  3. πŸ’¬ Adjustable Boost Converter with Pass-Through
boostboost convertermcp1640step-upvoltage
34 Posts 8 Posters 12.4k Views 7 Watching
    If you ask me, chip manufacturers should publish the PCB (gerber files, etc.) for their "typical" application circuit. It would save me from having to re-invent it just so I can take their chip for a test drive. As it stands, you have to buy their costly "evaluation boards"--or else go to the effort of creating your own--to help decide if you might want to possibly use their chip. It should be in their interest to make it as easy as possible for people to test drive their chips. What's the point in getting free sample chips if you have to create a PCB from scratch and wait two weeks for fabrication just to try it out? It makes no sense. Am I missing something?
    After reflecting on this question, I'm guessing that most EE's probably use a spice simulator, or similar CAD tool, for designing and testing their circuits. So, for them, having the physical chip itself isn't so important. Maybe I should look into doing the same.
      To expedite things, I just now posted Version 2:
      1. I re-did the routing placement to make it conform with the recommendations, and
      2. I cleaned up the silkscreen to make the component labels more legible.
        I just now posted Version 3.
        Changes from Version 2:
        1. Change to using the same type of shielded inductor that my other boost projects are using.
        2. Eliminated unnecessary header pins, and added a ground header pin.
        3. Changed the silkscreen on the MCP1640 land pattern to mitigate against potential for solder bridging.
          I've tested the board, and it works.
          Please purchase your PCB's for this project from the following link: https://pcbs.io/share/zyLW7
            Here is a photo of the assembled PCB, taken next to a quarter for scale:
              This project is now finished. :smile:
                Setting R1=680K gives a voltage output of 2.674v, which is great for charging 2.7v supercaps.
                  #21
                  I just now revised the board to expose the Enable pin, so now you can do a pass-through if you wish. I also made it more compact and gave it a ground-plane on the back. Enjoy!
                    #22
                    i received the upgraded PCB and assembled it. It tests out correctly. The project photo now shows the newest board. Project completed. :)
                    For 3.3v output, use R1=976 ohms and R2=562 ohms, as per the datasheet.
                      BTW, the same PCB and circuit can also be used with the MCP1640T instead of the MCP1640C if so desired. In that case, the ENABLE pin acts like an ON/OFF switch, instead of an ON/Pass-through switch.
                      • KoreshK
                        KoreshK
                        Koresh
                        Just little tip from me :) Use thermal relief instead of direct polygon connection.
                        It is much more useful in such cases.
                        • KoreshK Koresh
                          @Koresh said in πŸ’¬ Adjustable Boost Converter with Pass-Through:
                          Where do I put that exactly?
                          KoreshK 1 Reply Last reply
                            KoreshK
                            KoreshK
                            Koresh
                              Sorry if I'm being dense, but how are the thermal reliefs better? What's their advantage?
                                KoreshK
                                KoreshK
                                Koresh
                                wrote on last edited by Koresh
                                #28
                                @NeverDie It is much easier to solder the wire to pads with relief connection than the wire to directly connected pads. Your soldering point even can be unreliable if your pad is directly connected to very huge polygon and your soldering iron don't have enough power.
                                • B
                                  B
                                  bilbolodz
                                  Please upload it on PCBS.io and provide a direct link
                                  B 1 Reply Last reply
                                  • B bilbolodz
                                    B
                                    B
                                    bilbolodz
                                    I've uploaded it on PCBs.io:
                                    https://PCBs.io/share/zagYj
                                    ordered but no tested yet. Cost of for PCB: 1,35 USD
                                    • alexsh1A
                                      alexsh1A
                                      alexsh1
                                      #31
                                      @NeverDie I have got MCP1640CT-I/CHY in SOT-23 (BX5V marking on the chip)
                                      Can these be used for this project please?
                                      I also have some 8 pins ones, but there are not suitable
                                      • alexsh1A alexsh1
                                        @alexsh1
                                        If the pinout is the same, then the PCB should work.
                                          https://www.openhardware.io/view/279/Adjustable-Boost-Converter-with-Pass-Through
                                          Shravan V.KS
                                          Shravan V.KS
                                          Shravan V.K
                                          @openhardware-io
                                          I am having issues can someone help
                                          I am getting output voltage same as input , i removed enable pin supply still i was getting output voltage same as input what might be the issue?
                                          With your input, this post could be even better πŸ’—
