  3. πŸ’¬ Micro (nano) ampere meter (double)
measurement
39 Posts 16 Posters 17.4k Views 15 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/380/Micro-nano-ampere-meter-double
    • KoreshK
      KoreshK
      Koresh
      wrote on last edited by Koresh
      I like it! Great work! :)
      I realized this idea nearly year ago, but I am so lazy... so I didn't post it )
      This is my variant:
      I can make some suggestions.
      We can add a switch which will short inputs sometimes for automatic calibration. I used sealed contact relay.
      It is not clear for me how you realize input offset (input signal of HX711 should be between AGND+1.2 and AVDD-1.3 according HX711 datasheet. So I do it in the following way which is not optimal but easy:
      AWIA 1 Reply Last reply
      • Nca78N
        Parts ordered from a local shop, I should be able to make the assembly next week :)
        • KoreshK Koresh
          This is my variant:
          AWIA
          AWIA
          AWI
          @Koresh The offset is accomplished with a 2 * 1k voltage divider between Aref and gnd.
          It is probably a good idea to list all our (undocumented) projects to share with the MySensors community ;)
          • Nca78N
            wrote on last edited by Nca78
            Hello @AWI,
            I made one, but I have a problem with the refresh rate.
            As I have no jumper at the back to set refresh rate like on HX711 breakout board, I lifted the pin 15 (RATE) on my breakout board to connect to VCC using a 10k resistor.
            So now it's sampling at 80Hz, but the refresh rate is still a bit slow and the reactivity of the button is really bad. Despite setting only 2s to switch to next channel I have to keep the button pressed for several seconds more for the screen to change. And I need something like 2s press to trigger the offset setting.
            Do you have the same behavior or do I have to fix some settings in the code (didn't look into the details at the moment...) ?
            Thank you for sharing this great little project !
            AWIA rvendrameR 2 Replies Last reply
            • Nca78N Nca78
              Hello @AWI,
              AWIA
              AWIA
              AWI
              @Nca78 Looks good, Hard to say why the response is slow. There is quite some averaging in taking readings from the ADC and I tried to find a right balance between accuracy and response time/ button behaviour. For me it is not spot on but very usable.
              You could try to remove some of the averaging to get a better refresh rate. (i.e. the "32" to "8")
              Nca78N 1 Reply Last reply
                Wow, those HX711 modules really are inexpensive. As little as 48 cents each on Aliexpress.
                http://www.aliexpress.com/store/product/HX711-Module-Weighing-Sensor-Dedicated-AD-Module-For-Arduino-Free-Shipping-50PCS-LOT/716258_32228651474.html?spm=2114.12010615.0.0.MWbQV9
                I just ordered some from Amazon for about triple that price, but, meh, they'll be here this Sunday, not a month or two from now, so I'm cool with that. I'd like to use them to measure the rate of charge on some solar nodes that I'm in the process of figuring out how to make. Not sure, but at a mere 48 cents each, I might even bake them into the final design instead of being forced into a much longer measurement interval that the 10 bits of ADC on the ATmega328P would require.
                So, thanks for this great project write-up! It tipped me off to go look into it. And while I'm at it, I may as well make this project too. :)
                [Oops. I cancelled my Amazon order, as I just noticed that I should have ordered the shielded version, which Amazon doesn't appear to have. ]
                • AWIA AWI
                  @AWI said in πŸ’¬ Micro (nano) ampere meter (double):
                  Missed your answer when you posted it. Thank you for the suggestion, I will try to reduce the number of samples and hopefully I will find a good balance between reactivity and precision.
                  Else I will use 2 touch buttons in toggle mode so it will never miss a command.
                  • H
                    H
                    hotmelt
                    Just a question, are the common side of the shunts connectet to A(+) ? I can not see it on the picture it could also connecte to GND (but I don*t belive it).
                    Thank you for a helping hand!
                    • H
                      H
                      hotmelt
                      OK, I will give the answer by myself ;-) The common side of the shunt's should be connected to A+ / B+ that means together with the common side of the voltage divider for the offset.
                      Next question, is the any way to measure the voltage of the connected note ?- I know that there shoud be not a common GND - possibe do use Diodes?
