  2. Announcements
  3. 💬 Rain Gauge
💬 Rain Gauge
62 Posts 18 Posters 29.3k Views 17 Watching
    According to @Ivan-Z, the MI-SOL Rain Guage has CALIBRATE_FACTOR = 36
    https://forum.mysensors.org/topic/156/rain-guage/112
    TheoLT
    TheoLT
    TheoL
    @hek Thank you very much. This saves me a lot of time ;-)
    • hoefoigelH
      hoefoigelH
      hoefoigel
      When I try to compile the code above I get the error "'timeStatus' was not declared in this scope" in the line
      while (timeStatus() == timeNotSet && millis() - functionTimeout < 30000UL)
      I use Arduino IDE 1.6.10 and inserted the library "Time" from the MySensorsArduinoExamples in the Arduino libraries folder.
      Has anyone a hint for me? Thank you in advance!
      By the way: Thanks a lot to @hek and the forum for the project! :-)
        Might be best to check with @petewill and @BulldogLowell.
        A quick googling revealed this:
        https://github.com/PaulStoffregen/Time/issues/32
        So if you rename the Time library to Time2 or something and change the include it might work.
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @hek @hoefoigel ,
          I coded the basic sensor and @petewill added the rest and updated... Sorry I cannot be helpful!
          • petewillP
            petewillP
            petewill
            I am currently upgrading my devices to 2.0 using the 1.6.12 IDE. I'll try to work on this one in the next few days and post an update.
            • petewillP
              petewillP
              petewill
              I finally finished with the update and it has been merged to the MySensors github. Here is the link: https://github.com/mysensors/MySensorsArduinoExamples/tree/master/examples/RainGauge
              You will also need to download the updated Time library here: https://github.com/mysensors/MySensorsArduinoExamples/tree/master/libraries/Time
              Let me know if you run into any issues.
              • 李旻峰李
                李旻峰李
                李旻峰
                • 李旻峰李
                  李旻峰李
                  李旻峰
                  which sensor do you use for the rain gauge content sensor
                  • 李旻峰李 李旻峰
                    @李旻峰 the tipping bucket rain sensor is linked on the build page. See the link in the first post on this thread.
                    • U
                      U
                      user2684
                      Hi! I bought the rain gauge recommended in the page, put together a simplified version of the sketch which just reports the mm every hour and everything works just fine. However I did notice that during a sunny day almost every hour I have the equivalent of something between 0 and 3 interrupts happening which are clearly false positives. Do you guys suggest anything to mitigate this behavior? I don't think there is anything that can be done in software (an interrupt is an interrupt) so I was wondering if there is anything else which can do the magic :-)
                      • F
                        F
                        flopp
                        wrote on last edited by flopp
                        I have been using my tipping bucket for at least 6 month now and I also noticed that the last week I got some fake interrupt. We have had a very nice week in south Sweden so it must be something with the weather that makes the interrupt
                        U 1 Reply Last reply
                        • F flopp
                          U
                          U
                          user2684
                          @flopp I may have noticed something similar, while testing it, indoor, I had no fake interrupts at all (even if I did test it for a short time). When outside though, under the sunshine, I had frequent fake interrupts, like there is a voltage drop in that scenario causing it to trigger. I can of course survive with it but I was wondering if there may be a way to mitigate it somehow. I may try to "debounce" it by checking the input after the interrupt but not sure would be effective since I do expect the input to be HIGH again after the interrupt. Thanks
                          • F
                            F
                            flopp
                            My node is batteri powered, can it have something with the battery why this happens?
                            I have a second rain gauge powered by USB and that one doesn't give fake interrupt
                            • F flopp
                              U
                              U
                              user2684
                              Mine is powered by USB but still I have fake interrupts. Agree with you, I guess powering it with batteries could be worse since it is more likely that the voltage would fluctuate so causing fake interrupts. Btw, I assumed the board cannot sleep for this sketch to work, am I wrong? Or are you keeping it awake but still powering it with batteries? Thanks
                              F 1 Reply Last reply
                              • U user2684
                                F
                                F
                                flopp
                                @user2684
                                My board is sleep and wake up every 2 hours to send battery voltage or it wake up by interrupt
                                petewillP 1 Reply Last reply
                                • F flopp
                                  @user2684
                                  petewillP
                                  petewillP
                                  petewill
                                  @flopp & @user2684 Hmm. Strange. Mine has been running for around 2 years and I have never noticed this behavior. I live in an area where we get lots of nice weather so I'm sure I would have noticed it if it were happening to me. I know that's not helpful for you but hopefully we can get this fixed...
                                  I don't have any great ideas on how to fix this but you may want to try updating to the latest MySensors bata library. There were some updates recently that fixed some interrupt issues.
