean as possible, as I'm planning on creating 10-20 nodes in total I don't like to make them as "birdsnests" with multiple boards stiched together with wires.
                              It also almost became an obsesson to see how small I could get it :).
                              Maybe I can save a little $ by roling my own layout, but not the main driving force.
                              N 1 Reply Last reply
                              • tbowmoT tbowmo
                                @NotYetRated
                                N
                                N
                                NotYetRated
                                @tbowmo Ahh, understood! I too plan for, somewhere around 20 nodes. However I plan to wall wort power most of mine. The only real exception will be a few outside, and inconvenient to reach places.
                                I do like the idea of eliminating as much of the "birds nest" as possible... My first couple of, what I am currently calling prototype sensors, are, well inside their boxes, very ugly. haha.
                                • daulagariD
                                  daulagariD
                                  daulagari
                                  @tbowmo Very nice design!
                                  Personally I would make something similar but with the option to charge things using an external solar cell or just a charger. With the new generation of low-leakage NiMH rechargeable batteries I am very tempted using these to power the sensor.
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @daulagari
                                    Is it necessary to use solar power? A couple of standard AA batteries, is probably good for 2000mAh, and with a consumption of below 50uA, you got battery power for 4-5 years..
                                    Also the sun doesn't shine inside my house ;)
                                    / Thomas
                                    • daulagariD
                                      daulagariD
                                      daulagari
                                      Sounds great, 4-5 years without changing batteries but will that be real? The bad thing is that if true it take 4-5 years to prove it.
                                      But a solar cell does not need solar to generate (some) current unless your house is completely dark ;-)
                                      But yes, if it is only 2-3 year going with rechargeable batteries is overkill.
                                      • daulagariD daulagari
                                        tbowmoT
                                        tbowmoT
                                        tbowmo
                                        Probably not 4-5 years (it was just quick, off the head, calculations), but I would think that at least 2 years of service time should be obtainable.. But yes, we will first see it in a couple of years :D
                                        I plan to place my sensors in corners, or somewhere else, where there isn't any direct light on them. And then they don't create enough power to charge the batteries., so solarpower is just adding to the cost of the project, without any real benefit..
                                        • N
                                          N
                                          NotYetRated
                                          Woah, wait.... 2 years of power?? Okay, if I could even get, say 18 months, I would go with battery powered over wall worts in a majority of my sensors.
                                          I was assuming battery power may last 3-6 months or so, given the motion detection.
