  3. Minimal design thoughts
299 Posts 34 Posters 271.9k Views 17 Watching
    This will be a very small board indeed! Not an expert but couldn't the radio interfere with MCU at these short distances?
    • tbowmoT
      tbowmoT
      tbowmo
      @hek
      It would be more the other way arround. The MCU is making trouble for the receive path of the radio module. But the radio module has a large gnd plane on the bottom towards the mcu board, so it should be shielded.
      • tbowmoT
        tbowmoT
        tbowmo
        A new schematic / layout
        I'm almost ready for sending it off to China, and get some boards back :)
        Changes since last:
        2 LED's added (figured debug output could be nice)
        pullups added on i2c bus
        caps changed to 0603 footprint
        added a couple of extra caps for decoupling (MCU)
        Added BMP180 barometric sensor (only need 1 node with this one though)
        Moved components arround, squeezing things a little bit more together.
        Routed manually this time, not that big a board, so no need to use the autorute function
        Testpads on upper right corner of the pcba is GND, RXD/TXD and VCC, again nice to have serial available for debugging the first couple of boards.
        Board is designed with dirtypcbs.com in mind for production (Used their DRU file in eagle to check things).
        Schematic:
        and pcb layout:
        • bjornhallbergB
          bjornhallbergB
          bjornhallberg
          Fantastic! But I agree that is is perhaps a bit odd to have a footprint for a BMP180 on every board. You'll get a lot of boards when ordering 10x 5x5cm PCBs.
          0603 ... time to get soldering. Haha. But those solder pads look pretty big actually. Is this the issue where Eagle actually makes 0603 caps more solderable than 0805 by making the pads longer?
          tbowmoT 1 Reply Last reply
            tbowmoT
            tbowmoT
            tbowmo
            I know, but I thought that I just as well could put one in there when I was designing the pcb. Otherwise I would have to get it on an external pcb (sparkfun sells bmp180 breakut boards). And there was room for it :)
            Don't know, last time I used eagle (about 10 years ago) I made layouts with 0805 components, (and an atmega8). Actually I think that the board I made back then is still being used in production.
            /Thomas
            • bjornhallbergB
              bjornhallbergB
              bjornhallberg
              wrote on last edited by bjornhallberg
              #32
              Any thoughts on how to panelize it? You'd get like six boards on a 5x5 if those dimensions hold? Perhaps you could do some alternative layouts for different sensors? I understand dirtypcbs no longer do grooving (if they ever did) ... how much pcb space is lost to routing typically?
              In case anyone else is wondering about dirtypcbs, they seem to do an ok job typically:
              http://lab.kjlr.dk/p/handystick
              http://hackers.gallery/236/electronics/pcb-itead-studio-vs-dirtypcbs
              • tbowmoT
                tbowmoT
                tbowmo
                The full size is 16x31 mm at the moment. So it's almost the same size as the normal nrf24 modules on ebay. So if I panelize them i can get 4 modules in total on a single 5x5 area.
                Let's see when i come around to order them. I just like the dirty pcb as it reminds me of a song from my favorite rockband (ac/dc) :)
                • tbowmoT
                  tbowmoT
                  tbowmo
                  #34
                  Arh.. just found out that the pinheader for the radio was turned 180 degrees, so instead of the 2 boards being on top of eatch other, they would "go in two different directions". Had to rip up most of the board, and re-arrange things again.
                  only changes on the schematic, is that the LED's are moved to a couple of other pins.
                  / Thomas
                  • N
                    N
                    NotYetRated
                    Very interesting, this one board would cover all that I need for the majority of my sensors. Would need a couple of sensors with IR, and a couple of others. Is the reason for this the reduced foot print, a reduced cost over arduino pro's, or something else?
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @NotYetRated
                      One of the reasons is that I wanted to go with battery, without all the extra "cruft" that is on standard arduino boards (like regulators etc.),
                      Also I want to make it as clean as possible, as I'm planning on creating 10-20 nodes in total I don't like to make them as "birdsnests" with multiple boards stiched together with wires.
                      It also almost became an obsesson to see how small I could get it :).
                      Maybe I can save a little $ by roling my own layout, but not the main driving force.
                      N 1 Reply Last reply
                      • tbowmoT tbowmo
                        @NotYetRated
                        N
                        N
                        NotYetRated
                        @tbowmo Ahh, understood! I too plan for, somewhere around 20 nodes. However I plan to wall wort power most of mine. The only real exception will be a few outside, and inconvenient to reach places.
                        I do like the idea of eliminating as much of the "birds nest" as possible... My first couple of, what I am currently calling prototype sensors, are, well inside their boxes, very ugly. haha.
                        • daulagariD
                          daulagariD
                          daulagari
                          @tbowmo Very nice design!
                          Personally I would make something similar but with the option to charge things using an external solar cell or just a charger. With the new generation of low-leakage NiMH rechargeable batteries I am very tempted using these to power the sensor.
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @daulagari
                            Is it necessary to use solar power? A couple of standard AA batteries, is probably good for 2000mAh, and with a consumption of below 50uA, you got battery power for 4-5 years..
                            Also the sun doesn't shine inside my house ;)
                            / Thomas
                            • daulagariD
                              daulagariD
                              daulagari
                              Sounds great, 4-5 years without changing batteries but will that be real? The bad thing is that if true it take 4-5 years to prove it.
                              But a solar cell does not need solar to generate (some) current unless your house is completely dark ;-)
                              But yes, if it is only 2-3 year going with rechargeable batteries is overkill.
                              • daulagariD daulagari
                                tbowmoT
                                tbowmoT
                                tbowmo
                                Probably not 4-5 years (it was just quick, off the head, calculations), but I would think that at least 2 years of service time should be obtainable.. But yes, we will first see it in a couple of years :D
                                I plan to place my sensors in corners, or somewhere else, where there isn't any direct light on them. And then they don't create enough power to charge the batteries., so solarpower is just adding to the cost of the project, without any real benefit..
                                • N
                                  N
                                  NotYetRated
                                  Woah, wait.... 2 years of power?? Okay, if I could even get, say 18 months, I would go with battery powered over wall worts in a majority of my sensors.
                                  I was assuming battery power may last 3-6 months or so, given the motion detection.
                                  • N NotYetRated
                                    tbowmoT
                                    tbowmoT
                                    tbowmo
                                    With motion detection you probably are further down, also one problem is that the PIR sensors I have seen is only 3.3V, which means you need a step up converter to power it from battery. This also increases the powerdrain on the batteries.
                                    • N
                                      N
                                      NotYetRated
                                      Ahh okay. Ill stick with building my stuff out for wall power where possible, and probably test a few of your boards when available. :)
                                      • axillentA
                                        axillentA
                                        axillent
                                        @tbowmo Cool staff!
                                        Just one suggestion - to add so called FTDI programming interface like pro mini is using
                                        It allows to use an external USB<->UART converter to work ith the board as usual (using programming through bootloader and Serial debugger)
                                        It is simple, see PROGRAMMER connector for example here http://wiki.devicter.ru/images/f/f7/SNv3sch.png
                                        sense and drive
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @axillent
                                          Hmm have been thinking about it.. Just for the versatility of the unit for other people. I have plans to use good old atmel programmers (I have a bunch of them, both jtagice3, and the older serial/usb programmers), so it's not that big an issue for me to skip serial for programming
                                          And at the moment I can't find any room for it the serial (other than rxd/txd in upper right corner) It's almost become an obsession for me, to keep it at the small formfactor :) (Same size as a standard nrf24 module). Just to prove that it is possible to get it that small
                                          btw. squeezed a couple of testpads in for A0, A1 and D3 last night.