                      • Nca78N Nca78
                        Hello @AWI,
                        rvendrameR
                        rvendrameR
                        rvendrame
                        @Nca78 , my HX711 board looks like yours. I'm a bit confused on how to connect the J1 pins to the load / power. Can you share how did you connected it? Thx!
                        ESP8266 GW + mySensors 2.3.2
                        Alexa / Google Home
                        Nca78N 2 Replies Last reply
                        • rvendrameR rvendrame
                          @rvendrame sure, I'll do it tomorrow morning as I cannot do it right now. In case I forget, don't hesitate to ring me ;)
                          L 1 Reply Last reply
                            @rvendrame said in πŸ’¬ Micro (nano) ampere meter (double):
                            Soldering is a bit messy and not helping much to understand, so I did a (gorgeous) drawing. I think I'll frame that in my living room :D
                            And in case you want to increase the data rate
                            rvendrameR alexsh1A metceynM 4 Replies Last reply
                            • Nca78N Nca78
                              rvendrameR
                              rvendrameR
                              rvendrame
                              @Nca78 , perfect, thank you! I was right with the two 1K resistors, but I connected the 1R 1W resistors both to E+, instead A+ and B+ separately...
                              One more question, how did you connect the load to be measured? Sorry for dumb question, but this is the first time I build such type of device...
                              Alexa / Google Home
                              • Nca78N Nca78
                                rvendrameR
                                rvendrameR
                                rvendrame
                                @Nca78 , updating: I figured out how to connect the load, so I'm done with it (including calibration).
                                I changed the original code a bit, as I also wanted it a bit more responsive. I didn't lift pin 15 as you did.
                                BTW, what bootloader + clock are you using? Perhaps that could influence? I'm using MYSBootloaderV13pre.hex, 8Mhz internal clock...
                                Changes:
                                • Less average reading per cycle (from 32 to 4 ) --> Didn't notice significant changes in measurements.
                                • More accumulated avg reads ( from 16 to 32 ) --> Just to keep a less volatile avg numbers in display.
                                • Change the logic of short/long press. short press (~1s) = change mode, long press (~3s) = Offset.
                                In case you want to give it a try...
                                // uA meter with HX711
                                 PROJECT: MySensors - uA meter with HX711
                                 PROGRAMMER: AWI
                                 DATE: 20170414/ last update:
                                 FILE: AWI_uA_meter.ino
                                 LICENSE: Public domain
                                 Performance improvements: rvendrame
                                Hardware: tbd Nano ATmega328p board w/ NRF24l01
                                Special:
                                	program with Arduino Nano
                                SUMMARY:
                                	Measures mV accross a shunt resistor ~ uA - channel A
                                	Measures mV on channel B
                                	Modes:
                                		- default: measure uV in full resolution (Stable reading only for 0.1uV)
                                		- other:
                                			A: channel A: default, amplification 128 - div 500: 0.1uV stable,  range +/- 20mV, (1ohm +/- 20mA, res 100 nA)
                                			B: channel B: amplification 32 - div 125: 100nA stable, range +/- 80mV,  (10 ohm +/- 8 mA, res 10 nA)
                                			AB: both channels:
                                		- uA - calibration: depending on the actual shunt:
                                			0.47 ohm -> 1 uV ~ 2uA, range -40 mA - 40 mA
                                			1 ohm -> 1 uV = 1uA, range -20 mA - 20 mA
                                			10 ohm -> 1 uv = 0.1uA
                                		- mV - calibration, depend on amplification
                                	Button switch:
                                		- Short press, reset current channel to offset 0 (keep terminals shorted, no need with uA ;-)
                                		- Long press, change channel A (uA) / B(uA)/ A & B (uA)
                                	Hx711 24bit weight scale sensor
                                		- Noise and temperature sensitive (x bit effective)
                                	OLED 128x64 display
                                Remarks:
                                	Size is large as result of font library for display
                                update:
                                #include <U8g2lib.h>									// U8glib for OLED display
                                #include <Wire.h> 										// I2C
                                #include <Button.h>										// https://github.com/JChristensen/Button
                                #include "HX711.h"										// local ADC lib
                                const double calibrationFactorA = 599.18f ;				// calibration for channel A: set to 1.0 for known current and divide
                                const double calibrationFactorB = 149.76f ;				// calibration for channel B: set to 1.0 for known current and divide
                                long offsetChannelA = 0 ;								// channel offsets for A and B (drifts) are calibrated at startup and on command.