                                  Also, since this was not happening indoors is it possible that there is something else causing this issue like wind or heat?
                                  Lastly, did you make any changes to the code or wiring for your sensors?
                                  • F
                                    F
                                    flopp
                                    I am using version 1.5.?
                                    I have not opened the rain-box for at least 4 month and not changed the code.
                                    Maybe this error have been there since day one but I have not checked so often.
                                    But now I am checking daily because of other nodes that I added recently and then I noticed this
                                    • F flopp
                                      petewillP
                                      petewillP
                                      petewill
                                      @flopp What other types of nodes is this happening on? I'd definitely suggest updating to the latest version of the Beta code if you're having interrupt issues.
                                      • petewillP petewill
                                        F
                                        F
                                        flopp
                                        @petewill
                                        I have never seen it on other nodes and I don't think I had this error when it was cold
                                        • U
                                          U
                                          user2684
                                          wrote on last edited by user2684
                                          #23
                                          As for myself, I'm using an over-simplified version of your code (https://github.com/mysensors/NodeManager/blob/v1.5-dev/NodeManager.cpp#L585) but the principle should be the same I hope (btw I didn't have the chance to tell you what a great project you put together!). I'm with the latest beta release but since using the arduino's attachInterrupt() in a non-sleeping board, the mysensors' library should not have an impact in my scenario I guess.
                                          Something I want to check that may cause my issue I think is the power supply. I have a (chinese) USB wall plug connected to a (chinese) USB TTL connected to my arduino board. I wonder if a fluctuating power would generate this behavior (while indoor, it was connected to a different power supply). I'll try this way and report back.
                                          Out of curiosity those are the logs from my controller (0.11 is 1 interrupt). So this is happening at every hour, up to 9 times per hour so the heat cannot be the issue I might say:
                                          [2017-05-19 16:22:18] [plugin_mysensors.py:250 - process_inbound()] INFO: [serial_1][5][1] presented as S_RAIN
                                          [2017-05-19 17:22:07] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.88
                                          [2017-05-19 19:21:45] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
                                          [2017-05-19 20:21:35] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.66
                                          [2017-05-19 21:21:25] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.33
                                          [2017-05-19 22:21:16] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
                                          [2017-05-19 23:21:07] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.66
                                          [2017-05-20 00:21:00] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.33
                                          [2017-05-20 01:20:53] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
                                          [2017-05-20 02:20:47] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
                                          [2017-05-20 03:20:41] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
                                          [2017-05-20 04:20:33] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
                                          [2017-05-20 05:20:28] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
                                          [2017-05-20 06:20:24] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
                                          [2017-05-20 07:20:18] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
                                          [2017-05-20 08:20:12] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
                                          [2017-05-20 09:20:04] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
                                          [2017-05-20 10:19:56] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.77
                                          [2017-05-20 11:19:48] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.22
                                          [2017-05-20 12:19:37] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.44
                                          [2017-05-20 13:19:23] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.22
                                          [2017-05-20 14:19:09] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.22
                                          [2017-05-20 15:18:55] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.99
                                          [2017-05-20 16:18:43] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
                                          [2017-05-20 17:18:31] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
                                          [2017-05-20 18:18:21] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
                                          [2017-05-20 19:18:12] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
                                          [2017-05-20 20:18:03] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
                                          [2017-05-20 21:17:55] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
                                          [2017-05-20 22:17:50] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
                                          [2017-05-20 23:17:44] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
                                          [2017-05-21 00:17:39] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
                                          [2017-05-21 01:17:32] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
                                          [2017-05-21 02:17:24] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
                                          [2017-05-21 03:17:16] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
                                          [2017-05-21 04:17:10] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
                                          [2017-05-21 05:17:05] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
                                          [2017-05-21 06:16:58] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
                                          [2017-05-21 07:16:52] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
                                          [2017-05-21 08:16:45] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
                                          [2017-05-21 09:16:38] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
                                          [2017-05-21 10:16:32] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
                                          [2017-05-21 11:16:25] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
                                          [2017-05-21 12:16:16] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
                                          [2017-05-21 13:15:53] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
                                          [2017-05-21 14:15:30] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
                                          [2017-05-21 15:15:15] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
                                          [2017-05-21 16:15:02] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
                                          [2017-05-21 17:14:47] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
                                          [2017-05-21 18:14:35] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
                                          [2017-05-21 19:14:23] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.00
                                          [2017-05-21 20:14:11] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
                                          [2017-05-21 20:14:12] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.11
                                          [2017-05-21 21:14:01] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.44
                                          [2017-05-21 22:13:49] [plugin_mysensors.py:253 - process_inbound()] INFO: [serial_1][5][1][SET][V_RAIN]: 0.44
                                          12.5k