                                long offsetChannelB = 0 ;
                                const uint8_t HX711_dout = A1 ;							// HX711 data out pin
                                const uint8_t HX711_sck = A0 ;							// HX711 serial clock
                                const uint8_t buttonPin = A2 ;							// connects the button to select function and reset offset
                                //const unsigned long longPress = 1500UL ;				//	- long press set reference temperature - in ms												// 	- when alarm, short press resets alarm
                                Button myBtn(buttonPin, true,  true, 40);				// Declare the button( pin, pullup, invert, debounce ms)
                                enum convertMode_t {channelA, channelB, channelAB} ;	// measurement modes, 32 port B / 128 port A / A & B
                                HX711 scale;											// instantiate ADC
                                // U8G instantiate, Change this constructor to match the display!!!
                                U8G2_SSD1306_128X64_NONAME_1_HW_I2C u8g(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);   // All Boards without Reset of the Display
                                const int nettReadingsSize = 32 ; 						// the number of readings to determine the average and calculate variance/ accuracy
                                double lastReading, lastReadingB ;
                                double nettReadings[nettReadingsSize] ; 				// store the rolling average of readings
                                int nettReadingPointer = 0 ;
                                convertMode_t convertMode = channelA ;					// default channelA
                                enum state_t {idleState, waitForRelease} ;      // define possible states
                                static state_t state = idleState ;
                                  Serial.println("AWI uA meter");
                                	// u8g setup
                                	u8g.begin() ;
                                	u8g.setFont(u8g2_font_helvR14_tf);					// 'r' = reduced (or 'n' = numeric) font only for size
                                	//u8g.setFont(u8g2_font_profont15_tf);					// 'r' = reduced (or 'n' = numeric) font only for size
                                	// HX711.DOUT	- pin #A1
                                	// HX711.PD_SCK	- pin #A0
                                	// if parameter "gain" is ommited; the default value 128 is used by the library
                                	//   64 & 128 is port A ; 32 is port B
                                	scale.begin(HX711_dout, HX711_sck, 128); 			// set port based on state of selection
                                	LCD_banner("Initializing") ;
                                	Serial.print("read average: \t\t");
                                	Serial.println(scale.read_average(20));  			// print the average of 20 raw readings from the ADC
                                	getOffset();										// get the offsets (drift values)
                                	scale.set_offset(offsetChannelA) ;					// set it for measured channel
                                	scale.set_scale(calibrationFactorA);				// this value is obtained by calibrating with known value; see the README for details
                                	Serial.print("read: \t\t");
                                	Serial.println(scale.read());						// print a raw reading from the ADC
                                	Serial.println(scale.read_average(10));				// print the average of 20 readings from the ADC
                                	Serial.print("get value: \t\t");
                                	Serial.println(scale.get_value(5));					// print the average of 5 readings from the ADC minus the tare weight, set with tare()
                                	Serial.print("get units: \t\t");
                                	Serial.println(scale.get_units(5), 3);				// print the average of 5 readings from the ADC minus tare weight, divided by scale
                                	Serial.println("Readings:");
                                	//Serial.print("one reading:\t");
                                	//Serial.print(scale.get_units(), 1);
                                	//Serial.print("\t| average:\t");
                                	//Serial.println(scale.get_units(30), 3);
                                  checkButton();
                                	// get ADC readings dependent on setting: read A, B or A & B
                                	// only A reads has average buffer when A&B mode is selected
                                	if (convertMode == channelA){
                                		scale.set_gain(128) ;
                                		scale.set_scale(calibrationFactorA );			// set division to A value and set mode to A
                                		lastReading = scale.get_units(4) ; 			// get value (average 4 readings)corrected with scaling
                                		nettReadings[nettReadingPointer] = lastReading ;	// store readings in averagebuffer
                                		nettReadingPointer = (++nettReadingPointer) % nettReadingsSize ; // increment and wrap
                                    checkButton();
                                    LCD_local_display();
                                	} else if (convertMode == channelB){
                                		scale.set_gain(32) ;
                                		scale.set_offset(offsetChannelB) ;
                                		scale.set_scale(calibrationFactorB);			// set division to B value and set mode to B
                                    checkButton();
                                	} else if (convertMode == channelAB){				// if both channels average 128 readings iso 32 (no buffer)
                                		scale.set_scale(calibrationFactorA);			// set division to A value and set mode to A
                                		lastReading = scale.get_units(2) ; 		  	// get value (average 4 readings)corrected with scaling
                                		checkButton();
                                		scale.set_scale(calibrationFactorB);			// set division to A value and set mode to A
                                		lastReadingB = scale.get_units(2) ; 			// get value (average 4 readings) corrected with scaling
                                    checkButton();
                                		LCD_local_displayAB();
                                	//scale.power_down();			       				// put the ADC in sleep mode
                                	//delay(500);
                                	//scale.power_up();
                                	//delay(100);
                                void checkButton() {
                                  myBtn.read();                   // read button state
                                  switch (state){
                                     case idleState:                  // Idle
                                      if (myBtn.wasPressed()) {       // Pressed
                                        // change channel and wait release
                                        state = waitForRelease ;
                                      break ;
                                    case waitForRelease:
                                      if (myBtn.pressedFor(3000UL)) {  // Long Press
                                         LCD_banner("Offset");
                                         getOffset();
                                         state = idleState;
                                      } else if (myBtn.wasReleased()) { // Short Press
                                        state = idleState;
                                        switchMode() ;
                                      break ;
                                void LCD_banner(const char *s){
                                /* prints all avaiable variables on LCD display with units
                                	input: all "last" variables
                                	u8g.firstPage();
                                	do {
                                		int strWidth = u8g.getStrWidth(s) ;				// get the length of the string to determine print position
                                		u8g.drawStr((128- strWidth)/2, 40, s ) ;			// print right aligned
                                	} while (u8g.nextPage()) ;
                                void LCD_local_display(void){
                                	char buf[21];  										// buffer for max 20 char display
                                	char lastNettBuf[14];
                                	dtostrf(lastReading, 10, 2, lastNettBuf);			// Convert real to char
                                	char averageNettBuf[14];
                                	dtostrf(nettReadingsAverage(), 10, 2, averageNettBuf);	// Convert real to char
                                	char spreadNettBuf[14];
                                	dtostrf(nettReadingsSpread(), 10, 2, spreadNettBuf);	// Convert real to char
                                	Serial.print("Average: \t") ; Serial.print(nettReadingsAverage());
                                	Serial.print("\tSpread: \t") ; Serial.println(nettReadingsSpread());
                                	u8g.firstPage();
                                	do {
                                    checkButton();
                                		snprintf(buf, sizeof buf, "Current %s", (convertMode==channelB)?"B":"A"); // Header
                                		int strWidth = u8g.getStrWidth(buf) ;			//   length of the string to determine print position
                                		u8g.drawStr((128- strWidth)/2, 14, buf ) ;		//   print middle aligned
                                		u8g.drawStr(0,31,"I") ;							// Current
                                		snprintf(buf, sizeof buf, "%10s\xB5\A", lastNettBuf);
                                		u8g.drawStr((128- strWidth), 31, buf ) ;		//   print right aligned
                                		u8g.drawStr(0,47,"avg") ;						// Average current
                                		snprintf(buf, sizeof buf, "%10s\xB5\A", averageNettBuf);
                                		strWidth = u8g.getStrWidth(buf) ;				// get the length of the string to determine print position
                                		u8g.drawStr((128- strWidth), 47, buf ) ;		// print right aligned
                                		u8g.drawStr(0,63,"d\xB1") ;						// delta +/-
                                		snprintf(buf, sizeof buf, "%10s\xB5\A", spreadNettBuf);
                                		u8g.drawStr((128- strWidth), 63, buf ) ;		// print right aligned
                                void LCD_local_displayAB(void){
                                /* prints A & B channel on LCD display with units
                                	char lastNettBufB[14];
                                	dtostrf(lastReadingB, 10, 2, lastNettBufB);			// Convert real to char
                                	char lastNettBufAB[14];
                                	dtostrf(lastReading +lastReadingB, 10, 2, lastNettBufAB);	// Convert real to char for added values
                                	u8g.firstPage();
                                	do {
                                    checkButton();
                                		snprintf(buf, sizeof buf, "Current A+B"); 		// Header
                                		u8g.drawStr(0,31,"IA");							// Current A
                                		u8g.drawStr(0,47,"IB");							// Current B
                                		snprintf(buf, sizeof buf, "%10s\xB5\A", lastNettBufB);
                                		u8g.drawStr(0,63,"A+B");						// Current A + B
                                		snprintf(buf, sizeof buf, "%10s\xB5\A", lastNettBufAB);
                                // calculate average of nett readings
                                double nettReadingsAverage() {
                                	double sum = 0;
                                	for (byte i = 0; i < nettReadingsSize; i++) {
                                		sum += nettReadings[ i ];
                                	return sum / nettReadingsSize;
                                // calculate spread of nett readings (+/-)
                                double nettReadingsSpread() {
                                	double minReading = nettReadings[0];
                                	double maxReading = minReading ;
                                	for (byte i = 1; i < nettReadingsSize; i++) {
                                    checkButton();
                                		if (minReading > nettReadings[ i ]){
                                			minReading = nettReadings[i] ;
                                		if (maxReading < nettReadings[ i ]){
                                			maxReading = nettReadings[i] ;
                                	return (maxReading - minReading)/2 ;
                                // switch the mode
                                void switchMode(){
                                		convertMode = channelB ;
                                		convertMode = channelAB ;
                                // assuming both channels are shorted, calculate the offset values for channel A and B
                                double getOffset(){
                                	scale.set_gain(128) ;							// get channel A
                                	offsetChannelA = scale.read_average(32) ;		// average 512 readings for offset
                                	Serial.print("Offset A: \t") ;
                                	Serial.println(offsetChannelA);
                                	scale.set_gain(32) ;							// get channel B
                                	offsetChannelB = scale.read_average(32) ;		// average 512 readings for offset
                                	Serial.print("Offset B: \t") ;
                                	Serial.println(offsetChannelB);
                                Alexa / Google Home
                                  Changes:
                                   PROGRAMMER: AWI
                                  Special:
                                  SUMMARY:
                                  	Modes:
                                  		- other:
                                  			AB: both channels:
                                  	Button switch:
                                  	OLED 128x64 display
                                  Remarks:
                                  update:
                                  	// u8g setup
                                  	u8g.begin() ;
                                    checkButton();
                                      checkButton();
                                      checkButton();
                                  		checkButton();
                                      checkButton();
                                  	//delay(500);
                                  	//scale.power_up();
                                  	//delay(100);
                                    switch (state){
                                        break ;
                                           getOffset();
                                           state = idleState;
                                          state = idleState;
                                          switchMode() ;
                                        break ;
                                  	u8g.firstPage();
                                  	do {
                                  	u8g.firstPage();
                                  	do {
                                      checkButton();
                                  	u8g.firstPage();
                                  	do {
                                      checkButton();
                                  	double sum = 0;
                                      checkButton();
                                  // switch the mode
                                  void switchMode(){
                                  double getOffset(){
                                  @rvendrame thank you I will try it, good idea for the button change.
                                  Just need to change the code for another screen as I broke my oled :(
                                    For the short press, with the original code, I noticed that an easy way to get it every time is to press until the display changes, then release. Anyhow, worked for me.
                                    • mfalkviddM
                                      @AWI I'm unable to find the "local ADC lib". Is it available somewhere?
                                        AWIA
                                        AWIA
                                        AWI
                                        @mfalkvidd the 'local adc' library is the hx711 library which I placed in the sketch folder. Sorry for the confusion
                                        • AWIA AWI
                                          @AWI where can I download it? It does not seem to be compatible with the hx711 library I found through the Arduino IDE Library Manager :(
                                          EDIT: Seems to work with https://github.com/bogde/HX711 (if installing it manually)
                                          With your input, this post could be even better πŸ’—
